  3. Entwicklung
  4. Zigbee Adapter mit neuem Converter
zigbee adaptershpeherdherdsman
498 Beiträge 58 Kommentatoren 172.4k Aufrufe 78 Beobachtet
  • C craysee
    wollte heute umsteigen und bekomme folgende Fehlermeldung:
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee"
    install https://github.com/ioBroker/ioBroker.zigbee/tarball/410eb0cfb1c6f24a37b517e2da37ca586bcec686
    NPM version: 6.13.4
    npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/410eb0cfb1c6f24a37b517e2da37ca586bcec686 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
    ERR! code EACCESnpm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefilenpm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile'npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile']npm
    ERR! cause:npm ERR!
    { Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile'npm
    ERR! errno: -13,npm
    ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR!
    path:npm ERR! '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile' },npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile'',npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@serialport/.bindings.DELETE/build/Makefile',npm ERR! parent: 'iobroker.zigbee' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-01-18T17_44_11_302Z-debug.log
    ERROR: host.raspberrypi Cannot install https://github.com/ioBroker/ioBroker.zigbee/tarball/410eb0cfb1c6f24a37b517e2da37ca586bcec686: 243
    Das Problem,ich kann jetzt auch den alten Adapter nicht mehr installieren.Als Admin bin ich angemeldet und die Leerzeichen habe ich eigentlich auch kontrolliert.
    Kann mir jemand helfen?
    Cray
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #455
    @craysee du musst den installationsfixer laufen lassen - es gibt anscheinend Probleme mit den zugriffsrechten.
    A.
    • C Offline
      craysee
      #456
      Danke, hat geholfen. Hatte den eigentlich nach Update von Nodejs laufen lassen, aber anscheinend nicht richtig...
      CRay
      • J Offline
        Jan1
        #457
        Ich bin am überlegen, ob ich meine Mi RGBW E27 Lampen durch Zigbee ersetzten soll, weil ich bei den Mi Dingern über die Zonen etwas eingeschränkt bin.
        Deshalb mal die Frage hier in die Runde ob einer Lampen empfehlen kann, oder diese hier mit dem Adapter läuft?
        • C Offline
          craysee
          #458
          Also laufen tut es jetzt, aber alle Geräte sind auf "undefined". Im Log stehen die Geräte richtig drin. Dauert es jetzt, bis diese wieder erkannt werden oder muss ich alle neu anlernen?
          Cray
          • C craysee
            Cray
            Jan1
            #459
            @craysee
            Da wird wohl nur neu pairen helfen.
            • C Offline
              craysee
              #460
              bevor ich alles neu paire, hier mal ein Auszug aus dem LOG, da sind noch Fehlermeldungen im Zusammenhang mit Zigbee. Vielleicht lässt sich das ja noch umgehen.
              zigbee.0 2020-01-18 20:58:08.708 error at Timer.processTimers (timers.js:223:10))
              zigbee.0 2020-01-18 20:58:08.708 error at listOnTimeout (timers.js:263:5)
              zigbee.0 2020-01-18 20:58:08.708 error at tryOnTimeout (timers.js:300:5)
              zigbee.0 2020-01-18 20:58:08.708 error at ontimeout (timers.js:436:11)
              zigbee.0 2020-01-18 20:58:08.708 error at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
              zigbee.0 2020-01-18 20:58:08.708 error (26148) Failed to configure 0x00158d00031e9ea8 SP 120, attempt 1 (Error: AREQ - ZDO - bindRsp after 10000ms
              zigbee.0 2020-01-18 20:57:58.693 info (26148) Zigbee started
              zigbee.0 2020-01-18 20:57:58.692 info (26148) 0x00158d0003281ddd (addr 63086): SP 120 - Innr Smart plug (Router)
              zigbee.0 2020-01-18 20:57:58.691 info (26148) 0x000d6ffffe2e6102 (addr 31421): E1746 - IKEA TRADFRI signal repeater (Router)
              Es sind alle Karten vorhanden (undefined), aber ein neuer Pairungversuch klappt nicht (ohne löschen der vorhandenen Karten).
              CRay
              • AtifanA Offline
                AtifanA Offline
                Atifan
                #461
                ich würde gerne in meinem IoBroker den neuen Herdsman Adapter installieren, weiss aber nicht was ich machen muss. Ich bekomme ja nur die 0.11.5 angezeigt. Kann mir da einer weiter helfen? Danke!
                D AsgothianA 2 Antworten Letzte Antwort
                • AtifanA Atifan
                  deta
                  #462
                  @Atifan Über den Git die Katze und den Link oben rein.
                  • AtifanA Atifan
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #463
                    @Atifan In Der adapterübersicht, erweiterte Ansicht gibt es einen Button zur Installation von github. (Sieht aus wie ein stilisierter Katzenkopf)
                    Im damit geöffneten Dialog den Adapter auswählen - dann bekommst du die herdsman Variante.
                    A.
                    • AtifanA Offline
                      AtifanA Offline
                      Atifan
                      #464
                      Hi, Danke habe den neuen Adapter installiert bekommen.
                      Aber ich bekomme beim Start einen Fehler, iwie funktioniert der Adapter nicht richtig
                      45700336-1767-4129-aec1-9b78015e5cb3-image.png .
                      • AtifanA Atifan
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #465
                        @Atifan
                        Dann poste doch mal
                        • node version
                        • npm Version
                        • os
                        Außerdem wiederhole bitte die Installation, allerdings mit aktiviertem „mehr“ im installationsdialog. (Auch den Haken schließen wenn beendet) entfernen, damit du dir die log Ausgaben anschauen kannst.
                        Es sieht so aus als,ob etwas nicht mit installiert wurde.
                        A.
                        • AtifanA Offline
                          AtifanA Offline
                          Atifan
                          #466
                          Hallo.
                          Node.js v10.18.1
                          NPM 6.13.4
                          OS ist Debian 10.2.0
                          Das ganze läuft aber auf einem Intel NUC als VM unter Proxmox 6.2.
                          • AtifanA Offline
                            AtifanA Offline
                            Atifan
                            #467
                            PS: Ich hatte vor paar Tagen Node.js von 10.18.0. auf 10.18.1 geupdatet und danach "npm rebuild" gemacht. Evtl. hat es damit zu tun?
                            • AtifanA Atifan
                              Jan1
                              #468
                              @Atifan
                              NPM rebuild ist bei einem Update innerhalb der Grundversion nicht nötig, sollte aber auch nicht schaden.
                              • AtifanA Atifan
                                Hallo.
                                Node.js v10.18.1
                                NPM 6.13.4
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #469
                                @Atifan
                                @Asgothian sagte in Zigbee Adapter mit neuem Converter:
                                Das müsstest du auch noch tun.
                                A.
                                • AtifanA Offline
                                  AtifanA Offline
                                  Atifan
                                  schrieb am zuletzt editiert von Atifan
                                  #470
                                  @Asgothian: Sorry hatte ich vergessen.
                                  Habe jetzt den Zigbee-Adapter mehrmals deinstalliert und wieder neu installiert.
                                  Immer das gleiche. Die Installation funktioniert.
                                  Nach der Installation wird aber nicht automatisch eine Zigbee Instanz angelegt, ich weiß nicht ob das normal ist oder nicht?
                                  Wenn ich dann manuell eine Zigbee Instanz hinzufüge, ab dann kommen die Fehler im Log.
                                  Hier das Log für die Installation
                                  $ ./iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee --debug
                                  install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                                  NPM version: 6.13.4
                                  npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                                  + iobroker.zigbee@1.0.0-dadded 535 packages from 396 contributors in 11.76s
                                  21 packages are looking for funding  run `npm fund` for details
                                  upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tradfri.on-off-switch.png img/tradfri.on-off-switch.png image/png
                                  upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/orvibo_cr11s8uz.png img/orvibo_cr11s8uz.png image/png
                                  upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lumi_remote_b286opcn01.png img/lumi_remote_b286opcn01.png image/png
                                  upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lightify-b40tw.png img/lightify-b40tw.png image/png
                                  upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr4.png img/innr4.png image/png
                                  upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_gu10.png img/ikea_gu10.png image/png
                                  upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gledopto_gu10.png img/gledopto_gu10.png image/png
                                  upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/diy.png img/diy.png image/png
                                  upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_plug.png img/bitron_plug.png image/png
                                  upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.png img/TRADFRI.bulb.E27.png image/png
                                  upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/TRADFRI.bulb.E27.clear.png img/TRADFRI.bulb.E27.clear.png image/png
                                  upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LH-32ZB.png img/LH-32ZB.png image/png
                                  upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                                  upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                  upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                  upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                  upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                  upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                  upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                  upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                  upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                  upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                  upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                  upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                  upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                  upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                  upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                  upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                  upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                  upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                  process exited with code 0
                                  Und hier noch das Log wenn ich eine Instanz hinzufüge. Erst danach tauchen die Fehler im Log auf.
                                  $ ./iobroker add zigbee  --host IoBroker
                                  host.IoBroker create instance zigbee
                                  host.IoBroker object zigbee.0.info.groups created
                                  host.IoBroker object zigbee.0.info.pairingMessage created
                                  host.IoBroker object zigbee.0.info.pairingCountdown created
                                  host.IoBroker object zigbee.0.info.pairingMode created
                                  host.IoBroker object zigbee.0.info.connection created
                                  host.IoBroker object zigbee.0.info created
                                  host.IoBroker object system.adapter.zigbee.0.sigKill created
                                  host.IoBroker object system.adapter.zigbee.0.eventLoopLag created
                                  host.IoBroker object system.adapter.zigbee.0.outputCount created
                                  host.IoBroker object system.adapter.zigbee.0.inputCount created
                                  host.IoBroker object system.adapter.zigbee.0.uptime created
                                  host.IoBroker object system.adapter.zigbee.0.memRss created
                                  host.IoBroker object system.adapter.zigbee.0.memHeapTotal created
                                  host.IoBroker object system.adapter.zigbee.0.memHeapUsed created
                                  host.IoBroker object system.adapter.zigbee.0.cputime created
                                  host.IoBroker object system.adapter.zigbee.0.cpu created
                                  host.IoBroker object system.adapter.zigbee.0.compactMode created
                                  host.IoBroker object system.adapter.zigbee.0.connected created
                                  host.IoBroker object system.adapter.zigbee.0.alive created
                                  host.IoBroker object system.adapter.zigbee.0 created
                                  • AtifanA Atifan
                                    NPM version: 6.13.4
                                    dimaiv
                                    #471
                                    @Atifan
                                    Wo siehst du da die Fehler?
                                    ioBroker- NUC8i3 / Proxmox / VM
                                    Node.js v22.21.0
                                    NPM v10.9.4
                                    JS controller 7.1.0
                                    Admin 7.7.20
                                    ZigBee Adapter 3.3.1alpha.0
                                    Zigbee LAN Gateway CC2652P
                                    Zigbee Firmware 20250321
                                    • AtifanA Offline
                                      AtifanA Offline
                                      Atifan
                                      #472
                                      Da bei der Installation sieht man keine Fehler.
                                      Der Fehler kommt erst danach im Log vom IoBroker.
                                      host.IoBroker	2020-01-19 13:23:12.182	info	Restart adapter system.adapter.zigbee.0 because enabled
                                      host.IoBroker	2020-01-19 13:23:12.182	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                      host.IoBroker	2020-01-19 13:23:12.182	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: ^
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: throw err;
                                      host.IoBroker	2020-01-19 13:23:12.181	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
                                      host.IoBroker	2020-01-19 13:23:12.069	info	instance system.adapter.zigbee.0 started with pid 9105
                                      host.IoBroker	2020-01-19 13:22:42.060	info	Restart adapter system.adapter.zigbee.0 because enabled
                                      host.IoBroker	2020-01-19 13:22:42.060	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/lib/seriallist.js:3:25)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: Error: Cannot find module 'zigbee-herdsman/dist/adapter/serialPortUtils'
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: ^
                                      host.IoBroker	2020-01-19 13:22:42.060	error	Caught by controller[0]: throw err;
                                      host.IoBroker	2020-01-19 13:22:42.059	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
                                      host.IoBroker	2020-01-19 13:22:41.947	info	instance system.adapter.zigbee.0 started with pid 8605
                                      host.IoBroker	2020-01-19 13:22:11.940	info	Restart adapter system.adapter.zigbee.0 because enabled
                                      • AtifanA Atifan
                                        Jan1
                                        #473
                                        @Atifan sagte in Zigbee Adapter mit neuem Converter:
                                        serialPortUtils
                                        Also wenn Du über Github installierst, ist es normal, dass keine Instanz angelegt wird. Muss manuell erfolgen.
                                        Zum Fehler, da wird ja "serialPortUtils" an gemeckert. Liegt die Datei in dem Pfad /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter und wenn ja welche Recht e hast sie?
                                        Sind eigentlich mehre und sieht bei mir so aus:
                                        • AtifanA Offline
                                          AtifanA Offline
                                          Atifan
                                          #474
                                          Hi, den Ordner "dist" gibt es bei mir garnicht.
                                          Es gibt nur "/opt/iobroker/node_modules/zigbee-herdsman"
