  4. Kein Restore möglich
iobroker backup restore
5 Beiträge 3 Kommentatoren 572 Aufrufe 3 Beobachtet
  • I Offline
    I Offline
    intruder7
    Hallo, ich wollte mit ioBroker von einem Rock64 auf einen RockPro64 umziehen.
    Die Installation von ioBroker auf dem RockPro hat ohne Probleme funktioniert.
    Auf beiden Systemen sind folgende Versionen
    JS-controler 2.2.8
    node 10.19.0
    nodejs 10.19.0
    npm 6.13.4
    Er bricht aber jedesmal beim Restore ab mit folgender Meldung
    host.localhost Using backup file 2020_02_17-08_48_50_backupiobroker.tar.gz
    iobroker controller daemon is not running
    host.localhost OK.
    host.localhost Clear all objects and states...
    clean 367 objects...
    [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
    [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
    [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
    [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
    [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
    [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
    clean 279 states...
    host.localhost done.
    host.localhost Processed 0/17715 states
    host.localhost Processed 200/17715 states
    host.localhost Processed 400/17715 states
    host.localhost Processed 600/17715 states
    host.localhost Processed 800/17715 states
    host.localhost Processed 1000/17715 states
    host.localhost Processed 1200/17715 states
    host.localhost Processed 1400/17715 states
    host.localhost Processed 1600/17715 states
    host.localhost Processed 1800/17715 states
    host.localhost Processed 2000/17715 states
    host.localhost Processed 2200/17715 states
    host.localhost Processed 2400/17715 states
    host.localhost Processed 2600/17715 states
    host.localhost Processed 2800/17715 states
    host.localhost Processed 3000/17715 states
    host.localhost Processed 3200/17715 states
    host.localhost Processed 3400/17715 states
    host.localhost Processed 3600/17715 states
    host.localhost Processed 3800/17715 states
    host.localhost Processed 4000/17715 states
    host.localhost Processed 4200/17715 states
    host.localhost Processed 4400/17715 states
    host.localhost Processed 4600/17715 states
    host.localhost Processed 4800/17715 states
    host.localhost Processed 5000/17715 states
    host.localhost Processed 5200/17715 states
    host.localhost Processed 5400/17715 states
    host.localhost Processed 5600/17715 states
    host.localhost Processed 5800/17715 states
    host.localhost Processed 6000/17715 states
    host.localhost Processed 6200/17715 states
    host.localhost Processed 6400/17715 states
    host.localhost Processed 6600/17715 states
    host.localhost Processed 6800/17715 states
    host.localhost Processed 7000/17715 states
    host.localhost Processed 7200/17715 states
    host.localhost Processed 7400/17715 states
    host.localhost Processed 7600/17715 states
    host.localhost Processed 7800/17715 states
    host.localhost Processed 8000/17715 states
    host.localhost Processed 8200/17715 states
    host.localhost Processed 8400/17715 states
    host.localhost Processed 8600/17715 states
    host.localhost Processed 8800/17715 states
    host.localhost Processed 9000/17715 states
    host.localhost Processed 9200/17715 states
    host.localhost Processed 9400/17715 states
    host.localhost Processed 9600/17715 states
    host.localhost Processed 9800/17715 states
    host.localhost Processed 10000/17715 states
    host.localhost Processed 10200/17715 states
    host.localhost Processed 10400/17715 states
    host.localhost Processed 10600/17715 states
    host.localhost Processed 10800/17715 states
    host.localhost Processed 11000/17715 states
    host.localhost Processed 11200/17715 states
    host.localhost Processed 11400/17715 states
    host.localhost Processed 11600/17715 states
    host.localhost Processed 11800/17715 states
    host.localhost Processed 12000/17715 states
    host.localhost Processed 12200/17715 states
    host.localhost Processed 12400/17715 states
    host.localhost Processed 12600/17715 states
    host.localhost Processed 12800/17715 states
    host.localhost Processed 13000/17715 states
    host.localhost Processed 13200/17715 states
    host.localhost Processed 13400/17715 states
    host.localhost Processed 13600/17715 states
    host.localhost Processed 13800/17715 states
    host.localhost Processed 14000/17715 states
    host.localhost Processed 14200/17715 states
    host.localhost Processed 14400/17715 states
    host.localhost Processed 14600/17715 states
    host.localhost Processed 14800/17715 states
    host.localhost Processed 15000/17715 states
    host.localhost Processed 15200/17715 states
    host.localhost Processed 15400/17715 states
    host.localhost Processed 15600/17715 states
    host.localhost Processed 15800/17715 states
    host.localhost Processed 16000/17715 states
    host.localhost Processed 16200/17715 states
    host.localhost Processed 16400/17715 states
    host.localhost Processed 16600/17715 states
    host.localhost Processed 16800/17715 states
    host.localhost Processed 17000/17715 states
    host.localhost Processed 17200/17715 states
    host.localhost Processed 17400/17715 states
    host.localhost Processed 17600/17715 states
    17715 states restored.
    host.localhost Processed 0/20682 objects
    /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385
                && _objects[_index].id.match(/^system\.adapter\./)
    TypeError: _objects[_index].id.match is not a function
        at BackupRestore._setObjHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385:36)
        at runCallback (timers.js:706:11)
        at tryOnImmediate (timers.js:676:5)
        at processImmediate (timers.js:658:5)
    Habe das Restore mit dem Backitup Adapter als auch mit Console gemacht. Auch das Backup selbst habe ich auf beiden Wegen gemacht. Alles ohne Erfolg.
    ich bin echt am Verzweifeln. Seit mehr als einem Jahr lasse ich jede Nacht ein Backup machen und muss dann feststellen dass die Wiederherstellung gar nicht geht.
    Ich hoffe jemand hat einen Rat für mich.
    Viele Grüße
    I 1 Antwort Letzte Antwort
    • I intruder7
      JS-controler 2.2.8
      node 10.19.0
      nodejs 10.19.0
      npm 6.13.4
      host.localhost OK.
      clean 279 states...
      Viele Grüße
      I Offline
      I Offline
      intruder7
      keiner eine Idee? Gibt es sonst eine Möglichkeit alles rüberzubringen auf den neuen Server? Incl. aller adapter (incl. Adaptereinstellungen) objekte und states?
      S simatecS 2 Antworten Letzte Antwort
      • I intruder7
        schmuh
        @intruder7
        schau mal hier:
        https://forum.iobroker.net/topic/23036/gelöst-iobroker-restore-typeerror-name-trim-is-not-a-function/17
        • I intruder7
          simatecS Offline
          simatecS Offline
          simatec
          @intruder7
          Versuche mal nach der Restore Anleitung hier im Forum mit Backitup deinen Restore
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS simatec
            @intruder7
            I Offline
            I Offline
            intruder7
            @simatec
            Hab ich alles schon versucht. Er scheint das id.match nicht zu kennen. Wenn ich in der Javascript Datei die betreffende If Bedingung rausnehme dann läuft er durch. Nur weiß ich nicht was das für Auswirkungen hat. Hab den Restore deswegen auch noch nicht produktiv laufen und bin noch auf meinem alten System.
