  4. Test Adapter EnOcean v0.3.x
    6.4k
enocean
265 Beiträge 31 Kommentatoren 88.9k Aufrufe 12 Beobachtet
  • 9 Offline
    9 Offline
    9_Mad-Max_5
    #222
    @Jey-Cee
    Griff ist geschlossen
    Er wird schnell mit dem Uhrzeigersinn in Richtung kippen gedreht.
    enocean.0	2019-11-24 14:10:38.247	debug	(1257) else: window_handle
    enocean.0	2019-11-24 14:10:38.246	debug	(1257) variables to set : {"window_handle":2}
    enocean.0	2019-11-24 14:10:38.244	debug	(1257) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-24 14:10:38.243	debug	(1257) Packet type: 1
    enocean.0	2019-11-24 14:10:38.242	debug	(1257) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
    enocean.0	2019-11-24 14:10:38.039	debug	(1257) else: window_handle
    enocean.0	2019-11-24 14:10:38.038	debug	(1257) variables to set : {"window_handle":1}
    enocean.0	2019-11-24 14:10:38.036	debug	(1257) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-24 14:10:38.035	debug	(1257) Packet type: 1
    enocean.0	2019-11-24 14:10:38.034	debug	(1257) Received raw message: 55000707017af6e0019b0ffa2000ffffffff5c00
    Dort verhaart der griff für ca. 40 Sekunden.
    Von dort wird er schnell gegen den Uhrzeigersinn geschlossen ohne in der geöffnet Position zu verhaaren.
    enocean.0	2019-11-24 14:11:23.683	debug	(1257) else: window_handle
    enocean.0	2019-11-24 14:11:23.681	debug	(1257) variables to set : {"window_handle":2}
    enocean.0	2019-11-24 14:11:23.680	debug	(1257) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-24 14:11:23.679	debug	(1257) Packet type: 1
    enocean.0	2019-11-24 14:11:23.673	debug	(1257) Received raw message: 55000707017af6d0019b0ffa2000ffffffff5c00
    enocean.0	2019-11-24 14:11:22.972	debug	(1257) else: window_handle
    enocean.0	2019-11-24 14:11:22.972	debug	(1257) variables to set : {"window_handle":1}
    enocean.0	2019-11-24 14:11:22.971	debug	(1257) Message for ID 019b0ffa has been received.
    enocean.0	2019-11-24 14:11:22.971	debug	(1257) Packet type: 1
    enocean.0	2019-11-24 14:11:22.970	debug	(1257) Received raw message: 55000707017af6c0019b0ffa2000ffffffff5900
      mustang
      #223
      Moin - ich hab mich gerade erst angemeldet und iobroker vor 4 Tagen unter Kubuntu auf einem Kleinrechner installiert. Als Funkempfänger dient ein enocean-USB-Stick 300 mit externer Antenne.
      Von Eltako soll ein TF-FKE Fensterkontakt (mit zwei Schaltzuständen) zum Einsatz kommen. Laut Beschreibung von Eltako wird ein Funktelegramm "geschlossen 0xF0" und "offen 0xE0" gesendet.
      Entsprechend meines Logs in iobroker befinden sich die gesendeten Werte NICHT im String am Ende "ffffffff3700" sondern "55000707017af6(f0)fef6e05f2000ffffffff3700" unmittelbar vor der ID (fef6e05f). Das am Ende könnte vielleicht auch der RSSI-Wert des TF-FKE sein(?), jedoch sind die Schaltzustände bei meinem Kontakt mit Sicherheit an der von mir markierten Stelle. Ich weiß nur noch nicht, wie das auswerten soll - Programmieren ist nicht ganz so meins.
      Das Log:
      enocean.0 2019-12-10 05:18:20.204 debug (10372) variables to set : {}
      enocean.0 2019-12-10 05:18:20.203 debug (10372) Message for ID fef6e05f has been received.
      enocean.0 2019-12-10 05:18:20.203 debug (10372) Packet type: 1
      enocean.0 2019-12-10 05:18:20.202 debug (10372) Received raw message: 55000707017af6e0fef6e05f2000ffffffff3c00
      enocean.0 2019-12-10 05:18:19.148 debug (10372) variables to set : {}
      enocean.0 2019-12-10 05:18:19.147 debug (10372) Message for ID fef6e05f has been received.
      enocean.0 2019-12-10 05:18:19.147 debug (10372) Packet type: 1
      enocean.0 2019-12-10 05:18:19.146 debug (10372) Received raw message: 55000707017af6f0fef6e05f2000ffffffff3c00
      enocean.0 2019-12-10 05:17:16.426 debug (10372) variables to set : {}
      enocean.0 2019-12-10 05:17:16.425 debug (10372) Message for ID fef6e05f has been received.
      enocean.0 2019-12-10 05:17:16.424 debug (10372) Packet type: 1
      enocean.0 2019-12-10 05:17:16.424 debug (10372) Received raw message: 55000707017af6e0fef6e05f2000ffffffff3700
      enocean.0 2019-12-10 05:17:15.356 debug (10372) variables to set : {}
      enocean.0 2019-12-10 05:17:15.355 debug (10372) Message for ID fef6e05f has been received.
      enocean.0 2019-12-10 05:17:15.352 debug (10372) Packet type: 1
      enocean.0 2019-12-10 05:17:15.352 debug (10372) Received raw message: 55000707017af6f0fef6e05f2000ffffffff3700
      enocean.0 2019-12-10 05:16:54.556 debug (10372) system.adapter.admin.0: logging true
        mustang
        schrieb am zuletzt editiert von mustang
        #224
        @9_Mad-Max_5 So gesehen sehe ich bei dir die drei Schaltzustände: c0, d0, und e0! Mit der Drehgeschwindigkeit dürfte das nichts zu tun haben.
        • 9 Offline
          9 Offline
          9_Mad-Max_5
          #225
          @mustang
          Das ist sehr gut möglich.
          Dann hätte ich bei meiner einbau Position folgende Postionen:
          Offen mit Uhrzeigersinn: e0
          Offen gegen Uhrzeigersinn: c0
          Gekippt mit Uhrzeigersinn: d0
          Geschlossen gegen Uhrzeigersinn: d0
          Warum verstehe ich auch nicht.
          Normal müsste das ja aufgrund der Richtung alleine eine andere Nummer bekommen.
          @Jey-Cee
          Könnte man Aufgrund des vorigen Zustands den geschlossen neu setzten. Also wenn ich von einem c0 komme wird es zu einem geschlossen?
          • 9 Offline
            9 Offline
            9_Mad-Max_5
            #226
            uff ich habe heute nochmal ein wenig getestet auch mit einem anderen Griff.
            Bei dem klappt alles Problemlos es scheint mir so als wäre deine Software bis auf die Auto Erkennung Problemlos.
            Hier wurden beide als EnOcean Blinds and Shutter erkannt.
            • 9 9_Mad-Max_5
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #227
              @9_Mad-Max_5 OK das ist positiv. Auto erkennung muss ich mir anschauen wie das kommt.
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
                mustang
                #228
                @Jey-Cee
                So - jetzt hab ich mal wieder etwas Zeit gefunden mich mit den enocean-Modulen zu beschäftigen.
                Zur Zeit habe ich drei Eltako - 1x TF-FTE, 1x TF-FKe, 1x FSM14-UC. Alle werden als Light and Blind Control automatisch erkannt. Der FSM14 wird unter Objekte korrekt mit 4 Kanälen eingebunden und die Statusanzeige wechselt richtigerweise von false auf true bei entsprechendem Signal am Eingang jedes einzelnen Kanals. Was mir jetzt nicht klar ist, daß die TF-FKE und TF-FTE als einfache On/OFF-Schalter ebenfalls mit 4 Kanälen eingebunden werden und auf keinem Kanal bei Betätigung des Schalters eine Zustandsänderung von false auf true erfolgt? Erwarten würde ich auf mindestens einem Kanal eine Änderung. Wie schon von mir geschrieben, werden nur zwei Codes übermittelt. Die Auswertung des RSSI ist bei allen vorhanden.
                  mustang
                  #229
                  Hallo nochmal - laut anderer Foren (openHAB + knx) sollen die Schalter TF-FKE bzw. TF-FTE mit EEP F6-10-00 funktionieren. Lässt sich das beim einlernen irgendwie umstellen?
                  • M mustang
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #230
                    @mustang klar du kannst die Taster auch Manuell anlegen, dafür musst die ID (Seriennummer) wissen.
                    Dann wählst du die EEP aus und fertig.
                      MartyBr
                      #231
                      Hallo @Jey-Cee , ich habe an meinem Raspi einen USB Stick von Piotek angeschlossen. Damit werden meine Enocean Geräte in CUXD angelegt und ich kann sie in der CCU schalten.
                      Der Stick scheint von Eltako zu sein (ELT-FAM-USB-ESP3
                      Eltako EnOcean USB Gateway FAM-USB (ESP3 Version) Profi-Antenne (incl. CUxD EnOcean Lizenz))
                      In deiner Anleitung wird ein EnOcean USB 300 Gateway beschrieben.
                      Kann man nun meinen FAM-USB nutzen?
                      Martin
                      Martin
                      Homematic und Homematic IP
                      • M MartyBr
                        Martin
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #232
                        @MartyBr denke schon, am besten Testen.
                        • Jey CeeJ Jey Cee
                          MartyBr
                          #233
                          @Jey-Cee Danke. Dann teste ich das mal an einem langen Wochenende. Über Enocean laufen ca. 25 Geräte, u.a. die Rollo-Aktoren von Eltako.
                          Martin
                          • M MartyBr
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            #234
                            @MartyBr sagte in Test Adapter EnOcean v0.3.x:
                            die Rollo-Aktoren
                            Dann ist der Adapter nichts für dich, der Empfängt nur Daten senden hat noch keiner eingebaut.
                            • Jey CeeJ Jey Cee
                              die Rollo-Aktoren
                              MartyBr
                              #235
                              @Jey-Cee Schade. Ich hatte die Hoffnung, dass ich auch diese Geräte in den ioBroker installieren könnte.
                              Dann ziehe ich mir die weiter über den RPC Adapter rein.
                              Danke für die Info.
                              Martin
                                mustang
                                #236
                                Habe die beiden Eltako Taster TF-FKE + TF-FTE nun manuell angelegt und sie funktionieren - für andere vielleicht einfach zu handhaben, jedoch für mich nicht alles selbsterklärend. Die Variablen zur Konfiguration des EEP-Profils "F6-10-00" habe dann der Datei /opt/iobroker/node_modules/iobroker.enocean/eep/EEP2IOB.json entnommen.
                                Anbei die RAW-Daten meiner Konfig; sind vielleicht für andere noch hilfreich:
                                Konfig Objekt-fef6e05f
                                "user": "system.user.admin",
                                "ts": 1578758542666,
                                "common": {
                                "name": "Window Handle",
                                "role": "",
                                "icon": ""
                                "native": {
                                "id": "fef6e05f",
                                "manufacterer": "ENOCEAN GMBH",
                                "device": "Window Handle",
                                "desc": "native",
                                "eep": [
                                "F6-10-00"
                                "acl": {
                                "object": 1636,
                                "owner": "system.user.admin",
                                "_id": "enocean.0.fef6e05f",
                                "type": "device"
                                Konfig Objekt-window_handle
                                "ts": 1578775861405,
                                "common": {
                                "name": "window_handle",
                                "role": "switch",
                                "type": "number",
                                "min": "0",
                                "max": "2",
                                "def": "1",
                                "states": "",
                                "read": "true",
                                "write": "false"
                                "native": {},
                                "acl": {
                                "object": 1636,
                                "state": 1636
                                "_id": "enocean.0.fef6e05f.window_handle",
                                "type": "state"
                                Konfig Objekt-rssi
                                "_id": "enocean.0.fef6e05f.rssi",
                                "type": "state",
                                "common": {
                                "name": "Signal Strength",
                                "role": "value.rssi",
                                "type": "number",
                                "read": true,
                                "write": false
                                "native": {},
                                "ts": 1578759224684,
                                "acl": {
                                "object": 1636,
                                "state": 1636
                                Das war es dann erstmal, jetzt muß ich mich mit der Logik (Blockly) und einer Visualisierung beschäftigen.
                                Danke für die Hinweise - bis dann mustang
                                  mustang
                                  #237
                                  • Jey CeeJ Online
                                    Jey CeeJ Online
                                    Jey Cee
                                    #238
                                    Hier gehts zur Umfrage ob Interesse an einer Weiterentwicklung des enOcean Adapters besteht.
                                    • G Offline
                                      Grantlhaua
                                      #239
                                      Servus @Jey-Cee
                                      Eine kurze Frage, da ich evtl die meisten Aktoren raus werfe und gegen Shelly's täusche. Kann dieser Adapter schon die Daten der Wetterstation verarbeiten? Da muss er ja nur empfangen und nichts senden.
                                      Jey CeeJ P 2 Antworten Letzte Antwort
                                      • G Grantlhaua
                                        Servus @Jey-Cee
                                        Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #240
                                        @Grantlhaua sagte in Test Adapter EnOcean v0.3.x:
                                        Servus @Jey-Cee
                                        Welche Wetterstation? Ich denke eher nicht da sind wenig Geräte implementiert.
                                        • G Offline
                                          Grantlhaua
                                          #241
                                          Guten Morgen,
                                          den
                                          Eltako 4824664 Multisensor MS IP44 EnOcean mit Eltako 2719447 Funk-Sendemodul für Wetterdaten, FWS 61-24 V DC
                                          Viele Grüße
                                          G 1 Antwort Letzte Antwort
