  4. PI4 Lässt JS Kontrolle nicht updaten
js-controller 2.0.25
106 Beiträge 8 Kommentatoren 13.9k Aufrufe 9 Beobachtet
  • F freaktech
    gerne
    pi@iobrocker:/opt/iobroker $
    pi@iobrocker:/opt/iobroker $ sudo -H -u iobroker npm cache verify
    Cache verified and compressed (~/.npm/_cacache):
    Content verified: 2236 (238151167 bytes)
    Corrupted content removed: 6
    Content garbage-collected: 320 (25315666 bytes)
    Missing content: 6
    Index entries: 3784
    Finished in 38.938s
    AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    #78
    @freaktech sagte in PI4 Lässt JS Kontrolle nicht updaten:
    Bingo!
    Magst du noch ein weiteres mal iobroker upgrade self probieren? Bitte auch wieder die Ausgabe posten.
    F 1 Antwort Letzte Antwort
    • AlCalzoneA AlCalzone
      Bingo!
      freaktech
      #79
      @AlCalzone
      anbei
      pi@iobrocker:/opt/iobroker $ iobroker upgrade self
      Update js-controller from @1.5.14 to @2.0.29
      NPM version: 6.12.0
      npm install iobroker.js-controller@2.0.29 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      In file included from ../src/unix_dgram.cc:5:
      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnRecv({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:121:25: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           argv);
      ../../nan/nan.h:1024:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
                           argv);
      ../src/unix_dgram.cc: In function ‘void {anonymous}::OnWritable({anonymous}::SocketContext*)’:
      ../src/unix_dgram.cc:129:28: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
                           0, NULL);
                           0, NULL);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         domain      = info[0]->Int32Value();
      In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:26,
                       from /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:63,
                       from ../../nan/nan.h:54,
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2478:46: note: declared here
         V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         type        = info[1]->Int32Value();
      ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         protocol    = info[2]->Int32Value();
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         fd = info[0]->Int32Value();
      ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[1]);
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2892:28: note: declared here
                         explicit Utf8Value(Local<v8::Value> obj));
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         buf = info[1]->ToObject();
      In file included from /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:63,
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:10046:15: note: declared here
       Local<Object> Value::ToObject() const {
      ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         offset = info[2]->Uint32Value();
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:2477:47: note: declared here
         V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
      ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         length = info[3]->Uint32Value();
      ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
         String::Utf8Value path(info[4]);
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
      ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
      In file included from ../../nan/nan.h:54,
      ../src/unix_dgram.cc: At global scope:
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:570:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/node.h:604:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/unix_dgram.cc:420:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/node_object_wrap.h:85:78:   required from here
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                      reinterpret_cast<Callback>(callback), type);
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
      ../../nan/nan_object_wrap.h:65:61:   required from here
      /home/iobroker/.cache/node-gyp/10.15.2/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.4 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      Host "iobrocker" (linux) updated
      Execute: chmod -R 777 /opt/iobroker
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/lib': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/lib/hueHelper.js': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/package.json': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/instruction.png': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/index_m.html': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/index.html': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/hue.jpeg': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/admin/words.js': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/main.js': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/LICENSE': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/modules.xml': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/ioBroker.hue.iml': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/vcs.xml': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/misc.xml': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/.idea/workspace.xml': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/io-package.json': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.hue/README.md': Die Operation ist nicht erlaubt
      Chmod finished. Restart controller
      Starting node restart.js
      • F freaktech
        @AlCalzone
        anbei
        NPM version: 6.12.0
                             argv);
                             argv);
                             0, NULL);
                             0, NULL);
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        #80
        @freaktech Sieht an sich gut aus. Gibt iobroker -v jetzt endlich die neue Version aus?
          freaktech
          #81
          @AlCalzone
          im Host steht
          iobrocker
          Typ: js-controller
          Titel: JS controller
          OS: linux
          Verfügbar: 2.0.29
          Eingerichtet: 2.0.29
          Ereignisse: ⇥4 / ↦15
          • F Offline
            freaktech
            #82
            aber es laufen wieder einige Adapater nicht
            hue.0	2019-10-14 16:18:28.808	info	(18423) Terminated (NO_ERROR): Without reason
            hue.0	2019-10-14 16:18:28.806	info	(18423) terminating
            hue.0	2019-10-14 16:18:28.765	info	(18423) cleaned everything up...
            hue.0	2019-10-14 16:18:28.763	error	(18423) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
            hue.0	2019-10-14 16:18:28.760	error	(18423) uncaught exception: Bottleneck is not a constructor
            hue.0	2019-10-14 16:18:28.585	info	(18423) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
            hue.0	2019-10-14 16:18:23.415	info	(18356) Terminated (NO_ERROR): Without reason
            hue.0	2019-10-14 16:18:23.412	info	(18356) terminating
            hue.0	2019-10-14 16:18:23.362	info	(18356) cleaned everything up...
            hue.0	2019-10-14 16:18:23.359	error	(18356) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
            hue.0	2019-10-14 16:18:23.357	error	(18356) uncaught exception: Bottleneck is not a constructor
            hue.0	2019-10-14 16:18:23.149	info	(18356) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
            hue.0	2019-10-14 16:18:18.059	info	(18317) Terminated (NO_ERROR): Without reason
            hue.0	2019-10-14 16:18:18.056	info	(18317) terminating
            hue.0	2019-10-14 16:18:17.996	info	(18317) cleaned everything up...
            hue.0	2019-10-14 16:18:17.993	error	(18317) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
            hue.0	2019-10-14 16:18:17.991	error	(18317) uncaught exception: Bottleneck is not a constructor
            hue.0	2019-10-14 16:18:17.791	info	(18317) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
            hue.0	2019-10-14 16:18:11.508	info	(18257) Terminated (NO_ERROR): Without reason
            hue.0	2019-10-14 16:18:11.504	info	(18257) terminating
            hue.0	2019-10-14 16:18:11.457	info	(18257) cleaned everything up...
            hue.0	2019-10-14 16:18:11.454	error	(18257) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
            hue.0	2019-10-14 16:18:11.452	error	(18257) uncaught exception: Bottleneck is not a constructor
            hue.0	2019-10-14 16:18:11.265	info	(18257) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
            hue.0	2019-10-14 16:18:05.895	info	(18230) cleaned everything up...
            hue.0	2019-10-14 16:18:05.892	error	at process._tickCallback (internal/process/next_tick.js:68:7)
            hue.0	2019-10-14 16:18:05.892	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            hue.0	2019-10-14 16:18:05.892	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            hue.0	2019-10-14 16:18:05.892	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
            hue.0	2019-10-14 16:18:05.892	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
            hue.0	2019-10-14 16:18:05.892	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
            hue.0	2019-10-14 16:18:05.892	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
            • F freaktech
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              #83
              einige
              Du meinst nur Hue, oder? Probier mal den Adapter zu aktualisieren. Sollte jetzt funktionieren.
              • F Offline
                freaktech
                #84
                aktuelle dann
                diese
                • F freaktech
                  aktuelle dann
                  diese
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  #85
                  @freaktech Ohne die zugehörigen Logs kann ich da nix machen.
                  • F Offline
                    freaktech
                    #86
                    hue
                    da würde es auch schon einen 2.01 geben aber den zeigt er mir nicht an wie kann man bei den adaptern die latest installieren?
                    hue.0	2019-10-14 16:24:37.046	info	(20528) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:37.044	info	(20528) terminating
                    hue.0	2019-10-14 16:24:36.996	info	(20528) cleaned everything up...
                    hue.0	2019-10-14 16:24:36.993	error	(20528) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:36.991	error	(20528) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:36.833	info	(20528) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:32.211	info	(20511) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:32.209	info	(20511) terminating
                    hue.0	2019-10-14 16:24:32.166	info	(20511) cleaned everything up...
                    hue.0	2019-10-14 16:24:32.164	error	(20511) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:32.162	error	(20511) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:32.004	info	(20511) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:27.464	info	(20489) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:27.462	info	(20489) terminating
                    hue.0	2019-10-14 16:24:27.418	info	(20489) cleaned everything up...
                    hue.0	2019-10-14 16:24:27.416	error	(20489) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:27.415	error	(20489) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:27.259	info	(20489) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:22.977	info	(20445) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:22.975	info	(20445) terminating
                    hue.0	2019-10-14 16:24:22.934	info	(20445) cleaned everything up...
                    hue.0	2019-10-14 16:24:22.932	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    hue.0	2019-10-14 16:24:22.932	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    hue.0	2019-10-14 16:24:22.932	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    hue.0	2019-10-14 16:24:22.932	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                    hue.0	2019-10-14 16:24:22.932	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                    hue.0	2019-10-14 16:24:22.932	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                    hue.0	2019-10-14 16:24:22.932	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:22.932	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                    hue.0	2019-10-14 16:24:22.932	error	(20445) TypeError: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:22.931	error	(20445) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:22.773	info	(20445) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:18.023	info	(20429) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:18.021	info	(20429) terminating
                    hue.0	2019-10-14 16:24:17.975	info	(20429) cleaned everything up...
                    hue.0	2019-10-14 16:24:17.973	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    hue.0	2019-10-14 16:24:17.973	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    hue.0	2019-10-14 16:24:17.973	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    hue.0	2019-10-14 16:24:17.973	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                    hue.0	2019-10-14 16:24:17.973	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                    hue.0	2019-10-14 16:24:17.973	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                    hue.0	2019-10-14 16:24:17.973	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:17.973	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                    hue.0	2019-10-14 16:24:17.973	error	(20429) TypeError: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:17.968	error	(20429) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:17.791	info	(20429) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:13.116	info	(20395) terminating
                    hue.0	2019-10-14 16:24:13.075	info	(20395) cleaned everything up...
                    hue.0	2019-10-14 16:24:13.073	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    hue.0	2019-10-14 16:24:13.073	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    hue.0	2019-10-14 16:24:13.073	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    hue.0	2019-10-14 16:24:13.073	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                    hue.0	2019-10-14 16:24:13.073	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                    hue.0	2019-10-14 16:24:13.073	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                    hue.0	2019-10-14 16:24:13.073	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:13.073	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                    hue.0	2019-10-14 16:24:13.073	error	(20395) TypeError: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:13.072	error	(20395) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:12.905	info	(20395) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:08.599	info	(20379) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:08.597	info	(20379) terminating
                    hue.0	2019-10-14 16:24:08.554	info	(20379) cleaned everything up...
                    hue.0	2019-10-14 16:24:08.552	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    hue.0	2019-10-14 16:24:08.552	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    hue.0	2019-10-14 16:24:08.552	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    hue.0	2019-10-14 16:24:08.552	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                    hue.0	2019-10-14 16:24:08.552	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                    hue.0	2019-10-14 16:24:08.552	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                    hue.0	2019-10-14 16:24:08.552	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:08.552	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                    hue.0	2019-10-14 16:24:08.552	error	(20379) TypeError: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:08.550	error	(20379) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:08.382	info	(20379) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:24:04.029	info	(20363) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:24:04.027	info	(20363) terminating
                    hue.0	2019-10-14 16:24:03.969	info	(20363) cleaned everything up...
                    hue.0	2019-10-14 16:24:03.967	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                    hue.0	2019-10-14 16:24:03.967	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                    hue.0	2019-10-14 16:24:03.967	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                    hue.0	2019-10-14 16:24:03.967	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                    hue.0	2019-10-14 16:24:03.967	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                    hue.0	2019-10-14 16:24:03.967	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                    hue.0	2019-10-14 16:24:03.967	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                    hue.0	2019-10-14 16:24:03.967	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                    hue.0	2019-10-14 16:24:03.967	error	(20363) TypeError: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:03.966	error	(20363) uncaught exception: Bottleneck is not a constructor
                    hue.0	2019-10-14 16:24:03.782	info	(20363) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.hue, node: v10.15.2
                    hue.0	2019-10-14 16:23:59.121	info	(20346) Terminated (NO_ERROR): Without reason
                    hue.0	2019-10-14 16:23:59.119	info	(20346) terminating
                    hue.0	2019-10-14 16:23:59.077	info	(20346) cleaned everything up...
                    AlCalzoneA 2 Antworten Letzte Antwort
                    • F freaktech
                      hue
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      #87
                      @freaktech Auf npm ist nur eine 2.0.0 verfügbar. Ich hör mich mal direkt beim Entwickler um.
                        freaktech
                        #88
                        @AlCalzone
                        danke und für was ist das js2fs.0 ? das ist ja auch rot
                        • F freaktech
                          hue
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #89
                          @freaktech Es könnte sein, dass dein Hue-Adapter durch die Update-Orgie kaputt gegangen ist. Probier mal, manuell neu zu installieren:
                          cd /opt/iobroker
                          npm i iobroker.hue
                          Du hast keine Logs gepostet, die mit js2fs beginnen. Am besten startest du mal den Adapter neu und kopierst mir direkt den zugehörigen Log.
                          • F Offline
                            freaktech
                            #90
                            @AlCalzone said in PI4 Lässt JS Kontrolle nicht updaten:
                            npm i iobroker.hue
                            glaub das war nicht so ok
                            pi@iobrocker:/opt/iobroker $ npm i iobroker.hue
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.1 (node_modules/iobroker.js-controller/node_modules/fsevents):
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
                            + iobroker.hue@2.0.0
                            updated 1 package and audited 7012 packages in 28.382s
                            found 43 vulnerabilities (31 low, 1 moderate, 11 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                            • F freaktech
                              npm i iobroker.hue
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #91
                              updated 1 package
                              Doch! Musst den Adapter noch neustarten.
                              • F Offline
                                freaktech
                                #92
                                danach im LOG
                                hue.0	2019-10-14 16:37:22.582	error	(23824) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                hue.0	2019-10-14 16:37:22.580	error	(23824) uncaught exception: Bottleneck is not a constructor
                                hue.0	2019-10-14 16:37:17.954	error	(23801) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                hue.0	2019-10-14 16:37:17.952	error	(23801) uncaught exception: Bottleneck is not a constructor
                                hue.0	2019-10-14 16:37:13.404	error	(23785) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                hue.0	2019-10-14 16:37:13.400	error	(23785) uncaught exception: Bottleneck is not a constructor
                                hue.0	2019-10-14 16:37:08.578	error	(23751) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                hue.0	2019-10-14 16:37:08.574	error	(23751) uncaught exception: Bottleneck is not a constructor
                                hue.0	2019-10-14 16:37:03.897	error	(23735) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                hue.0	2019-10-14 16:37:03.895	error	(23735) uncaught exception: Bottleneck is not a constructor
                                • F Offline
                                  freaktech
                                  #93
                                  was ist eigentlich das andere JSFS ??
                                  AlCalzoneA apollon77A 2 Antworten Letzte Antwort
                                  • F freaktech
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    #94
                                    @freaktech Spiegelt Skripte zwischen Festplatte und ioBroker. Da mir es sehr danach klingt, dass du ihn nicht nutzt, frage ich mich, warum er überhaupt installiert und aktiv ist?!
                                    • F freaktech
                                      apollon77A Online
                                      apollon77A Online
                                      #95
                                      @freaktech Wenn Du den Adapter installiert hast solltest Du wissen was er tut, sonst lösch :-)
                                      Der Adapter synct JavaScript ins Filesystem. Ohne Konfig bleibt der ggf rot.
                                      • F Offline
                                        freaktech
                                        schrieb am zuletzt editiert von freaktech
                                        #96
                                        ok dann kann ich den löschen
                                        müsst man nur noch wissen was dieses LOGFEHLER bei HUE plötzlich sind
                                        hue.0	2019-10-14 16:44:51.066	error	(25827) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:51.065	error	(25827) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:46.280	error	(25812) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:46.279	error	(25812) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:41.630	error	(25796) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:41.629	error	(25796) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:36.973	error	(25780) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:36.971	error	(25780) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:32.036	error	(25764) TypeError: Bottleneck is not a constructor at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18) at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:32.032	error	(25764) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:27.409	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                        hue.0	2019-10-14 16:44:27.409	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                        hue.0	2019-10-14 16:44:27.409	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                        hue.0	2019-10-14 16:44:27.409	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                                        hue.0	2019-10-14 16:44:27.409	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                                        hue.0	2019-10-14 16:44:27.409	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                                        hue.0	2019-10-14 16:44:27.409	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:27.409	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                                        hue.0	2019-10-14 16:44:27.409	error	(25733) TypeError: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:27.405	error	(25733) uncaught exception: Bottleneck is not a constructor
                                        hue.0	2019-10-14 16:44:22.344	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                        hue.0	2019-10-14 16:44:22.344	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                        hue.0	2019-10-14 16:44:22.344	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                        hue.0	2019-10-14 16:44:22.344	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:524:17)
                                        hue.0	2019-10-14 16:44:22.344	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6427:25)
                                        hue.0	2019-10-14 16:44:22.344	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6723:66)
                                        hue.0	2019-10-14 16:44:22.344	error	at Object.ready (/opt/iobroker/node_modules/iobroker.hue/main.js:500:13)
                                        hue.0	2019-10-14 16:44:22.344	error	at main (/opt/iobroker/node_modules/iobroker.hue/main.js:1593:18)
                                        hue.0	2019-10-14 16:44:22.344	error	(25689) TypeError: Bottleneck is not a constructor
                                        • F freaktech
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #97
                                          @freaktech Hast du möglicherweise vor kurzem von einer alten Version auf die 2.0 aktualisiert?
