  4. [Geloest]Slave regelmäßig nicht erreichbar
slaves ohne verbindung
19 Beiträge 5 Kommentatoren 745 Aufrufe 4 Beobachtet
  • amg_666A amg_666
    @arteck Ich hatte gestern abend backitup wieder aktiviert. Heue Nachmittag ist der Slave wieder weg gewesen, LAN Kabel raus-/reingesteckt, dann liefs wieder (das war um 18:36)
    Log vom Slave
    smartmeter.0	2020-01-15 18:42:51.512	info	(718) Received 10 values, 3 updated
    tankerkoenig.0	2020-01-15 18:41:53.857	info	(708) Reading data from tankerkoenig ...
    smartmeter.0	2020-01-15 18:41:50.718	info	(718) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 18:40:50.134	info	(718) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 18:39:48.922	info	(718) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 18:38:47.025	info	(718) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 18:37:45.922	info	(718) Received 10 values, 3 updated
    backitup.2	2020-01-15 18:36:55.916	info	(753) [iobroker] backup was activated at 02:31 every 1 day(s)
    backitup.2	2020-01-15 18:36:55.771	info	(753) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.11.1
    tankerkoenig.0	2020-01-15 18:36:53.750	info	(708) Reading data from tankerkoenig ...
    tankerkoenig.0	2020-01-15 18:36:53.677	info	(708) Sync time set to 5 minutes or 300000 ms
    tankerkoenig.0	2020-01-15 18:36:53.632	info	(708) starting. Version 2.0.6 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v8.11.1
    modbus.0	2020-01-15 14:50:28.263	info	(735) Connected to slave 192.168.2.153
    host.stromzaehler	2020-01-15 14:50:27.502	info	instance system.adapter.backitup.2 started with pid 753
    modbus.0	2020-01-15 14:50:26.363	info	(735) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.modbus, node: v8.11.1
    smartmeter.0	2020-01-15 14:50:25.825	info	(718) Received 10 values, 10 updated
    smartmeter.0	2020-01-15 14:50:24.099	info	(718) starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v8.11.1
    host.stromzaehler	2020-01-15 14:50:23.634	info	instance system.adapter.modbus.0 started with pid 735
    host.stromzaehler	2020-01-15 14:50:19.492	info	instance system.adapter.smartmeter.0 started with pid 718
    host.stromzaehler	2020-01-15 14:50:15.491	info	instance system.adapter.tankerkoenig.0 started with pid 708
    host.stromzaehler	2020-01-15 14:50:15.448	info	starting 4 instances
    host.stromzaehler	2020-01-15 14:50:15.417	info	41 instances found
    host.stromzaehler	2020-01-15 14:50:14.984	info	connected to Objects and States
    host.stromzaehler	2020-01-15 14:50:14.774	info	ip addresses: 192.168.2.16 fd00::8dcb:f26d:4c6a:d91d fe80::ed27:71e8:b6cf:f50b
    host.stromzaehler	2020-01-15 14:50:14.769	info	hostname: stromzaehler, node: v8.11.1
    host.stromzaehler	2020-01-15 14:50:14.767	info	Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    host.stromzaehler	2020-01-15 14:50:14.752	info	iobroker.js-controller version 2.1.1 js-controller starting
    smartmeter.0	2020-01-15 14:56:16.153	info	(1000) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 14:55:13.796	info	(1000) Received 10 values, 1 updated
    tankerkoenig.0	2020-01-15 14:54:15.843	info	(644) Reading data from tankerkoenig ...
    smartmeter.0	2020-01-15 14:54:11.470	info	(1000) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 14:53:10.149	info	(1000) Received 10 values, 3 updated
    smartmeter.0	2020-01-15 14:52:09.512	info	(1000) Received 10 values, 1 updated
    smartmeter.0	2020-01-15 14:51:07.199	info	(1000) Received 10 values, 5 updated
    smartmeter.0	2020-01-15 14:50:02.415	info	(1000) Received 10 values, 1 updated
    @amg_666 sagte in Slave regelmäßig nicht erreichbar:
    kann es sein, dass der mount (wenn das Backup aufs NAS geht) noch hing und durch die Zwangstrennung beendet wurde?
      amg_666A Offline
      amg_666A Offline
      amg_666
      @Homoran Woran kann ich das sehen? Der hat sich heute nachmittag mal wieder abgemeldet und backitup steht auf 2:30 Uhr nachts. Ich hatte ja bacjkitup auch schonmal deaktiviert, das hat nix gebracht. Das Backup soll auf ein NAS gespeichert werden, das läuft über FTP.
      • amg_666A amg_666
        Hallo, ich betreibe iobroker auf einem Master mit 2 Slaves (alles Raspberry 3+). Alle Raspis sind per LAN angebunden. Ein Slave ist morgens grundsätzlich nicht erreichbar (steht im Master auf "offline"), manchmal reicht es wenn ich an dem Slave das LAN Kabel abziehe und neu verbinde, manchmal muss ich ihn hart neu starten (remote erreichbar ist er nicht).
        Master: node.js 8.11.4 und npm 6.5.0
        Beide Slaves haben node.js 8.11.1 und npm 6.5.0.
        Das Logfile vom Slave:
        host.stromzaehler	2020-01-14 05:17:21.443	info	instance system.adapter.modbus.0 started with pid 655
        host.stromzaehler	2020-01-14 05:17:17.476	info	instance system.adapter.tankerkoenig.0 started with pid 645
        host.stromzaehler	2020-01-14 05:17:17.393	info	starting 2 instances
        host.stromzaehler	2020-01-14 05:17:17.335	info	41 instances found
        host.stromzaehler	2020-01-14 05:17:16.757	info	connected to Objects and States
        host.stromzaehler	2020-01-14 05:17:16.417	info	ip addresses: 192.168.2.16 fd00::8dcb:f26d:4c6a:d91d fe80::ed27:71e8:b6cf:f50b
        host.stromzaehler	2020-01-14 05:17:16.408	info	hostname: stromzaehler, node: v8.11.1
        host.stromzaehler	2020-01-14 05:17:16.405	info	Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
        host.stromzaehler	2020-01-14 05:17:16.377	info	iobroker.js-controller version 2.1.1 js-controller starting
        Danach hatte ich das LAN Kabel neu gesteckt und es lief auch wieder.
        Was ich nicht verstehe ist, warum um 5:17 Uhr der js-controller und andere neu gestartet werden, die sollten doch eigentlich durchlaufen (?)
        Hat hier jemand eine Idee woran das liegen könnte bzw ob das den Fehler erklärt ?
        Andreas
        Dann fangen wir mal neu an.
        Was hat dieser Slave, das der andere nicht hat?
        Welche Adapter laufen da?
          amg_666A Offline
          amg_666A Offline
          amg_666
          @Homoran Meine raspberrys stehen in meinem Arbeitszimmer (Host und Slave1). Slave2 der regelmäßig offline geht steht im Hausanschlussraum (wegen optischem Leser für den Stromzähler). Alle Raspis sind über einen Switch mit dem Router verbunden.
          Auf dem Slave mit dem Problem laufen
          backitup 1.3.6
          modbus 3.0.0
          smartmeter 3.0.8
          tankerkoenig 2.0.6
          Auf dem anderen, der stabil läuft habe ich hauptsächlich Visualisierung drauf:
          backitup 1.3.6
          alexa2 2.6.4
          cloud 2.8.0
          daswetter 2.8.1
          ical (4 Instanzen) 1.7.0
          milight 0.3.6
          vis 1.2.3 (plus diverse Bibliotheken)
          • amg_666A amg_666
            backitup 1.3.6
            modbus 3.0.0
            smartmeter 3.0.8
            tankerkoenig 2.0.6
            backitup 1.3.6
            alexa2 2.6.4
            cloud 2.8.0
            daswetter 2.8.1
            milight 0.3.6
            backitup 1.3.6
            Warum läuft backitup auf dem slave?
            Sämtliche Informationen für eine Instanz, die auf dem Slave läuft, liegen auf dem Master (states, objects).
            Ein Backup des Masters enthält auch alle Kofigurationen der Slave-Instanzen.
            Vom slave aus, muss backitup sich alle Informationen vom Master holen.
            Ich kann mir vorstellen, dass er sich dabei verschlucken könnte.
              backitup 1.3.6
              amg_666A Offline
              amg_666A Offline
              amg_666
              @Homoran Ich habe backitup auf dem Master installiert, aber auf jedem Raspi eine Instanz installiert. Das ist falsch und das "Master Backup" beinhaltet alle Slaves? War mir nicht bewusst, ich würde dann mal die Instanzen auf den Slaves löschen und schaun was dann passiert, richtig?
              • amg_666A amg_666
                So habe ich das verstanden - vielleicht erhellt @simatec uns da mal.
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @Homoran
                  Mein Wissenstand ist auch so, dass der Master den Slave mit sichert.
                  Da der Backup Prozess ein Teil vom js-controller ist, wäre es Interessant, was @apollon77 und/oder @Bluefox dazu sagen können.
                  • Besuche meine Github Seite
                  • HowTo Restore ioBroker
                  • apollon77A Online
                    apollon77A Online
                    Also Objects und States und Files sollte passen weil die einfach aus der DB gelesen werden vom Master und damit sollte das egal sein wo es ausgeführt wird. Alles was natürlich ggf noch aus anderen "lokalen Verzeichnissen" mit gesichert wird ist natürlich ggf anders.
                    Ansonsten: testet es doch mal. Führt iobroker backup auf maste rund slave aus und vergleicht das erstellte tar.gz vom Inhalt und den Dateigrössen her
                    • apollon77A apollon77
                      amg_666A Offline
                      amg_666A Offline
                      amg_666
                      schrieb am zuletzt editiert von amg_666
                      @apollon77 Hallo, ich hab jetzt mal stichprobenartig in die Backups vom Master und vom Slave reingeschaut. Auf dem Slave läuft Smartmeter und ich habe in den Sicherungen nach den Einstellungen (Baudrate etc) gesucht und die ist in beiden Sicherungen abgelegt. Von daher würde ich auch annehmen, dass das so passt und das ich nur eine backitup Instanz auf dem Master brauche ("lokale" Dateien/Verzeichnisse habe ich nicht).
                      @Homoran Leider ist das Grundproblem weiter vorhanden. Ich werde mal in einer Mußestunde den Slave komplett neu und sauber aufsetzen und danach nochmal Feedback geben.
                      • amg_666A amg_666
                        apollon77A Online
                        apollon77A Online
                        Bitte mal js-controller 2.2.7 versuchen, da sind fixes für Reconnection Themen von Adaptern/Slaves zum Master drin
                          amg_666A Offline
                          amg_666A Offline
                          amg_666
                          AAAARGH 🙄 . kann es sein, dass der Fehler (Verlust der Verbindung zum Slave) garnicht am Slave liegt, sondern am Master? Mir ist aufgefallen, dass die grüne LED am Master sporadisch sehr lange Zeit an ist (Zeichen für Zugriffsprobleme auf die Speicherkarte), die Karte ist aber neu. Ich habe dann nochmal alle Instanzen gecheckt: der ical Adapter läuft dort mit 4 Instanzen, die alle zur gleichen Zeit per Cron gesteuert werden. Nachdem ich das vorgestern so geändert habe, dass die 4 Instanzen "konfliktfrei" gescheduled werden, scheint alles stabil zu laufen...
                          • amg_666A amg_666
                            apollon77A Online
                            apollon77A Online
                            @amg_666 also seit Controller 2.0 sollte auch so ein „zur gleichen Zeit gescheduled“ weniger problematisch sein weil die mir 4s Abstand gestartet werden. Vllt noch alter controller?
                            Aber ja. Sehr hohe Last auf dem Master kann ggf slaves beeinträchtigen. Hier hilft die 2.2.7 vom Controller die Probleme zu verhindern
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              @apollon77 Ich hab jetzt mal alle Systeme auf js-controller 2.2.7 upgedatet (ich hatte aber vorher aber schon eine 2er Version drauf). Das beobachte ich jetzt mal ein paar Tage und gebe dann nochmal Feedback und stelle meinen Post ggf auf gelöst. Vielen Dank für die Unterstützung!
                              Update: Scheint jetzt stabil zu sein, seit 3 Tagen keinerlei Aussetzer/Probleme
