  4. PI4 Lässt JS Kontrolle nicht updaten
js-controller 2.0.25
106 Beiträge 8 Kommentatoren 13.9k Aufrufe 9 Beobachtet
  • F freaktech
    aktuelle dann
    diese
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #85
    @freaktech Ohne die zugehörigen Logs kann ich da nix machen.
    • F Offline
      freaktech
      #86
      hue
      da würde es auch schon einen 2.01 geben aber den zeigt er mir nicht an wie kann man bei den adaptern die latest installieren?
      hue.0	2019-10-14 16:24:37.046	info	(20528) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:37.044	info	(20528) terminating
      hue.0	2019-10-14 16:24:36.996	info	(20528) cleaned everything up...
      hue.0	2019-10-14 16:24:36.993	error	(20528) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:36.991	error	(20528) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:36.833	info	(20528) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:32.211	info	(20511) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:32.209	info	(20511) terminating
      hue.0	2019-10-14 16:24:32.166	info	(20511) cleaned everything up...
      hue.0	2019-10-14 16:24:32.164	error	(20511) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:32.162	error	(20511) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:32.004	info	(20511) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:27.464	info	(20489) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:27.462	info	(20489) terminating
      hue.0	2019-10-14 16:24:27.418	info	(20489) cleaned everything up...
      hue.0	2019-10-14 16:24:27.416	error	(20489) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:27.415	error	(20489) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:27.259	info	(20489) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:22.977	info	(20445) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:22.975	info	(20445) terminating
      hue.0	2019-10-14 16:24:22.934	info	(20445) cleaned everything up...
      hue.0	2019-10-14 16:24:22.932	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      hue.0	2019-10-14 16:24:22.932	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      hue.0	2019-10-14 16:24:22.932	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      hue.0	2019-10-14 16:24:22.932	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
      hue.0	2019-10-14 16:24:22.932	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
      hue.0	2019-10-14 16:24:22.932	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
      hue.0	2019-10-14 16:24:22.932	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:22.932	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
      hue.0	2019-10-14 16:24:22.932	error	(20445) TypeError: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:22.931	error	(20445) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:22.773	info	(20445) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:18.023	info	(20429) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:18.021	info	(20429) terminating
      hue.0	2019-10-14 16:24:17.975	info	(20429) cleaned everything up...
      hue.0	2019-10-14 16:24:17.973	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      hue.0	2019-10-14 16:24:17.973	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      hue.0	2019-10-14 16:24:17.973	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      hue.0	2019-10-14 16:24:17.973	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
      hue.0	2019-10-14 16:24:17.973	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
      hue.0	2019-10-14 16:24:17.973	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
      hue.0	2019-10-14 16:24:17.973	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:17.973	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
      hue.0	2019-10-14 16:24:17.973	error	(20429) TypeError: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:17.968	error	(20429) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:17.791	info	(20429) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:13.116	info	(20395) terminating
      hue.0	2019-10-14 16:24:13.075	info	(20395) cleaned everything up...
      hue.0	2019-10-14 16:24:13.073	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      hue.0	2019-10-14 16:24:13.073	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      hue.0	2019-10-14 16:24:13.073	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      hue.0	2019-10-14 16:24:13.073	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
      hue.0	2019-10-14 16:24:13.073	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
      hue.0	2019-10-14 16:24:13.073	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
      hue.0	2019-10-14 16:24:13.073	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:13.073	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
      hue.0	2019-10-14 16:24:13.073	error	(20395) TypeError: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:13.072	error	(20395) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:12.905	info	(20395) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:08.599	info	(20379) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:08.597	info	(20379) terminating
      hue.0	2019-10-14 16:24:08.554	info	(20379) cleaned everything up...
      hue.0	2019-10-14 16:24:08.552	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      hue.0	2019-10-14 16:24:08.552	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      hue.0	2019-10-14 16:24:08.552	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      hue.0	2019-10-14 16:24:08.552	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
      hue.0	2019-10-14 16:24:08.552	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
      hue.0	2019-10-14 16:24:08.552	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
      hue.0	2019-10-14 16:24:08.552	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:08.552	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
      hue.0	2019-10-14 16:24:08.552	error	(20379) TypeError: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:08.550	error	(20379) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:08.382	info	(20379) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:24:04.029	info	(20363) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:24:04.027	info	(20363) terminating
      hue.0	2019-10-14 16:24:03.969	info	(20363) cleaned everything up...
      hue.0	2019-10-14 16:24:03.967	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      hue.0	2019-10-14 16:24:03.967	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      hue.0	2019-10-14 16:24:03.967	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      hue.0	2019-10-14 16:24:03.967	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
      hue.0	2019-10-14 16:24:03.967	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
      hue.0	2019-10-14 16:24:03.967	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
      hue.0	2019-10-14 16:24:03.967	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
      hue.0	2019-10-14 16:24:03.967	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
      hue.0	2019-10-14 16:24:03.967	error	(20363) TypeError: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:03.966	error	(20363) uncaught exception: Bottleneck is not a constructor
      hue.0	2019-10-14 16:24:03.782	info	(20363) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
      hue.0	2019-10-14 16:23:59.121	info	(20346) Terminated (NO_ERROR): Without reason
      hue.0	2019-10-14 16:23:59.119	info	(20346) terminating
      hue.0	2019-10-14 16:23:59.077	info	(20346) cleaned everything up...
      AlCalzoneA 2 Antworten Letzte Antwort
      • F freaktech
        hue
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #87
        @freaktech Auf npm ist nur eine 2.0.0 verfügbar. Ich hör mich mal direkt beim Entwickler um.
        F 1 Antwort Letzte Antwort
        • AlCalzoneA AlCalzone
          freaktech
          #88
          @AlCalzone
          danke und für was ist das js2fs.0 ? das ist ja auch rot
          • F freaktech
            hue
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            #89
            @freaktech Es könnte sein, dass dein Hue-Adapter durch die Update-Orgie kaputt gegangen ist. Probier mal, manuell neu zu installieren:
            cd /opt/iobroker
            npm i iobroker.hue
            Du hast keine Logs gepostet, die mit js2fs beginnen. Am besten startest du mal den Adapter neu und kopierst mir direkt den zugehörigen Log.
            • F Offline
              freaktech
              #90
              @AlCalzone said in PI4 Lässt JS Kontrolle nicht updaten:
              npm i iobroker.hue
              glaub das war nicht so ok
              pi@iobrocker:/opt/iobroker $ npm i iobroker.hue
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/iobroker.js-controller/node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              + iobroker.hue@2.0.0
              updated 1 package and audited 7012 packages in 28.382s
              found 43 vulnerabilities (31 low, 1 moderate, 11 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              • F freaktech
                npm i iobroker.hue
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                #91
                @freaktech sagte in PI4 Lässt JS Kontrolle nicht updaten:
                updated 1 package
                Doch! Musst den Adapter noch neustarten.
                • F Offline
                  freaktech
                  #92
                  danach im LOG
                  hue.0	2019-10-14 16:37:22.582	error	(23824) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                  hue.0	2019-10-14 16:37:22.580	error	(23824) uncaught exception: Bottleneck is not a constructor
                  hue.0	2019-10-14 16:37:17.954	error	(23801) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                  hue.0	2019-10-14 16:37:17.952	error	(23801) uncaught exception: Bottleneck is not a constructor
                  hue.0	2019-10-14 16:37:13.404	error	(23785) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                  hue.0	2019-10-14 16:37:13.400	error	(23785) uncaught exception: Bottleneck is not a constructor
                  hue.0	2019-10-14 16:37:08.578	error	(23751) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                  hue.0	2019-10-14 16:37:08.574	error	(23751) uncaught exception: Bottleneck is not a constructor
                  hue.0	2019-10-14 16:37:03.897	error	(23735) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                  hue.0	2019-10-14 16:37:03.895	error	(23735) uncaught exception: Bottleneck is not a constructor
                  • F Offline
                    freaktech
                    #93
                    was ist eigentlich das andere JSFS ??
                    AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                    • F freaktech
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      #94
                      @freaktech Spiegelt Skripte zwischen Festplatte und ioBroker. Da mir es sehr danach klingt, dass du ihn nicht nutzt, frage ich mich, warum er überhaupt installiert und aktiv ist?!
                      • F freaktech
                        apollon77A Online
                        apollon77A Online
                        #95
                        @freaktech Wenn Du den Adapter installiert hast solltest Du wissen was er tut, sonst lösch :-)
                        Der Adapter synct JavaScript ins Filesystem. Ohne Konfig bleibt der ggf rot.
                        • F Offline
                          freaktech
                          schrieb am zuletzt editiert von freaktech
                          #96
                          ok dann kann ich den löschen
                          müsst man nur noch wissen was dieses LOGFEHLER bei HUE plötzlich sind
                          hue.0	2019-10-14 16:44:51.066	error	(25827) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:51.065	error	(25827) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:46.280	error	(25812) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:46.279	error	(25812) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:41.630	error	(25796) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:41.629	error	(25796) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:36.973	error	(25780) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:36.971	error	(25780) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:32.036	error	(25764) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:32.032	error	(25764) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:27.409	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                          hue.0	2019-10-14 16:44:27.409	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                          hue.0	2019-10-14 16:44:27.409	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          hue.0	2019-10-14 16:44:27.409	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                          hue.0	2019-10-14 16:44:27.409	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                          hue.0	2019-10-14 16:44:27.409	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                          hue.0	2019-10-14 16:44:27.409	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:27.409	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                          hue.0	2019-10-14 16:44:27.409	error	(25733) TypeError: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:27.405	error	(25733) uncaught exception: Bottleneck is not a constructor
                          hue.0	2019-10-14 16:44:22.344	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                          hue.0	2019-10-14 16:44:22.344	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                          hue.0	2019-10-14 16:44:22.344	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                          hue.0	2019-10-14 16:44:22.344	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                          hue.0	2019-10-14 16:44:22.344	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                          hue.0	2019-10-14 16:44:22.344	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                          hue.0	2019-10-14 16:44:22.344	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                          hue.0	2019-10-14 16:44:22.344	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                          hue.0	2019-10-14 16:44:22.344	error	(25689) TypeError: Bottleneck is not a constructor
                          • F freaktech
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            #97
                            @freaktech Hast du möglicherweise vor kurzem von einer alten Version auf die 2.0 aktualisiert?
                              freaktech
                              #98
                              @AlCalzone
                              nein die 2.0 ist schon ein paar Wochen oben
                              ich bin jetzt mal bis 18:45 im Auto
                              würd mich freuen wenn du zwischenzeitlich was posten könntest was ich dann probieren kann
                              vielen danke für deine tollen bemühungen
                              lg
                              tom
                              • F freaktech
                                @AlCalzone
                                lg
                                tom
                                AlCalzoneA Offline
                                AlCalzoneA Offline
                                AlCalzone
                                #99
                                @freaktech Ich hab leider keine Ahnung was bei dem Adapter kaputt sein könnte. Das Problem liegt am Adapter bzw. einer Abhängigkeit davon. Der Entwickler ist informiert, ggf meldet er sich ja.
                                • foxriver76F Offline
                                  foxriver76F Offline
                                  foxriver76
                                  schrieb am zuletzt editiert von foxriver76
                                  #100
                                  Weiß spontan nicht woran es liegt. An Bottleneck wurde in letzter Zeit nichts geändert. Mach mal noch iobroker u hue. ansonsten schaue ich heute Abend nochmal.
                                  Videotutorials & mehr
                                  • apollon77A Online
                                    apollon77A Online
                                    #101
                                    wie wäre es mit (im ioBroker verzeiczhnis)
                                    • npm uninstall iobroker.hue
                                    • npm install iobroker.hue
                                    • iobroker upload hue
                                    • F Offline
                                      freaktech
                                      #102
                                      auch diese Befehle haben jetzt nichts gebracht
                                      ich versuch nun das Pi4 minimal Image und hoffe backitup kann restoren hab mir grad eine 2- sd besorgt
                                      • F Offline
                                        freaktech
                                        #103
                                        wie lange dauert ein Full restore mit backitup?
                                        er schaltet ja sofort den iobroker aus und man sieht keinen Fortschritt
                                        • F Offline
                                          freaktech
                                          #104
                                          na das klappt ja auch nicht ganz toll
