  4. js-controller 2 jetzt für alle im Stable
js-controllerjs-controller 2
556 Beiträge 74 Kommentatoren 209.4k Aufrufe 56 Beobachtet
    Motsche1
    #372
    Hallo
    Aldo ich versuche seit Stunden js-controller zu updaten. Immer mit Fehler und ich muss 1.6 wieder drauf machen damit Iobroker wieder geht.
    Habe einen Rockpro64 mit Iobroker und meldungen sind wie folgt:
    pi@rockpro64:~$ sudo iobroker upgrade self
    Update js-controller from @1.5.14 to @2.1.1
    NPM version: 6.13.4
    npm install iobroker.js-controller@2.1.1 --unsafe-perm --production --save --pre        fix "/opt/iobroker" (System call)
    ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: No such file or directory
         #include <bluetooth/bluetooth.h>
    compilation terminated.
    make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.4.192-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
    gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
    gyp ERR! node -v v10.18.0
    gyp ERR! node-gyp -v v5.0.5
    gyp ERR! not ok
    ../src/unix_dgram.cc: In function 'void {anonymous}::OnRecv({anonymous}::SocketContext*)':
    ../src/unix_dgram.cc:121:25: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                         argv);
    In file included from ../src/unix_dgram.cc:5:0:
    ../../nan/nan.h:1024:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../src/unix_dgram.cc: In function 'void {anonymous}::OnWritable({anonymous}::SocketContext*)':
    ../src/unix_dgram.cc:129:28: warning: 'v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)' is deprecated [-Wdeprecated-declarations]
                         0, NULL);
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:189:37: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    In file included from /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:26:0,
                     from /home/iobroker/.cache/node-gyp/10.18.0/include/node/node.h:63,
                     from ../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8config.h:324:3: note: in definition of macro 'V8_DEPRECATED'
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:230:28: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:258:28: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:259:27: warning: 'v8::Local<v8::Object> v8::Value::ToObject() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/iobroker/.cache/node-gyp/10.18.0/include/node/node.h:63:0,
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: 'uint32_t v8::Value::Uint32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/iobroker/.cache/node-gyp/10.18.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: 'uint32_t v8::Value::Uint32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:302:28: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:303:27: warning: 'v8::Local<v8::Object> v8::Value::ToObject() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:340:28: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: 'v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)' is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function 'Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/unix_dgram.cc:361:28: warning: 'int32_t v8::Value::Int32Value() const' is deprecated: Use maybe version [-Wdeprecated-declarations]
    /opt/iobroker/node_modules/ioredis/built/command.js:50
            this.args = lodash_1.flatten(args);
    TypeError: lodash_1.flatten is not a function
        at new Command (/opt/iobroker/node_modules/ioredis/built/command.js:50:30)
        at Redis.info (/opt/iobroker/node_modules/ioredis/built/commander.js:124:33)
        at Redis._readyCheck (/opt/iobroker/node_modules/ioredis/built/redis/index.js:430:10)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:47:18)
        at Object.onceWrapper (events.js:286:20)
        at Socket.emit (events.js:203:15)
        at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1093:10)
    npm WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: `node-gyp configure build`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@2.1.1 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@2.1.1 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2019-12-27T16_01_29_257Z-debug.log
    Host "rockpro64" (linux) updated
    Execute: chmod -R 777 /opt/iobroker
    Chmod finished. Restart controller
    Starting node restart.js
    • M Motsche1
      Hallo
      NPM version: 6.13.4
      gyp ERR! not ok
                           argv);
                           0, NULL);
      npm ERR! errno 1
      npm ERR!
      #373
      @Motsche1 Also die meisten Meldungen oben sind nur Warnungen.. Der Fehler mit dem "flatten" ist komisch. Dann gib mal bitte mehr Infos zu Deinem System.
      Was ist vorher drauf? 1.6 gibts nicht wirklich. 1.5.14? oder was? Nutzt Du Redis? Ist es ein Master/Slave System oder Einzel-Host?
        Motsche1
        #374
        Einzelhost
        nutze kein redis und es ist bzw war 1.5.14 drauf jetzt startet iobroker nicht
        müste erst 1.5.14 wieder drüber machen dann geht alles wieder
        • apollon77A Offline
          #375
          iobroker war sauber gestoppt davor? Keine Prozesse mehr gelaufen?
            Motsche1
            #376
            ja
            ist immernoch gestoppt
              #377
              Und was genau kommt als Fehler wnen Du wieder neu starten willst?
                Motsche1
                #378
                sudo iobroker start keine fehler kommt nix
                • M Motsche1
                  Motsche1
                  #379
                  erst bei sudo iobroker start admin
                    #380
                    Fehler im Logfile? /opt/iobroker/log/...
                      Motsche1
                      #381
                      also im moment kann er nicht starten da kein js controler da ist
                      das log ist seit 40 min nix neues drin hab aber vor 10 min versucht zu starten
                      • M Motsche1
                        Motsche1
                        #382
                        @Motsche1 ich lösch mal die log und installiere js neu mom
                          Motsche1
                          #383
                          alsoinstallation geht nur mit
                          dann hab ich wieder 1.5.14 drauf und iobroker laüft
                            Motsche1
                            #384
                            und dann hab ich im log fplgenden fehler wenn ich starte
                            2019-12-27 17:47:54.478  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                            2019-12-27 17:47:54.480  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                                at Object.openSync (fs.js:443:3)
                                at Object.writeFileSync (fs.js:1194:35)
                                at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2024:16)
                                at ontimeout (timers.js:436:11)
                                at tryOnTimeout (timers.js:300:5)
                                at listOnTimeout (timers.js:263:5)
                                at Timer.processTimers (timers.js:223:10)
                            • M Motsche1
                              #385
                              @Motsche1 Installation Fixer ... siehe FAQ!
                              Ansonsten mach mal
                                Motsche1
                                #386
                                hab ich beides schon durch --- selbes ergebnis
                                • M Motsche1
                                  #387
                                  @Motsche1 Immer dieser Fehler mit dem "Flatten"?
                                  Ruf mal nach install der 2.1.1 bitte manuell "iobroker setup first" auf.
                                  Und immer noch: Was steht im ioBroker Logfile?
                                    Motsche1
                                    #388
                                    @apollon77 said in js-controller 2 jetzt für alle im Stable:
                                    Iobroker setup first
                                    internal/modules/cjs/loader.js:638
                                        throw err;
                                    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                        at startup (internal/bootstrap/node.js:283:19)
                                        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                    und log file hatte ich schon gepostet aber gern nochmal
                                    2019-12-27 17:55:09.310  - error: uncaught exception: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                                    2019-12-27 17:55:09.314  - error: Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/pids.txt'
                                    2019-12-27 17:55:09.318  - info: iobroker _restart
                                    2019-12-27 17:55:09.745  - info: iobroker Starting node restart.js
                                    2019-12-27 17:55:09.768  - info: iobroker exit 0
                                    2019-12-27 17:55:09.809  - info: admin.0 starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.18.0
                                    2019-12-27 17:55:09.870  - info: admin.0 requesting all states
                                    2019-12-27 17:55:09.870  - info: admin.0 requesting all objects
                                    2019-12-27 17:55:11.485  - info: admin.0 received all objects
                                    2019-12-27 17:55:11.501  - warn: admin.0 No repository source configured
                                    2019-12-27 17:55:11.524  - info: admin.0 http server listening on port 8081
                                    2019-12-27 17:55:11.524  - info: admin.0 Use link "http://localhost:8081" to configure.
                                    2019-12-27 17:55:19.324  - info: host.rockpro64 force terminating
                                    2019-12-27 17:55:19.324  - info: Adapter admin still running
                                    2019-12-27 17:55:20.218  - info: host.rockpro64 instance system.adapter.sonoff.0 started with pid 26841
                                    2019-12-27 17:55:20.399  - info: admin.0 terminating http server on port 8081
                                    2019-12-27 17:55:21.905  - info: admin.0 terminating http server on port 8081
                                      #389
                                      Und jetzt bitte mal log von dem Install direkt per npm mit der 2.1.1
                                        Motsche1
                                        #390
                                        also 2.1.1 install und dann noch mal in die log schauen
                                          Motsche1
                                          #391
                                          iobroker log nix drin also neuer eintrag
                                          in der npm log steht
                                          0 info it worked if it ends with ok
                                          1 verbose cli [ '/usr/bin/node',
                                          1 verbose cli   '/usr/bin/npm',
                                          1 verbose cli   'install',
                                          1 verbose cli   'iobroker.js-controller@2.1.1' ]
                                          2 info using npm@6.13.4
                                          3 info using node@v10.18.0
                                          4 verbose npm-session 64667189d8460ead
                                          5 silly install loadCurrentTree
                                          6 silly install readLocalPackageData
                                          7 http fetch GET 304 https://registry.npmjs.org/iobroker.js-controller 325ms (from cache)
                                          8 silly pacote version manifest for iobroker.js-controller@2.1.1 fetched in 347ms
                                          9 timing stage:loadCurrentTree Completed in 11475ms
                                          10 silly install loadIdealTree
                                          11 silly install cloneCurrentTreeToIdealTree
                                          12 timing stage:loadIdealTree:cloneCurrentTree Completed in 136ms
                                          13 silly install loadShrinkwrap
                                          14 timing stage:loadIdealTree:loadShrinkwrap Completed in 2548ms
                                          15 silly install loadAllDepsIntoIdealTree
                                          16 silly resolveWithNewModule iobroker.js-controller@2.1.1 checking installable status
                                          17 http fetch GET 304 https://registry.npmjs.org/decache 124ms (from cache)
                                          18 silly pacote range manifest for decache@^4.5.1 fetched in 129ms
                                          19 silly resolveWithNewModule decache@4.5.1 checking installable status
                                          20 http fetch GET 304 https://registry.npmjs.org/semver 145ms (from cache)
                                          21 silly pacote range manifest for semver@^6.3.0 fetched in 152ms
                                          22 silly resolveWithNewModule semver@6.3.0 checking installable status
                                          23 http fetch GET 304 https://registry.npmjs.org/respjs 288ms (from cache)
                                          24 http fetch GET 304 https://registry.npmjs.org/readline-sync 294ms (from cache)
                                          25 silly pacote range manifest for respjs@^4.2.0 fetched in 300ms
                                          26 silly resolveWithNewModule respjs@4.2.0 checking installable status
                                          27 silly pacote range manifest for readline-sync@^1.4.10 fetched in 308ms
                                          28 silly resolveWithNewModule readline-sync@1.4.10 checking installable status
                                          29 http fetch GET 304 https://registry.npmjs.org/mime 319ms (from cache)
                                          30 http fetch GET 304 https://registry.npmjs.org/node-forge 322ms (from cache)
                                          31 http fetch GET 304 https://registry.npmjs.org/chokidar 345ms (from cache)
                                          32 silly pacote range manifest for mime@^2.4.4 fetched in 347ms
                                          33 silly resolveWithNewModule mime@2.4.4 checking installable status
                                          34 silly pacote range manifest for node-forge@^0.9.1 fetched in 351ms
                                          35 silly resolveWithNewModule node-forge@0.9.1 checking installable status
                                          36 http fetch GET 304 https://registry.npmjs.org/event-stream 363ms (from cache)
                                          37 silly pacote range manifest for chokidar@^3.3.0 fetched in 373ms
                                          38 silly resolveWithNewModule chokidar@3.3.1 checking installable status
                                          39 http fetch GET 304 https://registry.npmjs.org/ioredis 372ms (from cache)
                                          40 http fetch GET 304 https://registry.npmjs.org/iobroker.objects-redis 386ms (from cache)
                                          41 http fetch GET 304 https://registry.npmjs.org/socket.io-client 223ms (from cache)
                                          42 http fetch GET 304 https://registry.npmjs.org/socket.io 264ms (from cache)
                                          43 silly pacote range manifest for event-stream@^4.0.1 fetched in 417ms
                                          44 silly resolveWithNewModule event-stream@4.0.1 checking installable status
                                          45 silly pacote range manifest for ioredis@^4.14.1 fetched in 427ms
                                          46 silly resolveWithNewModule ioredis@4.14.1 checking installable status
                                          47 silly pacote range manifest for iobroker.objects-redis@^1.2.8 fetched in 444ms
                                          48 silly resolveWithNewModule iobroker.objects-redis@1.2.13 checking installable status
                                          49 silly pacote version manifest for socket.io-client@2.3.0 fetched in 280ms
                                          50 silly resolveWithNewModule socket.io-client@2.3.0 checking installable status
                                          51 silly pacote version manifest for socket.io@2.3.0 fetched in 322ms
                                          52 silly resolveWithNewModule socket.io@2.3.0 checking installable status
                                          53 http fetch GET 304 https://registry.npmjs.org/winston 217ms (from cache)
                                          54 http fetch GET 304 https://registry.npmjs.org/tar 229ms (from cache)
