  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 91.1k Aufrufe
  • P
    P
    pix
    Ok, habe jetzt die "zuverlässige" https://nodejs.org/en/download/ installiert (vorher iobroker gestoppt, backups). Neustart ioBroker ohne Probleme.
    Bei der AKtivierung der homekit-Instanz erscheint nun dieser Fehler
    2015-12-12 16:45:04.900 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.vis-google-fonts.0 terminated while should be started once
    2015-12-12 16:45:06.934 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
    2015-12-12 16:45:06.940 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 16823
    2015-12-12 16:45:07.389 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
    2015-12-12 16:45:07.394 - error: Error: Module version mismatch. Expected 46, got 47.
    at Error (native)
    at Object.Module._extensions..node (module.js:460:18)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:311:12)
    at Module.require (module.js:366:17)
    at require (module.js:385:17)
    at Object. <anonymous>(/Users/pix/Documents/iobroker/node_modules/mdns/lib/dns_sd.js:24:20)
    at Module._compile (module.js:435:26)
    at Object.Module._extensions..js (module.js:442:10)
    2015-12-12 16:45:07.455 - debug: homekit.0 objectDB connected
    2015-12-12 16:45:07.461 - debug: homekit.0 statesDB connected
    2015-12-12 16:45:07.625 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
    2015-12-12 16:45:07.627 - info: homekit.0 requesting all states
    2015-12-12 16:45:07.628 - info: homekit.0 requesting all objects
    2015-12-12 16:45:07.756 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
    2015-12-12 16:45:07.756 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled</anonymous>
    Deshalb lösche ich den Adapter komplett und installiere ganz neu:
    Tataa! :lol:
    MacMini-Ethernet:iobroker pix$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
    > curve25519@1.1.0 install /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519
    > node-gyp rebuild
    >!   CXX(target) Release/obj.target/curve/node_curve.o
      SOLINK_MODULE(target) Release/curve.node
    >! > ed25519@0.0.3 install /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519
    > node-gyp rebuild
    >!   CC(target) Release/obj.target/ed25519/src/ed25519/keypair.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sign.o
      CC(target) Release/obj.target/ed25519/src/ed25519/open.o
      CC(target) Release/obj.target/ed25519/src/ed25519/crypto_verify_32.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_double_scalarmult.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_frombytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_scalarmult_base.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_precomp_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p2_dbl.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_dbl.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_p2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_to_cached.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p3_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_madd.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_add.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_msub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_sub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p3.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_p1p1_to_p2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/ge_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_0.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_1.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_cmov.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_copy.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_neg.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_add.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sub.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_mul.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_sq2.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_invert.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_tobytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnegative.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_isnonzero.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_frombytes.o
      CC(target) Release/obj.target/ed25519/src/ed25519/fe_pow22523.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sc_reduce.o
      CC(target) Release/obj.target/ed25519/src/ed25519/sc_muladd.o
      CXX(target) Release/obj.target/ed25519/src/ed25519.o
      SOLINK_MODULE(target) Release/ed25519.node
    iobroker.homekit@0.0.6 node_modules/iobroker.homekit
    └── hap-nodejs@0.0.7 (srp@0.2.0, node-persist@0.0.6, curve25519@1.1.0, ed25519@0.0.3)
    Bei Installation der Instanz erscheint ein kleiner Fehler
    ! 2015-12-12 16:50:06.409 - info: iobroker add homekit 2015-12-12 16:50:07.233 - info: iobroker host.MacMini-Ethernet.fritz.box install adapter homekit 2015-12-12 16:50:07.259 - info: iobroker got /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin 2015-12-12 16:50:07.288 - info: iobroker upload [1] homekit.admin /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin/index.html index.html text/html 2015-12-12 16:50:07.355 - info: iobroker upload [0] homekit.admin /Users/pix/Documents/iobroker/node_modules/iobroker.homekit/admin/homekit.png homekit.png image/png 2015-12-12 16:50:07.437 - info: iobroker host.MacMini-Ethernet.fritz.box command: node "adapter/homekit/main.js" --install 2015-12-12 16:50:07.577 - info: iobroker module.js:339 throw err; ^ ! Error: Cannot find module '/Users/pix/Documents/adapter/homekit/main.js' at Function.Module._resolveFilename (module.js:337:15) at Function.Module._load (module.js:287:25) at Function.Module.runMain (module.js:467:10) at startup (node.js:136:18) at node.js:963:3 ! 2015-12-12 16:50:07.592 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit created 2015-12-12 16:50:07.691 - info: iobroker host.MacMini-Ethernet.fritz.box create instance homekit 2015-12-12 16:50:07.703 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.uptime created 2015-12-12 16:50:07.737 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memRss created 2015-12-12 16:50:07.771 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memHeapTotal created 2015-12-12 16:50:07.805 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.memHeapUsed created 2015-12-12 16:50:07.841 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.connected created 2015-12-12 16:50:07.875 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0.alive created 2015-12-12 16:50:07.907 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0 2015-12-12 16:50:07.909 - info: iobroker host.MacMini-Ethernet.fritz.box object system.adapter.homekit.0 created 2015-12-12 16:50:07.916 - info: iobroker exit 0 !
    .. läuft aber durch.
    und schließlich die Instanz aktiviert und … :evil: (siehe oben)
    2015-12-12 16:51:30.493 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
    2015-12-12 16:51:30.503 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 18771
    2015-12-12 16:51:30.992 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
    2015-12-12 16:51:30.999 - error: Error: Module version mismatch. Expected 46, got 47.
    at Error (native)
    2015-12-12 16:51:31.062 - debug: homekit.0 objectDB connected
    2015-12-12 16:51:31.067 - debug: homekit.0 statesDB connected
    2015-12-12 16:51:31.280 - info: homekit.0 starting. Version 0.0.6 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
    2015-12-12 16:51:31.283 - info: homekit.0 requesting all states
    2015-12-12 16:51:31.284 - info: homekit.0 requesting all objects
    2015-12-12 16:51:31.405 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)</anonymous>
    Welche Node-Version sollte ich nehmen? Deine 0.12.7 erscheint ja geradezu alpha, wenn ich nur die VErsionsnummern vergleiche :?:
    Pix
    • V
      V
      versteckt
      Ich probiere nachher mal die Version 4.2.3 aus, ev. kann ich es kurzfristig fixen.
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • V
        V
        versteckt
        Hallo, zumindest in WebStorm startet die homekit Instanz mit 4.2.3 ohne Probleme.
        Für mich sieht das nach einem Fehler beim kompilieren aus.
        Bei dir wird weder mdns noch bignum kompiliert.
        Ich muss mir das in Ruhe nochmals ansehen, jetzt steht kochen am Programm.
        Christians-Mac-mini:tmp christian$ npm install https://github.com/husky-koglhof/ioBroker.homekit/tarball/master --production
        > curve25519@1.1.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/curve25519
        > node-gyp rebuild
        > mdns@2.2.11 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
        > node-gyp rebuild
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_sd.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_browse.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_enumerate_domains.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_get_addr_info.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_process_result.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_deallocate.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_ref_sock_fd.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_register.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/dns_service_resolve.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/mdns_utils.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/network_interface.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/socket_watcher.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_ref.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_create.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_deallocate.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_set_value.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_get_length.o
          CXX(target) Release/obj.target/dns_sd_bindings/src/txt_record_buffer_to_object.o
          SOLINK_MODULE(target) Release/dns_sd_bindings.node
        > bignum@0.11.0 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
        > node-gyp configure build
          CXX(target) Release/obj.target/bignum/bignum.o
          SOLINK_MODULE(target) Release/bignum.node
        > ed25519@0.0.3 install /private/tmp/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ed25519
        > node-gyp rebuild
        ├── yalm@2.0.0 (ansi-styles@2.1.0)
        ├── yargs@3.31.0 (camelcase@2.0.1, decamelize@1.1.1, window-size@0.1.4, y18n@3.2.0, os-locale@1.4.0, cliui@3.1.0, string-width@1.0.1)
        └── hap-nodejs@0.0.7 (node-persist@0.0.6, debug@2.2.0, curve25519@1.1.0, mdns@2.2.11, srp@0.2.0, ed25519@0.0.3)
        • fischi87F
          fischi87F
          fischi87
          also ich habe den adapter drauf leider verbindet sich eve immer noch nicht mit diesem. muss man in der config des adapters noch etwas umstellen????
          Mit freundlichen Grüßen
          • V
            V
            versteckt
            Normal nicht, Probier mal beim User die letzten beiden Stellen auf FF zu ändern.
            Gesendet von meinem iPhone mit Tapatalk
            • fischi87F
              fischi87F
              fischi87
              Er startet zwar neu aber er übernimmt das FF nicht?
              Sagt dir das mehr?
              • H
                H
                Headroom68
                gleicher Fehler bei mir, wie bei fischi87.
                Kein Fehler bei der Installation.
                Konfiguration lässt sich nicht ändern und unter Eve wird keine Bridge gefunden.
                netstat -a | grep 51826
                tcp6 0 0 [::]:51826 [::]:* LISTEN
                tcp6 0 66688 Server-Banana-Pi.:51826 iPad-Air.f:49242 ESTABLISHED
                Headroom68
                • V
                  V
                  versteckt
                  Guten Morgen!
                  Das Config Thema kenn ich schon von occ, da habe ich das gleiche Problem.
                  Bitte ändert den Username direkt im Objekt:
                  Diesen Fehler muss ich mir genauer ansehen, bis dorthin sollte diese Lösung funktionieren.
                  • V
                    V
                    versteckt
                    Hallo, Version 0.0.7 ist hochgeladen.
                    Die Parameter werden nun korrekt gespeichert.
                    Zusätzlich wird im Debug die Konfiguration ins Logfile geschrieben.
                    Ausserdem kann der Name angepasst werden. Dies sollte aber nur initial durchgeführt werden.
                    Sollte die Homekit Bridge in iOS nicht sichtbar sein, sollte der Username (MAC Adress Style) geändert werden.
                    • fischi87F
                      fischi87F
                      fischi87
                      Guten morgen, hab die 7er version drauf und bekomme jetzt diesen Fehler im log:
                      • H
                        H
                        Headroom68
                        #66
                        bei mir hat es geholfen den Adapter zu deinstallieren un neu zu installieren.
                        Die Konfiguration kann dann auch geändert werden und der Adapter / Instanz startet ohne Fehler.
                        In Eve wird die Bridge angezeigt. Allerdings schlägt dann das hinzufügen fehl (Verbindung mit Zubehör nicht möglich).
                        Headroom68
                        • V
                          V
                          versteckt
                          #67
                          Ich mach nachher ein paar Screenshots bez. Einrichtung, muss jetzt zur Taekwondo Weihnachtsfeier.
                          • P
                            P
                            pix
                            #68
                            Hallo versteckt,
                            jetzt habe ich 0.0.7 fehlerfrei installalliert (alten Adapter vorher gelöscht). Beim Aktivieren der Instanz erscheint wieder der alte Fehler Error: Module version mismatch. Expected 46, got 47.
                            2015-12-13 12:51:08.835 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                            2015-12-13 12:51:15.981 - info: host.MacMini-Ethernet.fritz.box object change system.adapter.homekit.0
                            2015-12-13 12:51:15.993 - info: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 started with pid 25812
                            2015-12-13 12:51:16.595 - error: uncaught exception: Module version mismatch. Expected 46, got 47.
                            2015-12-13 12:51:16.603 - error: Error: Module version mismatch. Expected 46, got 47.
                            at Error (native)
                            2015-12-13 12:51:16.664 - debug: homekit.0 objectDB connected
                            2015-12-13 12:51:16.670 - debug: homekit.0 statesDB connected
                            2015-12-13 12:51:16.827 - info: homekit.0 starting. Version 0.0.7 in /Users/pix/Documents/iobroker/node_modules/iobroker.homekit
                            2015-12-13 12:51:16.830 - info: homekit.0 requesting all states
                            2015-12-13 12:51:16.831 - info: homekit.0 requesting all objects
                            2015-12-13 12:51:16.944 - error: host.MacMini-Ethernet.fritz.box instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                            2015-12-13 12:51:16.944 - info: host.MacMini-Ethernet.fritz.box Restart adapter system.adapter.homekit.0 because enabled</anonymous>
                            Aber ich weiss nicht, welches Modul das falsche ist :roll:
                            Gruß am Sonntag,
                            Pix
                            • V
                              V
                              versteckt
                              #69
                              Wie besprochen hier mal die Fotostrecke mit meinem iPad:
                              • V
                                V
                                versteckt
                                #70
                                @Pix:
                                Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden.
                                Christians-Mac-mini:ioBroker.homekit christian$ pwd
                                /Users/christian/DEVELOPMENT/node_modules/ioBroker.homekit
                                Christians-Mac-mini:ioBroker.homekit christian$ find . -name *.node -ls
                                8120828       48 -rwxr-xr-x    1 christian        staff               20924 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                                8120718      184 -rwxr-xr-x    1 christian        staff               93460 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                                8120810      208 -rwxr-xr-x    1 christian        staff              104624 Dec 12 18:18 ./node_modules/hap-nodejs/node_modules/mdns/build/Release/dns_sd_bindings.node
                                8120574      144 -rwxr-xr-x    1 christian        staff               69832 Dec 12 18:17 ./node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/build/Release/bignum.node
                                • P
                                  P
                                  pix
                                  #71
                                  Hallo Christian, danke für die Mühe.@versteckt:
                                  @Pix:
                                  Du müsstest vier verschiedene .node Dateien besitzen, welche bei der Installation kompiliert werden. `
                                  Interessant, ich habe nur zwei
                                  pix$ find . -name *.node -ls
                                  37736714       48 -rwxr-xr-x    1 pix              staff               20932 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/curve25519/build/Release/curve.node
                                  37736857      184 -rwxr-xr-x    1 pix              staff               93508 13 Dez 12:46 ./node_modules/hap-nodejs/node_modules/ed25519/build/Release/ed25519.node
                                  MacMini-Ethernet:iobroker.homekit pix$
                                  wo kriege ich die denn her? Ich habe zwischenzeitlich nochmal installiert, aber keine Veränderung.
                                  Gruß,
                                  Pix
                                  • V
                                    V
                                    versteckt
                                    #72
                                    Das finde ich spannend, ansich sollte das node Module hap-nodejs diese für dich kompilieren.
                                    Was passiert eigentlich wenn du folgendes ausführst?
                                    cd /tmp
                                    npm cache clean
                                    npm install hap-nodejs
                                    Dadurch wird dein NPM Cache ausgeleert und das zugrunde liegende Modul hap-nodejs in /tmp/node_modules/hap-nodejs
                                    installiert / kompiliert.
                                    Poste bitte mal diese Ausgabe.
                                    • fischi87F
                                      fischi87F
                                      fischi87
                                      #73
                                      bei mir läuft das Programm nun ihnen fehlen, werde es die tage testen und weiter berichten!!!
                                      top sache!!!!
                                      • P
                                        P
                                        pix
                                        #74
                                        @versteckt:
                                        cd /tmp
                                        npm cache clean
                                        Poste bitte mal diese Ausgabe. `
                                        npm cache clean ging nur mit sudo, dann kein Problem
                                        anschließend diese Ausgabe:
                                        MacMini-Ethernet:tmp pix$ npm install hap-node.js
                                        npm ERR! Darwin 15.0.0
                                        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "hap-node.js"
                                        npm ERR! node v4.2.3
                                        npm ERR! npm  v2.14.7
                                        npm ERR! code E404
                                        npm ERR! 404 Registry returned 404 for GET on https://registry.npmjs.org/hap-node.js
                                        npm ERR! 404
                                        npm ERR! 404 'hap-node.js' is not in the npm registry.
                                        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                        npm ERR! 404
                                        npm ERR! 404 Note that you can also install from a
                                        npm ERR! 404 tarball, folder, http url, or git url.
                                        npm ERR! Please include the following file with any support request:
                                        npm ERR!     /private/tmp/npm-debug.log
                                        Pix
                                        • V
                                          V
                                          versteckt
                                          #75
                                          Du hast 'nen Punkt zuviel, das Modul heisst hap-nodejs
                                          84.2k
