  4. Test js-controller v2.0.x (GitHub)
js-controller
1.0k Beiträge 48 Kommentatoren 507.0k Aufrufe 35 Beobachtet
  • smartboartS smartboart
    Mir ist noch was aufgefallen. Hab für den fullybrowser nen Chron Job im Admin angelegt.
    Alle 4 Stunden neustarten.... Der Log sieht dann so aus. Ist der einzige adapter mit nem Chron job bei mir..
    host.ioBroker-Rock 2019-10-15 12:56:00.433 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    host.ioBroker-Rock 2019-10-15 12:55:01.467 info instance system.adapter.fullybrowser.0 started with pid 28554
    host.ioBroker-Rock 2019-10-15 12:55:00.449 info Restart adapter system.adapter.fullybrowser.0 because enabled
    host.ioBroker-Rock 2019-10-15 12:55:00.443 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    host.ioBroker-Rock 2019-10-15 12:54:01.492 info instance system.adapter.fullybrowser.0 started with pid 27182
    host.ioBroker-Rock 2019-10-15 12:54:00.446 info Restart adapter system.adapter.fullybrowser.0 because enabled
    host.ioBroker-Rock 2019-10-15 12:54:00.446 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    host.ioBroker-Rock 2019-10-15 12:53:01.526 info instance system.adapter.fullybrowser.0 started with pid 25634
    host.ioBroker-Rock 2019-10-15 12:53:00.508 info Restart adapter system.adapter.fullybrowser.0 because enabled
    host.ioBroker-Rock 2019-10-15 12:53:00.507 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    host.ioBroker-Rock 2019-10-15 12:52:01.455 info instance system.adapter.fullybrowser.0 started with pid 24280
    host.ioBroker-Rock 2019-10-15 12:52:00.435 info Restart adapter system.adapter.fullybrowser.0 because enabled
    host.ioBroker-Rock 2019-10-15 12:52:00.434 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    host.ioBroker-Rock 2019-10-15 12:51:01.458 info instance system.adapter.fullybrowser.0 started with pid 22758
    host.ioBroker-Rock 2019-10-15 12:51:00.441 info Restart adapter system.adapter.fullybrowser.0 because enabled
    host.ioBroker-Rock 2019-10-15 12:51:00.440 error instance system.adapter.fullybrowser.0 terminated with code 156 (156)
    apollon77A
    apollon77A
    #794
    @smartboart sicher das es 4 stündlich ist? Das siehe eher nach minütlich aus.
    • D darkiop
      Ok, zweiter Test - jetzt ohne den admin.0 crash ....
      der Master ist wieder auf den Beinen, der Slave hat es aber nicht geschaft. stop/start aufm Slave und er ist wieder verbunden.
      Puffert der controller auch Logs? Die 3 hier sind eigentlich entstanden während redis weg war, geschrieben wurden sie nach dem redis wieder da war:
      2019-10-15 14:00:00.786  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 31.8 | Licht wird nicht geschaltet. +++
      2019-10-15 14:00:01.180  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 32.6 | Licht wird nicht geschaltet. +++
      2019-10-15 14:00:01.523  - info: javascript.0 (618) script.js.PRODUKTIV.Beleuchtung.01_Bewegungsmelder_Flur: +++ Bewegung im Flur. Helligkeitsschwelle bei < 10 | Aktuelle Helligkeit: 32.6 | Licht wird nicht geschaltet. +++
      Edit:
      So lange war redis weg:
      apollon77A
      apollon77A
      #795
      @darkiop hast du hier bitte das Slave log komplett von dem Zeitraum?
      • apollon77A apollon77
        smartboartS
        smartboartS
        smartboart
        schrieb am zuletzt editiert von smartboart
        #796
        @apollon77 said in [Aufruf] js-controller 2.0 Beta Test:
        ja sehr sicher...
        Das ist jadas verwunderliche...noch dazu der Fehler.
          ja sehr sicher...
          J
          J
          Jan1
          #797
          @smartboart
          das ist alle 4 Stunden jede Minute
          • J Jan1
            @smartboart
            smartboartS
            smartboartS
            smartboart
            #798
            @Jan1 oh ok..ich glaube ich sollte mich nochmal mit den Chron Zeiten auseinanderstzen..Danke!!!
              @smartboart denke alles nur Warnungen.
              smartboartS
              smartboartS
              smartboart
              #799
              ok danke..hab ich mir gedacht, macht auch keine Probleme. Wenn du oder sonst wer dennoch ne Idee hat wie man diese gyp und nan Warnungen abstellt, gerne her damit.....
                D
                D
                darkiop
                #800
                @apollon77
                Das ist alles von heute aufm Slave ab dem Zeitpunkt des Redis-Tests:
                log_slave.txt
                ioBroker Object Explorer: https://forum.iobroker.net/topic/84117/iobroker-object-explorer-dashboard-zum-verwalten-von-dps?_=1789113045261 | Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
                • apollon77A
                  apollon77A
                  #801
                  Sooooooo @darkiop Super Feedback!!
                  Die 2.0.32 ist auf GitHub, könntest Du alle 4 cases nochmal checken bitte?
                  Bisher wurden Adapter beim verlieren der States Connection beendet, aber der Host hat nur bei Objects-DB-verlust was getan ... Damit gab es Edge cases. Ist jetzt geändert.
                  D 2 Antworten Letzte Antwort
                  • D
                    D
                    darkiop
                    #802
                    Danke. Ich schau mal ob ich heut noch dazu komme :D
                      D
                      D
                      darkiop
                      #803
                      @apollon77 Noch ne Frage, kann ich eigentlich auch über Github eine alte Version ziehen? Also wie müsste ich z.b. vorgehen wenn ich jetzt wieder die 2.0.25 möchte für die es aber keine NPM Version gibt?
                      • SBorgS
                        SBorgS
                        SBorg
                        #804
                        Die Versionsnummer mit anhängen (geht bei allen NPM-Paketen), also npm install ioBroker/ioBroker.js-controller@2.0.25
                        LG SBorg ( SBorg auf GitHub)
                          D
                          D
                          darkiop
                          #805
                          @apollon77 sagte in [Aufruf] js-controller 2.0 Beta Test:
                          Das war jetzt doch Aufwändiger als Gedacht, siehe TF3 :D
                          tf_2-0-32.pdf
                          Mein Log von Heute ging eben auch per Mail an dich raus.
                          apollon77A 2 Antworten Letzte Antwort
                          • SBorgS SBorg
                            D
                            D
                            darkiop
                            #806
                            @SBorg Jep, das kenne ich - hab mich glaub falsch ausgedrückt. Kann ich auch zu einem Zeitpunkt eines Commits springen zu dem es keine Version gibt?
                            • D darkiop
                              apollon77A
                              apollon77A
                              #807
                              @darkiop geht nicht. Nur eine npm Version oder aktuellen GitHub Stand. Ansonsten ginge noch ein spezifischer GitHub Commit, was äquivalent zu einem alten Stand wäre.
                              Wozu brauchst Du die 2.0.25?
                                D
                                D
                                darkiop
                                #808
                                @apollon77 die 2.0.25 musste nur als Beispiel herhalten ;) wie würde der spezifische commit ausschauen?
                                • D darkiop
                                  tf_2-0-32.pdf
                                  apollon77A
                                  apollon77A
                                  #809
                                  @darkiop Ooooohhhkkkkk ... :-)
                                  Bei testfall 3 sieht man das er "restart" aufruft aber scheinbar wieder kein Restart passiert ... :-(
                                  • D darkiop
                                    apollon77A
                                    apollon77A
                                    #810
                                    @darkiop puuuhh da muss ich mal schauen ...
                                    Per Kommandozeile wäre es denke ich Bei zB 2.0.26 als https://github.com/ioBroker/ioBroker.js-controller/commit/2b2bb746da26cd06862a78a4eb1a1cf209e85d3e
                                    dann
                                    npm install ioBroker/ioBroker.js-controller#2b2bb746da26cd06862a78a4eb1a1cf209e85d3e
                                    • D darkiop
                                      tf_2-0-32.pdf
                                      apollon77A
                                      apollon77A
                                      #811
                                      @darkiop Also ich habe es mal nachgestellt und bei mir getestet. Effektiv geht alles korrekt, bei States dauert es ggf nur länger.
                                      Bei mir steht in der Konfig (iobroker-data/iobroker.json) bei states ein
                                      "options": {
                                            "auth_pass": null,
                                            "retry_max_delay": 15000
                                      Das MaxDelay 15000 bedeutet das ein Reconnect alle 15s versucht wird. Bei Objects steht im Default nichts, was bedeutet es sind 2s. Das sind mal mindestens die Dinge die für den Controller gelten. Es sollten 18 Connect Versuche gemacht werden ... also wenn Objects weg ist restarted alles nach 12x2=36s (grob). Bei States sind es 4:30min ... das passt zu meinen Ergebnissen. Und bei mir kam dann der Restart ...
                                        dann
                                        D
                                        D
                                        darkiop
                                        #812
                                        dann
                                        Danke. Werd ich ausprobieren.
                                          "options": {
                                                "auth_pass": null,
                                          D
                                          D
                                          darkiop
                                          #813
                                          @apollon77 Ok, d.h. du hattest nicht die vielen Fehler bei TF3?
                                          84.1k
