  4. Test Adapter swiss-weather-api v0.1.x
adaptertestweather
91 Beiträge 17 Kommentatoren 17.3k Aufrufe 18 Beobachtet
  • B baerengraben
    Aktuelle Test Version 2.2.2
    Veröffentlichungsdatum 9.1.2020
    Github Link https://github.com/baerengraben/ioBroker.swiss-weather-api
    Bereit zum Test
    Hallo zusammen
    Ich einen Adapter geschrieben, der die Wetter-Daten vom schweizer Staatsfernsehen https://developer.srgssr.ch/apis/srgssr-weather liest und im ioBroker zur Verfügung stellt. Ich bitte um Tests.
    Vielen Dank :)
    sigi234S Online
    sigi234S Online
    @baerengraben
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	at endReadableNT (_stream_readable.js:1145:12)
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	at IncomingMessage.emit (events.js:203:15)
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:983:89)
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	(7336) TypeError: Cannot read property 'toString' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.623	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.620	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    swiss-weather-api.0	2020-01-10 12:00:01.620	error	at endReadableNT (_stream_readable.js:1145:12)
    swiss-weather-api.0	2020-01-10 12:00:01.620	error	at IncomingMessage.emit (events.js:203:15)
    swiss-weather-api.0	2020-01-10 12:00:01.620	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:427:83)
    swiss-weather-api.0	2020-01-10 12:00:01.620	error	(7336) TypeError: Cannot read property '0' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.619	error	(7336) uncaught exception: Cannot read property '0' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	at endReadableNT (_stream_readable.js:1145:12)
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	at IncomingMessage.emit (events.js:203:15)
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1175:83)
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	(7336) TypeError: Cannot read property 'toString' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.616	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	at process._tickCallback (internal/process/next_tick.js:63:19)
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	at endReadableNT (_stream_readable.js:1145:12)
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	at IncomingMessage.emit (events.js:203:15)
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:123:92)
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	(7336) TypeError: Cannot read property 'toString' of undefined
    swiss-weather-api.0	2020-01-10 12:00:01.610	error	(7336) uncaught exception: Cannot read property 'toString' of undefined
    • sigi234S sigi234
      @baerengraben
      baerengraben
      schrieb am zuletzt editiert von baerengraben
      @sigi234 Vielen Dank fürs Testen! :)
      Ich habe eine kleine Korrektur gemacht und auf Github gestellt. Kannst du bitte die Adapter-Instanz löschen, den Adapter neu von Github ziehen, einen Upload machen und dann den Adapter neu installieren? Falls es weiterhin errors gibt, bitte gleich im Debug-Modus starten und das Log posten. - Das müsste aber eigentlich jetzt gehen...
      • B baerengraben
        sigi234S Online
        sigi234S Online
        @baerengraben
        swiss-weather-api.0	2020-01-10 19:43:01.487	info	(24948) Terminated (NO_ERROR): Without reason
        swiss-weather-api.0	2020-01-10 19:43:01.486	info	(24948) terminating
        swiss-weather-api.0	2020-01-10 19:43:00.994	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1002:89) at Incom
        swiss-weather-api.0	2020-01-10 19:43:00.993	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 19:43:00.993	debug	(24948) Hour Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
        swiss-weather-api.0	2020-01-10 19:43:00.992	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:1194:83) at Incom
        swiss-weather-api.0	2020-01-10 19:43:00.991	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 19:43:00.991	debug	(24948) 24h Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
        swiss-weather-api.0	2020-01-10 19:43:00.990	debug	(24948) chunksConcat: { "code": "404.02.001", "message": "Resource not found error", "info": "https://developer.srgssr.ch" }
        swiss-weather-api.0	2020-01-10 19:43:00.985	error	(24948) TypeError: Cannot read property 'toString' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:142:92) at Incomi
        swiss-weather-api.0	2020-01-10 19:43:00.985	error	(24948) uncaught exception: Cannot read property 'toString' of undefined
        swiss-weather-api.0	2020-01-10 19:43:00.984	debug	(24948) Current Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
        swiss-weather-api.0	2020-01-10 19:43:00.979	error	(24948) TypeError: Cannot read property '0' of undefined at IncomingMessage.<anonymous> (C:\Program Files\iobroker\Test\node_modules\iobroker.swiss-weather-api\main.js:446:83) at IncomingMessa
        swiss-weather-api.0	2020-01-10 19:43:00.979	error	(24948) uncaught exception: Cannot read property '0' of undefined
        swiss-weather-api.0	2020-01-10 19:43:00.973	debug	(24948) Week Forecast: {"code":"404.02.001","message":"Resource not found error","info":"https://developer.srgssr.ch"}
        swiss-weather-api.0	2020-01-10 19:43:00.972	debug	(24948) chunksConcat: { "code": "404.02.001", "message": "Resource not found error", "info": "https://developer.srgssr.ch" }
        swiss-weather-api.0	2020-01-10 19:43:00.804	debug	(24948) Access_Token : xxxxxxxxxxxxxxxxxxx
        swiss-weather-api.0	2020-01-10 19:43:00.628	debug	(24948) "xxxxxxxxxxxxxxxx" converted to Base64 is "xxxxxxxxxxxxxxxxxxxxx=="
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Define XML File:...
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Longitude: 14.xxxxxxxx
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Latitude 48.xxxxxxxxxxx
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Consumer Secret: xxxxxxxxxxx
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) Consumer Key: xxxxxxxxxxxxxxx
        swiss-weather-api.0	2020-01-10 19:43:00.622	debug	(24948) App Name: Sigi
        swiss-weather-api.0	2020-01-10 19:43:00.612	info	(24948) starting. Version 0.1.4 in C:/Program Files/iobroker/Test/node_modules/iobroker.swiss-weather-api, node: v10.16.3
          baerengraben
          Sehr komisch. Das SSRSSR-API beantwortet die Anfragen mit
          Darf ich wissen mit welcher Longitude / Latitude du die Abfrage machst? Ich habe die leise Vermutung, dass das API sich auf Schweizer Locations beschränkt. Kannst du auch mal Zürich (latitude: 47.36667 und longitude: 8.5) ausprobieren?
          • B baerengraben
            sigi234S Online
            sigi234S Online
            @baerengraben sagte in Test Adapter swiss-weather-api v0.1.x:
            Ja, mit diesen geht es. Meine sind aus Österreich.
              baerengraben
              Ok, ich "verbessere" den Adapter noch indem ich ihn auf Schweizer Locations einschränke und mache eine neue Version.
              Vielen Dank für diesen Test! Da wäre ich definitiv nicht darauf gekommen...
                baerengraben
                Die Anpassungen sind erledigt. Ich habe gleich eine neue Version 0.1.5 erstellt.
                • B baerengraben
                  sigi234S Online
                  sigi234S Online
                  Einfach per Git installieren?
                    baerengraben
                    Ja wieder genau gleich über Github ziehen, uploaden und neu installieren.
                    Der Adapter gibt nun einen Error aus, wenn eine Location gesucht wird, welche nicht vom API unterstützt wird.
                    • B baerengraben
                      sigi234S Online
                      sigi234S Online
                      Also nix für Österreich.
                        baerengraben
                        Leider werden nur Schweizer Adressen unterstützt. Der swiss-weather-api Adapter zieht die Wetter-Daten vom Schweizer Fernsehen. Die können da zwar gratis abgerufen werden, aber sie bieten explizit nur schweizer Adressen an. Dieser Adapter ist deswegen vorallem für Schweizer geeignet oder für Personen, die sich für Wetterdaten in der Schweiz interessieren.
                        dbwebD 1 Antwort Letzte Antwort
                        • B baerengraben
                          dbwebD Offline
                          dbwebD Offline
                          dbweb
                          @baerengraben Bin grade beim Testen, schön gibts jetzt auch mal was für die Schweiz, vielen Dank dafür.
                          Anmerkungen:
                          • ist natürlich etwas schade, dass man erstmal bis zu 30 Minuten warten muss damit etwas kommt. Weis aber auch nicht wie du das bei einem Schedule-Adapter anders lösen kannst ohne irgend ein "Gebastel" in der index_m.
                          • Dasselbe mit den Credentials, wenn man da was falsch eingibt, wartet man mal 30 Minuten um das dann im Log zu merken. Da könntest du evtl. auch vom Client aus einen Request abschicken um zu prüfen ob es soweit passt, auch wenn ich das nicht wirklich sauber finde.
                          Hast du, oder jemand anderes, schon eine VIS-Anzeige dazu gebaut?
                          B sigi234S 2 Antworten Letzte Antwort
                          • dbwebD dbweb
                            Anmerkungen:
                            baerengraben
                            @dbweb: Merci fürs Testen :)
                            @dbweb sagte in Test Adapter swiss-weather-api v0.1.x:
                            Anmerkungen:
                            Das ist ein guter Punkt, für den ich bis jetzt auch noch keine schöne Lösung gefunden habe. Beim Testen habe ich jeweils, nach dem Installieren, den Scheduler kurz auf 1min gesetzt. Anschliessend, wenn alles gut lief, dann wieder auf 30min.
                            Ansonsten habe ich leider auch keine bessere Möglichkeit gefunden das schöner umzusetzen.
                            Hier kann man eigentlich auch kurz den Scheduler auf 1min stellen, so dass man schneller feststellen kann ob's ok durchläuft oder nicht. Aber evtl. kann ich dem auch beikommen indem ich das noch besser Dokumentiere (z.B. mit Printscreens)?
                            Eine Visualisierung habe ich nicht umgesetzt. Ich persönlich verwende das API um die Daten vom ioBroker auf mein KNX-System zu schicken. Da wird es bei dann visualisiert. Wenn hier jemand die Visu im ioBroker dafür beitragen möchte/könnte wäre das natürlich super :)
                            • dbwebD dbweb
                              Anmerkungen:
                              sigi234S Online
                              sigi234S Online
                              Nicht direkt, aber:
                              https://forum.iobroker.net/topic/28717/vis-von-sigi234/23
                                Al Bundy
                                Ich nutze den Adapter in der Version 0.2.0. Seit einem Update von node.js von 10x auf 12.16.3 funktioniert dieser nicht mehr (Fehlermeldung im Log: error: instance system.adapter.swiss-weather-api.0 terminated with code 1 (JS_CONTROLLER_STOPPED))
                                Gibt es Probleme mit dem Adapter und der 12er Version?
                                • A Al Bundy
                                  trasaonis
                                  @Al-Bundy said in Test Adapter swiss-weather-api v0.1.x:
                                  Hab das gleiche Problem seit dem Update. Adapter lässt dich nicht mehr starten.
                                  • T trasaonis
                                    Al Bundy
                                    @trasaonis
                                    Ich habe die Instanz und den Adapter deinstalliert und nochmals komplett neu installiert. Nun läuft es wieder.
                                    • A Al Bundy
                                      @trasaonis
                                      trasaonis
                                      @Al-Bundy
                                      Danke! Hat bei mir auch funktioniert. Bin leider erst jetzt dazugekommen Adapter und Instanz neu zu installieren. Läuft wieder!👍
                                        M240-Swiss
                                        Hallo zusammen
                                        Als erstes: Ich bin noch Anfänger was iObroker angeht und falls der Beitrag hier nicht hingehört bitte verschieben.
                                        Ich konnte ioBroker auf einem Raspberry Pi 4 installieren und im Anschluss erste Adapter erfolgreich in Betrieb nehmen.
                                        Ich habe nun den swiss-weather Adapter installiert, Costumer-Key und - Secret eingegeben und auch die Koordinaten (innerhalb der Schweiz) eingetragen.
                                        Nun jedoch erscheinen mir im Log laufend Fehlermeldungen (siehe Spoiler unten)
                                        Hat mir dort jemand einen Tip? Besten Dank im Voraus und Gruss aus der Schweiz
                                        2020-07-22 21:00:01.447 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'ttn' of undefined
                                        2020-07-22 21:00:01.448 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'ttn' of undefined
                                        at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:602:26)
                                        at IncomingMessage.emit (events.js:326:22)
                                        at endReadableNT (_stream_readable.js:1244:12)
                                        at processTicksAndRejections (internal/process/task_queues.js:80:21)
                                        2020-07-22 21:00:01.455 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property '0' of undefined
                                        2020-07-22 21:00:01.459 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property '0' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:595:28
                                        at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55
                                        at /opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703
                                        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49
                                        at processTicksAndRejections (internal/process/task_queues.js:93:5)
                                        2020-07-22 21:00:01.462 - info: swiss-weather-api.0 (5701) terminating
                                        2020-07-22 21:00:01.464 - info: swiss-weather-api.0 (5701) Terminated (NO_ERROR): Without reason
                                        2020-07-22 21:00:01.473 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'smb3' of undefined
                                        2020-07-22 21:00:01.474 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'smb3' of undefined
                                        at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1690:26)
                                        2020-07-22 21:00:01.478 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                        2020-07-22 21:00:01.479 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1664:34
                                        2020-07-22 21:00:01.481 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property '0' of undefined
                                        2020-07-22 21:00:01.482 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property '0' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1682:34
                                        2020-07-22 21:00:01.493 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot convert undefined or null to object
                                        2020-07-22 21:00:01.494 - error: swiss-weather-api.0 (5701) TypeError: Cannot convert undefined or null to object
                                        at Function.keys ()
                                        at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1402:18)
                                        2020-07-22 21:00:01.499 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'ttn' of undefined
                                        2020-07-22 21:00:01.500 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'ttn' of undefined
                                        at IncomingMessage. (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:191:26)
                                        2020-07-22 21:00:01.505 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                        2020-07-22 21:00:01.506 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1394:34
                                        2020-07-22 21:00:01.507 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'toString' of undefined
                                        2020-07-22 21:00:01.508 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'toString' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:165:34
                                        2020-07-22 21:00:01.510 - error: swiss-weather-api.0 (5701) uncaught exception: Cannot read property 'date' of undefined
                                        2020-07-22 21:00:01.511 - error: swiss-weather-api.0 (5701) TypeError: Cannot read property 'date' of undefined
                                        at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:183:31
                                        2020-07-22 21:00:01.977 - info: host.raspberrypi instance system.adapter.swiss-weather-api.0 terminated with code 0 (NO_ERROR)
                                        • M M240-Swiss
                                          Hallo zusammen
                                          at Function.keys ()
                                          Slash12
                                          schrieb am zuletzt editiert von Slash12
                                          @M240-Swiss:
                                          Ich bekomme das gleiche Problem und wäre auch sehr dankbar für einen Ratschlag. Ich habe V2.2 des Adapters installiert.
                                          Löschen der Instanz und anschliessende Neuinstallation des Adapters haben leider nichts bewirkt.
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1682:34
                                          swiss-weather-api.0 2020-07-23 12:34:02.024 error (16834) TypeError: Cannot read property '0' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:02.023 error (16834) uncaught exception: Cannot read property '0' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1664:34
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error (16834) TypeError: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.992 error (16834) uncaught exception: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1394:34
                                          swiss-weather-api.0 2020-07-23 12:34:01.991 error (16834) TypeError: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.990 error (16834) uncaught exception: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.988 info (16834) Terminated (NO_ERROR): Without reason
                                          swiss-weather-api.0 2020-07-23 12:34:01.987 info (16834) terminating
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:595:28
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error (16834) TypeError: Cannot read property '0' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.984 error (16834) uncaught exception: Cannot read property '0' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:183:31
                                          swiss-weather-api.0 2020-07-23 12:34:01.983 error (16834) TypeError: Cannot read property 'date' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error (16834) uncaught exception: Cannot read property 'date' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at process._tickCallback (internal/process/next_tick.js:68:7)
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at (anonymous function).get (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:93703)
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at adapterObjects.getObject (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3216:55)
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error at /opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:165:34
                                          swiss-weather-api.0 2020-07-23 12:34:01.982 error (16834) TypeError: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.978 error (16834) uncaught exception: Cannot read property 'toString' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error at process._tickCallback (internal/process/next_tick.js:63:19)
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error at endReadableNT (_stream_readable.js:1143:12)
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error at IncomingMessage.emit (events.js:203:15)
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1690:26)
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error (16834) TypeError: Cannot read property 'smb3' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.973 error (16834) uncaught exception: Cannot read property 'smb3' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error at process._tickCallback (internal/process/next_tick.js:63:19)
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error at endReadableNT (_stream_readable.js:1143:12)
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error at IncomingMessage.emit (events.js:203:15)
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:1402:18)
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error at Function.keys (<anonymous>)
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error (16834) TypeError: Cannot convert undefined or null to object
                                          swiss-weather-api.0 2020-07-23 12:34:01.965 error (16834) uncaught exception: Cannot convert undefined or null to object
                                          swiss-weather-api.0 2020-07-23 12:34:01.961 error at process._tickCallback (internal/process/next_tick.js:63:19)
                                          swiss-weather-api.0 2020-07-23 12:34:01.961 error at endReadableNT (_stream_readable.js:1143:12)
                                          swiss-weather-api.0 2020-07-23 12:34:01.961 error at IncomingMessage.emit (events.js:203:15)
                                          swiss-weather-api.0 2020-07-23 12:34:01.961 error at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:602:26)
                                          swiss-weather-api.0 2020-07-23 12:34:01.961 error (16834) TypeError: Cannot read property 'ttn' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.960 error (16834) uncaught exception: Cannot read property 'ttn' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.952 error at process._tickCallback (internal/process/next_tick.js:63:19)
                                          swiss-weather-api.0 2020-07-23 12:34:01.952 error at endReadableNT (_stream_readable.js:1143:12)
                                          swiss-weather-api.0 2020-07-23 12:34:01.952 error at IncomingMessage.emit (events.js:203:15)
                                          swiss-weather-api.0 2020-07-23 12:34:01.952 error at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.swiss-weather-api/main.js:191:26)
                                          swiss-weather-api.0 2020-07-23 12:34:01.952 error (16834) TypeError: Cannot read property 'ttn' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.951 error (16834) uncaught exception: Cannot read property 'ttn' of undefined
                                          swiss-weather-api.0 2020-07-23 12:34:01.686 info (16834) Swiss-Weather-API: Start getWeatherInfos
                                          swiss-weather-api.0 2020-07-23 12:34:01.657 info (16834) starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.swiss-weather-api, node: v10.17.0, js-controller: 3.1.6
