  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
lgtv
861 Beiträge 113 Kommentatoren 386.3k Aufrufe 69 Beobachtet
  • marcusklM marcuskl
    Wenn ich die Remote funktionen nutze, kommt immer ein Error im Log, noch jemand das Problem ?
    2019-12-09 11:32:11.829 - error: lgtv.0 (5470) State change "remote.1" - VALUE: {"val":true,"ack":false,"ts":1575887531826,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575887531826}
    sigi234S Online
    sigi234S Online
    #394
    @marcuskl sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
    Welches Widget nimmst du?
    marcusklM 1 Antwort Letzte Antwort
    • sigi234S sigi234
      marcusklM Offline
      marcusklM Offline
      marcuskl
      #395
      @sigi234
      Nutze zur Visualisierung Lovelace und da die Button Card
      Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
      Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
        @sigi234
        sigi234S Online
        sigi234S Online
        #396
        @sigi234
        Teste mal das Widget:
        [{"tpl":"tplIconStateBool","data":{"oid":"lgtv.0.remote.1","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"invert_icon":false,"false_text":"","imageHeight":"103","true_text":"","click_value":"true","false_src":"/icons-mfd-svg/edit_numeric_1.svg","true_src":"/icons-mfd-svg/edit_numeric_1.svg"},"style":{"left":"497px","top":"110px","width":"60px","height":"60px","z-index":"1","font-size":"","color":"#d7cec1","text-align":"","text-shadow":"","background-color":"#000000","background":"transparent","border-width":"1px","border-style":"solid","border-color":"#0045db","border-radius":"5px","font-family":"RobotoCondensed-Light","box-shadow":"2px 2px 3px rgba(20, 20, 20, 50)","margin-left":"","padding-left":""},"widgetSet":"jqui"}]
        • sigi234S sigi234
          @sigi234
          marcusklM Offline
          marcusklM Offline
          marcuskl
          #397
          @sigi234 Ich nutze aber nicht Vis sonder Lovelace
            sigi234S Online
            sigi234S Online
            #398
            sonder Lovelace
            Ah ,ok dann weis ich es nicht.
            • S SchuetzeSchulz
              aufgrund mangelnden Angebots :lol: habe ich mich entschlossen einen Adapter für LG WebOS SmartTV's auf Basis von Hobbyquakers https://github.com/hobbyquaker/lgtv2 zu entwickeln.
              Ich habe es - bin kein JavaScript-Profi - schon soweit geschafft, dass er in der Adapterliste korrekt auftaucht:
              Und auch die Adapter-Konfiguration ist fertig:
              Bisher habe ich nur die Popup-Funktion eingebaut. Wenn also z.b. "lgtv.0.popup" irgend ein Wert übergeben wird (hier sind teilweise auch HTML-Tags möglich), wird auf dem Fernseher ein Info-Popup angezeigt:
              Nun mein großes Problem:
              Ich habe das bisher extrem "quick & dirty" gelöst, indem ich Hobbyquakers LGTV2 mittels
              var lgtvobj = require("lgtv2")({url: 'ws://' + adapter.config.IP + ':3000', timeout: adapter.config.timeout, reconnect: adapter.config.reconnect});
              eingebunden, würde aber gern die Funktionen aus Hobbyquakers Script direkt implementieren wollen, um es übersichtlicher zu haben.
              Einfaches "copy & paste" geht da natürlich nicht.
              Daher nun meine Frage, ob mir da jemand helfen kann bzw. mir Tipps geben kann, wie ich am Besten vorgehe?
              Ist so ein Adapter überhaupt gewünscht?
              Was haltet Ihr bisher davon?
              sigi234S Online
              sigi234S Online
              #399
              @SchuetzeSchulz
              Update V 1.1.2
              EDIT: Geht jetzt, einfach noch mal installiert.
              $ ./iobroker upgrade lgtv
              Update lgtv from @1.1.1 to @1.1.2
              NPM version: 6.9.0
              npm install iobroker.lgtv@1.1.2 --loglevel error --prefix "C:/Program Files/iobroker/Test" (System call)
              npm
               ERR! path C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.nodenpm ERR! code EPERMnpm ERR! errno -4048npm ERR! syscall unlink
              npm
               ERR! Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!  { [Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node']npm ERR!   cause:npm ERR!    { Error: EPERM: operation not permitted, unlink 'C:\Program Files\iobroker\Test\node_modules\iobroker.lgtv\node_modules\.websocket.DELETE\build\Release\validation.node'npm ERR!      errno: -4048,npm ERR!      code: 'EPERM',npm ERR!      syscall: 'unlink',npm ERR!
                    path:npm ERR!       'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node' },
              npm
              ERR!   stack:npm ERR!    'Error: EPERM: operation not permitted, unlink \'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node\'',npm ERR!   errno: -4048,npm
              ERR!   code: 'EPERM',npm ERR!   syscall: 'unlink',npm ERR!   path:npm ERR!    'C:\\Program Files\\iobroker\\Test\\node_modules\\iobroker.lgtv\\node_modules\\.websocket.DELETE\\build\\Release\\validation.node',npm ERR!
                 parent: 'iobroker.lgtv' }npm ERR! npm ERR!
               The operation was rejected by your operating system.npm ERR! It's possible that the file was already in use (by a text editor or antivirus),npm ERR! or that you lack permissions to access it.npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
              npm ERR! A complete log of this run can be found in:npm
              ERR!
                   C:\Program Files\iobroker\Test\env\npm-cache\_logs\2019-12-09T19_50_32_212Z-debug.log
              ERROR: host.Medion(Test) Cannot install iobroker.lgtv@1.1.2: 4294963248
              • D deta
                Hallo, ich hab da das Problem, das obwohl ich den LG sage erlaube Zugriff, kommt dann immer wieder eine neue Anfrage.
                Der LG ist per LAN im Netzwerk, genauso wie der Raspi, wo ioBroker drauf ist.
                Woran könnte es liegen?
                cu Deta
                mikiline
                schrieb am zuletzt editiert von mikiline
                #400
                @deta sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                cu Deta
                Habe genau das gleiche Problem.
                Gibt es denn hierzu eine Lösung?
                Danke und Grüsse
                Edit: scheint nach Installation des Adapters von GitHub zu funktionieren (vers. 1.1.3)
                • R Offline
                  RandyAndy
                  #401
                  ich würde gerne mit dem Adapter auh Einstellungen ändern.
                  Ich bin mir sicher das das irgendwie mit dem setstate... geht, aber wie.
                  Ich würde nämlich gerne die Sprache zwischen Deutsch und English auswählen können, bekomme es aber nicht hin.
                  Ich habe versucht das über keys zu machen, das ist aber nicht stabil und manchmal funktioniert es, meistens aber nicht.
                  Für jeden Tip wäre ich dankbar.
                  Andreas
                  • R Offline
                    R1Snake
                    #402
                    Kann man sich bei dem Popup auch Bilder anzeigen lassen?
                    S arteckA 2 Antworten Letzte Antwort
                    • R RandyAndy
                      Andreas
                      SchuetzeSchulz
                      #403
                      @RandyAndy
                      Hi, das geht leider nicht :(
                      R 1 Antwort Letzte Antwort
                      • R R1Snake
                        SchuetzeSchulz
                        #404
                        @R1Snake sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                        Das könnte klappen.
                        Einfach mal ein Bild mittels <img> HTML-Tag versuchen einzubinden.
                        • R R1Snake
                          arteckA Offline
                          arteckA Offline
                          arteck
                          #405
                          ja das geht
                          • R Offline
                            R1Snake
                            #406
                            Habs gerade mal ausprobiert mit einem Bild aus Google.
                            <img>https://imgr1.auto-motor-und-sport.de/VW-e-Golf-gallerySquareTeaser-d749540f-1199274.jpg</img>
                            Leider hat der Fernseher nur die URL angezeigt
                            • R R1Snake
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              #407
                              @R1Snake kein wunder ist ja auch falsch.
                              <img src="url">
                              Nur url ersetzen die " müssen bleiben.
                              Persönlicher Support
                              Spenden -> paypal.me/J3YC33
                              • S SchuetzeSchulz
                                @RandyAndy
                                RandyAndy
                                #408
                                @SchuetzeSchulz
                                Schade, gibt es eigentlich irgend eine Beschreibung der API (Link oder ähnliches).
                                ANdreas
                                • Jey CeeJ Jey Cee
                                  <img src="url">
                                  sigi234S Online
                                  sigi234S Online
                                  #409
                                  @Jey-Cee sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                  <img src="url">
                                  Getestet, geht nicht. Gib das so in ein Input-Widget ein:
                                  <img src="http://192.168.178.20:8107/vis.0/Wettericons/Wetter Hd/3.pngl">
                                  • sigi234S sigi234
                                    <img src="url">
                                    Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #410
                                    @sigi234 ach beim LG muss mann noch die Bildgröße angeben und es gab eine Beschränkung der größe.
                                    <img src="url" width="100px" height="100px">
                                    • R Offline
                                      R1Snake
                                      #411
                                      @Jey-Cee said in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
                                      Ausprobiert und funktioniert. Danke für die schnelle Hilfe.
                                      Eine kleine Sache noch. Wenn der TV ausgeschaltet ist, dann ist der Adapter gelb, da der Fernseher nicht erreichbar ist. Wenn ich den TV einschalte bleibt der Adapter gelb obwohl die Einstellung jede Sekunde nach dem TV "sucht". Wenn ich den Adapter neustarte ist er direkt grün.
                                      Muss ich noch irgendwas einstellen? Kann man im Tv einstellen das er immer erreichbar ist?
                                      • Jey CeeJ Jey Cee
                                        sigi234S Online
                                        sigi234S Online
                                        #412
                                        Geht, und wenn ich vom Pc ein Bild anzeigen möchte wie geht das?
                                        • R Offline
                                          R1Snake
                                          #413
                                          Die Festplatte wo das Bild liegt, muss von deinem TV aus erreichbar sein. Beispiele wären
                                          • NAS
                                          • Festplatte an deinem router
                                          • Oder eine Freigabe an deinem PC
                                          Wenn das gegeben ist, musst du einfach nur den Pfad ändern in:
                                          <img src=""C:\Users\Peter\Pictures\Bild.png"" width="100px" height="100px">
