  4. [Aufruf] Hue Adapter 2.0.0
    6.5k
testerhuehue adapter
86 Beiträge 19 Kommentatoren 12.6k Aufrufe 24 Beobachtet
    brain
    #72
    @foxriver76
    Hi, ich habe gestern den Adapter auf Version 2.0.1geupdatet (parallel zum Update des js-controllers auf 2.0). Auf die neue Objektstruktur bin ich umgestiegen.
    Nun läuft mein Log mit Meldungen des hue-Adapters voll:
    2019-10-13 20:20:50.637 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.638 - warn: hue.0 (16313) lightQueue: retry [1/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.666 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.666 - warn: hue.0 (16313) lightQueue: retry [2/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.693 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.694 - warn: hue.0 (16313) lightQueue: retry [3/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.720 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.721 - warn: hue.0 (16313) lightQueue: retry [4/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.747 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.748 - warn: hue.0 (16313) lightQueue: retry [5/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.774 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.775 - warn: hue.0 (16313) lightQueue: retry [6/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.802 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.803 - warn: hue.0 (16313) lightQueue: retry [7/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.830 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.831 - warn: hue.0 (16313) lightQueue: retry [8/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.857 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.858 - warn: hue.0 (16313) lightQueue: retry [9/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.886 - warn: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec failed: Error: Unknown type, On/Off plug-in unit,
    2019-10-13 20:20:50.887 - warn: hue.0 (16313) lightQueue: retry [10/10] job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec
    2019-10-13 20:20:50.913 - error: hue.0 (16313) lightQueue: job setLightState:10:5a66f2a220b64c26b7d978d80bc386ec max retry reached: Error: Unknown type, On/Off plug-in unit,
    Ich denke, das sind Probleme mit einem OSRAM Smart+ Plug, den ich davor einwandfrei schalten konnte. Die Steckdose ist zwar unter den Objekten angelegt, jedoch zeigt sie keine Reaktion, wenn ich den "ON"-Datenpunkt auf true setze.
    Gibt es einen Lösungsansatz?
    • B brain
      @foxriver76
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      #73
      @brain Hast du von GitHub installiert? Probier bitte Nochmal von GitHub. Gab einige Inkompatibelitäten mit der node-hue-api v3. Ansonsten bitte die offizielle 2.0.0 nutzen die sollte auf jeden Fall gehen.
      Videotutorials & mehr
      • foxriver76F foxriver76
        Wird wohl das Problem sein, werden wohl nur bei Neuanlage automatisch vom Adapter korrigiert.
        dslraserD Offline
        dslraserD Offline
        dslraser
        #74
        @foxriver76 sagte in [Aufruf] Hue Adapter 2.0.0:
        Alle Objekte gelöscht, neu angelegt mit neuer Struktur, alles für iot bearbeit (und x Scripte), aber läuft wie wie gewünscht.
        • arteckA arteck
          @sveni_lee ich habs auch 2 Spots und eine Lampe .. am Tisch.. also Gruppe Tisch erstellt..
          Tisch an - geht
          Tisch aus - geht
          sowohl über den Datenpunkt on als auch über brightness
          sveni_lee
          #75
          @arteck
          Ja, das klappt bei mir auch... aber wenn beide Lampen Tisch(1) und Tisch(2) abgeschaltet werden und zwar einzeln und nicht über die Gruppe, bleibt die Gruppe auf ON = true obwohl alles Lampen in der Gruppe auf false stehen.
          • dslraserD dslraser
            Stormbringer
            #76
            @dslraser sagte in [Aufruf] Hue Adapter 2.0.0:
            Darf man fragen wie viele Lampen du hast? 🙈 Hab 65, glaub kann mir da 2 wochen urlaub nehmen falls ich mal updaten muss 😂😂
            Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
            foxriver76F dslraserD 2 Antworten Letzte Antwort
            • S Stormbringer
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              #77
              Naja eigentlich müssten nur die min/Max Werte der Objekte angepasst werden. Würde auch mit einem kleinen Skript gehen. Und ansonsten kann man die Struktur ja auch halten durch die Option in den Adaptereinstellungen nur in den Cloud Adapter müsste man die Geräte dann neu aufnehmen.
              • S Stormbringer
                dslraserD Offline
                dslraserD Offline
                dslraser
                #78
                @Stormbringer sagte in [Aufruf] Hue Adapter 2.0.0:
                37
                  brain
                  #79
                  @foxriver76
                  Ich habe nun direkt auf 2.1.0 geupdatet (über GitHub). Die Fehler im Log tauchen immer noch auf. Allerdings kann ich die Steckdose nun wieder schalten - wenn auch nur über den Raum und nicht direkt über den Datenpunkt.
                  Meinst du ein Downgrade auf 2.0.0 könnte sinnvoll sein?
                  • B brain
                    @foxriver76
                    foxriver76F Offline
                    foxriver76F Offline
                    foxriver76
                    schrieb am zuletzt editiert von foxriver76
                    #80
                    @brain ja 2.0.0 und 2.0.1 nutzen noch die alte node-hue-api. Dann schaue ich mal was da nicht tut in der neuen Version.
                    Allerdings ist das nicht die 2.0.1 die du von GitHub installiert hast die auf npm ist.
                      brain
                      #81
                      @foxriver76
                      Danke. Mit Version 2.0.0 funktioniert es.
                        Apropo
                        #82
                        Ich kann leider nicht bestätigen, dass der Adapter beim Motion Sensor die Werte aus der App übernimmt. Und an/aus schalten des Sensors über den Adapter geht natürlich auch nicht. Installiert ist die 2.1.0 von Github. Firmware der Bridge ist auf dem neusten Stand.
                        Der Zustand vom DP "on" bleibt bei mir immer auf true stehen, wenn ich in der App aus schalte. Das einzige das sich ändert ist der DP "lastupdatet" wo mir dann Invalid Date angezeigt wird. Im Screenshot sieht man es ganz gut. Der obere Sensor ist per App eingeschaltet, der untere ausgeschaltet.
                        Wenn ich versuche per Datenpunkt "on" den Sensor auf false/true zu setzen kommt folgendes im Log falls dir das hilft:
                        hue.0	2019-10-16 11:37:41.684	error	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb max retry reached: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.666	warn	lightQueue: retry [10/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.666	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.636	warn	lightQueue: retry [9/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.631	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.601	warn	lightQueue: retry [8/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.601	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.575	warn	lightQueue: retry [7/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.575	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.551	warn	lightQueue: retry [6/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.547	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.516	warn	lightQueue: retry [5/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.511	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.488	warn	lightQueue: retry [4/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.484	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.461	warn	lightQueue: retry [3/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.457	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.433	warn	lightQueue: retry [2/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.429	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        hue.0	2019-10-16 11:37:41.409	warn	lightQueue: retry [1/10] job setLightState:undefined:05137e890358e12ec8f7a72380535adb
                        hue.0	2019-10-16 11:37:41.402	warn	lightQueue: job setLightState:undefined:05137e890358e12ec8f7a72380535adb failed: Api Error: The light id 'undefined' is not valid for this Hue Bridge.,
                        Wenn ich sonst irgendwie helfen kann einfach schreien ....
                        • A Apropo
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          #83
                          @Apropo schalten geht noch nicht.
                          Ist allerdings nur noch eine Kleinigkeit. Wann hast du von GitHub installiert. Wenn lauffähige Versionen gewünscht sind bitte maximal latest eher stable nutzen.
                          Siehe auch https://github.com/iobroker-community-adapters/ioBroker.hue/issues/76
                            Apropo
                            schrieb am zuletzt editiert von Apropo
                            #84
                            @foxriver76 die 2.1 von Github habe ich vor ner guten Stunde installiert. Vorher hatte ich es mit der 2.0 aus dem latest probiert die ich gestern Mittag installiert hatte. Beides mit dem selben Ergebnis.
                            • A Apropo
                              foxriver76F Offline
                              foxriver76F Offline
                              foxriver76
                              #85
                              @Apropo also mit der offiziellen 2.1 sollten alle Sensor States regelmäßig aktualisiert werden. Das was aktuell auf GitHub liegt ist mit Vorsicht zu genießen.
                                Apropo
                                #86
                                @foxriver76 ok, bin jetzt zurück auf 2.0 und warte brav auf ein Update
