  5. [Gelöst]Bewegungsmelder Aqara Flurlicht steuern
    5.6k
49 Beiträge 4 Kommentatoren 6.1k Aufrufe 5 Beobachtet
    acem
    So siehr es bei mir aus.
    • A acem
      Jan1
      @acem
      beantwortet aber nicht meine Frage😉
      • J Jan1
        @acem
         <variables>
           <variable type="" id="b6C.}5i;irmub]HRd:F3">durch Bewegung aktiviert</variable>
           <variable type="undefined" id="timeout">timeout</variable>
         </variables>
         <block type="on" id="gh9^ZFXoO2V`xl}0(:32" x="-637" y="-662">
           <field name="OID">zigbee.0.00158d0002ea07ac.occupancy</field>
           <statement name="STATEMENT">
             <block type="controls_if" id="b1-mpyGFJCyUO0@KXDES">
               <value name="IF0">
                 <block type="logic_compare" id="i6,DcT*Fo),2#VckyV8s">
                   <field name="OP">LT</field>
                   <value name="A">
                     <block type="get_value" id="oq]9w#ZU2:v9lUe}LBaS">
                       <field name="OID">zigbee.0.00158d0002ea07ac.illuminance</field>
                     </block>
                   </value>
                   <value name="B">
                     <block type="math_number" id="N?+P},RB!X-%OS/!,m5i">
                       <field name="NUM">20</field>
                     </block>
                   </value>
                 </block>
               </value>
               <statement name="DO0">
                 <block type="control" id="=]3-?D2/rVEd+K=:mYw7">
                   <mutation delay_input="false"></mutation>
                   <field name="OID">sonoff.0.Sonoff-Flur_1.POWER</field>
                   <value name="VALUE">
                     <block type="logic_boolean" id="CUC6y~|6/(LK)@Q::yrW">
                     </block>
                   </value>
                   <next>
                     <block type="variables_set" id=";3gjqI.v=oXV-Xn;_Wv#">
                       <field name="VAR" id="b6C.}5i;irmub]HRd:F3" variabletype="">durch Bewegung aktiviert</field>
                         <block type="logic_boolean" id="gxsnpYVLC~LIp@,61Uy{">
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
             <block type="on" id="CE3nUa2,Td/5hbLxX@z=">
               <field name="OID">zigbee.0.00158d0002ea07ac.no_motion</field>
                 <block type="timeouts_cleartimeout" id="-t[sG.^RSc]4e7N6al_c">
                   <next>
                     <block type="timeouts_settimeout" id="otU|AoV+X~ngM49?pFDA">
                       <field name="DELAY">9</field>
                         <block type="controls_if" id="nJOmgtQ;vS7}*ZBlnQZ5">
                           <value name="IF0">
                             <block type="logic_operation" id="f^r|)cn|g`2/0%bN.W5P" inline="false">
                               <field name="OP">AND</field>
                               <value name="A">
                                 <block type="logic_compare" id="S/JnAFH=NEJIJ,Lc_lWD">
                                   <field name="OP">GT</field>
                                   <value name="A">
                                     <block type="on_source" id=":EOf@^5K?=/R!y6Um5,~">
                                     </block>
                                   </value>
                                   <value name="B">
                                     <block type="math_number" id="swf{T/Z9r$eXwK^q*];g">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="variables_get" id="q9_C8GOti4,cZ^]hZ$7q">
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="control" id=":u#0[0}`(^e7C:(HJ8Lz">
                                 <block type="logic_boolean" id=",XF`s(J3#U|;=)W`|HFf">
                                 </block>
                               </value>
                               <next>
                                 <block type="variables_set" id="o}(6GL7LHjalNsf^Ghmn">
                                     <block type="logic_boolean" id="n+f/xY2~o.7@RfTUEPw+">
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
        </xml>
        Den DP occupancy-timeout hab ich auf 10s, so läuft das bei mir recht gut.
        acem
        schrieb am zuletzt editiert von acem
        @Jan1 sagte in Bewegungsmelder Aqara Flurlicht steuern:
        @acem
         <variables>
         </variables>
               <value name="IF0">
                   <value name="A">
                     </block>
                   </value>
                   <value name="B">
                     </block>
                   </value>
                 </block>
               </value>
                     </block>
                   </value>
                   <next>
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </statement>
           <next>
                   <next>
                           <value name="IF0">
                               <value name="A">
                                   <value name="A">
                                     </block>
                                   </value>
                                   <value name="B">
                                     </block>
                                   </value>
                                 </block>
                               </value>
                               <value name="B">
                                 </block>
                               </value>
                             </block>
                           </value>
                                 </block>
                               </value>
                               <next>
                                     </block>
                                   </value>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </statement>
             </block>
           </next>
         </block>
        </xml>
        Ist der DP occupancy-timeout nicht der Wert den ich unten von 9 auf 10 geändert habe?, es war nämlich eine Zeit 9 sec Eingestellt, oder welcher Wert ist das jetzt? :)
        • A acem
          @acem
           <variables>
           </variables>
                 <value name="IF0">
                     <value name="A">
                       </block>
                     </value>
                     <value name="B">
                       </block>
                     </value>
                   </block>
                 </value>
                       </block>
                     </value>
                     <next>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </statement>
             <next>
                     <next>
                             <value name="IF0">
                                 <value name="A">
                                     <value name="A">
                                       </block>
                                     </value>
                                     <value name="B">
                                       </block>
                                     </value>
                                   </block>
                                 </value>
                                 <value name="B">
                                   </block>
                                 </value>
                               </block>
                             </value>
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </statement>
               </block>
             </next>
           </block>
          </xml>
          Jan1
          @acem
          Nein, und genau auf die Änderung wird getriggert. Wird da nichts eingetragen, läuft das Script nicht.
          Schau Dir einfach an was bei den DPs passiert wenn was drin steht und wenn nicht, dann verstehst gleich wieso und warum.
          • J Jan1
            @acem
            acem
            @acem
            Bitte sei mir nicht böse aber kannst du mir Bitte erklären was ein DP ist :) und wo soll ich jetzt genau schauen ob sich was ändert oder nicht, ich bin halt keine Profi
            • A acem
              @acem
              Jan1
              @acem
              Daten Punkt im IOBroker unter Objekten.
                acem
                Datenpunkt bei mir im IoBroker.
                • A acem
                  Jan1
                  @acem
                  ja und kein 10s eingetragen
                  • J Jan1
                    @acem
                    acem
                    @acem
                    Wo trage ich die 10s ein?
                    • A acem
                      @acem
                      Jan1
                      @acem
                      Kennst das Spiel "finde den Fehler". Du hast 2 Bilder und einen Unterschied, bisschen Hirn einschalten schadet nicht und hilft beim verstehen ungemein, wenn man selber drauf kommt.
                      • J Jan1
                        @acem
                        acem
                        @acem
                        Ja kenne ich :) 👍
                        Danke.
                        • A acem
                          @acem
                          Ja kenne ich :) 👍
                          Danke.
                          Jan1
                          @acem
                          wenn da nix drin steht, dann geht der DP "occupancy" nicht mehr auf "false" zurück und das Script funktioniert nicht mehr.
                          Die BWM sind eh nicht so besonders, aber eben günstig und haben so ein paar blöde Eigenarten. Eine erneute Bewegung wird immer erst nach 10 Sekunden erkannt, desahalb habe ich auch den 9s Timeout im Script um das auf 1s zu reduzieren. Heißt wenn das Licht mal ausgeht, obwohl man sich im Erkennungsbereich befindet, muss man nur 1s warten, bis das licht wieder mit Bewegung an schaltet.
                          Bewegung muss dann auch noch recht deutlich ausfallen, damit wiederholte Bewegung erkannt wird. Beim ersten Einschalten reicht schon recht wenig. So sind meine Erfahrungen mit den Dingern und das Script ist eben genau auf das angepasst und läuft recht annehmbar.
                          • J Jan1
                            @acem
                            acem
                            @Jan1
                            Ich habe mich vorhin schon gefragt nachdem das Licht ausgegangen ist warum es sich bei Bewegung nicht wieder einschaltet, jetzt habe ich es wieder auf 9sec Eingestellt, Licht bleibt trotzdem aus und geht jetzt nicht mehr an.
                            • A acem
                              @Jan1
                              Jan1
                              @acem
                              Schau das Script an und Deine DPs, dann siehst warum. Tip, es macht genau was es soll😎
                              • J Jan1
                                @acem
                                acem
                                @acem
                                Habe nichts festgestellt, manchmal sieht man vor lauter Bäume den Wald nicht, Licht geht nicht an :)
                                • A acem
                                  @acem
                                  Jan1
                                  @acem
                                  Welche DPs sind den für das Script relevant und wie sind da die Werte und die die abgefragt werden?
                                  • J Jan1
                                    @acem
                                    acem
                                    @Jan1
                                    das was ich im DP unter IoBroker eingetragen habe nämlich die 10sec und die 20sec im Script
                                    • A acem
                                      @Jan1
                                      Jan1
                                      @acem
                                      Nö
                                      Noch ein Tip, hat mit der Zeit nix zu tun.
                                      • J Jan1
                                        @acem
                                        Nö
                                        acem
                                        @Jan1
                                        Machen wir jetzt ein Rate Spiel oder was? :)
                                        Ich bin halt nicht ganz fit in der Materie spann mich Bitte nicht auf die Folter :)
                                        • A acem
                                          @Jan1
                                          Jan1
                                          @acem
                                          Nein, aber wie ich oben schon geschrieben habe, was man selber rausfindet bringt einem wesentlich weiter wie das was man vorgekaut bekommt und viel bleibt nun nicht mehr übrig😉
