  4. Probleme beim Restore
backitup
27 Beiträge 5 Kommentatoren 3.1k Aufrufe 4 Beobachtet
    Schwammal
    Nachdem man das zu wiederherstellende Backup ausgewählt hat und Restore klick fängt der Prozess an und eine neues Fenster öffnet sich.
    [DEBUG] [iobroker] Start ioBroker Restore ...
    [DEBUG] [iobroker] iobroker controller daemon is not running
    [DEBUG] [iobroker] host.heimautomation OK.
    [DEBUG] [iobroker] host.heimautomation Clear all objects and states...
    [DEBUG] [iobroker] clean 391 objects...
    [ERROR] [iobroker] [Not critical] Cannot delete object 0_userdata.0: "Object is marked as non deletable"
    [ERROR] [iobroker] [Not critical] Cannot delete object alias.0: "Object is marked as non deletable"
    [ERROR] [iobroker] [Not critical] Cannot delete object system.repositories: "Object is marked as non deletable"
    [ERROR] [iobroker] [Not critical] Cannot delete object system.config: "Object is marked as non deletable"
    [ERROR] [iobroker] [Not critical] Cannot delete object enum.functions: "Object is marked as non deletable"
    [ERROR] [iobroker] [Not critical] Cannot delete object enum.rooms: "Object is marked as non deletable"
    [DEBUG] [iobroker] clean 305 states...
    [DEBUG] [iobroker] host.heimautomation done.
    [DEBUG] [iobroker] host.heimautomation Processed 0/15398 states
    [DEBUG] [iobroker] host.heimautomation Processed 200/15398 states
    [DEBUG] [iobroker] host.heimautomation Processed 400/15398 states
    [DEBUG] [iobroker] host.heimautomation Processed 7200/17466 objects
    [DEBUG] [iobroker] host.heimautomation Processed 7400/17466 objects
    [ERROR] [iobroker] /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385
    [ERROR] [iobroker] && _objects[_index].id.match(/^system\.adapter\./)
    [ERROR] [iobroker] ^
    [ERROR] [iobroker] TypeError: Cannot read property 'match' of null
    [ERROR] [iobroker] at BackupRestore._setObjHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:385:36)
    [ERROR] [iobroker] at runCallback (timers.js:706:11)
    [ERROR] [iobroker] at tryOnImmediate (timers.js:676:5)
    [ERROR] [iobroker] at processImmediate (timers.js:658:5)
    [DEBUG] [iobroker] ioBroker Restore completed successfully
    [EXIT] 1 **** Restore completed successfully!! ****
    Mod-Edit: Code in Code-Tags gesetzt!
    • S Schwammal
      @Schwammal sagte in Probleme beim Restore:
      Minimal oder Full?
        Schwammal
        Kann es sein dass diese Auswahl rausgefallen ist? Ich habe gerade die Version 1.3.6 drauf und kann es nicht mehr auswählen, daher gehe ich davon aus dass es Full ist. Auf dem NAS sind aber noch alte Minimal Backups zu finden (und zusätzlich noch Zigbee + Homematic)
        • S Schwammal
          @Schwammal Und genau deswegen ist das FULL rausgefallen - es gab immer wieder Probleme wegen nicht korrekter Nutzung!
          Das Full durfte nur auf dem ursprünglichen System wieder hergestllt werden (incl, node und npm-Version)!!!
            Schwammal
            Aber wenn ich bei auf beiden Systemen die gleiche Backitup Version nutze, sollte es doch egal sein, oder?
            • S Schwammal
              Nein!
              Das Full ist für die Hardware und die node/npm Version kompiliert.
              Sobald auch nur ein Faktor anders ist klappt es nicht!
                Schwammal
                OK, dann wäre ja das Minimal Backup das Richtige, welches es nicht mehr gibt. Ich würde mal versuchen die alte Installation auf die neuere NPM Version hoch zu bekommen, was vorhin leider nicht funktioniert hat. Ist die 6.1 Version schon zu gebrauchen?
                • S Schwammal
                  Richtig, da wird alles neu kompiliert
                  Doch! es gibt nur noch das minimal - heisst jetzt nur anders.
                    Schwammal
                    aber wenn es nur noch das Minimal gibt, sollte es ja auch unabhängig von anderen NPM Versionen funktioniert oder sehe ich das falsch.
                    • S Schwammal
                      Genau - das ist ja SInn des Minimal
                      gesichert werden die Konfigurationen.
                      Alles wird neu installiert bzw. kompiliert
                        Schwammal
                        Hi
                        Ich muss leider noch einmal nachfragen da das Update leider nicht so will wie ich. Ich habe das Gefühl die aktuelle 6.13 schon installiert zu haben aber Iobroker sieht das Anders:
                        npm install -g npm@latest
                        /opt/iobroker$ npm ls npm
                        iobroker@1.0.0 /opt/iobroker
                        ├─┬ iobroker.vis-weather@2.5.2
                        │ └── npm@6.13.4
                        └── npm@6.13.4
                        Trotzdem zeigt die Webgui 6.5 an und das auch noch dem ausführen des reinstall Skripts
                        • S Schwammal
                          Hi
                          │ └── npm@6.13.4
                          └── npm@6.13.4
                          iobroker@1.0.0
                          stimmt denn das?
                          Wir sind inzwischen bei 2.1.1
                          und was sagt:
                          node -v
                          npm -v
                          nodejs -v
                            Schwammal
                            Ich habe keine Ahnung wo die 1.0 herkommt. Das Webinterface sagt mit Controllerversion 2.1.1. Kann es sein dass ich mehrere Versionen installiert habe. Die Installation ist schon ein paar Jahre alt.
                            /opt/iobroker$ node -v
                            v10.18.0
                            /opt/iobroker$ npm -v
                            6.5.0
                            /opt/iobroker$ nodejs -v
                            v10.18.0
                            • S Schwammal
                              v10.18.0
                              6.5.0
                              v10.18.0
                              das hatte ich befürchtet.
                              Die Daten über node und npm zeigen es aber zumindest nicht auf Anhieb
                              Wie sieht das denn bei deiner neuen Installation aus?
                                Schwammal
                                v10.18.0
                                /opt/iobroker$ npm -v (kann ich nur mit sudo abfragen)
                                6.13.4
                                v10.18.0
                                Ich hab kein Problem damit die alte Installation platt zu machen aber die Daten würde ich schon gerne mitnehmen
                                • S Schwammal
                                  v10.18.0
                                  6.13.4
                                  v10.18.0
                                  Wenn die Backups aber schon korrupte Daten enthalten geht das nicht so einfach.
                                  Hast du auf der neuen Installation schon ioBroker neu installiert ohne weiteres zu machen?
                                    Schwammal
                                    Dachte ich mir fast. Die neue Installation ist quasi nackt und hat nur den Backitup Adapter geladen
                                    • S Schwammal
                                      Hi
                                      │ └── npm@6.13.4
                                      └── npm@6.13.4
                                      Hi
                                      │ └── npm@6.13.4
                                      └── npm@6.13.4
                                      Was sagt die neue denn dazu?
                                        Schwammal
                                        Interessant. Auch hier wird nicht die 2.1.1 angezeigt
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        └── (empty)
                                        • S Schwammal
                                          └── (empty)
                                          janschmidt76
                                          schrieb am zuletzt editiert von janschmidt76
                                          ich bin gerade beim Umzug meiner "alten" ioBroker-Installation von einem RPi3 auf einen RPi4 und bin an dem selben Fehler gescheitert. Ich habe mich ein bisschen durch den Code gelesen und debugged und habe einen "quick'n'dirty"-Fix eingebaut: in der Datei /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js in Zeile 385 die Bedingung "&& _objects[_index].id != null" ergänzt (s.u., Zeile 4). Ist sicherlich nicht schön und müsste u.U. genauer geprüft werden, insbesondere woher dieser null-Value um Backup kommt.
                                          Mit dieser Änderung lief der Restore bei mir dann aber fehlerfrei durch. Alles ohne Garantie, aber vielleicht hilft es Dir ja. 😊
                                              _setObjHelper(_index, _objects, callback) {
                                                  // Disable all adapters.
                                                  if (!this.dbMigration
                                                      && !_objects[_index].id.match(/^system\.adapter\.admin\./)
                                                      && !_objects[_index].id.match(/^system\.adapter\.backitup\./)) {
                                                      if (_objects[_index].doc.common && _objects[_index].doc.common.enabled) {
                                                          _objects[_index].doc.common.enabled = false;
                                          S apollon77A 2 Antworten Letzte Antwort
