  2. Русский
  3. ioBroker
  4. ioBroker установка и конфигурация
  5. Инсталляция под Linux
Geplant Angeheftet Gesperrt Verschoben ioBroker установка и конфигурация
256 Beiträge 29 Kommentatoren 134.8k Aufrufe
  • aurodionovA
    aurodionovA
    aurodionov
    #136
    Вобщем встал криво, по моему что-то не то с кодировкой
    root@SmartHome:/opt/iobroker# npm install iobroker
    npm ERR! not a package /tmp/npm-1594-psWTuwUR/1446747427997-0.4993789638392627/tmp.tgz
    iobroker@0.5.6 install /opt/iobroker/node_modules/iobroker
    node lib/setup.js
    ! npm install iobroker.js-controller --production --prefix /opt/iobroker
    npm WARN engine hawk@3.1.0: wanted: {"node":">=0.10.32"} (current: {"node":"0.10.29","npm":"1.4.21"})
    npm WARN engine cryptiles@2.0.5: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
    npm WARN engine hoek@2.16.3: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
    npm WARN engine boom@2.10.1: wanted: {"node":">=0.10.40"} (current: {"node":"0.10.29","npm":"1.4.21"})
    In file included from ../src/validation.cc:15:0:
    ../node_modules/nan/nan.h:328:47: error: ‘REPLACE_INVALID_UTF8’ is not a member of ‘v8::String’
    static const unsigned kReplaceInvalidUtf8 = v8::String::REPLACE_INVALID_UTF8;
    make: *** [Release/obj.target/validation/src/validation.o] Ошибка 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:267:23)
    gyp ERR! stack at ChildProcess.emit (events.js:98:17)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:809:12)
    gyp ERR! System Linux 3.16.0-4-686-pae
    gyp ERR! command "nodejs" "/usr/bin/node-gyp" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
    gyp ERR! node -v v0.10.29
    gyp ERR! node-gyp -v v0.12.2
    gyp ERR! not ok
    npm WARN This failure might be due to the use of legacy binary "node"
    npm WARN For further explanations, please read
    /usr/share/doc/nodejs/README.Debian
    In file included from ../src/bufferutil.cc:16:0:
    make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Ошибка 1
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
    gyp ERR! not ok
    npm WARN optional dep failed, continuing utf-8-validate@1.2.1
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
    gyp ERR! not ok
    npm WARN optional dep failed, continuing bufferutil@1.2.1
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
    gyp ERR! not ok
    npm install iobroker.admin --production --prefix /opt/iobroker
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/utf-8-validate
    gyp ERR! not ok
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/node_modules/bufferutil
    gyp ERR! not ok
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/utf-8-validate
    gyp ERR! not ok
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/node_modules/bufferutil
    gyp ERR! not ok
    Write "./iobroker start" to start the ioBroker
    Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    iobroker@0.5.6 node_modules/iobroker
    └── yargs@1.2.6 (minimist@0.1.0)
    root@SmartHome:/opt/iobroker# node -v
    v0.10.29
    Копаю дальше, натянул виз, не открывается
    Пишу с пульта….
    • H
      H
      Haus
      #137
      Привет всем
      Вчера мучался пол дня с установкой Iobroker на Debian, сначала думал может какие проблемы с 8.2 (кстати nodejs есть в репозитариях) накатил 7.9 та же фигня ошибок и варнингов при установке кучи. Перечитал все способы установки и вуаля.
      Debian 8.2 чистый под "root"
      apt-get update
      apt-get upgrade
      apt-get install curl
      apt-get install build-essential
      curl -sL https://deb.nodesource.com/setup | bash -
      apt-get install nodejs
      mkdir /opt/iobroker
      chmod 777 /opt/iobroker
      cd /opt/iobroker
      Проблемы с nodejs и npm в репозитах они старые и с кодировкой чего то не то если кому пригодится отпешитесь о результатах
      Вопрос к Bluefox не приходят обновления драйверов всё остальное как часы?
      ! root@Server1:~# cd /opt/iobroker
      ! root@Server1:/opt/iobroker# iobroker update
      ! update done
      ! Adapter "zwave" : 0.2.3
      ! Adapter "yr" : 0.1.9 , installed 0.1.9
      ! Adapter "wolf" : 0.0.9
      ! Adapter "web" : 1.2.1 , installed 1.2.1
      ! Adapter "vis-timeandweather": 0.0.2 , installed 0.0.2
      ! Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
      ! Adapter "vis-plumb" : 0.1.6
      ! Adapter "vis-metro" : 0.1.9
      ! Adapter "vis-lcars" : 0.1.6
      ! Adapter "vis-keyboard" : 0.0.2
      ! Adapter "vis-jqui-mfd" : 0.1.0
      ! Adapter "vis-hqwidgets" : 0.2.2 , installed 0.2.2
      ! Adapter "vis-google-fonts": 0.1.0
      ! Adapter "vis-fancyswitch": 0.1.0
      ! Adapter "vis-colorpicker": 0.1.1
      ! Adapter "vis-bars" : 0.1.1
      ! Adapter "vis" : 0.7.7 , installed 0.7.7
      ! Adapter "terminal" : 0.1.2
      ! Adapter "sonos" : 0.1.7
      ! Adapter "rickshaw" : 0.2.2 , installed 0.2.2
      ! Adapter "pushover" : 0.1.1
      ! Adapter "pushbullet" : 0.0.11
      ! Adapter "owfs" : 0.0.2 , installed 0.0.2
      ! Adapter "onkyo" : 0.1.9
      ! Adapter "socketio" : 1.0.0
      ! Adapter "simple-api" : 1.0.0
      ! Adapter "scenes" : 0.2.2
      ! Adapter "sayit" : 0.3.15 , installed 0.3.15
      ! Adapter "s7" : 0.2.4
      ! Adapter "ping" : 0.1.4
      ! Adapter "node-red" : 0.3.5
      ! Adapter "mqtt" : 0.2.15
      ! Adapter "modbus" : 0.3.9
      ! Adapter "mobile" : 0.0.5
      ! Adapter "megad" : 1.0.6 , installed 1.0.6
      ! Adapter "knx" : 0.2.10
      ! Controller "js-controller" : 0.7.15 , installed 0.7.15
      ! Adapter "javascript" : 1.0.7 , installed 1.0.7
      ! Adapter "icons-ultimate-png": 0.1.0
      ! Adapter "icons-open-icon-library-png": 0.1.1
      ! Adapter "icons-mfd-svg" : 0.1.2
      ! Adapter "icons-mfd-png" : 0.1.2
      ! Adapter "icons-material-svg": 0.1.0
      ! Adapter "icons-material-png": 0.1.0
      ! Adapter "icons-addictive-flavour-png": 0.1.0
      ! Adapter "ical" : 1.1.1 , installed 1.1.1
      ! Adapter "hmm" : 1.0.0
      ! Adapter "hue" : 0.5.1
      ! Adapter "hm-rpc" : 0.5.2
      ! Adapter "hm-rega" : 0.2.2
      ! Adapter "history" : 0.1.3 , installed 0.1.3
      ! Adapter "harmony" : 0.5.4
      ! Adapter "example" : 0.1.1 , installed 0.1.1
      ! Adapter "fritzbox" : 0.2.1
      ! Adapter "flot" : 0.1.1 , installed 0.1.1
      ! Adapter "email" : 0.1.2
      ! Adapter "dwd" : 1.0.1
      ! Adapter "cul" : 0.0.4
      ! Adapter "b-control-em" : 0.1.1
      ! Adapter "artnet" : 0.0.3
      ! Adapter "admin" : 0.6.6 , installed 0.6.6
      js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
      admin: 3.6.0
      javascript: 4.1.10
      web: 2.4.1 vis: 1.1.10
      cloud: 2.6.2
      Server: DELL FX170 / linux: Debian 9.5 Stretch
      Adapter: MegaD-2561, Mega-ES…
      • H
        H
        Haus
        #138
        @Haus:
        Привет всем
        apt-get update
        apt-get upgrade
        mkdir /opt/iobroker
        cd /opt/iobroker
        ! update done
        ! Adapter "admin" : 0.6.6 , installed 0.6.6 `
        Сам себе и отвечу
        Нет обновлений.
        На гите рабочие версии, которые ни в коем случае нельзя устанавливать, если не знаешь javascript.
        Процесс разработки следующий. Я сначала заливаю версию на гит (она может быть и не рабочей). Потом прошу пользователей, кто не боится трудностей и способен определить проблемы установить эти версии специальной командой.
        Если у них бежит, то я заливаю версию на npm и вот оттуда она доступна всем.
        Почему у тебя показываются версии с гита надо ещё выяснить.
        Рабочую версию, кстати, можно посмотреть здесь http://iobroker.net:8081 и http://iobroker.net:8082/vis/edit.html
        admin: 3.6.0
        javascript: 4.1.10
        cloud: 2.6.2
        • E
          E
          electric69
          #139
          Пытаюсь установить iobroker на bananapi образ http://www.armbian.com/banana-pi/.
          NodeJS и NPM https://github.com/nodejs/node-v0.x-archive/wiki/Installing-Node.js-via-package-manager#debian-and-ubuntu-based-linux-distributions без проблем:
          root@bananapi:/# nodejs -v
          v5.1.1
          root@bananapi:/# npm -v
          3.3.12
          root@bananapi:/#
          Затем:
          $ cd /opt
          $ mkdir iobroker
          $ cd iobroker
          $ sudo npm install iobroker
          Ошибка:
          • BluefoxB
            #140
            • E
              E
              electric69
              #141
              @Bluefox:
              sudo npm install iobroker `
              Тоже самое.
              Даже пробовал:
              root@bananapi:/opt/iobroker# ln -s /usr/bin/nodejs /usr/bin/node
              ln: failed to create symbolic link ‘/usr/bin/node’: File exists
              Говорит ссылка уже есть…
              Я так понимаю, что нет прав на запись?
              Хотя директорию node_modules и вложенные в нее создает...
              • BluefoxB
                #142
                А если
                sudo npm install iobroker --unsafe-perm
                • E
                  E
                  electric69
                  #143
                  @Bluefox:
                  А если
                  Вроде прокатило))
                  Устанавливаю драйвера…
                  • D
                    D
                    DAndre
                    #144
                    Здравствуйте.
                    CouchDB и Redis ставить?
                    <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
                    Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
                    • BluefoxB
                      #145
                      Нет.
                      Но можешь поставить influxdb, если знаешь как.
                      • D
                        D
                        DAndre
                        #146
                        Как пишут умные люди–-
                        для 64-битных систем
                        $ wget http://s3.amazonaws.com/influxdb/influx ... _amd64.deb
                        $ sudo dpkg -i influxdb_latest_amd64.deb
                        для 32-битных систем
                        $ wget http://s3.amazonaws.com/influxdb/influx ... t_i386.deb
                        $ sudo dpkg -i influxdb_latest_i386.deb
                        По завершении установки запустим InfluxDB:
                        $ sudo /etc/init.d/influxdb start
                        • D
                          D
                          DAndre
                          #147
                          Веселье в разгаре 😢
                          Last login: Sun Dec 20 18:44:57 2015 from homexp
                          xbmc@xbmc-desktop:~$ cd /opt/iobroker
                          xbmc@xbmc-desktop:/opt/iobroker$ sudo npm install iobroker
                          [sudo] password for xbmc:
                          npm http GET https://registry.npmjs.org/iobroker
                          npm http 304 https://registry.npmjs.org/iobroker
                          npm http GET https://registry.npmjs.org/yargs
                          npm http 304 https://registry.npmjs.org/yargs
                          npm http GET https://registry.npmjs.org/minimist
                          npm http 304 https://registry.npmjs.org/minimist
                          node lib/setup.js
                          sh: 1: node: not found
                          npm ERR! weird error 127
                          npm ERR! not ok code 0
                          куда податся. sudo npm install iobroker –unsafe-perm тоже не катит :(
                          • BluefoxB
                            #148
                            Команду node не находит.
                            Напиши
                            • D
                              D
                              DAndre
                              #149
                              @Bluefox:
                              Напиши
                              Есть. пошло. полетело ….......надолго ли
                              Спасиб. Пропишите для чайников.
                              ps Везде враги кругом засады :D sudo unit 6
                              • D
                                D
                                DAndre
                                #150
                                Системные настройки ==> репозитории
                                стер случайно.
                                Что туда вписать?
                                • BluefoxB
                                  #151
                                  @DAndre:
                                  стер случайно.
                                  Что туда вписать? `
                                  default  | conf/sources-dist.json
                                  online   | https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
                                  • K
                                    K
                                    kID
                                    #152
                                    @ford7:
                                    @ford7:
                                    Подскажите, как починить?
                                    вкладка "драйвера" пустая.
                                    upd:
                                    вкладка "сервера" тоже пустая.
                                    А в настройках все штатно: Вот при ****каждой**** попытке обновления js-controller происходит такая штука. Приходится заново руками js-controller устанавливать. Может у меня чего-то не так установилось изначально или строки какой-нить не хватает?
                                    Постигла та же самая печалька что и у ford7
                                    Только кроме описанного им на вкладке драйвера висит серая надпись "обновление", перестает обновляться Log. т.е вначале сообщения идут, а затем исчезают и чистое окно. При ребуте машины в окошко лога высыпается несколько строк.
                                    У меня лечится путем sudo iobroker restart, дальше все загружается и работает без глюков.
                                    sudo chmod 777 /opt/iobroker делал не помогает.
                                    По логу ни каких косяков не заметил.
                                    Удалил все драйвера кроме admina все так же.
                                    ! 2015-12-21 19:21:09.067 - info: host.debian-srv iobroker.js-controller version 0.8.2 js-controller starting
                                    ! 2015-12-21 19:21:09.072 - info: host.debian-srv Copyright © 2014-2015 bluefox, hobbyquaker
                                    ! 2015-12-21 19:21:09.073 - info: host.debian-srv hostname: debian-srv
                                    ! 2015-12-21 19:21:09.073 - info: host.debian-srv ip addresses:
                                    ! 2015-12-21 19:21:09.096 - info: inMem-states listening on port 9000
                                    ! 2015-12-21 19:21:09.122 - info: inMem-objects listening on port 9001
                                    ! 2015-12-21 19:21:09.129 - info: host.debian-srv InMemoryDB connected
                                    ! 2015-12-21 19:21:09.136 - info: host.debian-srv 1 instance found
                                    ! 2015-12-21 19:21:09.137 - info: host.debian-srv starting 1 instance
                                    ! 2015-12-21 19:21:09.156 - info: host.debian-srv instance system.adapter.admin.0 started with pid 935
                                    ! 2015-12-21 19:21:11.834 - info: admin.0 starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.admin
                                    ! 2015-12-21 19:21:11.916 - info: admin.0 requesting all states
                                    ! 2015-12-21 19:21:11.919 - info: admin.0 requesting all objects
                                    ! 2015-12-21 19:21:11.920 - info: admin.0 Request actual repository...
                                    ! 2015-12-21 19:21:11.924 - info: admin.0 http server listening on port 8081
                                    ! 2015-12-21 19:21:11.924 - info: admin.0 Use link "http://localhost:8081" to configure.
                                    ! 2015-12-21 19:21:12.146 - info: admin.0 received all states
                                    ! 2015-12-21 19:21:12.229 - info: admin.0 received all objects
                                    ! 2015-12-21 19:21:12.285 - info: host.debian-srv Update repository "default" under "conf/sources-dist.json"
                                    ! 2015-12-21 19:21:19.490 - info: admin.0 Repository received successfully.
                                    ! Все молчок :(
                                    ! sudo iobroker restart
                                    ! 2015-12-21 19:25:14.578 - info: host.debian-srv received SIGTERM
                                    ! 2015-12-21 19:25:14.579 - info: host.debian-srv stopInstance system.adapter.admin.0
                                    ! 2015-12-21 19:25:14.579 - info: host.debian-srv stopInstance system.adapter.admin.0 killing pid 935
                                    ! 2015-12-21 19:25:14.584 - info: admin.0 terminating http server on port 8081
                                    ! 2015-12-21 19:25:14.618 - info: admin.0 terminating
                                    ! 2015-12-21 19:25:14.646 - info: host.debian-srv instance system.adapter.admin.0 terminated with code 0 (OK)
                                    ! 2015-12-21 19:25:14.788 - info: host.debian-srv terminated
                                    ! 2015-12-21 19:25:15.590 - info: host.debian-srv received SIGTERM
                                    ! 2015-12-21 19:25:15.591 - info: host.debian-srv stopInstance system.adapter.admin.0
                                    ! 2015-12-21 19:25:15.591 - warn: host.debian-srv stopInstance system.adapter.admin.0 not running
                                    ! 2015-12-21 19:25:15.604 - info: host.debian-srv terminated
                                    ! 2015-12-21 19:25:17.376 - info: host.debian-srv iobroker.js-controller version 0.8.2 js-controller starting
                                    ! 2015-12-21 19:25:17.381 - info: host.debian-srv Copyright © 2014-2015 bluefox, hobbyquaker
                                    ! 2015-12-21 19:25:17.381 - info: host.debian-srv hostname: debian-srv
                                    ! 2015-12-21 19:25:17.381 - info: host.debian-srv ip addresses: 192.168.88.33 fe80::d250:99ff:fe76:6bdd
                                    ! 2015-12-21 19:25:17.396 - info: inMem-states listening on port 9000
                                    ! 2015-12-21 19:25:17.415 - info: inMem-objects listening on port 9001
                                    ! 2015-12-21 19:25:17.420 - info: host.debian-srv InMemoryDB connected
                                    ! 2015-12-21 19:25:17.425 - info: host.debian-srv 1 instance found
                                    ! 2015-12-21 19:25:17.426 - info: host.debian-srv starting 1 instance
                                    ! 2015-12-21 19:25:17.449 - info: host.debian-srv instance system.adapter.admin.0 started with pid 1061
                                    ! 2015-12-21 19:25:19.231 - info: admin.0 starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.admin
                                    ! 2015-12-21 19:25:19.292 - info: admin.0 requesting all states
                                    ! 2015-12-21 19:25:19.296 - info: admin.0 requesting all objects
                                    ! 2015-12-21 19:25:19.298 - info: admin.0 Request actual repository...
                                    ! 2015-12-21 19:25:19.300 - info: admin.0 http server listening on port 8081
                                    ! 2015-12-21 19:25:19.300 - info: admin.0 Use link "http://localhost:8081" to configure.
                                    ! 2015-12-21 19:25:19.485 - info: admin.0 received all objects
                                    ! 2015-12-21 19:25:19.497 - info: admin.0 received all states
                                    ! 2015-12-21 19:25:19.543 - info: host.debian-srv Update repository "default" under "conf/sources-dist.json"
                                    ! 2015-12-21 19:25:28.392 - info: admin.0 Repository received successfully.
                                    ! А тут все работает
                                    До того как прибил все драйвера в логе некоторые стартовали
                                    ! 2015-12-21 18:52:24.992 - info: host.debian-srv iobroker.js-controller version 0.8.2 js-controller starting
                                    ! 2015-12-21 18:52:24.997 - info: host.debian-srv Copyright © 2014-2015 bluefox, hobbyquaker
                                    ! 2015-12-21 18:52:24.998 - info: host.debian-srv hostname: debian-srv
                                    ! 2015-12-21 18:52:24.998 - info: host.debian-srv ip addresses:
                                    ! 2015-12-21 18:52:25.020 - info: inMem-states listening on port 9000
                                    ! 2015-12-21 18:52:25.045 - info: inMem-objects listening on port 9001
                                    ! 2015-12-21 18:52:25.049 - info: host.debian-srv InMemoryDB connected
                                    ! 2015-12-21 18:52:25.055 - info: host.debian-srv 5 instances found
                                    ! 2015-12-21 18:52:25.056 - info: host.debian-srv starting 4 instances
                                    ! 2015-12-21 18:52:25.072 - info: host.debian-srv instance system.adapter.admin.0 started with pid 931
                                    ! 2015-12-21 18:52:27.954 - info: admin.0 starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.admin
                                    ! 2015-12-21 18:52:28.032 - info: admin.0 requesting all states
                                    ! 2015-12-21 18:52:28.035 - info: admin.0 requesting all objects
                                    ! 2015-12-21 18:52:28.037 - info: admin.0 Request actual repository...
                                    ! 2015-12-21 18:52:28.040 - info: admin.0 http server listening on port 8081
                                    ! 2015-12-21 18:52:28.041 - info: admin.0 Use link "http://localhost:8081" to configure.
                                    ! 2015-12-21 18:52:28.331 - info: admin.0 received all states
                                    ! 2015-12-21 18:52:28.455 - info: admin.0 received all objects
                                    ! 2015-12-21 18:52:28.515 - info: host.debian-srv Update repository "default" under "conf/sources-dist.json"
                                    ! 2015-12-21 18:52:29.543 - info: host.debian-srv instance system.adapter.megad.0 started with pid 1017
                                    ! 2015-12-21 18:52:30.595 - info: megad.0 starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.megad
                                    ! 2015-12-21 18:52:30.731 - warn: megad.0 port 80 already in use
                                    ! 2015-12-21 18:52:33.618 - info: host.debian-srv instance system.adapter.web.0 started with pid 1023
                                    ! 2015-12-21 18:52:34.939 - info: web.0 starting. Version 1.3.3 in /opt/iobroker/node_modules/iobroker.web
                                    ! 2015-12-21 18:52:35.740 - info: web.0 socket.io server listening on port 8082
                                    ! 2015-12-21 18:52:35.746 - info: web.0 http server listening on port 8082
                                    ! 2015-12-21 18:52:36.435 - info: admin.0 Repository received successfully.
                                    ! 2015-12-21 18:52:38.036 - info: vis.0 starting. Version 0.7.9 in /opt/iobroker/node_modules/iobroker.vis
                                    ! 2015-12-21 18:52:39.321 - info: host.debian-srv instance system.adapter.vis.0 terminated while should be started once
                                    ! 2015-12-21 19:15:42.566 - info: host.debian-srv received SIGTERM
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.admin.0
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.admin.0 killing pid 931
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.megad.0
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.megad.0 killing pid 1017
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.web.0
                                    ! 2015-12-21 19:15:42.568 - info: host.debian-srv stopInstance system.adapter.web.0 killing pid 1023
                                    ! 2015-12-21 19:15:42.569 - info: host.debian-srv stopInstance system.adapter.vis.0
                                    ! 2015-12-21 19:15:42.569 - info: host.debian-srv stopInstance system.adapter.javascript.0
                                    ! 2015-12-21 19:15:42.569 - warn: host.debian-srv stopInstance system.adapter.javascript.0 not running
                                    ! 2015-12-21 19:15:42.572 - info: web.0 terminating http server on port 8082
                                    ! 2015-12-21 19:15:42.573 - info: web.0 terminated http server on port 8082
                                    ! 2015-12-21 19:15:42.569 - info: admin.0 terminating http server on port 8081
                                    ! 2015-12-21 19:15:42.600 - info: web.0 terminating
                                    ! 2015-12-21 19:15:42.613 - info: host.debian-srv instance system.adapter.web.0 terminated with code 0 (OK)
                                    ! 2015-12-21 19:15:42.626 - info: admin.0 terminating
                                    ! 2015-12-21 19:15:42.638 - info: host.debian-srv instance system.adapter.admin.0 terminated with code 0 (OK)
                                    ! 2015-12-21 19:15:42.787 - info: host.debian-srv terminated
                                    ! 2015-12-21 19:15:43.570 - info: host.debian-srv received SIGTERM
                                    ! 2015-12-21 19:15:43.571 - info: host.debian-srv stopInstance system.adapter.admin.0
                                    ! 2015-12-21 19:15:43.571 - warn: host.debian-srv stopInstance system.adapter.admin.0 not running
                                    ! 2015-12-21 19:15:43.572 - info: host.debian-srv stopInstance system.adapter.megad.0
                                    ! 2015-12-21 19:15:43.572 - warn: host.debian-srv stopInstance system.adapter.megad.0 not running
                                    ! 2015-12-21 19:15:43.574 - info: host.debian-srv stopInstance system.adapter.web.0
                                    ! 2015-12-21 19:15:43.574 - warn: host.debian-srv stopInstance system.adapter.web.0 not running
                                    ! 2015-12-21 19:15:43.574 - info: host.debian-srv stopInstance system.adapter.vis.0
                                    ! 2015-12-21 19:15:43.575 - info: host.debian-srv stopInstance system.adapter.javascript.0
                                    ! 2015-12-21 19:15:43.576 - warn: host.debian-srv stopInstance system.adapter.javascript.0 not running
                                    ! 2015-12-21 19:15:43.583 - info: host.debian-srv terminated
                                    2995_meross_log.txt
                                    • K
                                      K
                                      kID
                                      #153
                                      @kID:
                                      @ford7:
                                      upd:
                                      А в настройках все штатно: `
                                      Только кроме описанного им на вкладке драйвера висит серая надпись "обновление", перестает обновляться Log. т.е вначале сообщения идут, а затем исчезают и чистое окно. При ребуте машины в окошко лога высыпается несколько строк. `
                                      Получилось немного продвинуться в поисках истины :)
                                      Т.е победил этот глюк ? А дальше буду монгословным, потому как результат есть, а его объяснения нет.
                                      ! На чистую машину установил Debian 8.2 (jessie) графика KDE
                                      ! дальше по рецепту из wiki
                                      sudo apt-get update
                                      sudo apt-get install nodejs
                                      sudo apt-get install npm
                                      cd /opt
                                      mkdir iobroker
                                      cd iobroker
                                      sudo unit 6
                                      Получил как и многие вагон ошибок, хотя брокер установился и даже как то ворочался. Судя по логам не устраивала версия node.js
                                      ! удалил брокер
                                      ! sudo npm remove iobroker
                                      ! а дальше как подсказал Haus или написано https://github.com/nodejs/node-v0.x-arc … ge-manager
                                      apt-get update
                                      apt-get upgrade
                                      mkdir /opt/iobroker
                                      cd /opt/iobroker
                                      дальше обновил npm как он предлагал при старте.
                                      ! Без ошибок установил необходимые мне драйвера и перезагрузился.
                                      ! ВСЕ дальше вкладка "драйвера" пустая. вкладка "сервера" тоже пустая.
                                      ! Естественно подумал что, что-то накосячил при установке, поэтому попробовал различные варианты удаления всех компонентов, постепенно увеличивающийся глубины. Не помогло. Но пришел вопрос - как правильно удалить iobroker ???
                                      ! пробовал sudo rm -rf /opt/iobroker и sudo npm remove iobroker
                                      ! под конец брокер вообще отказался устанавливаться ругаясь на что то js
                                      ! помогло только
                                      ! sudo npm install iobroker –unsafe-perm
                                      ! После опытным путем дошел до iobroker restart после которого до перезагрузки все работает.
                                      ! А теперь по причине праздников решил все таки добить брокера или от безисходности все переустанвить
                                      К чему пришел:
                                      у меня в etc\network\interfaces
                                      source /etc/network/interfaces.d/*
                                      # The loopback network interface
                                      auto lo
                                      iface lo inet loopback
                                      вроде все правильно, как в книжках написано, дальше network-manager из KDE добавляет все необходимые интерфейсы настроенные
                                      в графической оболочке. И действительно появляется интернет, доступ к компьютеру извне.
                                      Но как только я привел
                                      interfaces к виду
                                      auto lo eth0
                                      allow-hotplug eth0
                                      iface eth0 inet dhcp
                                      на вкладке драйвера и сервера появилось содержимое.
                                      Почему так, объяснить не могу, вероятно брокер стартовал до того как KDE полностью настроит сеть, но по логам подтверждения этого не получил.
                                      • H
                                        H
                                        Haus
                                        #154
                                        kID страницей назад я описывал свой метод, попробуй всё ставится без единого warn и летает как пуля. До этого тоже вики, и куча разных методов.
                                        Я делал inet static
                                        # This file describes the network interfaces available on your system
                                        # and how to activate them. For more information, see interfaces(5).
                                        auto lo
                                        # The primary network interface
                                        iface eth0 inet static
                                        address 192.168.1.11
                                        netmask 255.255.255.0
                                        gateway 192.168.1.254
                                        auto eth0
                                        Тут моя шпаргалка :)
                                        ! //STATIC IP АДРЕС
                                        ! //и так заходим на наш сервер под рутом и отредактируем файл interfaces
                                        ! nano /etc/network/interfaces
                                        ! //Находим строку
                                        ! # The primary network interface
                                        ! и все что ниже удаляем, и в место удаленного пишем следующие:
                                        ! iface eth0 inet static
                                        ! address 192.168.1.10
                                        ! netmask 255.255.255.0
                                        ! gateway 192.168.1.254
                                        ! auto eth0
                                        ! Где:
                                        ! iface eth0 inet static - указывает, что интерфейс (iface eth0) находится в диапазоне адресов IPv4 (inet) со статическим ip (static);
                                        ! address 192.168.1.10 - указывает IP адрес для нашей сетевой карты
                                        ! netmask 255.255.255.0 - указывает маску сети
                                        ! gateway 192.168.1.254 - адрес шлюза (gateway), пишем адрес нашего роутера.
                                        ! auto eth0 - указывет системе что интерфейс eth0 необходимо включать автоматически при загрузке системы с вышеуказанными параметрами.
                                        ! //Теперь укажем DNS сервера
                                        ! nano /etc/resolv.conf
                                        ! в самый конце дописываем
                                        ! nameserver 192.168.1.254
                                        ! 192.168.1.254 - IP адрес роутера.
                                        ! //Так же можно добавить еще несколько DNS серверов, если те DNS сервера которые прописаны на роутере окажутся не рабочими.
                                        ! nameserver 8.8.8.8
                                        ! nameserver 8.8.4.4
                                        ! Это публичные DNS сервера Google
                                        ! reboot
                                        admin: 3.6.0
                                        javascript: 4.1.10
                                        cloud: 2.6.2
                                        • K
                                          K
                                          kID
                                          #155
                                          @Haus:
                                          kID страницей назад я описывал свой метод, попробуй всё ставится без единого warn и летает как пуля. До этого тоже вики, и куча разных методов. `
                                          Спасибо Haus, я вашим методом тоже пользовался.
                                          Но проблема у меня была другая, и хотя абсолютно весь другой сетевой софт работал под настройкой из графического шела, iobroker.admin отказывался показывать вкладку драйвер, лог и сервер. А как только описал eth0 в interfaces сразу все появилось. Я потом еще раз проверил :lol:
                                          Думаю BlueFox может пролить свет на эту особенность
                                          84.2k
