  4. javascript Adapter already running V4.3.4
javascript adapter
8 Beiträge 3 Kommentatoren 499 Aufrufe 3 Beobachtet
    MyMeyer
    schrieb am zuletzt editiert von MyMeyer
    Hallo, habe gerade die neue Version installiert und nun startet der Adapter nicht mehr. Iobroker bereits neu gestartet , aber leider keine Besserung.
    Was kann ich tun ?
    Hier der Auszug aus dem Log:
    host.iobroker 2019-12-23 12:18:19.058 warn instance system.adapter.javascript.0 already running with pid 902
    host.iobroker 2019-12-23 12:18:17.557 info stopInstance system.adapter.javascript.0 killing pid 902
    host.iobroker 2019-12-23 12:18:16.557 info stopInstance system.adapter.javascript.0 send kill signal
    host.iobroker 2019-12-23 12:18:16.557 info stopInstance system.adapter.javascript.0 (force=false, process=true)
    host.iobroker 2019-12-23 12:18:16.556 info "system.adapter.javascript.0" enabled
    Hier das Log wenn ich über die Konsole versuche:
    root@iobroker:/opt/iobroker# npm install iobroker.javascript@4.3.4
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript
    npm WARN svg-inline-react@1.0.3 requires a peer of react@^0.14.0 || ^15.0.0 but none is installed. You must install peer dependencies yourself.
    npm ERR! path /opt/iobroker/node_modules/iobroker.javascript
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript'
    npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript']
    npm ERR! stack:
    npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript'',
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'access',
    npm ERR! path: '/opt/iobroker/node_modules/iobroker.javascript' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! /home/iobroker/.npm/_logs/2019-12-23T11_27_16_248Z-debug.log
    Hier die System Konfiguration:
    iobroker
    Betriebssystem
    linux
    Architektur
    x64
    CPUs
    Geschwindigkeit
    3192 MHz
    Modell
    Common KVM processor
    RAM
    3.86 GB
    System Betriebszeit
    00:21:11
    Node.js
    v10.16.3 (Es gibt eine neuere Version: v10.18.0)
    NPM
    6.9.0
    Festplatte Größe
    27.43 GB
    Festplatte frei
    19.61 GB
    Anzahl der Adapter
    306
    Betriebszeit
    00:21:07
    Aktive Instanzen
    30
    Hostname
    iobroker
    MyMeyer
    Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
    HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
    dslraserD StrathColeS 3 Antworten Letzte Antwort
    • M MyMeyer
      Was kann ich tun ?
      npm ERR! errno -13
      npm ERR! stack:
      npm ERR!
      npm ERR!
      iobroker
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      3192 MHz
      Modell
      RAM
      3.86 GB
      System Betriebszeit
      00:21:11
      Node.js
      NPM
      6.9.0
      Festplatte Größe
      27.43 GB
      Festplatte frei
      19.61 GB
      Anzahl der Adapter
      306
      Betriebszeit
      00:21:07
      Aktive Instanzen
      30
      Hostname
      iobroker
      dslraserD Offline
      dslraserD Offline
      dslraser
      @MyMeyer
      wie hast Du den Adapter installiert ? (über die Katze ?)
      Hast Du einen Upload gemacht und die Instanz dann neu gestartet ?
      • M MyMeyer
        Was kann ich tun ?
        npm ERR! errno -13
        npm ERR! stack:
        npm ERR!
        npm ERR!
        iobroker
        Betriebssystem
        linux
        Architektur
        x64
        CPUs
        Geschwindigkeit
        3192 MHz
        Modell
        RAM
        3.86 GB
        System Betriebszeit
        00:21:11
        Node.js
        NPM
        6.9.0
        Festplatte Größe
        27.43 GB
        Festplatte frei
        19.61 GB
        Anzahl der Adapter
        306
        Betriebszeit
        00:21:07
        Aktive Instanzen
        30
        Hostname
        iobroker
        dslraserD Offline
        dslraserD Offline
        dslraser
        @MyMeyer
        Du könntest auch mal den Fixer über Dein System laufen lassen
        curl -sL https://iobroker.net/fix.sh | bash -
        • M MyMeyer
          Was kann ich tun ?
          npm ERR! errno -13
          npm ERR! stack:
          npm ERR!
          npm ERR!
          iobroker
          Betriebssystem
          linux
          Architektur
          x64
          CPUs
          Geschwindigkeit
          3192 MHz
          Modell
          RAM
          3.86 GB
          System Betriebszeit
          00:21:11
          Node.js
          NPM
          6.9.0
          Festplatte Größe
          27.43 GB
          Festplatte frei
          19.61 GB
          Anzahl der Adapter
          306
          Betriebszeit
          00:21:07
          Aktive Instanzen
          30
          Hostname
          iobroker
          StrathColeS Offline
          StrathColeS Offline
          StrathCole
          @MyMeyer Du hast npm install als root ausgeführt. Dann hat ioBroker keinen Zugriff auf die Dateien. Du hättest es wohl mit "sudo -u iobroker npm install" machen müssen. Jetzt müsstest du erst die Berechtigungen korrigieren (chown).
          SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
          • StrathColeS StrathCole
            MyMeyer
            @StrathCole
            Joo... Habe den Fix gestartet und nun läuft es wieder. Puhhh. :-).
            zu @dslraser ich habe das Update über den Button gemacht der mir im Menü angezeigt wird.
            Aber nun läuft es ja wieder. Gleich ne Backup machen.
            MyMeyer
            MyMeyer
              MyMeyer
              das Problem ist doch nicht gelöst. Nachdem Update auf 4.3.4 startet der JS nicht mehr korrekt durch.
              Meldung aus dem LOG:
              host.iobroker 2019-12-26 11:25:39.009 warn instance system.adapter.javascript.0 already running with pid 32285
              host.iobroker 2019-12-26 11:25:37.509 info stopInstance system.adapter.javascript.0 killing pid 32285
              host.iobroker 2019-12-26 11:25:36.508 info stopInstance system.adapter.javascript.0 send kill signal
              host.iobroker 2019-12-26 11:25:36.508 info stopInstance system.adapter.javascript.0 (force=false, process=true)
              host.iobroker 2019-12-26 11:25:36.507 info "system.adapter.javascript.0" enabled
              Jetzt möchte ich aber der Sache genau auf den Grund gehen und abstellen. Zur Zeit ist es egal welche JS version ich installiere. Er lässt sich leider nicht korrekt starten. Das Icon unter Instanzen bleibt ROT nach dem Start.
              Was kann ich tun und wie soll ich vorgehen ? Auch das Stoppen im Iobroker ist merkwürdig , weil immer der JS Prozess on bleibt. Ich muss ihn manuell über kill -9 stoppen damit das System offline geht.
              MyMeyer
              StrathColeS 1 Antwort Letzte Antwort
              • M MyMeyer
                StrathColeS Offline
                StrathColeS Offline
                StrathCole
                schrieb am zuletzt editiert von StrathCole
                @MyMeyer Ich hatte das Problem auch vorhin.
                Bei mir lag es daran, dass ich in einem Javascript eine ungültige Variable in einen State geschrieben habe. Mit diesem State habe ich in einem andern Skript weitergerechnet. Das hat scheinbar dazu geführt, dass der gesamte JS Adapter nicht mehr wollte und sich auch nicht korrekt beenden ließ.
                Ich habe dann erst alle Skripte gestoppt und danach via Shell auf dem Server mit kill -9 <pid> den JS Adapter abgeschossen und in der Oberfläche anschließend neu gestartet.
                Anschließend habe ich nacheinander alle Skripte gestartet, bis das Problem wieder auftrat.
                Bei mir war es ein Skript in "general", das es verursacht hat. Vielleicht, weil die Dinge darin global verfügbar sind?
                  MyMeyer
                  @StrathCole Danke für deine Tipp . Bin jetzt so auch vorgegangen. Und seit dem ich die alten Scripte für Stromberechnung nicht startet läuft der Adapter durch. Werde das jetzt die nächsten Stunden (Tage) beobachten und schauen was das Problem mit den alten Scripten sein könnte.
                  MyMeyer
