  4. [gelöst] TR-064
[gelöst] TR-064
tr-064 adapter fehlerfritz
6 Beiträge 4 Kommentatoren 716 Aufrufe 3 Beobachtet
  • L Offline
    Lacoste9
    schrieb am zuletzt editiert von Lacoste9
    Moin
    ich habe folgendes Problem
    host.raspberrypi	2019-12-03 09:43:40.539	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2019-12-03 09:43:40.538	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.raspberrypi	2019-12-03 09:43:40.537	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.raspberrypi	2019-12-03 09:43:40.536	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.raspberrypi	2019-12-03 09:43:40.535	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2019-12-03 09:43:40.534	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2019-12-03 09:43:40.534	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2019-12-03 09:43:40.533	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2019-12-03 09:43:40.532	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2019-12-03 09:43:40.531	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
    host.raspberrypi	2019-12-03 09:43:40.531	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.raspberrypi	2019-12-03 09:43:40.530	error	Caught by controller[0]: TypeError: fns.adapter is not a function
    host.raspberrypi	2019-12-03 09:43:40.529	error	Caught by controller[0]: ^
    host.raspberrypi	2019-12-03 09:43:40.528	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.raspberrypi	2019-12-03 09:43:40.526	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    host.raspberrypi	2019-12-03 09:43:37.517	info	instance system.adapter.tr-064.0 started with pid 31273
    host.raspberrypi	2019-12-03 09:43:07.470	info	Restart adapter system.adapter.tr-064.0 because enabled
    hat evtl jemand eine Idee?
    deinst. neu installiert habe ich schon. brachte leider nix
    MFG
    • L Lacoste9
      Moin
      MFG
      @Lacoste9
      Ich nutze diesen Adapter nicht.
      Sieh mal hier. Wäre eine Möglichkeit. tr-064 ist auch von soef
      • J.A.R.V.I.S.J Offline
        J.A.R.V.I.S.
        hey,
        versuch mal folgendes:
        cd /opt/iobroker/node_modules/iobroker.tr-064/
        npm install soef
        • R Offline
          RappiRN
          Verwendest du die community Version?
          Wenn nicht probiere bitte diese aus, die sollte weniger Probleme machen!
          Enrico
          • L Offline
            Lacoste9
            Community Version scheint zu laufen.
            Danke für den Hinweis
            wie kann ich ein Topic schliessen oder als gelöst makieren?
            J.A.R.V.I.S.J 1 Antwort Letzte Antwort
            • L Lacoste9
              J.A.R.V.I.S.
              @Lacoste9 [gelöst] in den Titel schreiben.
