  4. Test Adapter deConz v1.2.x Github
    6.7k
zigbeehuedeconz
250 Beiträge 30 Kommentatoren 55.2k Aufrufe 29 Beobachtet
  • PischleuderP Offline
    Pischleuder
    bei mir auch - nur etwas anderer error:
    deconz.0	2020-01-07 20:59:51.584	info	(16866) Got terminate signal TERMINATE_YOURSELF
    deconz.0	2020-01-07 20:59:51.334	debug	(16866) getDevices: {"statusCode":404,"body":"[]","headers":{"access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length":"2"},"request":{"uri":{"protocol":"http
    deconz.0	2020-01-07 20:59:51.331	debug	(16866) getAllGroups: {}
    deconz.0	2020-01-07 20:59:51.327	error	(16866) RangeError: Invalid time value at Date.toISOString (<anonymous>) at UTCtoLocal (/opt/iobroker/node_modules/iobroker.deconz/main.js:1712:35) at new setObjectAndState (/opt/iobroker/
    deconz.0	2020-01-07 20:59:51.326	error	(16866) uncaught exception: Invalid time value
    deconz.0	2020-01-07 20:59:51.308	debug	(16866) getAllSensors: {"1":{"config":{"configured":false,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":null,"manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark"
    deconz.0	2020-01-07 20:59:51.303	debug	(16866) getAllLights: {}
    deconz.0	2020-01-07 20:59:51.280	info	(16866) Got terminate signal TERMINATE_YOURSELF
    deconz.0	2020-01-07 20:59:51.210	debug	(16866) API version: 1.16.0
    deconz.0	2020-01-07 20:59:51.144	debug	(16866) M-SEARCH from 192.168.178.89 for "urn:schemas-upnp-org:device:basic:1"
    deconz.0	2020-01-07 20:59:51.031	info	(16866) Auto discovery
    deconz.0	2020-01-07 20:59:50.960	info	(16866) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.18.0
    deconz.0	2020-01-07 20:59:42.484	info	(16736) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    deconz.0	2020-01-07 20:59:42.481	info	(16736) terminating
    deconz.0	2020-01-07 20:59:42.075	info	(16736) Got terminate signal TERMINATE_YOURSELF
    • PischleuderP Pischleuder
      Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      @Pischleuder bei dir gibt es ein Problem mit lastupdated.
      @all könnt ihr mir bitte eure Logs, aus der Datei nicht im Admin, zeigen.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
      PischleuderP 1 Antwort Letzte Antwort
      • Jey CeeJ Jey Cee
        Pischleuder
        @Jey-Cee
        mir ist nicht ganz klar, was du möchtest :-)
        • coyoteC Offline
          coyoteC Offline
          coyote
          Irgendwie seltsam, bekomme jetzt nach einem Downgrade auch die "alte" Version nicht mehr zum Laufen...
          host.debian	2020-01-07 21:38:02.643	info	instance system.adapter.deconz.0 terminated with code 156 (156)
          host.debian	2020-01-07 21:38:02.446	warn	instance system.adapter.deconz.0 already running with pid 17549
          deconz.0	2020-01-07 21:38:01.023	info	(17549) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          deconz.0	2020-01-07 21:38:01.019	info	(17549) terminating
          host.debian	2020-01-07 21:38:00.945	info	stopInstance system.adapter.deconz.0 killing pid 17549
          host.debian	2020-01-07 21:38:00.914	info	stopInstance system.adapter.deconz.0 killing pid 17549
          deconz.0	2020-01-07 21:38:00.386	info	(17549) Got terminate signal TERMINATE_YOURSELF
          deconz.0	2020-01-07 21:38:00.374	info	(17549) Got terminate signal TERMINATE_YOURSELF
          host.debian	2020-01-07 21:37:59.945	info	stopInstance system.adapter.deconz.0 send kill signal
          host.debian	2020-01-07 21:37:59.930	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
          host.debian	2020-01-07 21:37:59.894	info	stopInstance system.adapter.deconz.0 send kill signal
          host.debian	2020-01-07 21:37:59.849	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
          deconz.0	2020-01-07 21:37:59.651	info	(17549) Auto discovery
          deconz.0	2020-01-07 21:37:59.613	info	(17549) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
          host.debian	2020-01-07 21:37:57.792	info	instance system.adapter.deconz.0 started with pid 17549
          host.debian	2020-01-07 21:37:57.749	info	instance system.adapter.deconz.0 terminated with code 156 (156)
          host.debian	2020-01-07 21:37:56.070	info	stopInstance system.adapter.deconz.0 killing pid 17532
          host.debian	2020-01-07 21:37:55.917	info	stopInstance system.adapter.deconz.0 killing pid 17532
          deconz.0	2020-01-07 21:37:55.589	info	(17532) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          deconz.0	2020-01-07 21:37:55.588	info	(17532) terminating
          deconz.0	2020-01-07 21:37:55.444	info	(17532) Got terminate signal TERMINATE_YOURSELF
          host.debian	2020-01-07 21:37:55.070	info	stopInstance system.adapter.deconz.0 send kill signal
          host.debian	2020-01-07 21:37:55.058	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
          deconz.0	2020-01-07 21:37:54.966	info	(17532) Got terminate signal TERMINATE_YOURSELF
          host.debian	2020-01-07 21:37:54.912	info	stopInstance system.adapter.deconz.0 send kill signal
          host.debian	2020-01-07 21:37:54.897	info	stopInstance system.adapter.deconz.0 (force=false, process=true)
          deconz.0	2020-01-07 21:37:54.735	info	(17532) Auto discovery
          deconz.0	2020-01-07 21:37:54.682	info	(17532) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.17.0
            Pischleuder
            schrieb am zuletzt editiert von Pischleuder
            ja, hatte ich auch - du musst dann ganz zurück auf die 1.0.1 - so war es zumindest bei mir.
            Interessant ist, dass bei dem 1.2.1, obwohl der Status immer zwischen rot und gelb wechselt. dennoch die richtigen Daten in die Knotenpunkte geschrieben werden.
            • lobomauL Offline
              lobomauL Offline
              lobomau
              schrieb am zuletzt editiert von lobomau
              Bei mir die gleiche Fehlermeldung wie bei coyote, Wechsel zw. gelb und rot. Aber Daten scheinen richtig geschrieben und aktualisert zu werden.
              Edit: der Adapter erhöht bei mir die CPU-Last für ioBroker von 22% auf knapp 60% . Ich habe erstmal den Adapter gestoppt.
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
              • coyoteC coyote
                Jey CeeJ Online
                Jey CeeJ Online
                Jey Cee
                @coyote Adapter komplett gelöscht und dann neu Installiert?
                @lobomau sagte in Test Adapter deConz v1.2.x Github:
                Ja das Liegt daran das er immer wieder neu startet, deswegen werden auch die Daten von deConz gelesen.
                • Jey CeeJ Jey Cee
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @Jey-Cee
                  Sind für Version 1.2.1 bestimmte Versions-Voraussetzungen nötig?
                  JSController, NodeJS?
                  Ich bin erstmal wieder auf die 1.1.2 zurück.
                  • coyoteC Offline
                    coyoteC Offline
                    coyote
                    @Jey-Cee ja, komplett gelöscht hatte ich auch.
                    Habe jetzt 1.0.1 nochmal installiert und wieder Update auf die letzte Version gemacht, ist jetzt wieder grün.
                    • Jey CeeJ Online
                      Jey CeeJ Online
                      Jey Cee
                      schrieb am zuletzt editiert von Jey Cee
                      @haselchen @coyote @lobomau Problem gefunden, Lösung erfordert etwas mehr Arbeit dauert also.
                      @Pischleuder @Marco-Laser bei euch gibt es noch ein anderes Problem darum kann ich mich erst kümmern wenn das andere erledigt ist.
                      Momentan NICHT Installieren, es gibt ein Schwerwiegendes Problem
                        Pischleuder
                        👍 gute Dinge benötigen Zeit :-)
                        Dennoch, obwohl der Adapter die ganze Nacht hindurch zwischen gelb und rot gewechselt hat, sind alle Daten permanent korrekt geschrieben worden - strange.
                          Alex975
                          wie komme ich jetzt eigentlich an die version 1.2.0 ran? Wenn ich über "aus eigener Url" auswähle wird ja nur die 1.2.1 installiert.
                          habe jetzt die 1.1.2 drauf (Adapter bleibt aber gelb)
                            Pischleuder
                            du schaltest im Admin Bereich bei den Adaptern oben den Expertenmodus an (das Piktogramm mit dem Bild), daraufhin erscheint neben den jeweiligen Adpatern ein + Zeichen. Hier kannst du nun eine bestimmte Version auswählen.
                              Jey CeeJ Online
                              Jey CeeJ Online
                              Jey Cee
                              @Pischleuder geht in dem fall nicht,die 1.2.0 ost nicht auf npm.
                              A 2 Antworten Letzte Antwort
                              • Jey CeeJ Jey Cee
                                Alex975
                                @Jey-Cee Ja, deswegen ja auch meine frage..
                                • Jey CeeJ Jey Cee
                                  Alex975
                                  @Jey-Cee
                                  Wäre es möglich einstweilen wieder die 1.2.0 Version beim Github hochzuladen? bekomme den Adapter nicht auf grün (nur gelb) und bekomme auch keine aktuellen Daten von meinen Bewegungsmeldern..
                                  • T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    @Alex975
                                    Ich hatte das gleiche Problem. Hab die 1.0.1 über die Console installiert, dann die 1.1.2 drüber und dann den PI neu gestartet. Danach gings wieder. :)
                                    Spenden
                                    • T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      könnte auch die 1.0.0 gewesen sein.
                                      Spenden
                                      • T ticaki
                                        Alex975
                                        @ticaki sagte in Test Adapter deConz v1.2.x Github:
                                        Ich hab ja die 1.1.2 wieder installiert bekommen (nach vorherigen Upgrade auf 1.0.1.).
                                        MEin Adapter wird aber in der V1.1.2 nicht mehr grün, trotz Erneuerung des API Keys und Neustart des Iobroker systems..
                                        • A Alex975
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @Alex975
                                          Und wenn du dich in der Phoscon Web App anmeldest und dann den Adapter neu startest?
