  4. Test Adapter fb-checkpresence v0.2.x
avmfritzboxfb-checkpresencesoaptr-064
259 Beiträge 26 Kommentatoren 51.1k Aufrufe 28 Beobachtet
    @afuerhoff History-Adapter Error...
    hatte das hier schonmal angesprochen, kam damals einmal, dann war es weg.. jetzt kommt der Fehler immer, wenn ich etwas and er Config des FB-Checkpresence Adapters ändere:
    2020-02-12 16:40:41.667  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 (force=false, process=true)
    2020-02-12 16:40:41.669  - info: host.iobroker stopInstance system.adapter.fb-checkpresence.0 send kill signal
    2020-02-12 16:40:42.225  - info: host.iobroker instance system.adapter.fb-checkpresence.0 terminated with code 156 (156)
    2020-02-12 16:40:44.975  - info: host.iobroker instance system.adapter.fb-checkpresence.0 started with pid 16504
    2020-02-12 16:40:47.198  - error: history.0 (14174) uncaught exception: Cannot read property 'push' of null
    2020-02-12 16:40:54.545  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
    2020-02-12 16:40:55.294  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
    2020-02-12 16:40:55.820  - error: fb-checkpresence.0 (16504) checkPresence: TypeError: Cannot read property 'history.0' of undefined
    2020-02-12 16:40:47.211  - error: history.0 (14174) TypeError: Cannot read property 'push' of null
        at storeCached (/opt/iobroker/node_modules/iobroker.history/main.js:182:34)
        at Object.objectChange (/opt/iobroker/node_modules/iobroker.history/main.js:131:21)
        at Immediate.options.objectChange.function.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1506:94)
        at runCallback (timers.js:705:18)
        at tryOnImmediate (timers.js:676:5)
        at processImmediate (timers.js:658:5)
    2020-02-12 16:41:13.873  - error: history.0 (14174) exception by stop: Cannot read property 'push' of null
    Sei so lieb und schau dir nochmal das starten und aufrufen von history an.. irgendwas läuft da ins leere..
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #94
    @ilovegym sagte in Test Adapter fb-checkpresence v0.2.x:
    Ich habe mir das mal angesehen. Ich kann den Fehler bei mir nicht nachstellen. Kannst Du den Loglevel mal auf Debug stellen und dann den Log posten.
    • afuerhoffA afuerhoff
      #95
      @afuerhoff mach ich, hab wegen einem anderen Fehler ( kann mit den aktuellen Latest-Versionen keine Scripte speichern oder ändern ), gerade ein Admin-Downgrade auf 4.0.0 und javascript-adapter 4.3.4 am laufen..
        Aktuelle Test Version 0.2.2
        Veröffentlichungsdatum 30.12.2019
        Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
        Installationshinweis Adapter ist im Latest Repository zu finden und sollte unter Admin installiert werden. Über Github bitte nur noch nach Aufforderung installieren.
        Hallo, ich habe gerade eine neue Version auf Github veröffentlicht. Bitte diese intensiv testen und die Ergebnisse hier posten.
        Änderungen:
        • Debug Informationen optimiert
        • Überprüfung, ob die benutzten Funktionen auch von der Fritzbox unterstützt werden
        • Whitelist/Blacklist Prüfung
        • Konfigurationsdialog optimiert
        Weitere Infos zum Adapter können auch hier eingesehen werden: https://forum.iobroker.net/topic/23490/test-adapter-fb-checkpresence-v0-1-x
        Infos zum Test:
        Es ist hilfreich im Fehlerfall den Loglevel im Bereich Instanzen auf debug zu stellen und den Log hier zu posten.
        Weiterhin ist auch die Einstellung der Konfiguration als zusätzliche Info nützlich.
        sigi234S Online
        sigi234S Online
        #96
        @afuerhoff
        Hallo, bekomme jetzt immer das:
        fb-checkpresence.0	2020-02-13 19:58:55.700	info	(8484) Sarah: No history before this day is available (lastVal = null)
        fb-checkpresence.0	2020-02-13 19:58:55.587	info	(8484) Ilse: No history before this day is available (lastVal = null)
        fb-checkpresence.0	2020-02-13 19:58:55.343	info	(8484) Sigi: No history before this day is available (lastVal = null)
        • sigi234S sigi234
          @afuerhoff
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #97
          @sigi234
          Hallo, hast Du evtl. einen Alias in der History bei den Datenpunkten angegeben?
            @sigi234
            sigi234S Online
            sigi234S Online
            #98
            @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
            @sigi234
            • sigi234S sigi234
              @sigi234
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #99
              @sigi234
              Kannst Du einmal auf die Tabellenwerte in der History umschalten. Sind dort Werte vom Vortag oder früher vorhanden.
                @sigi234
                sigi234S Online
                sigi234S Online
                #100
                @sigi234
                Ja
                • sigi234S sigi234
                  @sigi234
                  Ja
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #101
                  @sigi234
                  Das log changes interval steht bei Dir auf 5s. Ist das so gewollt? Der Adapter stellt den Wert auf 0 ein.
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    #102
                    @sigi234
                    Was sollte man einstellen?
                    • sigi234S sigi234
                      @sigi234
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #103
                      @sigi234
                      Wie gesagt. Der Adapter stellt 0 ein. Es werden also nur geänderte Werte gelogged.
                      Bei 5 wird alle 5s ein Wert geschrieben. Ich muss mal schauen, ob das der Grund ist für die LastVal Ausgabe.
                      sigi234S 2 Antworten Letzte Antwort
                      • MathiasJM Offline
                        MathiasJM Offline
                        MathiasJ
                        #104
                        Die instanz ist wieder gelb 😞
                        und bringt folgende Ausgabe:
                        fb-checkpresence.0	2020-02-14 04:54:56.670	debug	(14899) checkPresence scheduled
                        fb-checkpresence.0	2020-02-14 04:54:56.662	debug	(14899) getActive [{"Name":"Mathias","Active":"false","Kommt":"14.02.2020 02:59:33","Geht":"14.02.2020 03:34:33"}
                        fb-checkpresence.0	2020-02-14 04:54:56.627	debug	(14899) getActive Mathias 0
                        fb-checkpresence.0	2020-02-14 04:54:56.625	debug	(14899) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                        fb-checkpresence.0	2020-02-14 04:54:56.599	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                        fb-checkpresence.0	2020-02-14 04:54:56.580	error	(14899) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://sche
                        fb-checkpresence.0	2020-02-14 04:54:56.505	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                        fb-checkpresence.0	2020-02-14 04:54:56.502	debug	(14899) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.20","MACAddress":"94:87:E0:22:16:17","Active":"0","HostName":"Android","InterfaceType":"","X_AVM-DE_Port":"0","X_AVM-DE_Speed":"0","X_AVM-DE
                        fb-checkpresence.0	2020-02-14 04:54:56.472	debug	(14899) body <?xml version="1.0" encoding="UTF-8"?> <List> <!-- devicehosts :47 --> <Item> <Index>1</Index> <IPAddress>192.168.1.20</IPAddress> <MACAddress>94:87:E0:22:16:17</MACAddress> <Active>0</A
                        fb-checkpresence.0	2020-02-14 04:54:55.919	debug	(14899) response: 1 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                        fb-checkpresence.0	2020-02-14 04:54:55.874	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                        fb-checkpresence.0	2020-02-14 04:54:55.870	debug	(14899) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
                        fb-checkpresence.0	2020-02-14 04:54:55.842	debug	(14899) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
                        Gruß,
                        Mathias
                        IObroker auf dem NUC als VM.
                          @sigi234
                          sigi234S Online
                          sigi234S Online
                          #105
                          @sigi234
                          Neuer Log:
                          host.Medion(Test)	2020-02-14 11:00:00.057	info	instance system.adapter.darksky.0 started with pid 9112
                          fb-checkpresence.0	2020-02-14 10:59:13.160	info	(20816) Sarah: No history before this day is available (lastVal = null)
                          fb-checkpresence.0	2020-02-14 10:59:11.566	info	(20816) Ilse: No history before this day is available (lastVal = null)
                          fb-checkpresence.0	2020-02-14 10:58:50.920	info	(20816) Sigi: No history before this day is available (lastVal = null)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at processImmediate (timers.js:658:5)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at tryOnImmediate (timers.js:676:5)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at runCallback (timers.js:705:18)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at Immediate.setImmediate [as _onImmediate] (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\states\statesInRedis.js:227:41)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at change (C:\Program Files\iobroker\Test\node_modules\iobroker.js-controller\lib\adapter.js:4794:71)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	at Object.cb (C:\Program Files\iobroker\Test\node_modules\iobroker.fb-checkpresence\main.js:491:82)
                          fb-checkpresence.0	2020-02-14 10:58:31.233	warn	(20816) TypeError: Cannot read property 'val' of undefined
                            @guergen
                            Ich frage deshalb, weil der Fehler schon mal aufgetreten ist. Dann kommt er bei dir aber wirklich durch den Alias. Es sollte dann kein History Eintrag vom Vortag vorhanden sein.
                            Das mit dem Alias muss ich mal bei mir testen.
                            guergen
                            #106
                            @afuerhoff Habe jetzt den Alias mal weggelassen wenn das ein Problem sein könnte. Nu habe ich zwar Einträge in der Tabelle, aber Grafana findet nichts:
                            Und in den Log steht immer noch der Fehler:
                            • G guergen
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #107
                              @guergen
                              Die Meldung sollte nach einem Tag nicht mehr kommen. Ich brauche für die korrekte Funktion einen Eintrag vom Vortag oder davor.
                              G sigi234S 2 Antworten Letzte Antwort
                                @guergen
                                guergen
                                #108
                                @afuerhoff In der Tabelle oben drüber sind doch Einträge.... ansonsten kann ich Dir die morgen zur Verfügung stellen!
                                  @guergen
                                  sigi234S Online
                                  sigi234S Online
                                  #109
                                  Ist das selbe wie bei mir.
                                  MathiasJM 1 Antwort Letzte Antwort
                                  • MathiasJM MathiasJ
                                    Gruß,
                                    Mathias
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #110
                                    @MathiasJ sagte in Test Adapter fb-checkpresence v0.2.x:
                                    Hallo, dies ist ein "Internal Server Error". Die Fritzbox meldet den. Evtl. gab es Netzwerkprobleme oder ähnliches. Es ist eine Sammelfehler-Meldung der Fritzbox.
                                    Ist der Fehler wieder verschwunden?
                                    Vinze.ntV 1 Antwort Letzte Antwort
                                    • G guergen
                                      afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #111
                                      @guergen sagte in Test Adapter fb-checkpresence v0.2.x:
                                      Sorry. Hatte ich eben auf dem Handy nicht gesehen.
                                      G 1 Antwort Letzte Antwort
                                        Vinze.ntV Offline
                                        Vinze.ntV Offline
                                        Vinze.nt
                                        #112
                                        @afuerhoff Diesen Fehler habe ich auch. Habe die neuste version von GIT, allerdings funktioniert de Adapter problemlos! TOP!
                                        • sigi234S sigi234
                                          MathiasJM Offline
                                          MathiasJM Offline
                                          MathiasJ
                                          #113
                                          @sigi234
                                          Ja, die Meldungen sind weg.
                                          Aber:
                                          Die Geräte im Gastnetz werden erkannt, mein Handy jedoch nicht.
                                          Lösche ich das Handy von dieser Instanz und füge ich es Radar2 zu, wird auch dieses erkannt.
                                          Gruß,
                                          Mathias
