  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 663.6k Aufrufe 118 Beobachtet
    duffbeer2000
    schrieb am zuletzt editiert von duffbeer2000
    #202
    @Meistertr
    Hi ich hab mir jetzt auch mal die neue Version installiert. Was mir auffällt ist der "ReferenceError: that is not defined" im Log. Kommt die Karte nur mit Valetudo?
    Hab den ersten Saugroboter von Xiaomi den rockrobo.vacuum.v1 und läuft auf dem deutschen Server.
    mihome-vacuum.0	2020-02-19 10:21:54.902	debug	(12880) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":18}<<< 213100900000000003d7c8a15e4cfe321d32277cb36f22578c0653ca613f621d2d5
    mihome-vacuum.0	2020-02-19 10:21:54.892	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfe329884959db6f16cac2857d287ca0db2163b380369d7546477503af81c5cbfdca7e906fc22492627b98c8c9e9674a749db8a3fcb22aafdc66078e71de4a23a0277
    mihome-vacuum.0	2020-02-19 10:21:54.892	debug	(12880) sendMsg >>> {"id":18,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-02-19 10:21:54.891	debug	(12880) Timestamp: 5e4cfe32
    mihome-vacuum.0	2020-02-19 10:21:54.890	debug	(12880) lastid{"get_status":12,"get_consumable":14,"get_clean_summary":15,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":16,"get_carpet_mode":18,"get_room_mapping":9,"get_ma
    mihome-vacuum.0	2020-02-19 10:21:54.690	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfe323bde699e83a8af46a662c63b0a934dde53976748cb45ed5618c449e108872699901395142662c0716cf8293b442e0eb8
    mihome-vacuum.0	2020-02-19 10:21:54.690	debug	(12880) sendMsg >>> {"id":17,"method":"get_map_v1"}
    mihome-vacuum.0	2020-02-19 10:21:54.690	debug	(12880) Timestamp: 5e4cfe32
    mihome-vacuum.0	2020-02-19 10:21:54.689	debug	(12880) lastid{"get_status":12,"get_consumable":14,"get_clean_summary":15,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":16,"get_carpet_mode":8,"get_room_mapping":9,"get_map
    mihome-vacuum.0	2020-02-19 10:21:54.488	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfe3222b354013e161f54f0db2d958ea23cbde730841bc3fff7b7215192e9e773dfe147810cdf389a17d3d90a8810d3b7e9e7f49dfb550a1c627a4ed971527f43ca3e
    mihome-vacuum.0	2020-02-19 10:21:54.488	debug	(12880) sendMsg >>> {"id":16,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-02-19 10:21:54.487	debug	(12880) Timestamp: 5e4cfe32
    mihome-vacuum.0	2020-02-19 10:21:54.486	debug	(12880) lastid{"get_status":12,"get_consumable":14,"get_clean_summary":15,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":16,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:54.285	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfe32f9fb927bc4853efe2a127a72f5299a2abc0c86757b8df6d88aca3976207df900f2aa39d5e76a113c3614c66ea32dcfba8e8cc1def6f33ef013a34ad716a44e51
    mihome-vacuum.0	2020-02-19 10:21:54.285	debug	(12880) sendMsg >>> {"id":15,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-02-19 10:21:54.283	debug	(12880) Timestamp: 5e4cfe32
    mihome-vacuum.0	2020-02-19 10:21:54.282	debug	(12880) lastid{"get_status":12,"get_consumable":14,"get_clean_summary":15,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:54.081	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfe32af03087562fe9b474645655ca3e6de68c7b79ec1c11c99c02e4e58d4d3943f4d446a2e57a49e45bd3227f6ba82d5fbb88b307ed6e37add3e50b4c79ccf4bdb1c
    mihome-vacuum.0	2020-02-19 10:21:54.081	debug	(12880) sendMsg >>> {"id":14,"method":"get_consumable"}
    mihome-vacuum.0	2020-02-19 10:21:54.080	debug	(12880) Timestamp: 5e4cfe32
    mihome-vacuum.0	2020-02-19 10:21:54.079	debug	(12880) lastid{"get_status":12,"get_consumable":14,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:53.877	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfe31bd80ec97dba584c9bff7258e098707de020652f5d6eaf6f84f4d72fb4b0b53a2cd732b613d89c2d0004a4cdaf848e760
    mihome-vacuum.0	2020-02-19 10:21:53.877	debug	(12880) sendMsg >>> {"id":13,"method":"miIO.info"}
    mihome-vacuum.0	2020-02-19 10:21:53.876	debug	(12880) Timestamp: 5e4cfe31
    mihome-vacuum.0	2020-02-19 10:21:53.876	debug	(12880) lastid{"get_status":12,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":13,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:53.876	debug	(12880) requesting params every: 60 Sec
    mihome-vacuum.0	2020-02-19 10:21:53.876	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfe318feb7b58518a4eb6b6720229fd28d4f8da807baa5ade1848a79df158f22fde28b5a1923663747c5f5940a95416fcd3a2
    mihome-vacuum.0	2020-02-19 10:21:53.876	debug	(12880) sendMsg >>> {"id":12,"method":"get_status"}
    mihome-vacuum.0	2020-02-19 10:21:53.875	debug	(12880) Timestamp: 5e4cfe31
    mihome-vacuum.0	2020-02-19 10:21:53.875	debug	(12880) lastid{"get_status":12,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:53.874	debug	(12880) Connected
    mihome-vacuum.0	2020-02-19 10:21:53.873	debug	(12880) Receive <<< Helo <<< 213100200000000003d7c8a15e4cfe31ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-02-19 10:21:36.865	debug	(12880) Disconnect
    mihome-vacuum.0	2020-02-19 10:21:33.866	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfe1d706663aa2a089736e6ddb71738c1ffb88298a7c67a5efda2ae01cb8b346a0b16c2625d945a54c4e05647d0cfe6cbb810
    mihome-vacuum.0	2020-02-19 10:21:33.866	debug	(12880) sendMsg >>> {"id":11,"method":"get_status"}
    mihome-vacuum.0	2020-02-19 10:21:33.865	debug	(12880) Timestamp: 5e4cfe1d
    mihome-vacuum.0	2020-02-19 10:21:33.864	debug	(12880) lastid{"get_status":11,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:21:13.869	debug	(12880) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1199,"state":5,"battery":89,"clean_time":1268,"clean_area":21487500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0
    mihome-vacuum.0	2020-02-19 10:21:13.864	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfe09416ac10b616642fc4078641d5974c528cc252df2ba701a8bc668da1c556d9e6ac6e38918acf169db2bc8c9aa87208b5d
    mihome-vacuum.0	2020-02-19 10:21:13.864	debug	(12880) sendMsg >>> {"id":10,"method":"get_status"}
    mihome-vacuum.0	2020-02-19 10:21:13.863	debug	(12880) Timestamp: 5e4cfe09
    mihome-vacuum.0	2020-02-19 10:21:13.862	debug	(12880) lastid{"get_status":10,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:20:56.882	debug	(12880) Receive <<< {"result":"unknown_method","id":9}<<< 213100500000000003d7c8a15e4cfdf8d024efb74cd7814dfc81b1921516e0c7a7b8e992afda59687489bdec9d1b9afa7e9269b8beb254eab2d37b4e5079a91246024f1a06e74
    mihome-vacuum.0	2020-02-19 10:20:56.880	info	(12880) create state for carpet_mode
    mihome-vacuum.0	2020-02-19 10:20:56.879	debug	(12880) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":8}<<< 213100900000000003d7c8a15e4cfdf82cfe557e3c73b8acb15ee4390a4d00282d5
    mihome-vacuum.0	2020-02-19 10:20:56.865	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfdf8f95ad72db0f58e5ccf85d3c4afe637319d626b60446ed14942dee3acb5c44d1ad9dbf0d1982d578e8835dd1e3acdad3cb88ead0f781953adebb1fe08c0714601
    mihome-vacuum.0	2020-02-19 10:20:56.865	debug	(12880) sendMsg >>> {"id":9,"method":"get_room_mapping"}
    mihome-vacuum.0	2020-02-19 10:20:56.865	debug	(12880) Timestamp: 5e4cfdf8
    mihome-vacuum.0	2020-02-19 10:20:56.865	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":8,"get_room_mapping":9}
    mihome-vacuum.0	2020-02-19 10:20:56.864	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfdf8f9aba9afc2d3003699be698022fcbe207fb0d4d4a8644660b5ef4ed4bb735cc484015051999f8b5f073b479a1f006029c2803e24c9c6f13ac38ad77cdb842971
    mihome-vacuum.0	2020-02-19 10:20:56.864	debug	(12880) sendMsg >>> {"id":8,"method":"get_carpet_mode"}
    mihome-vacuum.0	2020-02-19 10:20:56.863	debug	(12880) Timestamp: 5e4cfdf8
    mihome-vacuum.0	2020-02-19 10:20:56.862	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5,"get_carpet_mode":8}
    mihome-vacuum.0	2020-02-19 10:20:56.061	warn	(12880) ReferenceError: that is not defined
    mihome-vacuum.0	2020-02-19 10:20:56.061	debug	(12880) Xiaomi Cloud: Login successful
    mihome-vacuum.0	2020-02-19 10:20:55.134	debug	(12880) CLEAN_LOGGING[{"Datum":"15.2","Start":"13:22","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"13.2","Start":"15:09","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":fa
    mihome-vacuum.0	2020-02-19 10:20:54.946	debug	(12880) Receive <<< {"result":[[1581602974,1581603042,2,0,0,0]],"id":7}<<< 213100600000000003d7c8a15e4cfdf678e87ca79d4d999a8bf9f99b6440f4665afebb37977ab0a1531dad9466073f17d1c7544f1992672f7bab3143c92a
    mihome-vacuum.0	2020-02-19 10:20:54.933	debug	(12880) sendMsgRaw >>> 213100600000000003d7c8a15e4cfdf66173a78d627dc8f6c6b90381a3aeb21d49d5cdf9d919a808cbcc2543f5a68160ece722036002b72b81ec7087ac5fe4a0602d9d1db7aac218e52dd452699488a6217f8dfbc2a22fdf
    mihome-vacuum.0	2020-02-19 10:20:54.932	debug	(12880) sendMsg >>> {"id":7,"method":"get_clean_record","params":[1581602974]}
    mihome-vacuum.0	2020-02-19 10:20:54.932	debug	(12880) Timestamp: 5e4cfdf6
    mihome-vacuum.0	2020-02-19 10:20:54.931	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":7,"X_send_command":0,"miIO.info":2,"get_sound_volume":5}
    mihome-vacuum.0	2020-02-19 10:20:54.930	debug	(12880) Request log entry: 1581602974
    mihome-vacuum.0	2020-02-19 10:20:54.734	debug	(12880) Receive <<< {"result":[[1581769345,1581769399,15,0,0,0]],"id":6}<<< 213100600000000003d7c8a15e4cfdf6b4672e046ef1ffce2c53be14a26b42745afebb37977ab0a1531dad9466073f1713b567389cf2f185feebb06477b
    mihome-vacuum.0	2020-02-19 10:20:54.729	debug	(12880) sendMsgRaw >>> 213100600000000003d7c8a15e4cfdf68b385046847026593218b65308a26aae7421ffc8809ddd1717fd077872b127e64b60221c32936026604837dc0967f5025e7df5be14d792fd19259e6fc74f5afcb15be7603410b9bb
    mihome-vacuum.0	2020-02-19 10:20:54.728	debug	(12880) sendMsg >>> {"id":6,"method":"get_clean_record","params":[1581769345]}
    mihome-vacuum.0	2020-02-19 10:20:54.728	debug	(12880) Timestamp: 5e4cfdf6
    mihome-vacuum.0	2020-02-19 10:20:54.727	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":6,"X_send_command":0,"miIO.info":2,"get_sound_volume":5}
    mihome-vacuum.0	2020-02-19 10:20:54.727	debug	(12880) Request log entry: 1581769345
    mihome-vacuum.0	2020-02-19 10:20:54.530	debug	(12880) Receive <<< {"result":[90],"id":5}<<< 213100400000000003d7c8a15e4cfdf665034b3877bc7932e02ac4d64d66b80e6fab81e96b50a7fef69429125d2eb7d424738108eacb0c177419c6411c95103c
    mihome-vacuum.0	2020-02-19 10:20:54.524	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfdf631aa1053ac6c8e095d0fb61ec9b6e2a0436b8f5c23a76f1fe3cd3bbcedba3e56dedf78a668a0154edd521800270ea9d146561c399847dde6f70c0219e9739c4b
    mihome-vacuum.0	2020-02-19 10:20:54.524	debug	(12880) sendMsg >>> {"id":5,"method":"get_sound_volume"}
    mihome-vacuum.0	2020-02-19 10:20:54.523	debug	(12880) Timestamp: 5e4cfdf6
    mihome-vacuum.0	2020-02-19 10:20:54.523	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2,"get_sound_volume":5}
    mihome-vacuum.0	2020-02-19 10:20:54.389	info	(12880) set nächster Timer: Nicht verfügbar
    mihome-vacuum.0	2020-02-19 10:20:54.331	debug	(12880) Receive <<< {"result":[1214255,18281305000,592,[1581769345,1581602974]],"id":4}<<< 213100700000000003d7c8a15e4cfdf66d852cb7d9287268a3228220a7f24b84a6fb87a767b429bfd475b1b535969d39082994958ceb
    mihome-vacuum.0	2020-02-19 10:20:54.322	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfdf63e03bd60cc75f39d4dfcd5675086a1789b4c212ecd6cf4425264f70e32ee96a2338f6938ffe249da1d119535d2c8f1eedd49392eed7d5a7e3d91ee19a6c64a62
    mihome-vacuum.0	2020-02-19 10:20:54.322	debug	(12880) sendMsg >>> {"id":4,"method":"get_clean_summary"}
    mihome-vacuum.0	2020-02-19 10:20:54.321	debug	(12880) Timestamp: 5e4cfdf6
    mihome-vacuum.0	2020-02-19 10:20:54.320	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":4,"get_clean_record":0,"X_send_command":0,"miIO.info":2}
    mihome-vacuum.0	2020-02-19 10:20:54.125	debug	(12880) Receive <<< {"result":[{"main_brush_work_time":635978,"side_brush_work_time":566197,"filter_work_time":419737,"sensor_dirty_time":99682}],"id":3}<<< 213100b00000000003d7c8a15e4cfdf5a61a252c71
    mihome-vacuum.0	2020-02-19 10:20:54.119	debug	(12880) sendMsgRaw >>> 213100500000000003d7c8a15e4cfdf6624590091080598529887d9cd39e8c6f72431b6c004540cfbc580dc2eda47d091a323655ca2e935a6961c55ef51c74ff4e3c55ffb7791a475495629aaeb35951
    mihome-vacuum.0	2020-02-19 10:20:54.119	debug	(12880) sendMsg >>> {"id":3,"method":"get_consumable"}
    mihome-vacuum.0	2020-02-19 10:20:54.118	debug	(12880) Timestamp: 5e4cfdf6
    mihome-vacuum.0	2020-02-19 10:20:54.117	debug	(12880) lastid{"get_status":1,"get_consumable":3,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"miIO.info":2}
    mihome-vacuum.0	2020-02-19 10:20:53.925	debug	(12880) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.3.9_003468","ap":{"ssid":"DramaQueen","bssid":"B4:FB:E4:2E:6B:84","rssi":-41},"netif":{"loca
    mihome-vacuum.0	2020-02-19 10:20:53.922	debug	(12880) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1198,"state":5,"battery":89,"clean_time":1250,"clean_area":21227500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0
    mihome-vacuum.0	2020-02-19 10:20:53.911	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfdf593623ded2933d2344a3fe28afa9ebc6f7ee401b1a145fb3d9ae527c453c8bbe11d0674ca3e53a535ba1f988eb20f8d8a
    mihome-vacuum.0	2020-02-19 10:20:53.911	debug	(12880) sendMsg >>> {"id":2,"method":"miIO.info"}
    mihome-vacuum.0	2020-02-19 10:20:53.910	debug	(12880) Timestamp: 5e4cfdf5
    mihome-vacuum.0	2020-02-19 10:20:53.910	debug	(12880) lastid{"get_status":1,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0,"miIO.info":2}
    mihome-vacuum.0	2020-02-19 10:20:53.909	debug	(12880) requesting params every: 60 Sec
    mihome-vacuum.0	2020-02-19 10:20:53.909	debug	(12880) sendMsgRaw >>> 213100400000000003d7c8a15e4cfdf5bc766d38f0e29943c77d5f9728815f7dd4f5fd46107c7e2364749c87a8e55b1539a3c50d8429cbfff341380fc10f3924
    mihome-vacuum.0	2020-02-19 10:20:53.908	debug	(12880) sendMsg >>> {"id":1,"method":"get_status"}
    mihome-vacuum.0	2020-02-19 10:20:53.908	debug	(12880) Timestamp: 5e4cfdf5
    mihome-vacuum.0	2020-02-19 10:20:53.906	debug	(12880) lastid{"get_status":1,"get_consumable":0,"get_clean_summary":0,"get_clean_record":0,"X_send_command":0}
    mihome-vacuum.0	2020-02-19 10:20:53.905	debug	(12880) Connected
    mihome-vacuum.0	2020-02-19 10:20:53.905	debug	(12880) Receive <<< Helo <<< 213100200000000003d7c8a15e4cfdf5ffffffffffffffffffffffffffffffff
    mihome-vacuum.0	2020-02-19 10:20:53.896	info	(12880) New generation or new fw detected, create new states goto and zoneclean
    mihome-vacuum.0	2020-02-19 10:20:53.866	debug	(12880) server started on 0.0.0.0:53421
    mihome-vacuum.0	2020-02-19 10:20:53.850	info	(12880) Create state clean_home for controlling by cloud adapter
    mihome-vacuum.0	2020-02-19 10:20:53.849	info	(12880) Expert mode enabled, states created
    mihome-vacuum.0	2020-02-19 10:20:53.842	debug	(12880) Xiaomi Cloud: Logging in
    mihome-vacuum.0	2020-02-19 10:20:53.840	debug	(12880) Maphelper_config___{"username":"*****************","password":"************","deviceId":"*******","clientId":"******","server":"de","valetudo":false,"mimap":true,"ip":"192.168.***.***","COL
    mihome-vacuum.0	2020-02-19 10:20:53.840	debug	(12880) load Map creator... true
    mihome-vacuum.0	2020-02-19 10:20:53.788	info	(12880) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
    • C Coffeelover
      @dirkhe Zunächst habe ich nur aktualisiert. Der Sauger war immernoch im Adapter, aber keine Karte. Habe daraufhin die Instanz komplett gelöscht und neu hinzugefügt. Dabei kam ich in eine Schleife: Adapter muss aktiv sein, um "Get devices" durchzuführen. Zum Speichern hat er aber einen Token gefordert. Deswegen habe ich vorübergehend 32x0 eingetragen. Dann gespeichert, Instanz aktiviert und dann get Device gedrückt. Token und IP standen oben und habe ich händisch übernommen. Alle Infos passen auch, nur auf die Karte warte ich noch. Fahre ihn später mal los und teste, ob dann die Karte auch kommt.
      Coffeelover
      schrieb am zuletzt editiert von Coffeelover
      #203
      Leider ist die Karte nicht aufgetaucht.
      Lib und Canvas habe ich installiert. Im Log habe ich keinerlei Fehler.
      Login ist auf CN-Server, Gerät ist ein Gen1. Mittels Flole-App sehe ich die Karte.
      Anbei mal ein Debug-Auszug. Auffällig empfinde ich die Info: Mappointer_nomap_retry.
      Den Fehler von @duffbeer2000 habe ich auch: mihome-vacuum.0 2020-02-19 12:40:08.875 warn (9093) ReferenceError: that is not defined
      mihome-vacuum.0	2020-02-19 11:54:44.322	debug	(19472) Mappointer_updated
      mihome-vacuum.0	2020-02-19 11:54:44.321	debug	(19472) Receive <<< {"result":["roboroommap%2F64673245%2F0"],"id":675}<<< 213100600000000003dad5dd5e4d141e28f8b25976f378a180f431bf24bae1bf0d680f66181c23d0fd7545d7f4a902e1d23c25281c86a616a7a06b4796ceed
      mihome-vacuum.0	2020-02-19 11:54:44.316	debug	(19472) Mappointer_nomap___retry
      mihome-vacuum.0	2020-02-19 11:54:44.316	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141eea1d69363a30da3e84abd1c6cc1dc2c96afcfdae924b7fca018f22fb9cfd5f835aefe754c91f825c74f28f1f0733cd64e7d6b5bdbba834936f0fa2eaf9d45e57
      mihome-vacuum.0	2020-02-19 11:54:44.315	debug	(19472) sendMsg >>> {"id":675,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:54:44.315	debug	(19472) Timestamp: 5e4d141e
      mihome-vacuum.0	2020-02-19 11:54:44.314	debug	(19472) lastid{"get_status":671,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":673,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:43.812	debug	(19472) Receive <<< {"result":["retry"],"id":674}<<< 213100400000000003dad5dd5e4d141e648dedede061817ce8f9743449a73db4d48a272bc94731cb263787e4d6b4af5c2f556d8cf4c8c6d399758e162416ee81
      mihome-vacuum.0	2020-02-19 11:54:43.807	debug	(19472) Mappointer_nomap___retry
      mihome-vacuum.0	2020-02-19 11:54:43.807	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141df65fc117ffa66c44495bb0e933a9354cb7fb01fde02051527afafe30959900352f2703e732b474766bb50af5850f7d19efd4bd5d1ccaf6a452e29f0fc38f7daf
      mihome-vacuum.0	2020-02-19 11:54:43.807	debug	(19472) sendMsg >>> {"id":674,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:54:43.805	debug	(19472) Timestamp: 5e4d141d
      mihome-vacuum.0	2020-02-19 11:54:43.804	debug	(19472) lastid{"get_status":671,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":673,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:43.507	debug	(19472) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":673}<<< 213100900000000003dad5dd5e4d141dc002d6cba38541364d2bba09e92b5e9aba
      mihome-vacuum.0	2020-02-19 11:54:43.500	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141d2c6628ed23398b8e0a6171906a5c77cfbeaadb2441182cf7097e32dca164d89ee1e487ec757066ab9b51914b5ac32e35d4d03debeffe3308690e04655adfd1ea
      mihome-vacuum.0	2020-02-19 11:54:43.500	debug	(19472) sendMsg >>> {"id":673,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-02-19 11:54:43.499	debug	(19472) Timestamp: 5e4d141d
      mihome-vacuum.0	2020-02-19 11:54:43.498	debug	(19472) lastid{"get_status":671,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":673,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:43.304	debug	(19472) Receive <<< {"result":["retry"],"id":672}<<< 213100400000000003dad5dd5e4d141dcc061fb1956410e922c8c964072ca48ad48a272bc94731cb263787e4d6b4af5c42bb9528311c981e432953f4fb52d5cb
      mihome-vacuum.0	2020-02-19 11:54:43.298	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141d24002d43c0fb55507119aa59aa08fb4ddb32931a04bd6667443e73888ca6efb8d384937dfe8f4038bfd9913f94e780bd390af84d0c60007619735a3625a3988e
      mihome-vacuum.0	2020-02-19 11:54:43.298	debug	(19472) sendMsg >>> {"id":672,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:54:43.297	debug	(19472) Timestamp: 5e4d141d
      mihome-vacuum.0	2020-02-19 11:54:43.297	debug	(19472) lastid{"get_status":671,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:43.127	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2746,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0}
      mihome-vacuum.0	2020-02-19 11:54:43.120	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141da4989e0c396a4ab8bea0938fa66c4bffeec517375fe6601161195c81363009fd5e203a685e2dc622d291642410a5b42e4ed0a75990ad8832cceb7524a34ceeb9
      mihome-vacuum.0	2020-02-19 11:54:43.120	debug	(19472) sendMsg >>> {"id":671,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:54:43.119	debug	(19472) Timestamp: 5e4d141d
      mihome-vacuum.0	2020-02-19 11:54:43.118	debug	(19472) lastid{"get_status":671,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:43.103	debug	(19472) Receive <<< {"result":[3],"id":670}<<< 213100400000000003dad5dd5e4d141dcbb310494cc42495341826678fd19bd3391782ef091bc9afd0b88205d4ec304afc2e22eb73980762bcdfd742d56f80aa
      mihome-vacuum.0	2020-02-19 11:54:43.096	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141d8cdb69ef1c449909595514c3e0662f9754a508a3d87994d43c32caa1b9538baf5876fff59be4629db7e95256092e714daa5da9d2dcfc380b96132b260ef7abf3
      mihome-vacuum.0	2020-02-19 11:54:43.096	debug	(19472) sendMsg >>> {"id":670,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-02-19 11:54:43.095	debug	(19472) Timestamp: 5e4d141d
      mihome-vacuum.0	2020-02-19 11:54:43.094	debug	(19472) lastid{"get_status":666,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":670,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:42.902	debug	(19472) Receive <<< {"result":[1596681,23627500000,906,[1582097581,1582042566,1581863478,1581784671,1581664138,1581576497,1581489846,1581422722,1581418701,1581245848,1581237019,1581165103,1581084838,1
      mihome-vacuum.0	2020-02-19 11:54:42.893	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141c10faa15e15e0b2101724082a84bca854c125bcbc7b62481355da306f7bc527c005f369deade744c929c68804527f62da9f2b8ac3706f99b50fb15daeea3bac63
      mihome-vacuum.0	2020-02-19 11:54:42.893	debug	(19472) sendMsg >>> {"id":669,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-02-19 11:54:42.892	debug	(19472) Timestamp: 5e4d141c
      mihome-vacuum.0	2020-02-19 11:54:42.891	debug	(19472) lastid{"get_status":666,"get_consumable":668,"get_clean_summary":669,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:42.698	debug	(19472) Receive <<< {"result":[{"main_brush_work_time":621997,"side_brush_work_time":236598,"filter_work_time":69826,"sensor_dirty_time":45064}],"id":668}<<< 213100b00000000003dad5dd5e4d141c7aab460df2
      mihome-vacuum.0	2020-02-19 11:54:42.690	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d141c0a1e6e918ce0cc1b092ac4e7f97b38c358e0ada256feea1c385696aa7287a2adc9160714fa89f241e50b5f5c75dca09f8a1a4c009343f2ea91f96ac05a2d4a82
      mihome-vacuum.0	2020-02-19 11:54:42.690	debug	(19472) sendMsg >>> {"id":668,"method":"get_consumable"}
      mihome-vacuum.0	2020-02-19 11:54:42.689	debug	(19472) Timestamp: 5e4d141c
      mihome-vacuum.0	2020-02-19 11:54:42.688	debug	(19472) lastid{"get_status":666,"get_consumable":668,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:42.494	debug	(19472) Receive <<< {"partner_id":"","id":667,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.0_003532","ap":{"ssid":"WLAN@Dienst","bssid":"CC:CE:1E:CB:21:71","rssi":-49},"netif":{"lo
      mihome-vacuum.0	2020-02-19 11:54:42.488	debug	(19472) sendMsgRaw >>> 213100400000000003dad5dd5e4d141cc73faca8bfe54eb9196cd65fd1dbccf695d555c7bc0e752cd9ec9e49f224e9e045ba847d412fc7cbd2bf18338ffc773a
      mihome-vacuum.0	2020-02-19 11:54:42.488	debug	(19472) sendMsg >>> {"id":667,"method":"miIO.info"}
      mihome-vacuum.0	2020-02-19 11:54:42.487	debug	(19472) Timestamp: 5e4d141c
      mihome-vacuum.0	2020-02-19 11:54:42.487	debug	(19472) lastid{"get_status":666,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":667,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":15
      mihome-vacuum.0	2020-02-19 11:54:42.486	debug	(19472) requesting params every: 60 Sec
      mihome-vacuum.0	2020-02-19 11:54:23.126	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2745,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0
      mihome-vacuum.0	2020-02-19 11:54:23.118	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d1409818694dcc346196ab05b91732c4560f4957167ac106c65fd1e3dffafa58a778ece82bbc3e5a8a83cc969d08e1ad0920c3a126efcd5fa213dafd6ddc42d968ff3
      mihome-vacuum.0	2020-02-19 11:54:23.118	debug	(19472) sendMsg >>> {"id":666,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:54:23.117	debug	(19472) Timestamp: 5e4d1409
      mihome-vacuum.0	2020-02-19 11:54:23.116	debug	(19472) lastid{"get_status":666,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:54:03.123	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2744,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0
      mihome-vacuum.0	2020-02-19 11:54:03.116	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13f56b289eeaa03a863ed8c539f82df47bb1ad01bdbf13f558988294b4edc5c1383ee360bf2d79ca3ddc167cfc40e627968fef770fb33ccc66cb956c65da1c955fc6
      mihome-vacuum.0	2020-02-19 11:54:03.116	debug	(19472) sendMsg >>> {"id":665,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:54:03.115	debug	(19472) Timestamp: 5e4d13f5
      mihome-vacuum.0	2020-02-19 11:54:03.114	debug	(19472) lastid{"get_status":665,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:44.321	debug	(19472) Mappointer_updated
      mihome-vacuum.0	2020-02-19 11:53:44.320	debug	(19472) Receive <<< {"result":["roboroommap%2F64673245%2F1"],"id":664}<<< 213100600000000003dad5dd5e4d13e2b802130517ca5adca381e7ae272e62540d680f66181c23d0fd7545d7f4a902e1d23c25281c86a616a7a06b4796cee
      mihome-vacuum.0	2020-02-19 11:53:44.315	debug	(19472) Mappointer_nomap___retry
      mihome-vacuum.0	2020-02-19 11:53:44.314	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e26a66b0b63ab34655d5c32a1328a43ea25a1b6942deb05d5c2cd53f239faabd783878bffec5845c4cfc2ac3bf7073c283ecc3fc5c3c03c0f0ec389c84d1ca5118
      mihome-vacuum.0	2020-02-19 11:53:44.314	debug	(19472) sendMsg >>> {"id":664,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:53:44.314	debug	(19472) Timestamp: 5e4d13e2
      mihome-vacuum.0	2020-02-19 11:53:44.313	debug	(19472) lastid{"get_status":660,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:43.812	debug	(19472) Receive <<< {"result":["retry"],"id":663}<<< 213100400000000003dad5dd5e4d13e25e70c68afa20e4a6d21093822d01a368d48a272bc94731cb263787e4d6b4af5c7aaf28483482051353b24fb8d6996a38
      mihome-vacuum.0	2020-02-19 11:53:43.807	debug	(19472) Mappointer_nomap___retry
      mihome-vacuum.0	2020-02-19 11:53:43.806	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e10646b2ee597aed81f5fd3b3e2480919191d3510992f203283b83bb1590887cf32b280ea020f65cef5fb99e17c805710484236a7fa1f4205f7a267a9b4430475a
      mihome-vacuum.0	2020-02-19 11:53:43.806	debug	(19472) sendMsg >>> {"id":663,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:53:43.805	debug	(19472) Timestamp: 5e4d13e1
      mihome-vacuum.0	2020-02-19 11:53:43.805	debug	(19472) lastid{"get_status":660,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:43.506	debug	(19472) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":662}<<< 213100900000000003dad5dd5e4d13e114bb78cd033808ee5973bd5dc7da8863b
      mihome-vacuum.0	2020-02-19 11:53:43.499	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e1db5da963661c69ec06562649e0712b7243590eca15aabd7d613a56a444588b42f7d3a88e932c3019dbe78a7ee37bf0808ab3c12eae6f53fc2209a3252365fc76
      mihome-vacuum.0	2020-02-19 11:53:43.499	debug	(19472) sendMsg >>> {"id":662,"method":"get_carpet_mode"}
      mihome-vacuum.0	2020-02-19 11:53:43.498	debug	(19472) Timestamp: 5e4d13e1
      mihome-vacuum.0	2020-02-19 11:53:43.497	debug	(19472) lastid{"get_status":660,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":662,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:43.303	debug	(19472) Receive <<< {"result":["retry"],"id":661}<<< 213100400000000003dad5dd5e4d13e1b88625b7bb3c381d1c6e182c9ab14560d48a272bc94731cb263787e4d6b4af5c6e940965ba768ec79fd15dfd057c50aa
      mihome-vacuum.0	2020-02-19 11:53:43.297	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e1feecc3b050508c205ff0d9b6793dc155e20aa4427da4fff210f375c9a010e3ca395b2eda83f7e74c52f80da23b63bccef0f9e693d24b9b57214a42e942b7a868
      mihome-vacuum.0	2020-02-19 11:53:43.297	debug	(19472) sendMsg >>> {"id":661,"method":"get_map_v1"}
      mihome-vacuum.0	2020-02-19 11:53:43.296	debug	(19472) Timestamp: 5e4d13e1
      mihome-vacuum.0	2020-02-19 11:53:43.295	debug	(19472) lastid{"get_status":660,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:43.122	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2743,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0
      mihome-vacuum.0	2020-02-19 11:53:43.114	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e1a82a0fbf3f2fa27e29e2945ddc1d596e25eceb8f0b8861a7e3959bbc6db606d090caa98221bfb7b585fa340fa73218306169330288f7b8bfdcdba76e72f24947
      mihome-vacuum.0	2020-02-19 11:53:43.114	debug	(19472) sendMsg >>> {"id":660,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:53:43.114	debug	(19472) Timestamp: 5e4d13e1
      mihome-vacuum.0	2020-02-19 11:53:43.113	debug	(19472) lastid{"get_status":660,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:43.102	debug	(19472) Receive <<< {"result":[3],"id":659}<<< 213100400000000003dad5dd5e4d13e1d7e8266d6b4c7c5fce075c304bf8522d391782ef091bc9afd0b88205d4ec304af2f11d7d715d5fbdf096178d8aa2dbde
      mihome-vacuum.0	2020-02-19 11:53:43.095	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e1de0de8d7e7469befe0caa300450a287c5a14a45f3ee2c0f15e6acb99f0fb562db3979196750f3377ddeec163504f7c679255f881475f0e4b40a619d91decd9ae
      mihome-vacuum.0	2020-02-19 11:53:43.094	debug	(19472) sendMsg >>> {"id":659,"method":"get_sound_volume"}
      mihome-vacuum.0	2020-02-19 11:53:43.093	debug	(19472) Timestamp: 5e4d13e1
      mihome-vacuum.0	2020-02-19 11:53:43.092	debug	(19472) lastid{"get_status":655,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":659,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:42.902	debug	(19472) Receive <<< {"result":[1596681,23627500000,906,[1582097581,1582042566,1581863478,1581784671,1581664138,1581576497,1581489846,1581422722,1581418701,1581245848,1581237019,1581165103,1581084838,
      mihome-vacuum.0	2020-02-19 11:53:42.892	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e0c49029967d1ee3f051ce8efd62147514be3314398e43b5407fdf6371f943bedb9e284fea504a7d957dc4637fbb92443133b6962d7fb19baf8c0a768985b7ee86
      mihome-vacuum.0	2020-02-19 11:53:42.892	debug	(19472) sendMsg >>> {"id":658,"method":"get_clean_summary"}
      mihome-vacuum.0	2020-02-19 11:53:42.891	debug	(19472) Timestamp: 5e4d13e0
      mihome-vacuum.0	2020-02-19 11:53:42.891	debug	(19472) lastid{"get_status":655,"get_consumable":657,"get_clean_summary":658,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:42.697	debug	(19472) Receive <<< {"result":[{"main_brush_work_time":621997,"side_brush_work_time":236598,"filter_work_time":69826,"sensor_dirty_time":45064}],"id":657}<<< 213100b00000000003dad5dd5e4d13e05a8d3ee8f
      mihome-vacuum.0	2020-02-19 11:53:42.690	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13e0860b29827c4ce1e24a6983040926fa2307f89d31f12d5142e9dca023b1ef6452a6c04172d0e843dc70acb94df981d9f29a81fc7f20b150502e0329fa7aaa32f8
      mihome-vacuum.0	2020-02-19 11:53:42.690	debug	(19472) sendMsg >>> {"id":657,"method":"get_consumable"}
      mihome-vacuum.0	2020-02-19 11:53:42.690	debug	(19472) Timestamp: 5e4d13e0
      mihome-vacuum.0	2020-02-19 11:53:42.689	debug	(19472) lastid{"get_status":655,"get_consumable":657,"get_clean_summary":644,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:42.494	debug	(19472) Receive <<< {"partner_id":"","id":656,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.0_003532","ap":{"ssid":"WLAN@Dienst","bssid":"CC:CE:1E:CB:21:71","rssi":-49},"netif":{"l
      mihome-vacuum.0	2020-02-19 11:53:42.488	debug	(19472) sendMsgRaw >>> 213100400000000003dad5dd5e4d13e02caff041647a4997a6604b364d5176f3cc4a5704bd304ab2b84313b978c516adb41ecb7969112e040208e551f2f20bc6
      mihome-vacuum.0	2020-02-19 11:53:42.488	debug	(19472) sendMsg >>> {"id":656,"method":"miIO.info"}
      mihome-vacuum.0	2020-02-19 11:53:42.487	debug	(19472) Timestamp: 5e4d13e0
      mihome-vacuum.0	2020-02-19 11:53:42.486	debug	(19472) lastid{"get_status":655,"get_consumable":643,"get_clean_summary":644,"get_clean_record":27,"X_send_command":0,"miIO.info":656,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:42.486	debug	(19472) requesting params every: 60 Sec
      mihome-vacuum.0	2020-02-19 11:53:33.419	debug	(19472) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-02-19 11:53:23.118	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2742,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0
      mihome-vacuum.0	2020-02-19 11:53:23.112	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13cd017325ad52780d241acec4006336b80450a252de35c7f7b8d8bd2b6701d2da7fbe5ff40db5d2401ea6864e980555cb893cc8c24a0dcbab0eced1a1866e63df63
      mihome-vacuum.0	2020-02-19 11:53:23.111	debug	(19472) sendMsg >>> {"id":655,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:53:23.110	debug	(19472) Timestamp: 5e4d13cd
      mihome-vacuum.0	2020-02-19 11:53:23.109	debug	(19472) lastid{"get_status":655,"get_consumable":643,"get_clean_summary":644,"get_clean_record":27,"X_send_command":0,"miIO.info":642,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:53:03.116	debug	(19472) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2741,"state":10,"battery":86,"clean_time":899,"clean_area":18585000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":90,"dnd_enabled":0
      mihome-vacuum.0	2020-02-19 11:53:03.109	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13b989c205fcc7d76c97974d43843e8faf489a20a04eddd68c24f4ff922ad681be08c29e4b0acfa82c25247c135e171566b5ddcab28e4a09c48dc16301253c0dae3d
      mihome-vacuum.0	2020-02-19 11:53:03.109	debug	(19472) sendMsg >>> {"id":654,"method":"get_status"}
      mihome-vacuum.0	2020-02-19 11:53:03.108	debug	(19472) Timestamp: 5e4d13b9
      mihome-vacuum.0	2020-02-19 11:53:03.107	debug	(19472) lastid{"get_status":654,"get_consumable":643,"get_clean_summary":644,"get_clean_record":27,"X_send_command":0,"miIO.info":642,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:52:57.769	debug	(19472) Receive <<< {"result":["ok"],"id":653}<<< 213100400000000003dad5dd5e4d13b40aacad1ab1806d40a696121fb10869cd66ef55bc0dc8f7dc9a0014e09d00b27c48fcf49cf18b9d42e8c6503ff4a3aa6f
      mihome-vacuum.0	2020-02-19 11:52:57.765	debug	(19472) sendMsgRaw >>> 213100400000000003dad5dd5e4d13b3ad0d8d5fc4322400e87f581b59cedc750f846659aecaf6b8561f9c7c39226afc08c172df659876de051e40bfeabcfd54
      mihome-vacuum.0	2020-02-19 11:52:57.765	debug	(19472) sendMsg >>> {"id":653,"method":"app_pause"}
      mihome-vacuum.0	2020-02-19 11:52:57.764	debug	(19472) Timestamp: 5e4d13b3
      mihome-vacuum.0	2020-02-19 11:52:57.763	debug	(19472) lastid{"get_status":646,"get_consumable":643,"get_clean_summary":644,"get_clean_record":27,"X_send_command":0,"miIO.info":642,"get_sound_volume":645,"get_carpet_mode":648,"get_room_mapping":1
      mihome-vacuum.0	2020-02-19 11:52:57.763	debug	(19472) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1582109577759,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582109577759}
      mihome-vacuum.0	2020-02-19 11:52:56.582	debug	(19472) Receive <<< {"result":["ok"],"id":652}<<< 213100400000000003dad5dd5e4d13b2b34769bec86a0ae0351974544500d80366ef55bc0dc8f7dc9a0014e09d00b27cd0dcb00f3b81fb39459aff88714d8719
      mihome-vacuum.0	2020-02-19 11:52:56.571	debug	(19472) sendMsgRaw >>> 213100500000000003dad5dd5e4d13b2cc9fc4be3bee822ac9ced3c1afd2d8b3170713bde8976eed19a4c03419c40775e31fa33abfd16a5c821da4f935ceb82e8091e88fac585e4771710c56f9b821dc
      mihome-vacuum.0	2020-02-19 11:52:56.571	debug	(19472) sendMsg >>> {"id":652,"method":"app_pause","params":[30]}
      mihome-vacuum.0	2020-02-19 11:52:56.570	debug	(19472) Timestamp: 5e4d13b2
      Gerade nochmal das Log gefiltert auf Info. Das "Terminated" kam von mir. Ich hatte einmal die Karte über Cloud deaktiviert. (1. Terminated) und dann wieder aktiviert (2. Terminated). Kann es sein, dass deswegen keine Karte gezogen wird?
      mihome-vacuum.0	2020-02-19 12:48:49.264	warn	(9181) ReferenceError: that is not defined
      mihome-vacuum.0	2020-02-19 12:48:47.812	info	(9181) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-02-19 12:48:47.229	warn	(9181) Time difference between Mihome Vacuum and ioBroker: 42 sec
      mihome-vacuum.0	2020-02-19 12:48:47.209	info	(9181) New generation or new fw detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-02-19 12:48:47.122	info	(9181) Cloud control disabled
      mihome-vacuum.0	2020-02-19 12:48:47.120	info	(9181) Expert mode enabled, states created
      mihome-vacuum.0	2020-02-19 12:48:46.985	info	(9181) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.17.0
      mihome-vacuum.0	2020-02-19 12:48:40.074	info	(9165) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-02-19 12:48:40.073	info	(9165) terminating
      mihome-vacuum.0	2020-02-19 12:48:40.070	info	(9165) Got terminate signal TERMINATE_YOURSELF
      mihome-vacuum.0	2020-02-19 12:48:24.245	info	(9165) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-02-19 12:48:24.125	warn	(9165) Time difference between Mihome Vacuum and ioBroker: 42 sec
      mihome-vacuum.0	2020-02-19 12:48:23.816	info	(9165) New generation or new fw detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-02-19 12:48:23.698	info	(9165) Cloud control disabled
      mihome-vacuum.0	2020-02-19 12:48:23.696	info	(9165) Expert mode enabled, states created
      mihome-vacuum.0	2020-02-19 12:48:23.649	info	(9165) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.17.0
      mihome-vacuum.0	2020-02-19 12:48:17.584	info	(9146) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-02-19 12:48:17.583	info	(9146) terminating
      mihome-vacuum.0	2020-02-19 12:48:17.581	info	(9146) Got terminate signal TERMINATE_YOURSELF
      MeistertrM 1 Antwort Letzte Antwort
      • C Coffeelover
        MeistertrM Offline
        MeistertrM Offline
        Meistertr
        #204
        @Coffeelover lad nochmal von git hatte noch einen reference Fehler drin
        • D dirkhe
          @Coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
          @Meistertr das ist tatsächlich ein Problem bei Neuinstallationen...
          MeistertrM Offline
          MeistertrM Offline
          Meistertr
          #205
          @dirkhe ich Bau die Config nochmal um aber mit abbrechen Adapter starten geht es auch..
          • C Offline
            Coffeelover
            #206
            Gesagt, getan, gefreut.
            Das war es, jetzt ist zumindest auch bei mir die Karte da.
            • MeistertrM Meistertr
              Adnim
              #207
              @Meistertr
              Hi! tausend Dank für dieses Kunstwerk von Adapter und deine investierte Zeit.
              Habe nen S50 gen2 mit Valetudo RE 0.9.0 und der Akutellen Version vom Adapter von Github installiert. Map Räume alles funzt <3
              Mit den Räumen musste ich aber schon stark nachhelfen er hat mir nur einen für die gesamte Fläche angezeigt, das war etwas irrtierend und ich dachte daher das funzt nicht.Tut es aber, man muss nur die Räume dann aufteilen.
                schmuh
                #208
                @Meistertr
                kann ich bestätigen, map64 und erstmalig auch mapURL ist gefüllt.
                Großen Dank
                Werner
                  tazdevil20
                  #209
                  @Meistertr
                  In der Scriptlösung gab es wohl die Möglichkeit die Karte etwas zu zoomen (dort musste wohl eine Zeile angepasst werden). Lässt sich soetwas auch mit dem Adapter machen?
                  Ich hätte den rot markierten Bereich zur Verfügung.
                  C 1 Antwort Letzte Antwort
                  • T tazdevil20
                    @Meistertr
                    Coffeelover
                    #210
                    @tazdevil20 Ich hatte das gleiche "Problem". Ich habe ein HTML-Widget eingefügt und das übergroß skaliert. Z-Index 1. Dazu habe ich HTML-Widgets mit Hintergrundfarbe auf Z-Index 2 gelegt und die überschüssigen Ränder abgeschnitten. Alle anderen Widgets haben Z-Index > 2.
                    Edit: Bild vergessen:
                    T B 2 Antworten Letzte Antwort
                    • C Coffeelover
                      tazdevil20
                      #211
                      @Coffeelover
                      Danke für die Antwort. Ich verstehe nur gerade das Beschriebene nicht. :(
                      Kannst Du das/die Widgets exportieren und zur Verfügung stellen. Dann verstehe ich es sicherlich :)
                      • T tazdevil20
                        @Coffeelover
                        Coffeelover
                        #212
                        @tazdevil20 Gerne. Anbei.
                        Hab dir zur besseren Übersicht die "Überdecker" farbig gemacht.
                        [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":true,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"class":"myframe","name":"Rahmen"},"style":{"left":"5px","top":"468px","box-shadow":"","z-index":"2","width":"500px","height":"330px"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{mihome-vacuum.0.map.map64}","class":"","name":"Sauger Bild"},"style":{"left":"-130px","top":"335px","width":"700px","height":"600px","z-index":"0"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Überdecker"},"style":{"left":"0px","top":"330px","z-index":"1","background":"","width":"508px","height":"138px","background-color":"blue"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Überdecker"},"style":{"left":"508px","top":"331px","z-index":"1","background":"","width":"200px","height":"467px","background-color":"green"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Überdecker"},"style":{"left":"0px","top":"468px","z-index":"1","background":"","width":"5px","height":"330px","background-color":"red"},"widgetSet":"basic"}]
                        • MeistertrM Offline
                          MeistertrM Offline
                          Meistertr
                          #213
                          Wenn es soweit fertig ist werde ich noch einen zoom einfügen
                            blackeagle998
                            schrieb am zuletzt editiert von blackeagle998
                            #214
                            @Meistertr
                            ich habe heute den Adapter aktualisiert und bekomme jetzt bei jeder Bewegung des Saugers sekündlich folgende Fehlermeldung im LOG:
                            mihome-vacuum.0	2020-02-19 16:43:44.528	error	(5373) SyntaxError: Unexpected token G in JSON at position 0
                            Adapter Version 2.0.5
                            Sauger: Roborock S50
                            Außerdem noch kurz folgende Fragen:
                            In der MiHome App hat die Karte jetzt Räume abgeteilt, Namen kann ich dafür momentan keine vergeben, richtig?
                            Außerdem hat der Adapter unter "rooms" eben diese Räume nicht erkannt/erstellt, muss man das manuell machen?
                            Danke vorab für eure Unterstützung!
                            • C Coffeelover
                              tazdevil20
                              #215
                              @Coffeelover
                              Danke. Ganz verstehen tue ich es jetzt trotzdem noch nicht. Im Endefekt überdeckst du doch nur die leeren Bereiche und schneidest dadurch die Karte heraus. Die Größe der Karte/Anzeige bleibt gleich.
                              Ich möchte die Karte größer dargestellt haben. Dann warte ich einfach bis das implementiert ist. Ist ja nur ein "Schönheisfehler" in meiner VIS.
                              @Meistertr
                              Vielen Dank!
                              • T tazdevil20
                                @Coffeelover
                                @Meistertr
                                Vielen Dank!
                                Coffeelover
                                #216
                                @tazdevil20 Das meinte ich mit übergroß skaliert. Also z.B. Left = -130, top = -130, width = 150%, hight = 150%
                                [{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{mihome-vacuum.0.map.map64}","class":"","name":"Sauger Bild"},"style":{"left":"-130px","top":"-130px","width":"150%","height":"150%","z-index":"0"},"widgetSet":"basic"}]
                                • C Coffeelover
                                  tazdevil20
                                  #217
                                  @Coffeelover
                                  Das habe ich jetzt verstanden. Mir war nicht klar, dass ich Prozentzahlen in die Felder eingeben kann. Danke für den Hinweis.
                                  • T tazdevil20
                                    @Coffeelover
                                    Coffeelover
                                    #218
                                    @tazdevil20 Gerne. Es geht auch mit absoluten Werten...
                                      @Diginix der fehler mit Error when receiving mapurl sollte nun behoben sein , in deinem log aktualisiert er die Karte auf jeden fall, konnte mind. einen Kartendurchlauf sehen
                                      blackeagle998
                                      #219
                                      @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                                      mihome-vacuum.0	2020-02-19 18:58:24.090	error	(3043) Error when receiving mapurl
                                      Ich bekomme den Fehler leider auch 😞
                                      DiginixD MeistertrM 2 Antworten Letzte Antwort
                                      • B blackeagle998
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        #220
                                        @blackeagle998 Hast du auch schon das letzte Update von GIT installiert?
                                        Bei mir funktioniert alles mit der Version von heute morgen.
                                        ..:: So long! Tom ::..
                                        • DiginixD Diginix
                                          blackeagle998
                                          #221
                                          @Diginix
                                          Ich habe den Adapter vorhin von GIT installiert, Version steht auf 2.0.5, ich probiere es einfach nochmal.
