  4. [Vorlage] Anwesenheitssimulation - Script
272 Beiträge 40 Kommentatoren 105.0k Aufrufe 37 Beobachtet
  • L
    L
    looxer01
    im ersten post. ist ein spoiler tag - einfach öffnen.
    vG Looxer
    • S
      S
      starfish
      hier gabs etwas roten Text im Log - hab das orig.script nur an meine Gegebenheiten angepasst (nur 1 Aktor aufm Testrechner)
      ! javascript.0 2016-01-02 02:15:37 info javascript.0 script.js.aws: registered 2 subscriptions and 7 schedules
      ! javascript.0 2016-01-02 02:15:37 info javascript.0 Start javascript script.js.aws
      ! javascript.0 2016-01-02 02:15:37 info javascript.0 received all objects
      ! javascript.0 2016-01-02 02:15:37 info javascript.0 received all states
      ! javascript.0 2016-01-02 02:15:36 info javascript.0 requesting all objects
      ! javascript.0 2016-01-02 02:15:36 info javascript.0 requesting all states
      ! javascript.0 2016-01-02 02:15:36 info javascript.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.javascript
      ! bananapi2 2016-01-02 02:15:30 info host.bananapi2 instance system.adapter.javascript.0 started with pid 2374
      ! bananapi2 2016-01-02 02:15:00 info host.bananapi2 Restart adapter system.adapter.javascript.0 because enabled
      ! bananapi2 2016-01-02 02:15:00 error host.bananapi2 instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)
      ! javascript.0 2016-01-02 02:15:00 error ReferenceError: addTime is not defined at isTimeInRange (script.js.aws:487:17) at Object. (script.js.aws:149:8) at Job.job (/opt/iobroker/node_modules/iobroker.javascript/javasc
      ! javascript.0 2016-01-02 02:15:00 error uncaught exception: addTime is not defined
      etwas später:
      ! host-bananapi2 2016-01-02 02:25:01 error instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)
      ! ReferenceError: 2016-01-02 02:25:01 error at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      ! ReferenceError: 2016-01-02 02:25:01 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:410:11)
      ! ReferenceError: 2016-01-02 02:25:01 error at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:139:10)
      ! ReferenceError: 2016-01-02 02:25:01 error at Job.job (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1197:34)
      ! ReferenceError: 2016-01-02 02:25:01 error at Object. (script.js.aws:214:8)
      ! ReferenceError: 2016-01-02 02:25:01 error at isTimeInRange (script.js.aws:487:17)
      ! ReferenceError: 2016-01-02 02:25:01 error addTime is not defined
      ! uncaught 2016-01-02 02:25:01 error exception: addTime is not defined
      • blauholstenB
        blauholstenB
        blauholsten
        @starfish:
        ! javascript.0 2016-01-02 02:15:00 error uncaught exception: addTime is not defined `
        So wie es aussieht hast du das globale script timeinrange nicht.
        Das musst du vorher anlegen, sonst geht es nicht.
        - Alarm Adapter
        • L
          L
          looxer01
          ich habe die Funktionen von Baetz jetzt dem Main-Program hinzugefuegt.
          Damit ist kein globales Script mehr notwendig.
          Ich werde spaeter noch den Link zu Baetz Beitrag hinzufuegen.
          Version ist jetzt 0.41
          habs aber noch nicht getestet :oops:
          vG Looxer
          • S
            S
            starfish
            danke, errors gibts keine mehr und im aws-log tut sich was. zu "baetz" schweigt sich das Forum und auch Google aus (zu TimeInRange ebenfalls).
            • L
              L
              looxer01
              Forumsmitglied Beatz
              http://forum.iobroker.com/viewtopic.php … a40#p11167
              vG
              • L
                L
                looxer01
                Beim Testen sind mir zwei unschöne Fehler aufgefallen
                1. Das letzte eingetragene Geraet wurde nie per Zufall gewaehlt.
                2. Ein Log Fehler "keine Aktion…." auch wenn geschaltet wurde
                Version 0.42 hochgeladen
                vG Looxer
                • L
                  L
                  looxer01
                  ich habe Version 0.43 hochgeladen mit ein paar Aenderungen am Code.
                  • Bereinigungen und Dokumentation
                  • Ausschalten der Geraete bei Deaktivierung der AWS
                  Folgendes ist noch zu tun
                  • Ausschalten der Geraete bei Deaktivierung der AWS optional machen oder einen intelligenteren Ansatz finden
                  • Wenn ein nicht existentes Geraet in den Einstellungen angegeben wird, dann startet der javascript adapter mal eben neu.
                  Das werde ich abstellen mit dem Ziel, dass nur ein Logeintrag erzeugt wird
                  Fuer die Zukunft.
                  Falls das Konzept ok ist wuerde ich die Einstellungen ggf als Profile erweitern. So koennte man z.B. fuer jeden Wochentag ein anderes Profil einstellen koennen ggf auch nach Jahreszeit unterscheiden.
                  vG Looxer
                  • P
                    P
                    pix
                    Hey,
                    super Arbeit! Leider habe ich den WAF der AWS nicht berücksichtigt. Unser Licht soll aus bleiben, wenn keiner da. Ich arbeitet dran 8-) :lol:
                    Dennoch interessiert mich dein Projekt.
                    Bei Durchsehen des Codes bin ich noch über diese Stelle gestolpert:
                    ! ` > // Einstellung teilnehmende Homematic Geräte je IDGruppe maximal 5 - Eingabe der Homematic ID
                    var IDGruppe11 = "hm-rpc.0.JEQ0xxxxxx.1.LEVEL"; // Licht Wohnzimmer Esstisch Deckenlampe
                    var IDGruppe12 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Terrassentuere
                    var IDGruppe13 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Wohnzimmer Esstisch Stehlampe
                    var IDGruppe14 = " ";
                    var IDGruppe15 = " ";
                    var Grp1ZufAnz = 3; // Anzahl der Geräte zur zufälligen Bestimmung des Geraetes
                    var IDGruppe21 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Schwimmbad Nebenlicht;
                    var IDGruppe22 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Kinderbad;
                    var IDGruppe23 = " ";
                    var IDGruppe24 = " ";
                    var IDGruppe25 = " ";
                    var Grp2ZufAnz = 2; // Anzahl der Geräte zur zufälligen Bestimmung des Geraetes
                    var IDGruppe31 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Flur oben Wand;
                    var IDGruppe32 = "hm-rpc.0.JEQ0xxxxxx.1.STATE"; // Licht Flur oben unten;
                    var IDGruppe33 = " ";
                    var IDGruppe34 = " ";
                    var IDGruppe35 = " ";
                    var Grp3ZufAnz = 2; // Anzahl der Geräte zur zufälligen Bestimmung des Geraetes
                    var IDGruppe41 = " ";
                    var IDGruppe42 = " ";
                    var IDGruppe43 = " ";
                    var IDGruppe44 = " ";
                    var IDGruppe45 = " ";
                    var Grp4ZufAnz = 5; // Anzahl der Geräte zur zufälligen Bestimmung des Geraetes
                    var IDGruppe51 = " ";
                    var IDGruppe52 = " ";
                    var IDGruppe53 = " ";
                    var IDGruppe54 = " ";
                    var IDGruppe55 = " ";
                    var Grp5ZufAnz = 5; // Anzahl der Geräte zur zufälligen Bestimmung des Geraetes `
                    Ist es richtig, dass ich als Anwender, die Zahl der Geräte ind er Gruppe zählen muss und zB in Grp2ZufAnz = 2 eintragen muss? Kann man da nicht mir einem Array arbeiten? Einfach die Geräte dort kommasepariert eintragen und vom Skript durchzählen lassen. So könnte auch die zufällige Auswahl des zu schaltenden Gerätes erleichtert werden. Du kannst pro Gruppe ein Array anlegen oder ein auch mehrdimensionales Array aus mehreren Gruppen, in denen wieder jeweils mehrere Geräte liegen.
                    Pix
                    • L
                      L
                      looxer01
                      Danke Pix fuer dein Feedback- - das freut mich wirklich….
                      @pix:
                      dLeider habe ich den WAF der AWS nicht berücksichtigt. Pix `
                      na ja, wenn es dann mal zum worst case kommt waere das sicher anders.
                      Ich kann ja mal eine Einbruchssimulation schreiben :lol:
                      @pix:
                      Ist es richtig, dass ich als Anwender, die Zahl der Geräte ind er Gruppe zählen muss und zB in Grp2ZufAnz = 2 eintragen muss? `
                      nein, so ist es nicht gemeint aber vielleicht der Normalfall. Man kann durchaus GrpZufAnz hoeher setzen als die Anzahl der Gruppenmitglieder.
                      Dann wird es weniger Einschaltaktionen geben was so gewuenscht sein kann. Das Zufallsprinzip entscheidet. Je höher die Zahl desto weniger wird geschaltet.
                      Auf Arrays habe ich bewusst verzichtet, da der Code dann nicht leichter lesbar wird und auch sonst keine Vorteile bringen wuerde. Auch die Einstellungen wuerden dann noch etwas komplizierter werden.
                      vG Looxer
                      • S
                        S
                        starfish
                        hallo Ralf, Du erinnerst dich sicher an meine Frage mit der Synchronizität. Ich hab jetzt rausgefunden, weshalb (zumindest bei mir) dieser Eindruck entsteht:
                        ! iobroker log
                        ! hm-rpc-0 2016-01-04 05:19:01 info setValue ["IEQ0074994:1","STATE",false] BOOL
                        ! hm-rpc-0 2016-01-04 05:05:59 info setValue ["IEQ0074994:1","STATE",true] BOOL
                        ! hm-rpc-0 2016-01-04 05:00:00 info setValue ["IEQ0074994:1","STATE",true] BOOL
                        ! javascript-0 2016-01-04 05:00:00 info script.js.aws: EVENT IDGruppe11; hm-rpc.0.IEQ0074994.1.STATE; undefined; 359; 1141; 05:05:59; 05:25:00;
                        ! AWSLog:
                        ! 04.01.2016 ;05:00:00 ;IDGruppe11;hm-rpc.0.IEQ0074994.1.STATE;undefined;359;1141;05:05:59;05:25:00;
                        es werden reproduzierbar 2 Einschaltbefehle abgesetzt: einer sofort, der 2. mit der Zufallsverzögerung. Bei der Ausschaltzeit wird die Zufallsverzögerung nicht hinzugezählt.
                        • L
                          L
                          looxer01
                          @starfish:
                          es werden reproduzierbar 2 Einschaltbefehle abgesetzt: einer sofort, der 2. mit der Zufallsverzögerung. Bei der Ausschaltzeit wird die Zufallsverzögerung nicht hinzugezählt. `
                          ich habe den Fehler gefunden und jetzt auch die Einschaltverzoegerung zur geplanten Ausschaltzeit hinzugefuert.
                          Vielen Dank fuer das Feedback, echt super.
                          Version 0.44
                          Koenntest du beides mit deinen Einstellungen nochmals testen und mir Bescheid geben ?
                          EDIT 09:33: es gibt noch ein Problem bei der Addition der Einschaltverzoegerung zur geplanten Ausschaltzeit.
                          Ich lade gleich nochmal eine neue Version hoch
                          EDIT 09:41: getestet und jetzt funktioniert es - Version 0.45
                          vG Looxer
                          • S
                            S
                            starfish
                            hab erst v. 0.44 - die scheint bez. Einschaltdelay richtig zu laufen, ausser vielleicht die Ausschaltzeit ist 1-2 Min zu früh - genaueres kann ich erst heute Nachmittag sagen bzw. die v. 0.45 laden.
                            • L
                              L
                              looxer01
                              warte noch auf eine neue Version. 0.46 lade ich ich in den nächsten 1 - 2 Stunden hoch
                              5278_neues_textdokument.txt
                              • L
                                L
                                looxer01
                                so, habe jetzt die Version 0.50 geladen.
                                Diese Version sollte bezueglich ein-ausschaltverzoegerung in sync laufen mit den realen Schaltungen.
                                Es kann mal eine Sekunde Differenz geben -
                                Ausserdem funktioniert jetzt der Check ob ein Geraet exisitiert. Das hat bisher zu einer uncaught exception gefuehrt, was
                                dann wiederum den javascript adapter veranlasst hat neu zu starten. Passiert jetzt nicht mehr z.B. wenn eine ID falsch eingegeben wurde.
                                Dafuer kommt jetzt ein interner Log-Eintrag hoch. Das Programm läuft weiter
                                Daher auch der Versionssprung.
                                vG Looxer
                                • S
                                  S
                                  starfish
                                  jetzt habe ich 2 Zyklen durch, die Zufalls- Ein- und Auszeiten scheinen jetzt zu stimmen. Super - Danke. Jetzt müsste Flot nur auch noch STATE Signale darstellen können. :x
                                  • L
                                    L
                                    looxer01
                                    nun ist Version 0.60 verfuegbar.
                                    • fix Astrozeit
                                    • Neue Funktion Astro1zeit bis - damit kann bis zur Morgendaemmerung geschaltet werden - analog der Astrozeit von
                                    • Das Ausschalten aller teilnehmenden Geraete bei Deaktivierung der AWS ist jetzt optional und laesst sich in den Einstellungen ein-ausschalten
                                    • Stabilitaetsverbesserungen
                                    Damit sind zunaechst alle geplanten Funktionen implementiert (und etwas mehr).
                                    Waere schoen, wenn noch etwas getestet wuerde. Diese Woche kann ich noch schnell reagieren auf Anfragen:)
                                    vG Looxer
                                    • L
                                      L
                                      looxer01
                                      Version 0.61
                                      • Bei der zufaelligen Bestimmung der Geraete wurde immer von cer Gruppe 1 Definition GrpZufAnz ausgegangen. Ist jetzt gefixt
                                      • Bei der Ausschaltung aller Teilnehmer wird jetzt zwischen zwei Ausschaltvorgängen 300 Millisekunden Zeit gelassen (Vermeidung von Funkchaos)
                                      • Codeoptimierungen
                                      vG Looxer
                                      • S
                                        S
                                        starfish
                                        vonAstro und bisAstro funktioniert hier jetzt. Nun gehts ans Optimieren. Ich denke, dass das Skript flexibel genug ist, um die meisten Wünsche zu befriedigen. Vielen Dank an looxer01.
                                        Gruss
                                        starfish
                                        • L
                                          L
                                          looxer01
                                          Version 0.65 ist jetzt online.
                                          • Die Reaktion auf bereits eingeschaltete Geraete ist jetzt durch eine Variable einstellbar gemacht - entweder keine Aktion oder uebesteuerung -
                                          Allerdings ist diese Variable noch nicht in den Einstellungen zu finden, sondern im Bereich darunter. u.U kann diese Einstellung auch ungewünschte
                                          Nebeneffekte haben - ist also zu testen
                                          • weitere Codeoptimierungen
                                          • Das AWS-Aktiv Flag ist jetzt ebenfalls variabel gemacht. Damit kann leichter eine andere Variable verwendet werden, z.B eine Variable aus der CCU
                                          Insgesamt ist das Script jetzt stabil. Weitere Fehler habe ich nicht gefunden.
                                          vG Looxer
                                          84.2k
