  4. Zigbee Adapter lässt sich nicht installieren.
zigbee adapter cc2531
5 Beiträge 3 Kommentatoren 520 Aufrufe 3 Beobachtet
  • R Offline
    RASS
    Ich versuche verzweifelt den Zigbee Adapter zu installieren. Den Fixer habe ich auch schon probiert. Aus dem Fehlermeldungen werde ich nicht schlau. Das System ist auf dem neusten Stand.
    Kompletter Log als nächsten Beitrag.
    • R Offline
      RASS
      schrieb am zuletzt editiert von RASS
      (...)  Erster Teil des Logs habe ich gespart.
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:41:48: error: no matching function for call to ‘v8::Value::ToString()’   v8::String::Utf8Value path(info[0]->ToString());                                                ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2572:44: note: candidate: ‘v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2572:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2588:31: note: candidate: ‘v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const’                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2588:31: note:   candidate expects 1 argument, 0 provided                 Local<String> ToString(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:48:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:113:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:250:53: error: no matching function for call to ‘v8::Value::ToObject()’   v8::Local<v8::Object> options = info[1]->ToObject();                                                     ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(                                            ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2576:44: note:   candidate expects 1 argument, 0 providedIn file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note: candidate: ‘v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const’                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:2590:31: note:   candidate expects 1 argument, 0 provided                 Local<Object> ToObject(Isolate* isolate) const);                               ^~~~~~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));        ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:3403:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));        ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:3403:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));        ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:3403:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));        ^In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:25,                 from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:3403:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8config.h:311:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(2, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~
      ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   data->callback.Call(1, argv);                              ^In file included from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^
      ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^../src/serialport.cpp:460:17: error: variable or field ‘init’ declared void   void init(v8::Handle<v8::Object> target) {                 ^~~~~~../src/serialport.cpp:460:17: error: ‘Handle’ is not a member of ‘v8’../src/serialport.cpp:460:34: error: expected primary-expression before ‘>’ token   void init(v8::Handle<v8::Object> target) {                                  ^../src/serialport.cpp:460:36: error: ‘target’ was not declared in this scope   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~
      ../src/serialport.cpp:460:36: note: suggested alternative: ‘tzset’   void init(v8::Handle<v8::Object> target) {                                    ^~~~~~                                    tzset
      In file included from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:../src/serialport.cpp:485:25: error: ‘init’ was not declared in this scope NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:566:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
      ../src/serialport.cpp:485:25: note: suggested alternative: ‘int’ NODE_MODULE(serialport, init);                         ^~~~/home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:566:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/serialport.cpp:485:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
      In file included from /home/iobroker/.cache/node-gyp/12.14.0/include/node/node.h:63,                 from ../../nan/nan.h:54,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/12.14.0/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      /home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../../nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/12.14.0/include/node/v8.h:10004:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
      make: *** [serialport.target.mk:110: Release/obj.target/serialport/src/serialport.o] Fehler 1
      gyp
       ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:210:5)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
      gyp ERR! System Linux 4.19.75-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/serialportgyp ERR! node -v v12.14.0gyp ERR!
      node-gyp -v v5.0.5gyp ERR! not ok
      npm ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the serialport@6.2.2 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-12-26T17_22_33_618Z-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.zigbee@0.10.2: 1
      • R RASS
        gyp
         ERR! build error
        GlasfaserG Offline
        GlasfaserG Offline
        @RASS
        Ist nicht gerade gut lesbar !
        Code und logs bitte in Code Tags packen. Im Editor </> auswählen.
        Würde sagen du hast node 12.14.0 installiert .
        Zeige mal :
        cd /opt/iobroker
        npm -v
        node -v
        nodejs-v
        Aktuell ist 10.18.0
        Für mal das durch :
        Node.js für ioBroker richtig updaten
        R 1 Antwort Letzte Antwort
        • arteckA Offline
          arteckA Offline
          arteck
          formatier das LOG mal bitte...
          • GlasfaserG Glasfaser
            @RASS
            Zeige mal :
            cd /opt/iobroker
            npm -v
            node -v
            nodejs-v
            Aktuell ist 10.18.0
            Für mal das durch :
            RASS
            @Glasfaser
            NPM: 6.13.4
            Nodejs: 12.14.0
            Node: 12.14.0
            Ich habe jetzt eine "Downgrade" der Nodejs gemacht und...funktioniert! Vielen Dank!
