  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker MySensors
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
106 Beiträge 13 Kommentatoren 47.5k Aufrufe
  • M
    M
    Maxtox
    смотри
    https://youtu.be/FDPYlRaAp9E
    а потом всё пропадает!!!!
    host-raspberrypi 2016-02-19 19:50:09 info instance system.adapter.mysensors.0 started with pid 3189
    host-raspberrypi 2016-02-19 19:49:46 info Restart adapter system.adapter.mysensors.0 because enabled
    host-raspberrypi 2016-02-19 19:49:46 error instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
    mysensors-0 2016-02-19 19:49:46 info cleaned everything up…
    TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
    TypeError: 2016-02-19 19:49:46 error at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
    TypeError: 2016-02-19 19:49:46 error at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
    TypeError: 2016-02-19 19:49:46 error at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
    TypeError: 2016-02-19 19:49:46 error at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
    TypeError: 2016-02-19 19:49:46 error at Array.forEach (native)
    TypeError: 2016-02-19 19:49:46 error at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
    TypeError: 2016-02-19 19:49:46 error at SerialPort.EventEmitter.emit (events.js:95:17)
    TypeError: 2016-02-19 19:49:46 error at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
    TypeError: 2016-02-19 19:49:46 error at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
    TypeError: 2016-02-19 19:49:46 error Cannot read property 'id' of undefined
    uncaught 2016-02-19 19:49:46 error exception: Cannot read property 'id' of undefined
    mysensors-0 2016-02-19 19:49:46 info Rx-Raw 255
    mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_VERSION|_1.0
    mysensors-0 2016-02-19 19:49:46 debug количество сообщений 3
    mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;12;1.0
    mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_SKETCH_NAME|_ETHduino by JR
    mysensors-0 2016-02-19 19:49:46 debug количество сообщений 2
    mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;11;ETHduino by JR
    mysensors-0 2016-02-19 19:49:46 info _0|255|internal|false|I_GATEWAY_READY|_Gateway startup complete.
    mysensors-0 2016-02-19 19:49:46 debug количество сообщений 1
    mysensors-0 2016-02-19 19:49:46 info Rx-Raw 0;255;3;0;14;Gateway startup complete.
    mysensors-0 2016-02-19 19:49:46 info _Temperature for the sensor 42 is0|255|internal|false|I_LOG_MESSAGE|_Starting gateway (R-NGA-, 2.0.0-beta)
    mysensors-0 2016-02-19 19:49:46 debug количество сообщений 0
    mysensors-0 2016-02-19 19:49:46 info Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
    log from Arduino:
    Temperature for the sensor 42 is -127.00
    0;42;1;1;0;-127.00
    mysensors-0 2016-02-19 19:49:45 debug Communication port:/dev/ttyUSB0
    mysensors-0 2016-02-19 19:49:45 info starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
    mysensors-0 2016-02-19 19:49:45 debug statesDB connected
    mysensors-0 2016-02-19 19:49:45 debug objectDB connected
    host-raspberrypi 2016-02-19 19:49:41 info instance system.adapter.mysensors.0 started with pid 3156
    host-raspberrypi 2016-02-19 19:49:39 info Restart adapter system.adapter.mysensors.0 because enabled
    Arduino MEGA 2560 R3 / ioBroker / DOino Sketch
    • M
      M
      Maxtox
      after a new reset ардуины:
      the LOG:
      [color]host-raspberrypi	2016-02-19 19:53:16	info	Restart adapter system.adapter.mysensors.0 because enabled
      host-raspberrypi	2016-02-19 19:53:16	error	instance system.adapter.mysensors.0 terminated with code 6 (uncaught exception)
      mysensors-0	2016-02-19 19:53:16	info	cleaned everything up...
      TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:388:9
      TypeError:	2016-02-19 19:53:16	error	at afterRead (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:372:20)
      TypeError:	2016-02-19 19:53:16	error	at SerialPortFactory.SerialPort._emitData (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:396:20)
      TypeError:	2016-02-19 19:53:16	error	at Object.SerialPort.opts.dataCallback (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/serialport.js:181:12)
      TypeError:	2016-02-19 19:53:16	error	at Object.parser (/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:24:13)
      TypeError:	2016-02-19 19:53:16	error	at Array.forEach (native)
      TypeError:	2016-02-19 19:53:16	error	at /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/parsers.js:25:17
      TypeError:	2016-02-19 19:53:16	error	at SerialPort.EventEmitter.emit (events.js:95:17)
      TypeError:	2016-02-19 19:53:16	error	at SerialPort. (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:293:8)
      TypeError:	2016-02-19 19:53:16	error	at mkdbmsgUnique (/opt/iobroker/node_modules/iobroker.mysensors/mysensors.js:121:23)
      TypeError:	2016-02-19 19:53:16	error	Cannot read property 'id' of undefined
      uncaught	2016-02-19 19:53:16	error	exception: Cannot read property 'id' of undefined
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 255
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_VERSION_|_1.0
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 3
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;12;1.0
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_SKETCH_NAME_|_ETHduino by JR
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 2
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;11;ETHduino by JR
      mysensors-0	2016-02-19 19:53:16	info	__0_|_255_|_internal_|_false_|_I_GATEWAY_READY_|_Gateway startup complete.
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 1
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw 0;255;3;0;14;Gateway startup complete.
      mysensors-0	2016-02-19 19:53:16	info	__Temperature for the sensor 42 is0_|_255_|_internal_|_false_|_I_LOG_MESSAGE_|_Starting gateway (R-NGA-, 2.0.0-beta)
      mysensors-0	2016-02-19 19:53:16	debug	количество сообщений 0
      mysensors-0	2016-02-19 19:53:16	info	Rx-Raw Temperature for the sensor 42 is0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
      mysensors-0	2016-02-19 19:53:15	debug	Communication port:/dev/ttyUSB0
      mysensors-0	2016-02-19 19:53:15	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.mysensors
      mysensors-0	2016-02-19 19:53:14	debug	statesDB connected
      mysensors-0	2016-02-19 19:53:14	debug	objectDB connected[/color]
      • V
        V
        Vlad_k
        Переустанавливай драйвер, сделал фильтрацию мусора, должно работать.
        ты сам скетч писал?
        • M
          M
          Maxtox
          Да… Писал сам....
          Спасибо!
          Сейчас оттестю...
          • M
            M
            Maxtox
            Console LOG:
            root@raspberrypi:/opt/iobroker# npm install https://github.com/DJONvl/iobroker.myse … all/master
            npm http GET https://github.com/DJONvl/iobroker.myse ... all/master
            npm http 200 https://github.com/DJONvl/iobroker.myse ... all/master
            npm http GET https://registry.npmjs.org/sensors
            npm http GET https://registry.npmjs.org/serialport
            npm http 304 https://registry.npmjs.org/sensors
            npm http 304 https://registry.npmjs.org/serialport
            npm http GET https://registry.npmjs.org/optimist
            npm http GET https://registry.npmjs.org/nan
            npm http GET https://registry.npmjs.org/bindings/1.2.1
            npm http GET https://registry.npmjs.org/sf/0.1.7
            npm http GET https://registry.npmjs.org/async/0.9.0
            npm http GET https://registry.npmjs.org/debug
            npm http 304 https://registry.npmjs.org/nan
            npm http 304 https://registry.npmjs.org/debug
            npm http 304 https://registry.npmjs.org/sf/0.1.7
            npm http 200 https://registry.npmjs.org/optimist
            npm http 304 https://registry.npmjs.org/bindings/1.2.1
            npm http 304 https://registry.npmjs.org/async/0.9.0
            npm http GET https://registry.npmjs.org/ms/0.7.1
            npm http 304 https://registry.npmjs.org/ms/0.7.1
            npm http GET https://registry.npmjs.org/wordwrap
            npm http GET https://registry.npmjs.org/minimist
            npm http 304 https://registry.npmjs.org/wordwrap
            npm http 304 https://registry.npmjs.org/minimist
            serialport@2.0.6 install /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport
            node-pre-gyp install --fallback-to-build
            node-pre-gyp http GET https://github.com/voodootikigod/node-s … arm.tar.gz
            node-pre-gyp http 404 https://github.com/voodootikigod/node-s ... arm.tar.gz
            node-pre-gyp http Pre-built binary not available for your system, looked for https://github.com/voodootikigod/node-s ... arm.tar.gz (falling back to source compile with node-gyp)
            make: Entering directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
            CXX(target) Release/obj.target/serialport/src/serialport.o
            CXX(target) Release/obj.target/serialport/src/serialport_unix.o
            CXX(target) Release/obj.target/serialport/src/serialport_poller.o
            SOLINK_MODULE(target) Release/obj.target/serialport.node
            SOLINK_MODULE(target) Release/obj.target/serialport.node: Finished
            COPY Release/serialport.node
            COPY /opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build/Release/node-v11-linux-arm/serialport.node
            TOUCH Release/obj.target/action_after_build.stamp
            make: Leaving directory '/opt/iobroker/node_modules/iobroker.mysensors/node_modules/serialport/build'
            iobroker.mysensors@0.0.1 node_modules/iobroker.mysensors
            ├── sensors@0.1.0
            └── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, nan@2.0.9, debug@2.2.0, optimist@0.6.1)
            • M
              M
              Maxtox
              смотрим!!!
              https://youtu.be/SyWTYB084xQ
              УЖЕ ЛУЧШЕ!
              Только BIND не сработал!
              • V
                V
                Vlad_k
                bind срабатывает, только переменная не сохраняется
                смотри что сделай:
                нажми bind в списке devices появятся твои юниты щелкни по любому 2 раза и нажми сохранить, чтобы активировалась кнопка Сохранить и выйти
                ToDo сделать активацию сохранения при добавлении в список новых юнитов
                • M
                  M
                  Maxtox
                  Ок… Попробую...
                  • M
                    M
                    Maxtox
                    Привет, могу ставить новую версию? Bluefox что-то запулил?!
                    • V
                      V
                      Vlad_k
                      да ставь
                      • M
                        M
                        Maxtox
                        смотрим!!!
                        https://youtu.be/mvjW1XE959E
                        • M
                          M
                          Maxtox
                          не читает… только информация из presentation
                          https://youtu.be/wylcfQUxXgk
                          • V
                            V
                            Vlad_k
                            @Maxtox:
                            смотрим!!!
                            https://youtu.be/mvjW1XE959E `
                            1 ты очень торопишься и не даешь запуститься драйверу, поэтому входя в настройки селектор ком портов пустой
                            2 ты добавил один и тот же юнит несколько раз, зачем? все равно имя переменной одно создается
                            3 для управления реле тебе нужно прописать в RAW посылку управляющую твоим реле без Value
                            а так все работает отлично
                            • M
                              M
                              Maxtox
                              смотрим
                              почему ack TRUE?
                              https://youtu.be/rPdlEBoaDGc
                              в скетче на ардуине
                              `present(i, iomodus[i].sensorType, iomodus[i].description, false);`
                              смотрим что происходит
                              [https://youtu.be/mcUTM45SjG8](https://youtu.be/mcUTM45SjG8)[/i][/i]
                              • M
                                M
                                Maxtox
                                @Vlad_k:
                                @Maxtox:
                                смотрим!!!
                                а так все работает отлично `
                                1. привык так :-)
                                2. убрал!
                                3. смотрим https://youtu.be/IiU1DlUT9cc
                                • V
                                  V
                                  Vlad_k
                                  все правильно, что тебя смущает? то что в ком порт от юнита приходит то и отображается, в логе постоянно надо жать кнопку обновить иначе не корректно показывает, но это не проблема в драйвере
                                  • M
                                    M
                                    Maxtox
                                    проблема в том что VALUE ПРЫГАЕТ, я думаю из за ack=TRUE,
                                    https://youtu.be/-uoDqlupOiE
                                    mysensors-0 2016-02-21 11:34:21 info Rx-Raw 0;58;1;1;0;55.91
                                    mysensors-0 2016-02-21 11:32:34 info _0|42|set|true|V_TEMP|_-127.00
                                    mysensors-0 2016-02-21 11:31:43 info raw_data_error 1
                                    mysensors-0 2016-02-21 11:33:36 info Rx-Raw 0;58;1;1;0;56.07
                                    mysensors-0 2016-02-21 11:34:21 info ack is not set!
                                    пробыvал изменит RAW от RELAY…Скрипт зависает! (последнее видео)
                                    • M
                                      M
                                      Maxtox
                                      BUG
                                      смотри как время в логе выходит!
                                      Или как ты время лога сортируешь?
                                      mysensors-0	2016-02-21 11:34:25	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw -127.00
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw TYPE
                                      mysensors-0	2016-02-21 11:32:38	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:31:47	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:33:39	info	raw_data_error 1
                                      mysensors-0	2016-02-21 11:32:38	info	Rx-Raw 58
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw -127.00
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw 42
                                      mysensors-0	2016-02-21 11:32:38	info	Rx-Raw PIN
                                      mysensors-0	2016-02-21 11:31:47	info	Rx-Raw 42
                                      mysensors-0	2016-02-21 11:33:39	info	Rx-Raw String
                                      mysensors-0	2016-02-21 11:32:38	info	__0_|_58_|_set_|_true_|_V_TEMP_|_40.08
                                      mysensors-0	2016-02-21 11:34:25	info	Rx-Raw PIN
                                      • V
                                        V
                                        Vlad_k
                                        0;8;1;1;2 для твоего реле напиши, остальные поля можно не трогать
                                        не понял какое время? только мусор и температура в логе
                                        • M
                                          M
                                          Maxtox
                                          https://youtu.be/LFCIhMTMtIY
                                          84.2k
