  4. Caught + CHMOD Error
errorr chmod caught
3 Beiträge 3 Kommentatoren 257 Aufrufe 3 Beobachtet
    kaifly
    ich erhalte im Logfile alle paar Sekunden diese ganzen Error-Meldungen. Da ich doch sehr neu bin im Thema Raspberry PI habe ich leider keine Ahnung, was ich noch ausprobieren kann... Ich hoffe, mir kann hier jemand einen Tipp geben.
    Liebe Grüße
    Kai
    host.raspberrypi	2019-12-02 21:39:17.779	info	Restart adapter system.adapter.info.0 because enabled
    host.raspberrypi	2019-12-02 21:39:17.778	info	instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
    host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    host.raspberrypi	2019-12-02 21:39:17.777	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:81767)
    host.raspberrypi	2019-12-02 21:39:17.776	error	Caught by controller[0]: at adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
    host.raspberrypi	2019-12-02 21:39:17.776	error	Caught by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
    host.raspberrypi	2019-12-02 21:39:17.775	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
    host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.raspberrypi	2019-12-02 21:39:17.774	error	Caught by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
    host.raspberrypi	2019-12-02 21:39:17.773	error	Caught by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
    host.raspberrypi	2019-12-02 21:39:17.772	error	Caught by controller[0]: TypeError: Cannot read property 'split' of undefined
    Gerade auch ein Update auf die aktuelle JS-Controller Version versucht und da klingt es nur so (Auszug...)
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/none.node': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/obj.target': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Release/obj.target/none.node': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/Makefile': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/osx-temperature-sensor/build/none.target.mk': Die Operation ist nicht erlaubt
    Hostname
    raspberrypi
    Betriebssystem
    linux
    Architektur
    arm
    CPUs
    Geschwindigkeit
    1400 MHz
    Modell
    ARMv7 Processor rev 4 (v7l)
    RAM
    926.08 MB
    System Betriebszeit
    00:07:15
    Node.js
    v10.16.3 (Es gibt eine neuere Version: v10.17.0)
    NPM
    6.9.0
    Festplatte Größe
    12.6 GB
    Festplatte frei
    5.81 GB
    Anzahl der Adapter
    260
    Betriebszeit
    00:10:23
    Aktive Instanzen
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc.
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    • arteckA Offline
      arteckA Offline
      arteck
      welche js-controller Version ??
      • R Offline
        roolix
        Bei mir dieselben Fehler:
        Hardwaresystem: PI4
        Arbeitsspeicher: 4GB
        Betriebssystem: Debian buster
        Nodejs-Version: 10.19.0
        NPM-Version: 6.13.4
        js-controller: 2.2.8 (macht man doch über iobroker version, oder?)
        Installationsart: Skript (ursprünglich)
        Image genutzt: Ja
        Stoppe ich den Adapter "iobroker Informationsseite" (info.0) verschwinden die Fehler.
        as of August '23
        RPi4
        Plattform: linux
        RAM: 3.75 GB
        Node.js: v18.17.1
        NPM: 9.6.7
        82.9k
