  4. Test Adaper Tado v0.1.x
tadoadaptertesting team
868 Beiträge 62 Kommentatoren 316.2k Aufrufe 59 Beobachtet
  • M mech
    Hab grad mal aus dem Github das Update eingespielt. Bekomme nun folgende Fehler:
    Caught	2019-10-13 21:02:15.610	error	by controller[78]: (node:31783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reject
    Caught	2019-10-13 21:02:15.610	error	by controller[78]: at process._tickCallback (internal/process/next_tick.js:68:7)
    Caught	2019-10-13 21:02:15.610	error	by controller[78]: at Tado.DoAwayConfiguration (/opt/iobroker/node_modules/iobroker.tado/main.js:1249:11)
    Caught	2019-10-13 21:02:15.609	error	by controller[78]: at Tado.create_state (/opt/iobroker/node_modules/iobroker.tado/main.js:1277:27)
    Caught	2019-10-13 21:02:15.609	error	by controller[78]: (node:31783) UnhandledPromiseRejectionWarning: TypeError: Cannot set property 'write' of undefined
    Caught	2019-10-13 21:02:15.609	error	by controller[77]: (node:31783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reject
    Caught	2019-10-13 21:02:15.609	error	by controller[76]: at process._tickCallback (internal/process/next_tick.js:68:7)
    Caught	2019-10-13 21:02:15.609	error	by controller[76]: at Tado.DoZoneStates (/opt/iobroker/node_modules/iobroker.tado/main.js:1110:18)
    Caught	2019-10-13 21:02:15.609	error	by controller[76]: at Tado.create_state (/opt/iobroker/node_modules/iobroker.tado/main.js:1277:27)
    Caught	2019-10-13 21:02:15.609	error	by controller[76]: (node:31783) UnhandledPromiseRejectionWarning: TypeError: Cannot set property 'write' of undefined
    Caught	2019-10-13 21:02:15.609	error	by controller[75]: (node:31783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reject
    Caught	2019-10-13 21:02:15.609	error	by controller[75]: at process._tickCallback (internal/process/next_tick.js:68:7)
    Caught	2019-10-13 21:02:15.608	error	by controller[75]: at Tado.DoZoneStates (/opt/iobroker/node_modules/iobroker.tado/main.js:1121:18)
    Caught	2019-10-13 21:02:15.608	error	by controller[75]: at Tado.create_state (/opt/iobroker/node_modules/iobroker.tado/main.js:1277:27)
    Caught	2019-10-13 21:02:15.608	error	by controller[75]: (node:31783) UnhandledPromiseRejectionWarning: TypeError: Cannot set property 'write' of undefined
    Caught	2019-10-13 21:02:15.608	error	by controller[74]: (node:31783) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by reject
    Caught	2019-10-13 21:02:15.608	error	by controller[73]: at process._tickCallback (internal/process/next_tick.js:68:7)
    senger1985
    @mech bitte ziehe dir die neue Version von GitHub und gibt bitte bescheid, ob es läuft.
    • M mech
      DutchmanD Offline
      DutchmanD Offline
      Dutchman
      @mech sagte in [Aufruf] Neuer Adaper Tado:
      fixed in 0.1.1
      zusätzlich :
      • Bleiben die eingestellten Temperaturen jetzt vorhanden
      • Werde im info channel alle daten der API auseschrieben
      • C Offline
        CrazyCreator
        tado.0 2019-10-14 00:57:06.365 error (25535) Send this info to developer !!! { Unhandable information found in DoHome : "usePreSkillsApps" with value : true
        • C CrazyCreator
          senger1985
          @CrazyCreator bitte versuche erneut den Adapter zu installieren, wir haben gerade noch einen Fix durchgeführt.
          Sollte der Fehler erneut auftauchen, werden wir uns das morgen anschauen.
          • C Offline
            CrazyCreator
            Habe ich gerade eben gemacht ... Fehler bleibt. Bin jetzt auf der 0.1.1
            • C CrazyCreator
              senger1985
              @CrazyCreator okay, habe bitte bis morgen Geduld, wir werden uns das morgen anschauen.
              • C Offline
                CrazyCreator
                schrieb am zuletzt editiert von CrazyCreator
                Kein Problem ... Bin so froh das es vorwärts geht, da kommt es auf ein paar Tage mehr oder weniger nicht mehr an :)
                P.S. Wieso wird mir in der Adapterübersicht nicht angezeigt wenn es ein Update gibt?
                • S senger1985
                  @Stormbringer kannst du mal bitte von GitHub updaten und testen, ob es so ist, wie du meintest?
                  Stormbringer
                  @senger1985 sagte in [Aufruf] Neuer Adaper Tado:
                  Müsste da warten bis die Modi drinnen sind. Sonst kann ich’s schlecht beurteilen. Oder soll ich heute abend mal nur das Temperaturverhakten anschauen?
                  Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
                  • C CrazyCreator
                    Stormbringer
                    @CrazyCreator sagte in [Aufruf] Neuer Adaper Tado:
                    Denke hängt damit zusammen, dass er noch nicht im Repo ist 😉
                    • S Stormbringer
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @Stormbringer sagte in [Aufruf] Neuer Adaper Tado:
                      https://github.com/ioBroker/ioBroker.repositories/pull/505
                      • R Offline
                        Roland Ambrosch
                        schrieb am zuletzt editiert von Roland Ambrosch
                        Danke für den genialen Adapter!
                        Habe gerade frisch von github installiert und bekomme
                        • R Roland Ambrosch
                          DutchmanD Offline
                          DutchmanD Offline
                          Dutchman
                          schrieb am zuletzt editiert von Dutchman
                          @Roland-Ambrosch sagte in [Aufruf] Neuer Adaper Tado:
                          super danke das ist ein neuer wert den wir nicht kennen !
                          Er meldet in DoHome, wen der Fehler wieder auftritt poste mal bitte den Inhalt des Datenpunktes
                          ''tado.0.143236._info.JSON_response.Stage_02_HomeData"
                          Bitte beachte das hier persönliche daten drinstehen, entferne diese also bitte oder schicke mir die daten privat.
                          tip : benutzt http://jsonviewer.stack.hu um die daten lesbar zu machen!
                          Daten einfügen und auf format klicken
                          Das ganze kan man sich auch als Tabelle anschauen
                          • C Offline
                            Coffeelover
                            schrieb am zuletzt editiert von Coffeelover
                            kann ich den Tado-Modus (Home/Away) per Switch verändern? Sehe ich das richtig, dass ich den Wert für jeden Raum setzen kann?
                            Auf der Anwenderseite mal die Frage - ich hoffe sie führt hier nicht zu weit: Wie legt ihr die Steuerung eurer Heizung an, damit das wirklich smart ist?
                            Mein Ziel: Die Intelligenz in Tado nutzen (z.B. mit Pre-Heating), jedoch abhängig davon, ob ich daheim bin oder nicht. Dieser Zustand wird jedoch nicht über Tado gemeldet, sondern soll eigentlich aus einem State in iobroker gesteuert werden.
                            Variante 1: Ich baue mir, über Szenen, Blockly, Node-Red... die Flows, die zeit- und modusgetriggert die Solltemperatur ändern.
                            Variante 2: Ich lege die Heizungspläne in Tado selbst an und steuere den Status "Home/Away" je Raum.
                            Oder gibt es noch Möglichkeiten?
                            Ziel ist eine klassische Heizungssteuerung:
                            • Genutze Räume heizen, z.B. im Kinderzimmer die Heizung früher runterdrehen als im Wohnzimmer...
                            • Bei kurzer Abwesenheit tagsüber die Heizungen etwas reduzieren, abends aber wieder hochfahren. Eine Idee dazu wäre vielleicht: Über iobroker absenken, wenn auf Abwesend gestellt wird und diese Änderung bis zum nächsten Event im Zeitplan beizubehalten. -> Kann der Adapter das schon?
                            • Bei längeren Abwesenheiten die Heizung reduzieren und vor dem heimkommen wieder hochfahren.
                              Dabei sollte alles automatisch laufen - vielleicht mit Ausnahme der Heimkehr nach längerer Abwesenheit.
                            • C Coffeelover
                              Stormbringer
                              @Coffeelover Home / Away Temperatur Ansteuerung fände ich auch super, falls das noch per Adapter geht und nicht zu viel Arbeitsaufwand ist. Dann könnte ich alle Zusatzskripte über Board schmeissen.
                              Das Feature würde ich hernehmen um bei zu Bett gehen die Away Temperatur anzusteuern. Ansonsten habe ich nur noch Heizung aus, wenn Fenster offen und einen Kurzboost Modus als Skript dann laufen. Rufe ich entweder per Alexa auf oder wenn jemand duscht oder badet...
                              Ansonsten lasse ich alles vom System regeln, was es echt gut macht. Vor allem ob jemand daheim ist oder vorheizen, wenn man in die Nähe kommt. Wüsste nicht warum ich das über den ioBroker laufen lassen sollte, dann hätte man ja gleich ein normales Funkthermostat nehmen können. Mit nur genutzten Räumen heizen ist ein guter Ansatz aber denke ich wird sehr schwer zum umsetzen sein. Entweder hast so einen Versatz drinnen, dass dich erst mal ne Zeit lang im Zimmer friert oder die Heizung geht dauern aus und ein. Aber Geschmackssache g
                              C H 2 Antworten Letzte Antwort
                              • S Stormbringer
                                Coffeelover
                                @Stormbringer Mein aktuelles Problem: Meine Frau mag die Standorterkennung in der App nicht freischalten. Deswegen klappt "Annährung" auch nicht.
                                Habe mir aber gerade nochmal die Intelligenten Zeitpläne angeschaut. Wenn ich das Away/Home über mein SmartHome triggern könnte, würde das vermutlich schon ausreichen. Ich müsste nur mehr Heizphase" tagsüber einplanen, wenn es nicht auf away steht.
                                Fenster brauche ich nicht - wegen Fußbodenheizung fahre ich auch beim Lüften die Heizung nicht runter.
                                • C Coffeelover
                                  Stormbringer
                                  @Coffeelover Wie triggerst denn Smarthome ohne Standorterkennung?
                                  C 1 Antwort Letzte Antwort
                                  • S Stormbringer
                                    Coffeelover
                                    @Stormbringer Mein Handy triggert automatisch über Standort, meine Frau setzt den Status händisch beim Verlassen (und ankommen). Fürs Ankommen gibt es einen guten Ansatz über das Einloggen im WLAN, fürs Verlassen ist das zu unsicher.
                                    • C Coffeelover
                                      senger1985
                                      schrieb am zuletzt editiert von senger1985
                                      @Coffeelover und @Stormbringer im Moment habe ich meine Anwesenheitskontrolle komplett mit dem tr-064-Adapter umgesetzt.
                                      Wenn sich mein Smartphone im W-Lan befindet, wird mein Datenpunkt "Anwesend" auf "true" gesetzt und wenn mein Smartphone aus dem W-Lan verschwindet, wird der Datenpunkt auf "false" gesetzt.
                                      Das funktioniert bei mir sehr zuverlässig.
                                      Wir sind aber auch noch am schauen, ob und wie wir das mit dem Tado-Adapter umsetzen können.
                                      C S 2 Antworten Letzte Antwort
                                      • S senger1985
                                        Coffeelover
                                        @senger1985 Das würde bei mir auch funktionieren, meine Frau schaltet ihr Handy aber gerne nachts ab. Deswegen kann ich abwesend nicht automatisch setzen. Aber damit kann sie leben, das wäre also fein.
                                        => Home/Away über Adapter steuerbar wäre ein Traum. :-)
                                        • S senger1985
                                          Stormbringer
                                          naja wenns das heizen anfängt, wenn man erst daheim ist. find ich das wenig smart. und für solche lösungen wärt ihr wahrscheinlich mit homematic, z wave oder zigbee thermostate billiger weggekommen 😉
                                          C DutchmanD 2 Antworten Letzte Antwort
