  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 89.7k Aufrufe
  • fischi87F
    fischi87F
    fischi87
    #86
    Servus,
    also bei mir läuft der adapter ja recht gut aber ein freund wollte diesen auch haben und da hab ich Probleme mit der installation.
    habe dass schon versucht wie bei pix aber ohne erfolg.?!
    dns_sd_bindings.target.mk:130: recipe for target 'Release/obj.target/dns_sd_bindings/src/dns_sd.o' failed
    make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
    gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
    gyp ERR! System Linux 4.1.7-v7+
    gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
    gyp ERR! node -v v0.10.22
    gyp ERR! node-gyp -v v0.11.0
    gyp ERR! not ok
    npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the mdns@2.2.11 install script.
    npm ERR! This is most likely a problem with the mdns package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     node-gyp rebuild
    npm ERR! You can get their info via:
    npm ERR!     npm owner ls mdns
    npm ERR! There is likely additional logging output above.
    npm ERR! System Linux 4.1.7-v7+
    npm ERR! command "/usr/local/bin/node" "/usr/local/bin/npm" "install" "https://github.com/husky-koglhof/ioBroker.homekit/tarball/master" "--production"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v0.10.22
    npm ERR! npm -v 1.3.14
    npm ERR! code ELIFECYCLE
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0
    root@raspberrypi:/opt/iobroker#
    Mit freundlichen Grüßen
    • V
      V
      versteckt
      #87
      Hallo fischi87, welche Node Version verwendest du?
      habe gerade gesehen, da wurde mit der 0.10er probiert.
      Will nur Fehler ausschliessen, vermute aber eher, das eine library fehlt.
      Ich such mal schnell und gebe Bescheid.
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • V
        V
        versteckt
        #88
        Probier mal folgendes:
        apt-get update
        apt-get install git-core libnss-mdns libavahi-compat-libdnssd-dev -y
        • V
          V
          versteckt
          #89
          Gleich mal als Info, bei mir hat nach der Aktualisierung von ioBroker auf die letzte Version
          homekit nicht mehr funktioniert.
          Musste einen neuen Username setzen, und leider am iPhone alles neu einrichten.
          Dass muss ich mir genauer ansehen. Ev. war es auch nur bei mir ein Problem.
          • fischi87F
            fischi87F
            fischi87
            #90
            weil du der beste best :-)
            danke genau da war der Fehler vielen dank und weiter so!!!
            • fischi87F
              fischi87F
              fischi87
              #91
              Nein, hab das selbe Problem mit dem Adapter :(
              • V
                V
                versteckt
                #92
                Welches Problem nun?
                Gesendet von meinem iPhone mit Tapatalk
                • fischi87F
                  fischi87F
                  fischi87
                  #93
                  Geräte sind nicht mehr erreichbar mit eve.
                  • V
                    V
                    versteckt
                    #94
                    Ok, kannst du einen reboot durchführen?
                    Ich muss das ansonsten genau analysieren.
                    Ich hab bei mir alles in eve gelöscht und von vorne angefangen und das sollte der letzte Weg sein.
                    • fischi87F
                      fischi87F
                      fischi87
                      #95
                      okay hast recht noch Löschung von eve alles wieder cool!!!
                      • fischi87F
                        fischi87F
                        fischi87
                        #96
                        servus
                        also der homefit adapter läuft unter eve nicht mehr, Aktoren waren nicht mehr erreichbar und nach neuinstallation findet eve den Biobroker bridge nicht mehr!!!
                        gibt es neue erkennnise bezüglich des adapters?
                        • V
                          V
                          versteckt
                          #97
                          Hallo, nein leider noch nicht.
                          War die letzten Tage mit dem ZWave Adapter beschäftigt.
                          Ich muss mal den "Hersteller" von hap-nodejs quälen,
                          für mich sieht das nach einem Caching / Persistence Problem aus.
                          Sobald ich etwas neues weiss, gebe ich Bescheid.
                          • BluefoxB
                            #98
                            Wie ist der Stand vom Adapter?
                            • V
                              V
                              versteckt
                              #99
                              Hallo Bluefox!
                              Habe soeben meine Änderungen bez. Types hochgeladen.
                              Ist auch bereits im npmjs eingepflegt.
                              Die Anpassungen bez. WeatherUnderGround sind drinnen. Es werden alle Temperaturen ausser Forecast angezeigt.
                              Ich selber habe den Adapter bei mir für Homematic, zWave und jetzt WeatherUnderGround seit der Entwicklung im Einsatz.
                              LG Christian
                              • BluefoxB
                                #100
                                @versteckt:
                                Hallo Bluefox!
                                LG Christian `
                                Ich habe eigentlich HomeKit gemeint. :)
                                Alle andere sind schon in Repository drin.
                                1057_view2-widgets-3profile-published-21-1_jqui_input.txt
                                • V
                                  V
                                  versteckt
                                  #101
                                  ev. nicht gut geschrieben.
                                  In npmjs ist die Version 0.0.9 hochgeladen von iobroker.homekit.
                                  Ist halt noch im Alpha Stadium, es müssten mehr testen, bzw. Fehler einmelden.
                                  Würde mich aber freuen, wenn auch dieser Adapter in ioBroker fix integriert wird.
                                  LG Christian
                                  • BluefoxB
                                    #102
                                    @versteckt:
                                    LG Christian `
                                    Ich wollte den gestern schon integrieren, aber kein NPM Paket gefunden. Dann in der nächsten Version.
                                    • V
                                      V
                                      versteckt
                                      #103
                                      Ok, danke.
                                      Wurde erst heute in npmjs hochgeladen, davor war halt einfach nur die GitHub Version aktiv.
                                      LG Christian
                                      • V
                                        V
                                        versteckt
                                        #104
                                        Hallo, aufgrund eines Fehlers mit dem Store wurde
                                        grade eben eine neue Version 0.0.10 hochgeladen.
                                        Hatte gestern nur auf Mac getestet aber nicht auf Raspi, aber nun läufts.
                                        LG Christian
                                        • C
                                          C
                                          chaos99
                                          #105
                                          hallo, ich hab jetzt mal alles überflogen , aber ich sehe noch nicht durch, wie funktioniert das ganze , was muss ich auf dem iphone installieren und was bei iobroker ?
                                          84.2k
