  4. [iot] Andere Probleme mit dem iot-Adapter bzw der Nutzung
cloud
256 Beiträge 48 Kommentatoren 64.1k Aufrufe 30 Beobachtet
  • fantasticmaxpowerF fantasticmaxpower
    Hier ist jetzt nochmal die log nach einem Neustart und anschließend grünem iot adapter. Kann mir bitte jemand sagen was hier falsch läuft?
    2019-10-15 16:49:27.914 - info: host.ioBroker-RasPi iobroker.js-controller version 1.5.14 js-controller starting
    2019-10-15 16:49:27.924 - info: host.ioBroker-RasPi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2019-10-15 16:49:27.924 - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v8.16.0
    2019-10-15 16:49:27.929 - info: host.ioBroker-RasPi ip addresses: 192.168.0.206 2a02:908:1b2:7ea0:88ec:707b:3423:742f fe80::98ce:337c:aafc:59c2
    2019-10-15 16:49:29.046 - info: host.ioBroker-RasPi inMem-objects listening on port 9001
    2019-10-15 16:49:29.072 - info: host.ioBroker-RasPi InMemoryDB connected
    2019-10-15 16:49:29.131 - info: host.ioBroker-RasPi 32 instances found
    2019-10-15 16:49:29.185 - info: host.ioBroker-RasPi starting 16 instances
    2019-10-15 16:49:29.417 - info: host.ioBroker-RasPi instance system.adapter.admin.0 started with pid 668
    2019-10-15 16:49:29.436 - info: host.ioBroker-RasPi States connected to redis: 127.0.0.1:6379
    2019-10-15 16:49:32.980 - error: host.ioBroker-RasPi instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:32.981 - info: host.ioBroker-RasPi Restart adapter system.adapter.admin.0 because enabled
    2019-10-15 16:49:33.216 - info: host.ioBroker-RasPi instance system.adapter.web.0 started with pid 678
    2019-10-15 16:49:36.149 - error: host.ioBroker-RasPi instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:36.150 - info: host.ioBroker-RasPi Restart adapter system.adapter.web.0 because enabled
    2019-10-15 16:49:37.250 - info: host.ioBroker-RasPi instance system.adapter.history.0 started with pid 689
    2019-10-15 16:49:38.586 - error: host.ioBroker-RasPi instance system.adapter.history.0 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:38.586 - info: host.ioBroker-RasPi Restart adapter system.adapter.history.0 because enabled
    2019-10-15 16:49:41.263 - info: host.ioBroker-RasPi instance system.adapter.hm-rpc.1 started with pid 699
    2019-10-15 16:49:42.837 - error: host.ioBroker-RasPi instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:42.838 - info: host.ioBroker-RasPi Restart adapter system.adapter.hm-rpc.1 because enabled
    2019-10-15 16:49:45.252 - info: host.ioBroker-RasPi instance system.adapter.hm-rpc.2 started with pid 709
    2019-10-15 16:49:46.752 - error: host.ioBroker-RasPi instance system.adapter.hm-rpc.2 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:46.752 - info: host.ioBroker-RasPi Restart adapter system.adapter.hm-rpc.2 because enabled
    2019-10-15 16:49:49.271 - info: host.ioBroker-RasPi instance system.adapter.hm-rega.1 started with pid 720
    2019-10-15 16:49:51.966 - error: host.ioBroker-RasPi instance system.adapter.hm-rega.1 terminated with code 7 (Adapter already running)
    2019-10-15 16:49:51.966 - info: host.ioBroker-RasPi Restart adapter system.adapter.hm-rega.1 because enabled
    2019-10-15 16:49:53.284 - info: host.ioBroker-RasPi instance system.adapter.pushover.0 started with pid 730
    2019-10-15 17:11:18.950 - info: pushover.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:19.014 - info: pushover.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.pushover, node: v8.16.0
    2019-10-15 17:11:27.174 - info: host.ioBroker-RasPi instance system.adapter.admin.0 started with pid 751
    2019-10-15 17:11:29.657 - info: admin.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:29.745 - info: admin.0 starting. Version 3.6.7 in /opt/iobroker/node_modules/iobroker.admin, node: v8.16.0
    2019-10-15 17:11:29.812 - info: admin.0 requesting all states
    2019-10-15 17:11:29.815 - info: admin.0 requesting all objects
    2019-10-15 17:11:29.817 - info: admin.0 Request actual repository...
    2019-10-15 17:11:30.815 - info: host.ioBroker-RasPi instance system.adapter.web.0 started with pid 765
    2019-10-15 17:11:31.465 - info: admin.0 received all states
    2019-10-15 17:11:32.587 - info: web.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:32.656 - info: web.0 starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.web, node: v8.16.0
    2019-10-15 17:11:32.782 - info: host.ioBroker-RasPi instance system.adapter.history.0 started with pid 779
    2019-10-15 17:11:32.945 - info: admin.0 received all objects
    2019-10-15 17:11:32.978 - warn: admin.0 No repository source configured
    2019-10-15 17:11:33.028 - info: admin.0 http server listening on port 8081
    2019-10-15 17:11:33.029 - info: admin.0 Use link "http://localhost:8081" to configure.
    2019-10-15 17:11:33.179 - info: host.ioBroker-RasPi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2019-10-15 17:11:33.773 - info: web.0 socket.io server listening on port 8082
    2019-10-15 17:11:33.779 - info: web.0 http server listening on port 8082
    2019-10-15 17:11:34.449 - info: history.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:34.538 - info: history.0 starting. Version 1.8.6 in /opt/iobroker/node_modules/iobroker.history, node: v8.16.0
    2019-10-15 17:11:34.631 - info: history.0 enabled logging of Außentemperatur (Count=1), Alias=true
    2019-10-15 17:11:34.632 - info: history.0 enabled logging of hm-rpc.2.LEQ0846785.4.VALVE_STATE (Count=2), Alias=false
    2019-10-15 17:11:34.632 - info: history.0 enabled logging of hm-rpc.2.MEQ0053460.4.VALVE_STATE (Count=3), Alias=false
    2019-10-15 17:11:34.633 - info: history.0 enabled logging of hm-rpc.2.MEQ0055761.4.VALVE_STATE (Count=4), Alias=false
    2019-10-15 17:11:34.633 - info: history.0 enabled logging of hm-rpc.2.MEQ0055771.4.VALVE_STATE (Count=5), Alias=false
    2019-10-15 17:11:34.633 - info: history.0 enabled logging of Badezimmer klein Temperatur (Count=6), Alias=true
    2019-10-15 17:11:34.634 - info: history.0 enabled logging of hm-rpc.2.MEQ0451694.4.VALVE_STATE (Count=7), Alias=false
    2019-10-15 17:11:34.634 - info: history.0 enabled logging of Wohn- Esszimmer Temperatur (Count=8), Alias=true
    2019-10-15 17:11:34.634 - info: history.0 enabled logging of Kinderzimmer Temperatur (Count=9), Alias=true
    2019-10-15 17:11:34.635 - info: history.0 enabled logging of Badezimmer Temperatur (Count=10), Alias=true
    2019-10-15 17:11:34.635 - info: history.0 enabled logging of hm-rpc.2.OEQ1670804.1.TEMPERATURE (Count=11), Alias=false
    2019-10-15 17:11:34.635 - info: history.0 enabled logging of hm-rpc.2.OEQ1714060.4.VALVE_STATE (Count=12), Alias=false
    2019-10-15 17:11:35.622 - info: admin.0 Repository received successfully.
    2019-10-15 17:11:37.058 - info: host.ioBroker-RasPi instance system.adapter.hm-rpc.1 started with pid 793
    2019-10-15 17:11:38.621 - info: hm-rpc.1 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:38.683 - info: hm-rpc.1 starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.16.0
    2019-10-15 17:11:38.837 - info: hm-rpc.1 [META] Meta data updated
    2019-10-15 17:11:40.936 - info: host.ioBroker-RasPi instance system.adapter.hm-rpc.2 started with pid 807
    2019-10-15 17:11:41.459 - info: host.ioBroker-RasPi instance system.adapter.radar.0 started with pid 813
    2019-10-15 17:11:42.687 - info: hm-rpc.1 binrpc server is trying to listen on 192.168.0.206:18701
    2019-10-15 17:11:42.688 - info: hm-rpc.1 binrpc client is trying to connect to 192.168.0.10:8701/ with ["xmlrpc_bin://192.168.0.206:18701","hm-rpc.1"]
    2019-10-15 17:11:42.843 - info: hm-rpc.2 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:42.925 - info: hm-rpc.1 binrpc -> listDevices 18
    2019-10-15 17:11:42.934 - info: hm-rpc.2 starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.16.0
    2019-10-15 17:11:42.954 - info: hm-rpc.1 new CUxD devices/channels after filter: 0
    2019-10-15 17:11:42.960 - info: hm-rpc.1 Connected
    2019-10-15 17:11:43.145 - info: hm-rpc.2 [META] Meta data updated
    2019-10-15 17:11:43.491 - info: radar.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:43.631 - info: radar.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.radar, node: v8.16.0
    2019-10-15 17:11:43.894 - info: radar.0 radar set to scan every 90 sec and printers every 500 scans.
    2019-10-15 17:11:43.895 - info: radar.0 BT Bin Dir = '/opt/iobroker/node_modules/iobroker.radar\bin\bluetoothview\'
    2019-10-15 17:11:45.653 - info: host.ioBroker-RasPi instance system.adapter.javascript.0 started with pid 847
    2019-10-15 17:11:46.315 - info: host.ioBroker-RasPi instance system.adapter.hm-rega.1 started with pid 853
    2019-10-15 17:11:46.795 - info: hm-rpc.2 binrpc server is trying to listen on 192.168.0.206:12001
    2019-10-15 17:11:46.796 - info: hm-rpc.2 binrpc client is trying to connect to 192.168.0.10:2001/ with ["xmlrpc_bin://192.168.0.206:12001","hm-rpc.2"]
    2019-10-15 17:11:46.854 - info: hm-rpc.2 binrpc <- system.listMethods ["hm-rpc.2"]
    2019-10-15 17:11:46.875 - info: hm-rpc.2 binrpc <- listDevices ["hm-rpc.2"]
    2019-10-15 17:11:46.933 - info: hm-rpc.2 binrpc -> 248 devices
    2019-10-15 17:11:47.194 - info: hm-rpc.2 Connected
    2019-10-15 17:11:48.829 - info: hm-rega.1 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:48.929 - info: hm-rega.1 starting. Version 2.4.12 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v8.16.0
    2019-10-15 17:11:49.024 - info: hm-rega.1 subscribe hm-rpc.2.BidCoS-RF.50.PRESS_SHORT
    2019-10-15 17:11:49.130 - info: hm-rega.1 ReGaHSS 192.168.0.10 up
    2019-10-15 17:11:49.276 - info: hm-rega.1 time difference local-ccu 0s
    2019-10-15 17:11:49.320 - info: hm-rega.1 update favorites to enum.favorites
    2019-10-15 17:11:49.380 - info: hm-rega.1 update functions to enum.functions
    2019-10-15 17:11:49.494 - info: host.ioBroker-RasPi instance scheduled system.adapter.ical.0 0 * * * *
    2019-10-15 17:11:49.507 - info: hm-rega.1 update rooms to enum.rooms
    2019-10-15 17:11:49.512 - info: host.ioBroker-RasPi instance system.adapter.ical.0 started with pid 869
    2019-10-15 17:11:50.562 - info: hm-rega.1 hm-rpc.2.MEQ0345075.1 has been added to room Wohn- Esszimmer
    2019-10-15 17:11:50.563 - info: hm-rega.1 hm-rpc.2.LEQ0751823.1 has been added to room Wohn- Esszimmer
    2019-10-15 17:11:50.563 - info: hm-rega.1 hm-rpc.2.LEQ0846785.4 has been added to room Wohn- Esszimmer
    2019-10-15 17:11:50.564 - info: hm-rega.1 hm-rpc.2.MEQ0397792.2 has been removed from room Wohn- Esszimmer
    2019-10-15 17:11:50.564 - info: hm-rega.1 hm-rpc.2.MEQ0397792.1 has been removed from room Wohn- Esszimmer
    2019-10-15 17:11:50.564 - info: hm-rega.1 hm-rpc.2.MEQ0399707.2 has been removed from room Wohn- Esszimmer
    2019-10-15 17:11:50.568 - info: hm-rega.1 hm-rpc.2.OEQ0538939.3 has been added to room Schlafzimmer
    2019-10-15 17:11:50.568 - info: hm-rega.1 hm-rpc.2.OEQ1714060.4 has been added to room Schlafzimmer
    2019-10-15 17:11:50.569 - info: hm-rega.1 hm-rpc.2.OEQ0484079.1 has been removed from room Schlafzimmer
    2019-10-15 17:11:50.569 - info: hm-rega.1 hm-rpc.2.OEQ0484079.2 has been removed from room Schlafzimmer
    2019-10-15 17:11:50.572 - info: hm-rega.1 hm-rpc.2.NEQ0946032.1 has been added to room Flur
    2019-10-15 17:11:50.573 - info: hm-rega.1 hm-rpc.2.MEQ0670337.2 has been removed from room Flur
    2019-10-15 17:11:53.007 - info: radar.0 Init item Handy_Max with { name: 'Handy_Max', ip: '192.168.0.136', macs: '', bluetooth: '76:BB:46:00:00:1A', id: 'Handy_Max', hasBT: true, printer: false, hasECB: false, hasIP: true, rip: '192.168.0.136' }
    2019-10-15 17:11:53.062 - info: radar.0 Init item Handy_Jelena with { name: 'Handy_Jelena', ip: '192.168.0.178', macs: 'B4:8B:19:E5:F8:00', bluetooth: 'B4:8B:19:E5:F8:01', id: 'Handy_Jelena', hasMAC: [ 'B4:8B:19:E5:F8:00' ], hasBT: true, printer: false, hasECB: false, hasIP: true, rip: '192.168.0.178' }
    2019-10-15 17:11:53.957 - info: host.ioBroker-RasPi instance system.adapter.iot.0 started with pid 882
    2019-10-15 17:11:55.296 - info: javascript.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:55.626 - info: javascript.0 starting. Version 3.6.4 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.16.0
    2019-10-15 17:11:55.798 - info: javascript.0 requesting all states
    2019-10-15 17:11:55.801 - info: javascript.0 requesting all objects
    2019-10-15 17:11:55.833 - info: ical.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:56.738 - info: hm-rega.1 got 21 programs
    2019-10-15 17:11:56.890 - info: hm-rega.1 added/updated 21 programs
    2019-10-15 17:11:56.891 - info: hm-rega.1 deleted 0 programs
    2019-10-15 17:11:57.454 - info: javascript.0 received all states
    2019-10-15 17:11:57.684 - info: hm-rega.1 got 15 variables
    2019-10-15 17:11:57.763 - info: hm-rega.1 added/updated 15 variables
    2019-10-15 17:11:57.764 - info: hm-rega.1 deleted 0 variables
    2019-10-15 17:11:57.765 - info: hm-rega.1 request state values
    2019-10-15 17:11:57.986 - info: ical.0 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v8.16.0
    2019-10-15 17:11:58.248 - info: iot.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:11:58.605 - info: iot.0 starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
    2019-10-15 17:11:58.707 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2019-10-15 17:11:58.907 - info: hm-rega.1 got state values
    2019-10-15 17:11:59.263 - info: ical.0 processing URL: Abfallkalender https://calendar.google.com/calendar/ical/5sj5sklb37t0dmuchmgoh81gm0%40group.calendar.google.com/private-2972214c632eabd90b51ae825f09ff2f/basic.ics
    2019-10-15 17:12:00.657 - info: radar.0 No UWZ warning because of Delay is 0
    2019-10-15 17:12:00.658 - info: radar.0 radar adapter initialized 2 devices, ExternalNetwork = 300.
    2019-10-15 17:12:00.659 - info: radar.0 radar set use of noble(true), fping(true), doMac(true), doHci(true), doBtv(false) and doUwz(null,0,0,,false).
    2019-10-15 17:12:01.267 - info: javascript.0 received all objects
    2019-10-15 17:12:01.501 - info: javascript.0 Start javascript script.js.Briefkasten.Briefkasten_voll_leer
    2019-10-15 17:12:01.533 - info: javascript.0 script.js.Briefkasten.Briefkasten_voll_leer: registered 1 subscription and 0 schedules
    2019-10-15 17:12:01.534 - info: javascript.0 Start javascript script.js.Anwesenheit.Anwesenheit_max
    2019-10-15 17:12:01.542 - info: javascript.0 script.js.Anwesenheit.Anwesenheit_max: registered 1 subscription and 0 schedules
    2019-10-15 17:12:01.543 - info: javascript.0 Start javascript script.js.Anwesenheit.Anwesenheit_jelena
    2019-10-15 17:12:01.548 - info: javascript.0 script.js.Anwesenheit.Anwesenheit_jelena: registered 1 subscription and 0 schedules
    2019-10-15 17:12:01.549 - info: javascript.0 Start javascript script.js.Anwesenheit.Abwesenheit_Bedingung
    2019-10-15 17:12:01.554 - info: javascript.0 script.js.Anwesenheit.Abwesenheit_Bedingung: registered 1 subscription and 0 schedules
    2019-10-15 17:12:01.555 - info: javascript.0 Start javascript script.js.Anwesenheit.Abwesenheit_master
    2019-10-15 17:12:01.561 - info: javascript.0 script.js.Anwesenheit.Abwesenheit_master: registered 2 subscriptions and 0 schedules
    2019-10-15 17:12:01.563 - info: javascript.0 Start javascript script.js.Internetradio.Wandtaster_Bedienung
    2019-10-15 17:12:01.569 - info: javascript.0 script.js.Internetradio.Wandtaster_Bedienung: registered 12 subscriptions and 0 schedules
    2019-10-15 17:12:01.896 - info: iot.0 Connection changed: connect
    2019-10-15 17:12:04.843 - info: host.ioBroker-RasPi instance system.adapter.ical.0 terminated with code 0 (OK)
    2019-10-15 17:12:05.219 - info: iot.0 Request google home devices
    2019-10-15 17:12:15.242 - info: iot.0 Request google home devices
    2019-10-15 17:12:25.240 - info: iot.0 Request google home devices
    2019-10-15 17:12:26.478 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Handy_Max
    2019-10-15 17:12:26.713 - info: radar.0 Adapter initialization finished!
    2019-10-15 17:12:35.252 - info: iot.0 Request google home devices
    2019-10-15 17:12:44.745 - info: iot.0 Request google home devices
    2019-10-15 17:12:54.771 - info: iot.0 Request google home devices
    2019-10-15 17:12:56.326 - info: host.ioBroker-RasPi object change system.adapter.iot.0
    2019-10-15 17:12:56.331 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0
    2019-10-15 17:12:56.331 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0 killing pid 882
    2019-10-15 17:12:56.398 - error: Caught by controller[3]: (node:882) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'smartName' of undefined
    2019-10-15 17:12:56.398 - error: Caught by controller[3]: at GoogleHome.getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1316:38)
    2019-10-15 17:12:56.398 - error: Caught by controller[3]: at Object.keys.forEach.id (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1704:38)
    2019-10-15 17:12:56.398 - error: Caught by controller[3]: at Array.forEach ()
    2019-10-15 17:12:56.399 - error: Caught by controller[3]: at _readObjects.then.data (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1703:38)
    2019-10-15 17:12:56.399 - error: Caught by controller[4]: (node:882) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 6)
    2019-10-15 17:12:56.399 - error: Caught by controller[5]: (node:882) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'smartName' of undefined
    2019-10-15 17:12:56.399 - error: Caught by controller[5]: at GoogleHome.getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1316:38)
    2019-10-15 17:12:56.400 - error: Caught by controller[5]: at Object.keys.forEach.id (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1704:38)
    2019-10-15 17:12:56.400 - error: Caught by controller[5]: at Array.forEach ()
    2019-10-15 17:12:56.400 - error: Caught by controller[5]: at _readObjects.then.data (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1703:38)
    2019-10-15 17:12:56.400 - error: Caught by controller[6]: (node:882) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 7)
    2019-10-15 17:12:56.400 - error: Caught by controller[7]: (node:882) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'smartName' of undefined
    2019-10-15 17:12:56.401 - error: Caught by controller[7]: at GoogleHome.getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1316:38)
    2019-10-15 17:12:56.401 - error: Caught by controller[7]: at Object.keys.forEach.id (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1704:38)
    2019-10-15 17:12:56.401 - error: Caught by controller[7]: at Array.forEach ()
    2019-10-15 17:12:56.401 - error: Caught by controller[7]: at _readObjects.then.data (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1703:38)
    2019-10-15 17:12:56.401 - error: Caught by controller[8]: (node:882) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 8)
    2019-10-15 17:12:56.402 - info: host.ioBroker-RasPi instance system.adapter.iot.0 terminated with code 0 (OK)
    2019-10-15 17:12:58.865 - info: host.ioBroker-RasPi instance system.adapter.iot.0 started with pid 942
    2019-10-15 17:13:01.084 - info: iot.0 States connected to redis: 127.0.0.1:6379
    2019-10-15 17:13:01.217 - info: iot.0 starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v8.16.0
    2019-10-15 17:13:01.263 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
    2019-10-15 17:13:08.374 - info: iot.0 Connection changed: connect
    Ich weiss nicht mehr weiter...
    tombox
    @fantasticmaxpower da es ja ein google home problem ist kannst du ruhig in den thread kommen:
    https://forum.iobroker.net/topic/24061/google-home-assistant-iobroker-einrichten-nutzen/
    Es scheint so als hättest du die eignen Einstellungen in den erweiterten Optionen aktiviert kann es sein?
    Wenn nicht dann mal die version von mir via github installieren eine Anleitung steht im Beitrag 1 und schauen ob sich die Google Devices dann wieder laden.
    fantasticmaxpowerF 1 Antwort Letzte Antwort
    • T tombox
      fantasticmaxpowerF Offline
      fantasticmaxpower
      schrieb am zuletzt editiert von fantasticmaxpower
      @tombox Ich habe auf deinen Hinweis geprüft ob der Haken sitzt. Er saß nicht. Ich habe ihn mal gesetzt und jetzt hat er die Geräte geladen. Ist das jetzt gut oder schlecht? Muss der Haken sitzen oder nicht?
      In der Google Home App werden mir jetzt auch die Geräte angezeigt freu
        tombox
        @fantasticmaxpower Eigentlich sollte man ihn nicht aktivieren außer man weiß genau das man ihn braucht. Hast du mehrere Instanzen von iot laufen oder andere Auffälligkeiten?
        • T tombox
          fantasticmaxpower
          @tombox Nein ich habe nur eine iot Instanz am laufen. Andere Auffälligkeiten sind mir bisher nicht aufgefallen!
          Der Log sieht auch normal aus, oder fällt da was auf?
          2019-10-15 21:32:35.089 - info: iot.0 Request google home devices
          2019-10-15 21:32:41.135 - info: iot.0 Request google home devices
          2019-10-15 21:32:51.176 - info: iot.0 Request google home devices
          2019-10-15 21:33:01.179 - info: iot.0 Request google home devices
          2019-10-15 21:33:14.830 - info: iot.0 Request google home devices
          2019-10-15 21:33:24.870 - info: iot.0 Request google home devices
          2019-10-15 21:33:34.974 - info: iot.0 Request google home devices
          2019-10-15 21:33:44.944 - info: iot.0 Request google home devices
          2019-10-15 21:33:52.112 - info: iot.0 Request google home devices
          2019-10-15 21:33:54.936 - info: iot.0 Request google home devices
          2019-10-15 21:34:01.289 - info: iot.0 Request google home devices
          2019-10-15 21:34:02.205 - info: iot.0 Request google home devices
          2019-10-15 21:34:07.991 - info: iot.0 Request google home devices
          2019-10-15 21:34:17.994 - info: iot.0 Request google home devices
          2019-10-15 21:34:30.522 - info: iot.0 Request google home devices
          2019-10-15 21:34:42.137 - info: iot.0 Request google home devices
          2019-10-15 21:34:52.139 - info: iot.0 Request google home devices
          2019-10-15 21:35:02.689 - info: iot.0 Request google home devices
          2019-10-15 21:35:12.606 - info: iot.0 Request google home devices
          2019-10-15 21:35:16.653 - info: iot.0 Request google home devices
          2019-10-15 21:35:23.423 - info: iot.0 Request google home devices
          2019-10-15 21:35:33.472 - info: iot.0 Request google home devices
          2019-10-15 21:35:39.765 - info: iot.0 Request google home devices
          2019-10-15 21:35:49.828 - info: iot.0 Request google home devices
          2019-10-15 21:35:59.830 - info: iot.0 Request google home devices
          2019-10-15 21:36:09.829 - info: iot.0 Request google home devices
          2019-10-15 21:36:10.934 - info: iot.0 Request google home devices
          2019-10-15 21:36:19.832 - info: iot.0 Request google home devices
          2019-10-15 21:36:20.937 - info: iot.0 Request google home devices
          2019-10-15 21:36:28.712 - info: iot.0 Request google home devices
          2019-10-15 21:36:39.440 - info: iot.0 Request google home devices
          2019-10-15 21:36:49.950 - info: iot.0 Request google home devices
          2019-10-15 21:37:00.442 - info: iot.0 Request google home devices
          2019-10-15 21:37:11.440 - info: iot.0 Request google home devices
          2019-10-15 21:41:47.922 - info: iot.0 Request google home devices
          2019-10-15 21:41:58.479 - info: iot.0 Request google home devices
          2019-10-15 21:42:09.465 - info: iot.0 Request google home devices
          2019-10-15 21:42:20.437 - info: iot.0 Request google home devices
          2019-10-15 21:42:31.435 - info: iot.0 Request google home devices
          2019-10-15 21:42:55.446 - info: host.ioBroker-RasPi object change system.adapter.iot.0
          2019-10-15 21:42:55.447 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0
          2019-10-15 21:42:55.447 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0 killing pid 13013
          2019-10-15 21:42:55.498 - error: Caught by controller[5]: (node:13013) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'smartName' of undefined
          2019-10-15 21:42:55.499 - error: Caught by controller[5]: at GoogleHome.getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1316:38)
          2019-10-15 21:42:55.499 - error: Caught by controller[5]: at Object.keys.forEach.id (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1704:38)
          2019-10-15 21:42:55.499 - error: Caught by controller[5]: at Array.forEach ()
          2019-10-15 21:42:55.499 - error: Caught by controller[5]: at _readObjects.then.data (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1703:38)
          2019-10-15 21:42:55.499 - error: Caught by controller[6]: (node:13013) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 94)
          2019-10-15 21:42:55.499 - info: host.ioBroker-RasPi instance system.adapter.iot.0 terminated with code 156 ()
          2019-10-15 21:42:57.973 - info: host.ioBroker-RasPi instance system.adapter.iot.0 started with pid 13277
          2019-10-15 21:43:00.211 - info: iot.0 States connected to redis: 127.0.0.1:6379
          2019-10-15 21:43:00.351 - info: iot.0 starting. Version 1.1.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
          2019-10-15 21:43:00.395 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2019-10-15 21:43:02.679 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:43:02.733 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:43:02.845 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:43:02.961 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:43:03.027 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:43:03.040 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:43:03.082 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:43:03.124 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:43:03.181 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:43:03.224 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:43:03.254 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:43:03.285 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:43:03.315 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:43:03.352 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:43:03.382 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:43:03.401 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:43:03.421 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:43:03.440 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:43:03.459 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:43:03.477 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:43:03.496 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:43:03.526 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:43:03.557 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:43:03.570 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:43:03.594 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:43:03.625 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:43:03.655 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:43:03.686 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:43:03.880 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:43:03.881 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:43:03.882 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:43:03.882 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:43:03.882 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:43:03.883 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:43:03.884 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:43:03.884 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:43:03.884 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:43:03.885 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:43:03.885 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:43:03.885 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:43:03.886 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:43:03.886 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:43:03.886 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:43:03.887 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:43:03.887 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:43:03.887 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:43:03.888 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:43:03.888 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:43:03.888 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:43:03.890 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:43:03.890 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:43:03.890 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:43:03.891 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:43:03.892 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:43:03.892 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:43:03.892 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:43:03.913 - info: iot.0 Connection changed: connect
          2019-10-15 21:43:04.190 - error: iot.0 [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically: {"error":"Email not found or URL key not found"}
          2019-10-15 21:43:04.191 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:43:04.192 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:43:47.240 - info: iot.0 Request google home devices
          2019-10-15 21:43:48.243 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:43:48.244 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:43:48.244 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:43:48.245 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:43:48.245 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:43:48.246 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:43:48.246 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:43:48.246 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:43:48.247 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:43:48.247 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:43:48.248 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:43:48.248 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:43:48.248 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:43:48.249 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:43:48.249 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:43:48.250 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:43:48.250 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:43:48.250 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:43:48.251 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:43:48.251 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:43:48.251 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:43:48.253 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:43:48.253 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:43:48.254 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:43:48.254 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:43:48.255 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:43:48.255 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:43:48.256 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:43:48.267 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:47:43.802 - info: iot.0 Request google home devices
          2019-10-15 21:47:44.881 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:47:44.882 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:47:44.883 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:47:44.883 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:47:44.884 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:47:44.884 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:47:44.885 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:47:44.885 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:47:44.885 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:47:44.886 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:47:44.886 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:47:44.886 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:47:44.887 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:47:44.887 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:47:44.887 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:47:44.888 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:47:44.889 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:47:44.889 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:47:44.889 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:47:44.890 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:47:44.890 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:47:44.891 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:47:44.892 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:47:44.892 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:47:44.892 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:47:44.893 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:47:44.894 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:47:44.894 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:47:44.906 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:48:28.907 - info: iot.0 Request google home devices
          2019-10-15 21:48:29.937 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:48:29.938 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:48:29.938 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:48:29.939 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:48:29.939 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:48:29.940 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:48:29.941 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:48:29.941 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:48:29.942 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:48:29.942 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:48:29.943 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:48:29.943 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:48:29.944 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:48:29.944 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:48:29.945 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:48:29.946 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:48:29.946 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:48:29.947 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:48:29.947 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:48:29.948 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:48:29.948 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:48:29.949 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:48:29.950 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:48:29.950 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:48:29.951 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:48:29.952 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:48:29.952 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:48:29.953 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:48:29.965 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:54:38.169 - info: iot.0 Request google home devices
          2019-10-15 21:54:39.070 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:54:39.071 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:54:39.071 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:54:39.072 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:54:39.072 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:54:39.073 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:54:39.073 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:54:39.074 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:54:39.074 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:54:39.074 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:54:39.075 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:54:39.075 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:54:39.075 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:54:39.076 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:54:39.076 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:54:39.077 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:54:39.077 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:54:39.078 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:54:39.078 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:54:39.078 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:54:39.079 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:54:39.080 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:54:39.081 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:54:39.081 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:54:39.081 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:54:39.082 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:54:39.083 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:54:39.083 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:54:39.089 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:56:36.360 - info: iot.0 Request google home devices
          2019-10-15 21:56:37.321 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:56:37.322 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:56:37.323 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:56:37.324 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:56:37.324 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:56:37.325 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:56:37.325 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:56:37.326 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:56:37.326 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:56:37.327 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:56:37.327 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:56:37.327 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:56:37.328 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:56:37.328 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:56:37.328 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:56:37.329 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:56:37.329 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:56:37.330 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:56:37.330 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:56:37.330 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:56:37.331 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:56:37.332 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:56:37.333 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:56:37.333 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:56:37.333 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:56:37.334 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:56:37.335 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:56:37.335 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:56:37.354 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
          2019-10-15 21:57:19.391 - info: iot.0 Request google home devices
          2019-10-15 21:57:20.325 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
          2019-10-15 21:57:20.326 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
          2019-10-15 21:57:20.327 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
          2019-10-15 21:57:20.327 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
          2019-10-15 21:57:20.328 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
          2019-10-15 21:57:20.328 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
          2019-10-15 21:57:20.329 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
          2019-10-15 21:57:20.329 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
          2019-10-15 21:57:20.330 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
          2019-10-15 21:57:20.330 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
          2019-10-15 21:57:20.331 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
          2019-10-15 21:57:20.331 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
          2019-10-15 21:57:20.332 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
          2019-10-15 21:57:20.332 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
          2019-10-15 21:57:20.333 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
          2019-10-15 21:57:20.333 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
          2019-10-15 21:57:20.334 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
          2019-10-15 21:57:20.335 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
          2019-10-15 21:57:20.335 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
          2019-10-15 21:57:20.336 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
          2019-10-15 21:57:20.336 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
          2019-10-15 21:57:20.337 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
          2019-10-15 21:57:20.338 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
          2019-10-15 21:57:20.338 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
          2019-10-15 21:57:20.338 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
          2019-10-15 21:57:20.339 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
          2019-10-15 21:57:20.340 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
          2019-10-15 21:57:20.340 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
          2019-10-15 21:57:20.356 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
            tombox
            @fantasticmaxpower Der Log sieht nicht so gut aus. Ich empfehle dir meine Version via github zu installieren und die "Eigene Optionen" wieder rauszunehmen dann wird auch ein aussagekräftiger Log erzeugt.
            https://github.com/TA2k/ioBroker.iot
            • T tombox
              fantasticmaxpower
              @tombox habe aus github deine url installiert. Der Fehler bleibt. HIer der LOG nach Installation ohne den Haken
              2019-10-15 22:26:59.149 - info: iobroker url "https://github.com/TA2k/ioBroker.iot"
              2019-10-15 22:27:00.094 - info: iobroker install https://github.com/TA2k/ioBroker.iot/tarball/master
              2019-10-15 22:27:01.474 - info: iobroker npm install https://github.com/TA2k/ioBroker.iot/tarball/master --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
              2019-10-15 22:27:54.879 - info: iobroker ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden #include
              2019-10-15 22:27:54.880 - info: iobroker compilation terminated.
              2019-10-15 22:27:54.889 - info: iobroker make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
              2019-10-15 22:27:54.895 - info: iobroker gyp
              2019-10-15 22:27:54.897 - info: iobroker
              2019-10-15 22:27:54.898 - info: iobroker ERR! build error
              2019-10-15 22:27:54.900 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp
              2019-10-15 22:27:54.902 - info: iobroker ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack at ChildProcess.emit (events.js:198:13)
              gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp
              2019-10-15 22:27:54.904 - info: iobroker ERR! System Linux 4.14.98-v7+gyp
              2019-10-15 22:27:54.905 - info: iobroker ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
              gyp ERR! node -v v10.16.3
              gyp ERR!
              2019-10-15 22:27:54.907 - info: iobroker node-gyp -v v3.8.0gyp ERR! not ok
              2019-10-15 22:27:57.977 - info: iobroker npm
              2019-10-15 22:27:57.978 - info: iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              2019-10-15 22:27:57.985 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: `node-gyp configure build`
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              2019-10-15 22:27:58.131 - info: iobroker got /opt/iobroker/node_modules/iobroker.iot/admin
              2019-10-15 22:27:58.160 - info: iobroker upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
              2019-10-15 22:27:58.312 - info: iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/copy-content.6fe0b363.svg static/media/copy-content.6fe0b363.svg image/svg+xml
              2019-10-15 22:27:58.381 - info: iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.af82c137.js.map static/js/runtime~main.af82c137.js.map application/json
              2019-10-15 22:27:58.478 - info: iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.af82c137.js static/js/runtime~main.af82c137.js application/javascript
              2019-10-15 22:27:58.540 - info: iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.60bef8dc.chunk.js.map static/js/main.60bef8dc.chunk.js.map application/json
              2019-10-15 22:27:58.599 - info: iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.60bef8dc.chunk.js static/js/main.60bef8dc.chunk.js application/javascript
              2019-10-15 22:27:58.657 - info: iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2cf5c4e.chunk.js.map static/js/2.d2cf5c4e.chunk.js.map application/json
              2019-10-15 22:28:01.191 - info: iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2cf5c4e.chunk.js static/js/2.d2cf5c4e.chunk.js application/javascript
              2019-10-15 22:28:02.281 - info: iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.3d8149f0.chunk.css.map static/css/2.3d8149f0.chunk.css.map application/json
              2019-10-15 22:28:02.343 - info: iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.3d8149f0.chunk.css static/css/2.3d8149f0.chunk.css text/css
              2019-10-15 22:28:02.404 - info: iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
              2019-10-15 22:28:02.465 - info: iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.35a0418551f6a51386be701e075ea3a1.js precache-manifest.35a0418551f6a51386be701e075ea3a1.js application/javascript
              2019-10-15 22:28:02.523 - info: iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
              2019-10-15 22:28:02.581 - info: iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
              2019-10-15 22:28:02.643 - info: iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
              2019-10-15 22:28:02.703 - info: iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/x-icon
              2019-10-15 22:28:02.766 - info: iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
              2019-10-15 22:28:02.828 - info: iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
              2019-10-15 22:28:02.892 - info: iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
              2019-10-15 22:28:02.964 - info: iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
              2019-10-15 22:28:03.606 - info: iobroker exit 0
              2019-10-15 22:28:05.760 - info: host.ioBroker-RasPi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
              2019-10-15 22:29:27.960 - info: iobroker add iot --host ioBroker-RasPi
              2019-10-15 22:29:29.276 - info: iobroker host.ioBroker-RasPi install adapter iot
              2019-10-15 22:29:29.302 - info: iobroker got /opt/iobroker/node_modules/iobroker.iot/admin
              2019-10-15 22:29:29.328 - info: iobroker upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
              2019-10-15 22:29:29.497 - info: iobroker upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/media/copy-content.6fe0b363.svg static/media/copy-content.6fe0b363.svg image/svg+xml
              2019-10-15 22:29:29.589 - info: iobroker upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.af82c137.js.map static/js/runtime~main.af82c137.js.map application/json
              2019-10-15 22:29:29.726 - info: iobroker upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime~main.af82c137.js static/js/runtime~main.af82c137.js application/javascript
              2019-10-15 22:29:29.788 - info: iobroker upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.60bef8dc.chunk.js.map static/js/main.60bef8dc.chunk.js.map application/json
              2019-10-15 22:29:29.848 - info: iobroker upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.60bef8dc.chunk.js static/js/main.60bef8dc.chunk.js application/javascript
              2019-10-15 22:29:29.906 - info: iobroker upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2cf5c4e.chunk.js.map static/js/2.d2cf5c4e.chunk.js.map application/json
              2019-10-15 22:29:32.557 - info: iobroker upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.d2cf5c4e.chunk.js static/js/2.d2cf5c4e.chunk.js application/javascript
              2019-10-15 22:29:33.752 - info: iobroker upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.3d8149f0.chunk.css.map static/css/2.3d8149f0.chunk.css.map application/json
              2019-10-15 22:29:33.837 - info: iobroker upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.3d8149f0.chunk.css static/css/2.3d8149f0.chunk.css text/css
              2019-10-15 22:29:33.898 - info: iobroker upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
              2019-10-15 22:29:33.958 - info: iobroker upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.35a0418551f6a51386be701e075ea3a1.js precache-manifest.35a0418551f6a51386be701e075ea3a1.js application/javascript
              2019-10-15 22:29:34.017 - info: iobroker upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
              2019-10-15 22:29:34.076 - info: iobroker upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
              2019-10-15 22:29:34.137 - info: iobroker upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
              2019-10-15 22:29:34.198 - info: iobroker upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/x-icon
              2019-10-15 22:29:34.260 - info: iobroker upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
              2019-10-15 22:29:34.322 - info: iobroker upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
              2019-10-15 22:29:34.380 - info: iobroker upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
              2019-10-15 22:29:34.443 - info: iobroker upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
              2019-10-15 22:29:34.853 - info: iobroker host.ioBroker-RasPi object system.adapter.iot created
              2019-10-15 22:29:34.906 - info: iobroker host.ioBroker-RasPi create instance iot
              2019-10-15 22:29:34.920 - info: iobroker host.ioBroker-RasPi object iot.0.certs.forceUserCreate created
              2019-10-15 22:29:34.954 - info: iobroker host.ioBroker-RasPi object iot.0.certs.urlKey created
              2019-10-15 22:29:34.988 - info: iobroker host.ioBroker-RasPi object iot.0.certs.certificate created
              2019-10-15 22:29:35.037 - info: iobroker host.ioBroker-RasPi object iot.0.certs.private created
              2019-10-15 22:29:35.071 - info: iobroker host.ioBroker-RasPi object iot.0.certs.public created
              2019-10-15 22:29:35.105 - info: iobroker host.ioBroker-RasPi object iot.0.certs.id created
              2019-10-15 22:29:35.145 - info: iobroker host.ioBroker-RasPi object iot.0.certs created
              2019-10-15 22:29:35.173 - info: iobroker host.ioBroker-RasPi object iot.0.services created
              2019-10-15 22:29:35.208 - info: iobroker host.ioBroker-RasPi object iot.0.smart.updatesResult created
              2019-10-15 22:29:35.241 - info: iobroker host.ioBroker-RasPi object iot.0.smart.updatesYA created
              2019-10-15 22:29:35.272 - info: iobroker host.ioBroker-RasPi object iot.0.smart.updatesGH created
              2019-10-15 22:29:35.304 - info: iobroker host.ioBroker-RasPi object iot.0.smart.updates3 created
              2019-10-15 22:29:35.336 - info: iobroker host.ioBroker-RasPi object iot.0.smart.updates created
              2019-10-15 22:29:35.374 - info: iobroker host.ioBroker-RasPi object iot.0.smart.lastResponse created
              2019-10-15 22:29:35.413 - info: iobroker host.ioBroker-RasPi object iot.0.smart.lastCommandObj created
              2019-10-15 22:29:35.451 - info: iobroker host.ioBroker-RasPi object iot.0.smart.lastCommand created
              2019-10-15 22:29:35.489 - info: iobroker host.ioBroker-RasPi object iot.0.smart.lastRoom created
              2019-10-15 22:29:35.537 - info: iobroker host.ioBroker-RasPi object iot.0.smart.lastFunction created
              2019-10-15 22:29:35.577 - info: iobroker host.ioBroker-RasPi object iot.0.info.remoteTill created
              2019-10-15 22:29:35.615 - info: iobroker host.ioBroker-RasPi object iot.0.info.connection created
              2019-10-15 22:29:35.652 - info: iobroker host.ioBroker-RasPi object iot.0.info created
              2019-10-15 22:29:35.695 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.outputCount created
              2019-10-15 22:29:35.739 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.inputCount created
              2019-10-15 22:29:35.784 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.uptime created
              2019-10-15 22:29:35.829 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.memRss created
              2019-10-15 22:29:35.873 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.memHeapTotal created
              2019-10-15 22:29:35.915 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.memHeapUsed created
              2019-10-15 22:29:35.956 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.cputime created
              2019-10-15 22:29:35.997 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.cpu created
              2019-10-15 22:29:36.038 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.connected created
              2019-10-15 22:29:36.078 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0.alive created
              2019-10-15 22:29:36.132 - info: host.ioBroker-RasPi object change system.adapter.iot.0
              2019-10-15 22:29:36.154 - info: iobroker host.ioBroker-RasPi object system.adapter.iot.0 created
              2019-10-15 22:29:36.175 - info: iobroker exit 0
              2019-10-15 22:30:17.336 - info: host.ioBroker-RasPi object change system.adapter.iot.0
              2019-10-15 22:30:27.920 - info: host.ioBroker-RasPi object change system.adapter.javascript.0
              2019-10-15 22:30:27.922 - info: host.ioBroker-RasPi "system.adapter.javascript.0" disabled
              2019-10-15 22:30:27.922 - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0
              2019-10-15 22:30:27.923 - info: host.ioBroker-RasPi stopInstance system.adapter.javascript.0 killing pid 11783
              2019-10-15 22:30:27.929 - info: javascript.0 Stop script script.js.Internetradio.Wandtaster_Bedienung
              2019-10-15 22:30:27.988 - info: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 156 ()
              2019-10-15 22:30:45.843 - info: host.ioBroker-RasPi object change system.adapter.iot.0
              2019-10-15 22:30:45.844 - info: host.ioBroker-RasPi "system.adapter.iot.0" enabled
              2019-10-15 22:30:45.881 - info: host.ioBroker-RasPi instance system.adapter.iot.0 started with pid 14368
              2019-10-15 22:30:48.102 - info: iot.0 States connected to redis: 127.0.0.1:6379
              2019-10-15 22:30:48.289 - info: iot.0 starting. Version 1.1.9 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
              2019-10-15 22:30:48.333 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2019-10-15 22:30:48.351 - error: iot.0 Cannot read URL key: Not exists
              2019-10-15 22:30:50.574 - info: iot.0 Connection changed: connect
              2019-10-15 22:31:04.433 - info: iot.0 Request google home devices
              2019-10-15 22:31:14.429 - info: iot.0 Request google home devices
              Hier der LOG mit Haken bei eigene Einstellungen
              gyp
              gyp ERR!
              2019-10-15 22:33:35.902 - info: host.ioBroker-RasPi object change system.adapter.iot.0
              2019-10-15 22:33:35.903 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0
              2019-10-15 22:33:35.904 - info: host.ioBroker-RasPi stopInstance system.adapter.iot.0 killing pid 14368
              2019-10-15 22:33:35.960 - info: host.ioBroker-RasPi instance system.adapter.iot.0 terminated with code 156 ()
              2019-10-15 22:33:38.430 - info: host.ioBroker-RasPi instance system.adapter.iot.0 started with pid 14433
              2019-10-15 22:33:40.590 - info: iot.0 States connected to redis: 127.0.0.1:6379
              2019-10-15 22:33:40.728 - info: iot.0 starting. Version 1.1.9 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
              2019-10-15 22:33:40.772 - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
              2019-10-15 22:33:43.011 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
              2019-10-15 22:33:43.071 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
              2019-10-15 22:33:43.191 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
              2019-10-15 22:33:43.320 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
              2019-10-15 22:33:43.387 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
              2019-10-15 22:33:43.405 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
              2019-10-15 22:33:43.449 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
              2019-10-15 22:33:43.495 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
              2019-10-15 22:33:43.559 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
              2019-10-15 22:33:43.608 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
              2019-10-15 22:33:43.642 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
              2019-10-15 22:33:43.675 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
              2019-10-15 22:33:43.707 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
              2019-10-15 22:33:43.740 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
              2019-10-15 22:33:43.773 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
              2019-10-15 22:33:43.795 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
              2019-10-15 22:33:43.817 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
              2019-10-15 22:33:43.838 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
              2019-10-15 22:33:43.860 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
              2019-10-15 22:33:43.881 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
              2019-10-15 22:33:43.903 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
              2019-10-15 22:33:43.940 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
              2019-10-15 22:33:43.972 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
              2019-10-15 22:33:43.988 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
              2019-10-15 22:33:44.015 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
              2019-10-15 22:33:44.049 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
              2019-10-15 22:33:44.084 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
              2019-10-15 22:33:44.118 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
              2019-10-15 22:33:44.210 - info: iot.0 Connection changed: connect
              2019-10-15 22:33:44.335 - info: iot.0 hm-rpc.2.MEQ1482056.1 is auto added with type light.
              2019-10-15 22:33:44.339 - info: iot.0 hm-rpc.2.MEQ1482136.1 is auto added with type light.
              2019-10-15 22:33:44.343 - info: iot.0 hm-rpc.2.MEQ0345046.1 is auto added with type dimmer.
              2019-10-15 22:33:44.350 - info: iot.0 hm-rpc.2.MEQ0344447.1 is auto added with type dimmer.
              2019-10-15 22:33:44.354 - info: iot.0 hm-rpc.2.MEQ0344982.1 is auto added with type dimmer.
              2019-10-15 22:33:44.359 - info: iot.0 hm-rpc.2.LEQ0800171.1 is auto added with type temperature.
              2019-10-15 22:33:44.363 - info: iot.0 hm-rpc.2.NEQ0401394.2 is auto added with type socket.
              2019-10-15 22:33:44.367 - info: iot.0 hm-rpc.2.NEQ0401394.1 is auto added with type socket.
              2019-10-15 22:33:44.371 - info: iot.0 hm-rpc.2.MEQ1658508.1 is auto added with type info.
              2019-10-15 22:33:44.376 - info: iot.0 hm-rpc.2.NEQ0946148.1 is auto added with type info.
              2019-10-15 22:33:44.380 - info: iot.0 hm-rpc.2.MEQ1658507.1 is auto added with type info.
              2019-10-15 22:33:44.384 - info: iot.0 hm-rpc.2.MEQ1658470.1 is auto added with type info.
              2019-10-15 22:33:44.388 - info: iot.0 hm-rpc.2.MEQ1658428.1 is auto added with type info.
              2019-10-15 22:33:44.392 - info: iot.0 hm-rpc.2.NEQ0065172.1 is auto added with type info.
              2019-10-15 22:33:44.396 - info: iot.0 hm-rpc.2.OEQ0427964.1 is auto added with type info.
              2019-10-15 22:33:44.401 - info: iot.0 hm-rpc.2.MEQ0670337.2 is auto added with type button.
              2019-10-15 22:33:44.405 - info: iot.0 hm-rpc.2.OEQ0484079.2 is auto added with type button.
              2019-10-15 22:33:44.409 - info: iot.0 hm-rpc.2.OEQ0484079.1 is auto added with type button.
              2019-10-15 22:33:44.413 - info: iot.0 hm-rpc.2.MEQ0397792.2 is auto added with type button.
              2019-10-15 22:33:44.417 - info: iot.0 hm-rpc.2.MEQ0397792.1 is auto added with type button.
              2019-10-15 22:33:44.421 - info: iot.0 hm-rpc.2.MEQ0399707.2 is auto added with type button.
              2019-10-15 22:33:44.426 - info: iot.0 hm-rpc.2.MEQ0273483.1 is auto added with type socket.
              2019-10-15 22:33:44.430 - info: iot.0 hm-rpc.2.MEQ0272437.1 is auto added with type socket.
              2019-10-15 22:33:44.434 - info: iot.0 hm-rpc.2.MEQ0273483.2 is auto added with type info.
              2019-10-15 22:33:44.438 - info: iot.0 hm-rpc.2.MEQ0272437.2 is auto added with type info.
              2019-10-15 22:33:44.443 - info: iot.0 hm-rpc.2.OEQ1428660.1 is auto added with type info.
              2019-10-15 22:33:44.447 - info: iot.0 hm-rpc.2.OEQ1428665.1 is auto added with type info.
              2019-10-15 22:33:44.451 - info: iot.0 hm-rpc.2.OEQ1428691.1 is auto added with type info.
              2019-10-15 22:33:44.693 - error: iot.0 [GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically: {"error":"Email not found or URL key not found"}
              2019-10-15 22:33:44.695 - warn: iot.0 [GHOME] Invalid URL key. Status update is disabled you can set states but not receive state updates: {"error":"Email not found or URL key not found"}
              • fantasticmaxpowerF fantasticmaxpower
                gyp
                gyp ERR!
                gyp
                gyp ERR!
                tombox
                @fantasticmaxpower Eigenartig sollte so nicht funktionieren.
                • T tombox
                  fantasticmaxpower
                  @tombox grundsätzlich bin ich erstmal Happy das es geht. Allerdings würde ich gerne wissen weshalb mein Setup diesen Haken benötigt.Hat das eventuell iwelche negativen Auswirkungen ?
                  Habe ich eigentlich schon Danke gesagt ...Danke!
                  Jetzt kann ich den gratis Google Home Mini auspacken und weitermachen !
                    tombox
                    @fantasticmaxpower Es hat keinerlei negative auswirkung. Du kannst ihn aber nicht mehr entfernen ohne iot neu zu installieren bzw durch den hm adapter deine geräte neu anlegen zu müssen
                    • T tombox
                      fantasticmaxpower
                      @tombox habe den Haken bei "eigene Einstellungen" eben wieder rausgenommen und gespeichert. iot startet neu und findet auf einmal alle Geräte! Der Haken ist nach einem Neustart auch immer noch deaktiviert. Befehle kann ich über googlehome auch absetzen und Geräteaktualisierung hat auch funktioniert.
                      Das einzige was fehlt ist das Assistenten Angebot bei iobroker.pro.
                      Vielleicht kannst du das mal checken?
                      Schließlich habe ich ja erfolgreich einen Befehl gesendet.
                        skokarl
                        schrieb am zuletzt editiert von skokarl
                        Ich begreife das System nicht.
                        Mag ja gut sein, aber ich finds extrem undurchsichtig.
                        Adapter ist grün, Google home installiert, und mit IOBroker verknüpft.
                        Was heisst das ?
                        und Ja, ich habe viel gelesen, nur anscheinend ja nicht verstanden, sonst wüsste ich was das heisst. 😇
                        fantasticmaxpowerF BBTownB T 3 Antworten Letzte Antwort
                        • S skokarl
                          Was heisst das ?
                          fantasticmaxpower
                          #66
                          @skokarl Ich glaube die Meldungen verschwinden wenn man ein Abo bei iobroker.pro abgeschlossen hat.
                          • S skokarl
                            Was heisst das ?
                            BBTownB Offline
                            BBTownB Offline
                            BBTown
                            #67
                            @skokarl was soll denn der google-home adapter bewirken?
                            • BBTownB BBTown
                              skokarl
                              #68
                              @BBTown sagte in [iot] Andere Probleme mit dem iot-Adapter bzw der Nutzung:
                              Hast Du die Anleitung schonmal gelesen ?
                              Google Home, nicht Adapter.
                              GHome ist die App.
                              BBTownB 1 Antwort Letzte Antwort
                              • S skokarl
                                GHome ist die App.
                                BBTownB Offline
                                BBTownB Offline
                                BBTown
                                #69
                                @skokarl und hast Du dir schon mal die Adapterübersicht angeschaut?
                                • BBTownB BBTown
                                  skokarl
                                  #70
                                  @BBTown
                                  Du liest nicht richtig.
                                  Und die Anleitung kennst Du auch nicht.
                                  Und den Adapter hatte ich nie erwähnt.
                                  • S skokarl
                                    @BBTown
                                    BBTownB Offline
                                    BBTownB Offline
                                    BBTown
                                    schrieb am zuletzt editiert von BBTown
                                    #71
                                    @skokarl
                                    dafür dass Du nicht einmal den Unterschied zwischen dem Cloud- und dem IoT-Adapter kennst, rsikierst Du hier eine ziemlich dicke Lippe.
                                    Du hast geschrieben, Du hast "Google Home" installiert, aber nicht ob Du damit den Adapter oder die Android-App meinst - darauf wollte ich dich hinweisen, und jetzt würde ich dich bitten mal über deinen Ton und deine Art nachzudenken.
                                    S 2 Antworten Letzte Antwort
                                    • BBTownB BBTown
                                      @skokarl
                                      skokarl
                                      #72
                                      @BBTown
                                      merkst du eigentlich selbst nicht dass du nix
                                      ausser Kommentare dazu geben kannst ? Langeweile ?
                                      • BBTownB BBTown
                                        @skokarl
                                        skokarl
                                        #73
                                        @skokarl
                                        und dicke Lippe.... auf das primitive Niveau begebe ich mich nicht.
                                        • S skokarl
                                          Was heisst das ?
                                          tombox
                                          #74
                                          @skokarl Das bedeutet ohne iobroker.pro funktionieren Anfragen und Antworten bei google home aber es werden state Änderung bei ioBroker automatisch an Google Home übertragen, sondern müssen bevor google home antworten kann bei ioBroker erfragt werden
