  3. Entwicklung
  4. Adapter mihome-vacuum anpassungen
vacuumadapterentwicklungtestroborockzeitplanraumreinigung
589 Beiträge 73 Kommentatoren 196.3k Aufrufe 72 Beobachtet
  • D dirkhe
    @mumurik Teste bitte mal folgendes:
    Du gehst in die config des Adapters (am besten mit chrome)
    dann drückst du F12, damit du in die Entwickler tools kommst:
    da gehst du auf console und wählst den content iframe aus. Dann gibst du rechts folgendes ein
    socket.emit('getObjectView', 'system', 'state', {
             startkey: namespace + 'rooms..mapIndex',
             endkey: namespace + 'rooms.\u9999.mapIndex'
    }, function (err, states) { console.log(states) });
    und postest das Ergebnis
    M
    M
    mumurik
    schrieb am zuletzt editiert von mumurik
    #121
    @dirkhe
    n {io: n, nsp: "/", json: n, ids: 7, acks: {…}, …}
    VM267:4
    {rows: Array(27)}
    rows: Array(27)
    0: {id: "mihome-vacuum.0.rooms.loadRooms", value: {…}}
    1: {id: "mihome-vacuum.0.rooms.multiRoomClean", value: {…}}
    2: {id: "mihome-vacuum.0.rooms.addRoom", value: {…}}
    3: {id: "mihome-vacuum.0.rooms.137001123082.mapIndex", value: {…}}
    4: {id: "mihome-vacuum.0.rooms.137001123082.roomClean", value: {…}}
    5: {id: "mihome-vacuum.0.rooms.137001074750.mapIndex", value: {…}}
    6: {id: "mihome-vacuum.0.rooms.137001074750.roomClean", value: {…}}
    7: {id: "mihome-vacuum.0.rooms.137001074749.mapIndex", value: {…}}
    8: {id: "mihome-vacuum.0.rooms.137001074749.roomClean", value: {…}}
    9: {id: "mihome-vacuum.0.rooms.137001123083.mapIndex", value: {…}}
    10: {id: "mihome-vacuum.0.rooms.137001123083.roomClean", value: {…}}
    11: {id: "mihome-vacuum.0.rooms.137001123081.mapIndex", value: {…}}
    12: {id: "mihome-vacuum.0.rooms.137001123081.roomClean", value: {…}}
    13: {id: "mihome-vacuum.0.rooms.137001068653.mapIndex", value: {…}}
    14: {id: "mihome-vacuum.0.rooms.137001068653.roomClean", value: {…}}
    15: {id: "mihome-vacuum.0.rooms.137001102054.mapIndex", value: {…}}
    16: {id: "mihome-vacuum.0.rooms.137001102054.roomClean", value: {…}}
    17: {id: "mihome-vacuum.0.rooms.137001102055.mapIndex", value: {…}}
    18: {id: "mihome-vacuum.0.rooms.137001102055.roomClean", value: {…}}
    19: {id: "mihome-vacuum.0.rooms.137001123082.roomFanPower", value: {…}}
    20: {id: "mihome-vacuum.0.rooms.137001074750.roomFanPower", value: {…}}
    21: {id: "mihome-vacuum.0.rooms.137001074749.roomFanPower", value: {…}}
    22: {id: "mihome-vacuum.0.rooms.137001123083.roomFanPower", value: {…}}
    23: {id: "mihome-vacuum.0.rooms.137001123081.roomFanPower", value: {…}}
    24: {id: "mihome-vacuum.0.rooms.137001068653.roomFanPower", value: {…}}
    25: {id: "mihome-vacuum.0.rooms.137001102054.roomFanPower", value: {…}}
    26: {id: "mihome-vacuum.0.rooms.137001102055.roomFanPower", value: {…}}
    length: 27
    __proto__: Array(0)
    __proto__: Object
    • D
      D
      dirkhe
      #122
      das scheint, wie vermutet ein bug im JS-controller zu sein, der in der 2er version gefixt ist. Ich baue mal noch eine extra Abfrage ein, die nochmal auf mapIndex filtert
      M 2 Antworten Letzte Antwort
      • D dirkhe
        M
        M
        mumurik
        #123
        @dirkhe
        super, danke!
        • D dirkhe
          @xADDRx siehe meinen Kommentar von oben
          @dirkhe sagte in Adapter mihome-vacuum anpassungen:
          Die Karte wird in/durch die App in Räume aufgeteilt. Dabei bekommt jeder Raum eine fortlaufende Nummer. Da man in der Regel dann drei Karten hat (incl Backup), ist man bei der aktuellen dann irgendwann bei 3 x Räume. Ich vermute zumindest, dass der Index daher kommt. Da hilft dann nur ausprobieren und den Sauger einfach mal irendwo hinschicken, zb. nach 10 per customcommand app_segment_clean;10. Wenn du dann einen Treffer hast, kannst du per addRoom die 10 einegebn und er legt dir den Raum an.
          X
          X
          xADDRx
          #124
          @dirkhe Hab jetzt mal einiges versucht. sobald ich eine Nummer eingebe, fährt der Roboter kurz raus und wieder rein... Habt ´Ihr einen Tipp für mich?
          Ist es eig. normal das einige Räume die selbe Farbe haben?IMG_20200119_004727.PNG
          Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
          • X xADDRx
            D
            D
            dirkhe
            #125
            @xADDRx sagte in Adapter mihome-vacuum anpassungen:
            Kannst du mal das Log schicken, ggf, den Afdapter vorher auf debug stellen
            Das mit den Raumfarben weiß ich nicht, aber da die nicht zusammenhängend sind, wird das wahrscheinlich egal sein. Bekommst du denn für jeden Raum eine eigene Nummer?
            X 1 Antwort Letzte Antwort
            • M
              M
              misteriobroker
              schrieb am zuletzt editiert von misteriobroker
              #126
              Hallo an alle,
              ich bin nun auch auf die neueste 2008er Software beim S50 und Mi Vacuum Adapter auf die 1.1.5 geupdated.
              Leider bekomme ich einfach nicht den "rooms" Reiter in den Objekten.
              Ich habe bei x send commant auch schon "get_room_mapping" eingegeben, aber es klappt einfach nicht.
              Was mache ich denn falsch?
              Eine aktuelle Karte ist in der Mi Home App angelegt, die Räume kann ich markieren etc.
              Den Raspi habe ich schon neu gestartet.
              Ich schaffe es einfach nicht.
              Könnt ihr mir helfen?
              Grüße Kai
              D DiginixD 2 Antworten Letzte Antwort
              • M misteriobroker
                Hallo an alle,
                Grüße Kai
                D
                D
                dirkhe
                #127
                @misteriobroker sagte in Adapter mihome-vacuum anpassungen:
                get_room_mapping
                was kommt denn bei get_room_mapping zurück?
                • D
                  D
                  dirkhe
                  #128
                  Zur Info,
                  der Adpater ist mittlerweile im offiziellen github Account und gemergt:
                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                  Ich habe heute noch eine Neue Version hochgeladen:
                  https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/README_de.md#changelog
                  • M misteriobroker
                    Hallo an alle,
                    Grüße Kai
                    DiginixD
                    DiginixD
                    Diginix
                    #129
                    @misteriobroker Mit der alten 1.1.5 Version funktioniert das ja auch alles nicht. Du musst die 1.9.x über Git installieren oder schauen wann sie nun über den offiziellen Kanal bei dir ankommt.
                    ..:: So long! Tom ::..
                    • D dirkhe
                      M
                      M
                      mumurik
                      #130
                      Ist es auch schon in der neuen Version gefixt, oder muß ich zwingend auf JS-Controller 2.x upgraden?
                      • D
                        D
                        dirkhe
                        #131
                        Sollte gefixt sein, zumindest die bekannte Stelle ist in der aktuellen Version
                        • B
                          B
                          base
                          schrieb am zuletzt editiert von base
                          #132
                          bei mir wird der Datenpunkt send_command nicht mehr angezeigt???
                          ok, erledigt. Hatte den Haken bei der Neuinstallation vergessen
                          • D
                            D
                            dirkhe
                            #133
                            In der config angehakt?
                            • D dirkhe
                              B
                              B
                              base
                              #134
                              @dirkhe ja, das war der Fehler...
                              ich habe Valetudo 0.8.2 installiert. Gibt es eine Möglichkeit gespeicherte Karten per send command zu laden?
                              MeistertrM 1 Antwort Letzte Antwort
                              • D dirkhe
                                M
                                M
                                mumurik
                                #135
                                Habe soeben die Version 1.10.1 installiert, leider wird multiCleanRoom immer noch nicht angesteuert.
                                Hier der Auszug aus der Console:
                                • D
                                  D
                                  dirkhe
                                  schrieb am zuletzt editiert von dirkhe
                                  #136
                                  Das Log in der Console wird sich auch nicht ändern, erst wenn du den js controller updatest. Was ich gemacht habe ist quasi diese Abfrage zu machen und bei jedem state zu fragen, ob es sich um mapindex handelt, also die Liste zusätzlich zu filtern.
                                  Wahrscheinlich gibt es mit dem alten js controller noch mehr Probleme. Wie sieht denn jetzt dein Log aus?
                                  Ich habe gerade nochmal einen kleinen fix gemacht, lade nochmal runter, bitte
                                  • D dirkhe
                                    M
                                    M
                                    mumurik
                                    #137
                                    @dirkhe
                                    mihome-vacuum.0	2020-01-19 17:46:33.160	error	[8](unknown) -> data for segment is not a number
                                    mihome-vacuum.0	2020-01-19 17:46:33.159	debug	Receive <<< {"error":{"code":-10000,"message":"data for segment is not a number"},"id":8}<<< 21310070000000000f9d2ccf5e2487e8c9051a4918a4ed5fa74f4af3d0fc86180d55212412c09a0daa616947a3b1b72c0a841aacf20
                                    mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsgRaw >>> 21310060000000000f9d2ccf5e2487e7baeddb91e685ffd1b5d10376ab481804d5b038b381e72cc623fef9f4b40f8cfc5b3792455b1aaee44afa7bd56e5b38c844505b8b566afd5408801c56ae5f9fd2b246176debcb61543c93a4761
                                    mihome-vacuum.0	2020-01-19 17:46:31.798	debug	sendMsg >>> {"id":8,"method":"app_segment_clean","params":[null,null]}
                                    mihome-vacuum.0	2020-01-19 17:46:31.795	debug	Timestamp: 5e2487e7
                                    mihome-vacuum.0	2020-01-19 17:46:31.793	info	trigger cleaning segment 16,19
                                    mihome-vacuum.0	2020-01-19 17:46:31.791	debug	redis pmessage messagebox.system.adapter.mihome-vacuum.0 messagebox.system.adapter.mihome-vacuum.0 {"command":"cleanSegments","message":"16,19","from":"system.adapter.mihome-vacuum.0","_id":77384923}
                                    mihome-vacuum.0	2020-01-19 17:46:31.788	debug	sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: 16,19
                                    mihome-vacuum.0	2020-01-19 17:46:31.786	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomFanPower
                                    mihome-vacuum.0	2020-01-19 17:46:31.784	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomFanPower
                                    mihome-vacuum.0	2020-01-19 17:46:31.781	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123083.roomClean
                                    mihome-vacuum.0	2020-01-19 17:46:31.779	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.137001123082.roomClean
                                    mihome-vacuum.0	2020-01-19 17:46:31.777	error	state must be .mapIndex for roomManager.cleanRooms mihome-vacuum.0.rooms.multiRoomClean
                                    mihome-vacuum.0	2020-01-19 17:46:31.635	debug	stateChange mihome-vacuum.0.rooms.multiRoomClean {"val":true,"ack":false,"ts":1579452391626,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1579452391626}
                                    • M mumurik
                                      @dirkhe
                                      D
                                      D
                                      dirkhe
                                      #138
                                      @mumurik lade nochmal herunter bitte
                                      • D dirkhe
                                        M
                                        M
                                        mumurik
                                        #139
                                        @dirkhe
                                        jetzt läufts, sowohl multiRoomClean, als auch die Timer.
                                        Vielen Dank für die Mühe!
                                        • B base
                                          MeistertrM
                                          MeistertrM
                                          Meistertr
                                          #140
                                          @base nein wird aber noch anderweitig integriert.
                                          83.9k
