  4. IoBroker Images für BananaPi, Cubietruck und Cubox i4
134 Beiträge 11 Kommentatoren 25.9k Aufrufe 1 Beobachtet
    derrapf
    Hi Rainer
    Ich glaube ich habe den Fehler gefunden:
    Ich hab falsch kopiert. ich hatte das /tmp/node_modules/iobroker.web unter /opt/iobroker/node_modules/iobroker.web kopiert gehabt. Mist.
    Jetzt hab ich alles nochmal verschoben und jetzt läuft auch der Vis.
    Die Logs sehen auch besser aus. Immerin gibts aber noch Fehler. Aber andere. Oder sind die harmlos?
    Drücke Strg+A und danach Strg+C, um den Inhalt in die Zwischenablage zu kopieren. Klicke irgendwo, um das Fenster zu schliessen.
    host-bananapi	2015-09-27 01:16:30	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:26	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:25	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:12	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:09	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:06	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:16:01	error	instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:52	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:44	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:38	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:30	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:17	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:15	error	instance system.adapter.hm-rpc.1 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:14	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:12	error	instance system.adapter.hm-rega.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:09	error	instance system.adapter.hm-rpc.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:15:05	error	instance system.adapter.sayit.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:14:58	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:14:55	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
    host-bananapi	2015-09-27 01:14:33	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    Ansonsten: Super! Die Basis scheint jetzt OK zu sein.
    Jetzt muss ich nur noch den Sayit zum Quatschen bringen und das Dashui das ich noch auf der CCU.IO habe irgendwie auf den IOBroker bringen.
    Hast Du einen Tip wie? Ansonsten google ich mal ne Runde.
    Gruss Ralf
    • BluefoxB Offline
      BluefoxB Offline
      Wenn du "already running " siehst, muss man die Kiste neu starten.
        derrapf
        Hallo Bluefox
        Diese "already running" Ausgaben kamen egentlich erst nach dem ich den Web Adapter installiert und rebootet hatte.
        Heute bin ich nochmal auf die IOBroker-Seite und die antwortete nicht mehr. Dann hab ich IOBroker restartet: Keine Änderung.
        Erst nach dem Rebot funktioniert die Seite wieder.
        Bis jetzt sieht das Log super aus: Alles blau; nix rot. Hoffe so bleibt es.
        Gruss Ralf
          Wenn du irgendwann -meistens nach einer Installation einer instanz- anschließend einen code 7 Fehler bekommst, hilft nur reboot.
          Gesendet von meinem LIFETAB_S785X mit Tapatalk
            derrapf
            Hi Rainer
            Danke für die Info. Das merke ich mir.
            Rein interessehalber: Was passiert da eigentlich?
            "instance system.adapter.admin.0 terminated with code 7 (Adapter already running)"
            klingt jetzt für mich nicht wie ein schlimmer Fehler: Ich würde diese Meldung so interpretieren, dass versucht wurde eine Instanz zu starten, diese aber schon läuft. Also eigentlich doch alles OK und gefühlt doch gar kein Fehler, oder?
            Warum brauch ich dann schwerste Bandagen (reboot)?
            Gruss Ralf
              Weil diese mit code7 beendete instanz anschließend sofort versucht wieder zu starten, "because enabled".
              Dann schaukelt sich das irgendwann auf.
              • L Offline
                little_tiger
                …ich kann die Beobachtung von Ralf bestätigen. Wenn ich mich einige Stunden nicht angemeldet habe, ist kein Zugriff mehr möglich. Da hilft nur Hard reset (Netz). Der BananaPi ist dann auch laut fritzbox nicht mehr im Netz angemeldet.
                Was kann das sein?
                Patrick
                  derrapf
                  Ahh!
                  Gut zu wissen, dass das bei mir kein Einzelfall war.
                  Ich hab grad mal nachgeschaut: Noch läuft der IOBroker.
                  Werde mal morgen nachmittag nochmal draufschauen. Mal sehen ob er dann noch lebt
                  Gruss Ralf
                  • L Offline
                    little_tiger
                    … Also mein BananaPi ist jetzt (nach ca. 15 Std.) wieder offline....
                      @little_tiger:
                      Also mein BananaPi ist jetzt (nach ca. 15 Std.) wieder offline…. `
                      Auch kein Zugriff mehr per ftp/ssh?
                      Wenn doch, bitte log ansehen (/opt/iobroker/log/iobroker.2015-09-28.log) (oder…-27.log)
                        derrapf
                        Bei mir sieht es zum Glück gut aus. Bn grad drauf. Er lebt noch und die Logs sind immer noch blau.
                        Jetzt kann ich mich dann also langsam um die wirklichen Frage nach dem "wie funktionierts" kümmern. Sayit und Dashui ist dann also dran.
                        Gruss Ralf
                        • L Offline
                          little_tiger
                          Peinlich, peinlich. Im heutigen Fall hat meine Frau mich gelinkt ;-)
                          … Die brauchte die Steckdose. Das hat man davon, wenn man zum Testen im Wohnzimmer alles anschließt.
                          Ich werde weiter beobachten...
                            derrapf
                            Hi
                            Nachtrag:
                            War jetzt wieder zwei Tage in München.
                            Habe heute abend die IOBroker Seite aufgerufen aber die blieb weiss (bis auf das drehende Zahnrad was man fuer ein paar Sekunden sah).
                            Der BaPi ist aber ganz normal per ssh erreichbar.
                            ps -e liefert:
                            root@bananapi:~# ps -e
                              PID TTY          TIME CMD
                                1 ?        00:00:14 init
                                2 ?        00:00:00 kthreadd
                                3 ?        00:01:57 ksoftirqd/0
                                5 ?        00:00:00 kworker/u:0
                                6 ?        00:00:00 migration/0
                                7 ?        00:00:00 migration/1
                                8 ?        00:00:00 kworker/1:0
                                9 ?        00:00:57 ksoftirqd/1
                               10 ?        00:00:00 cpuset
                               11 ?        00:00:00 khelper
                               12 ?        00:00:00 kdevtmpfs
                               13 ?        00:00:00 netns
                               14 ?        00:00:02 sync_supers
                               15 ?        00:00:00 bdi-default
                               16 ?        00:00:00 kintegrityd
                               17 ?        00:00:00 crypto
                               18 ?        00:00:00 kblockd
                               19 ?        00:00:00 khubd
                               20 ?        00:00:00 cpufreq_uevent
                               21 ?        00:00:46 kworker/1:1
                               22 ?        00:00:00 cfg80211
                               24 ?        00:00:00 rpciod
                               25 ?        00:00:00 khungtaskd
                               26 ?        00:00:02 kswapd0
                               27 ?        00:00:00 ksmd
                               28 ?        00:00:00 fsnotify_mark
                               29 ?        00:00:00 ecryptfs-kthrea
                               30 ?        00:00:00 nfsiod
                               31 ?        00:00:00 cifsiod
                               32 ?        00:00:00 jfsIO
                               33 ?        00:00:00 jfsCommit
                               34 ?        00:00:00 jfsCommit
                               35 ?        00:00:00 jfsSync
                               36 ?        00:00:00 xfsalloc
                               37 ?        00:00:00 xfs_mru_cache
                               38 ?        00:00:00 xfslogd
                               52 ?        00:00:00 scsi_eh_0
                               53 ?        00:00:00 kworker/u:1
                               54 ?        00:00:00 sun7i-spi.0
                               55 ?        00:00:00 bond0
                               63 ?        00:00:00 kmpathd
                               64 ?        00:00:00 kmpath_handlerd
                               65 ?        00:22:46 cfinteractive
                               66 ?        00:00:00 binder
                               67 ?        00:00:00 codec_resume
                               68 ?        00:03:02 hdmi proc
                               69 ?        00:00:00 deferwq
                               70 ?        00:00:27 mmcqd/0
                               71 ?        00:00:00 jbd2/mmcblk0p1-
                               72 ?        00:00:00 ext4-dio-unwrit
                              186 ?        00:00:00 udevd
                              279 ?        00:00:00 udevd
                              282 ?        00:00:00 udevd
                              600 ?        00:00:00 krfcommd
                             1954 ?        00:00:00 rsyslogd
                             2002 ?        00:00:01 cron
                             2046 ?        00:00:00 dbus-daemon
                             2053 ?        00:01:29 haveged
                             2108 ?        00:00:00 bluetoothd
                             2126 ?        00:00:00 lircd
                             2239 ?        00:00:58 ntpd
                             2275 ?        00:00:00 sshd
                             2330 ?        03:21:03 io.admin.0
                             2332 tty1     00:00:00 getty
                             2333 tty2     00:00:00 getty
                             2334 ttyS0    00:00:00 getty
                             2339 ?        02:51:06 io.javascript.0
                             2342 ?        00:44:02 io.node-red.0
                             2349 ?        00:42:33 io.sayit.0
                             3295 ?        00:10:21 node-red
                             3638 ?        00:00:00 kworker/0:0
                             3640 ?        00:00:00 flush-179:0
                             3641 ?        00:00:00 kworker/0:1
                             3706 ?        00:00:00 kworker/0:2
                             3707 ?        00:00:00 sshd
                             3709 pts/0    00:00:00 bash
                             3766 pts/0    00:00:00 ps
                            root@bananapi:~#
                            Hier die logs 743_logs.zip
                            Gruss Ralf
                            • W Offline
                              W Offline
                              Wolle_HB
                              ich bin neu in diesem Forum und werde wohl in nächster Zeit diverse Fragen stellen.
                              Beschäftige mich seit ein paar Wochen mit dem Thema Homematic und habe schon viele Dinge hier gelernt.
                              Von daher hier mal ein erstes Feedback zu meiner Cubox 4 Installation.
                              Ich habe das fertige Image aus dieser Site genommen.
                              Was mir als erstes aufgefallen ist.
                              Eine super Beschreibung wie ich das Ganze auf die SD Card bekomme auf einem Windows System. :)
                              Nach dem booten kennt der allerdings eth0 nicht, bzw nimmt eine falsche Mac Adresse.
                              Hilfe gab mir folgender Beitrag:
                              https://muffinresearch.co.uk/vmware-sio … r-cloning/
                              Geht auch für die Installation, Methode 2.
                              Danach Reboot, alles gut :D mit dem LAN
                              Ipad als Hotspot war dann eine echte Herausfordernung. :-)
                              auto wlan1
                              allow-hotplug wlan1
                              iface wlan1 inet dhcp
                              wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
                              wpa-ssid "Wolfgangs iPad"
                              wpa-psk "topsecret"
                              Soweit mal was von einem Newbie.
                                tapir
                                ich habe das SD-Image für den Cubietruck (10.10.2015) heruntergeladen und gestartet.
                                Leider nimmt er das root-Passwort "ioBrokerRoot" nicht.
                                Das pi-Passwort "raspberry" funktioniert.
                                Die Verbindung wurde per SSH aufgebaut.
                                Den "firstrun"-boot kann ich nicht sehen, weil kein Monitor am Cubietruck angeschlossen ist.
                                In der Beschreibung steht: "… das Passwort für den User root muss geändert werden".
                                Ist das ein Hinweis, oder erscheint beim "firstrun"-boot eine Aufforderung?
                                  derrapf
                                  Hallo Rainer
                                  Bezugnehmend auf den Thread http://forum.iobroker.net/viewtopic.php?f=20&t=4673 hab ich jetzt mal das neue Bananapi-Image angefangen zu testen.
                                  Das Erste was mir aufällt ist mal wieder das englische Tastaturlayout, dass mir immer wieder Probleme macht.
                                  Kannst Du nicht in der /etc/default/keyboard entsprechend die Zeile unten wie folgt ändern?
                                  XKBLAYOUT="de"
                                  Ansonsten bin ich grad dabei die interfaces auf WLAN umzustellen.
                                  Das Erste was mir hier aufällt ist ein Effekt den ich auch hatte als ich selber Jessie installieren wollte: Die Remote Session per SSH bricht immer wieder plötzlich ab. Ich muss mal rausfinden warum. Habe jetzt den EDIMAX Stick entsprechend so eingestellt, dass er sich nicht schlafen legt. Mal sehen ob es was hilft. Ich bin parallel zur Telnet Session noch direkt auf dem Bananapi. Parallel lassse ich auf dem Bananapi meinen Router anpingen; Das funktioniert auch während de SSH Abbruchs prblemlos.
                                  Und was sehr seltsam ist:
                                  Wenn ich sudo reboot eingebe, dann braucht er zum Beenden über 5 Minuten:
                                  A stop job is running for LSB: sarts ioBroker (xxxx/5min)
                                  ````xxx zählt durch.
                                  Was ist das? Und kann man den Reboot beschleunigen?
                                  Ich teste mal weiter und melde mich
                                  Gruss Ralf
                                    derrapf
                                    Das mit dem nicht funktionierenden SSH ist ein Problem. Wenn ich das nicht in den Griff bekomme gehts hier nicht weiter. Der Pi läuft headless, also muss SSH zwingend funktionieren.
                                    Ich habe mal folgendes gemacht:
                                    Per SSH eingeloggt und einen Rechner im Netz gepingt:
                                    root@ioBroker-BPi:~# ping 192.168.111.160
                                    PING 192.168.111.160 (192.168.111.160) 56(84) bytes of data.
                                    64 bytes from 192.168.111.160: icmp_seq=1 ttl=64 time=2724 ms
                                    64 bytes from 192.168.111.160: icmp_seq=2 ttl=64 time=1723 ms
                                    64 bytes from 192.168.111.160: icmp_seq=3 ttl=64 time=723 ms
                                    64 bytes from 192.168.111.160: icmp_seq=4 ttl=64 time=1.77 ms
                                    64 bytes from 192.168.111.160: icmp_seq=5 ttl=64 time=2.40 ms
                                    64 bytes from 192.168.111.160: icmp_seq=6 ttl=64 time=3.01 ms
                                    64 bytes from 192.168.111.160: icmp_seq=7 ttl=64 time=1.92 ms
                                    From 192.168.111.173 icmp_seq=16 Destination Host Unreachable
                                    From 192.168.111.173 icmp_seq=17 Destination Host Unreachable
                                    From 192.168.111.173 icmp_seq=18 Destination Host Unreachable
                                    64 bytes from 192.168.111.160: icmp_seq=19 ttl=64 time=52.2 ms
                                    Man sieht dass es irgendwann nicht mehr klappt und dann bricht der Putty auch die Verbindung ab.
                                    Ich habe gleichzeitig die /etc/log/auth.log getailed.
                                    Hier sehe ich
                                    Jan 7 01:01:11 ioBroker-BP1 systemd-logind[590]: New session c12 of user root
                                    Jan 7 01:01:37 ioBroker-BP1 sshd[4125]: pam_unix(sshd:session): session closed for user root
                                    Jan 7 01:01:37 ioBroker-BP1 systemd-logind[590]: Removed session c12.
                                    Wenn ich den Tail weiterkaufen lasse (und keine SSH Session weiterhin aufmache) dann gehts so weiter:
                                    Jan 7 01:05:01 ioBroker-BP1 CRON[4228]: pam_unix(cron:session): session opened for user root (uid=0)
                                    Jan 7 01:05:01 ioBroker-BP1 CRON[4228]: pam_unix(cron:session): session closed for user root
                                    Jan 7 01:09:01 ioBroker-BP1 CRON[4239]: pam_unix(cron:session): session opened for user root (uid=0)
                                    Jan 7 01:09:02 ioBroker-BP1 CRON[4239]: pam_unix(cron:session): session closed for user root
                                    Macht da der Cron eine SSH Session auf??
                                    Auj jeden Fall kann ich nicht erkennen warum die SSH Session abstirbt.
                                    Irgend ne Idee?
                                    Gruss Ralf
                                      derrapf
                                      So jetzt hab ichs versaut.
                                      Ein apt-get upgrade hat nach dem Reboot dafür gesorgt, dass nun zig mal die Meldung
                                      ethernet@01c50000 Waiting for PHY auto negotiation to complete ... TIMEOUT !
                                      kommt.
                                      Statt dem normalen Prompt steht jetzt ein````
                                      Eingeben kann man nix.
                                      Gruss Ralf
                                        Hallo Ralf,
                                        Wifi Anbindung kann ich nicht empfehlen und habe dies daher auch weder im Image installiert geschweige denn getestet.
                                        Was die Internationalisation Options angeht, sollte diese im Image auf deutsches Keyboard eingestellt sei, es sei denn dort hätte ich es vergessen.
                                        Dies teste ich üblicherweise nicht, da ich nur headless arbeite.
                                        Deine Probleme führe ich auf eine schlechte WLAN Anbindung zurück, was immer wieder vorkommt, weswegen ich diese nicht empfehle (s.o.).
                                        Im Moment solltest du das Image nochmal neu auf die Karte schieben, bevorbdu sonst noch mehr zeit in ein korruptes System steckst.
                                        PS du hast aber das aktuelle image, nicht das jahrealte?
                                          derrapf
                                          Hallo Rainer
                                          Ich habe das Image mit dem Namen ioBroker_Image_BPi_20160910.img verwendet. Ich hoffe das ist das Richtige.
                                          Bzgl. des Keyboards: Nein das ist auf englisch nach der Installation des Images.
                                          Da hast Du den Eintrag in keyboards vergessen umzustellen.
                                          Das müsste aber auffallen wenn Du headless arbeitest.
                                          Es sein denn Du haettest ein engl. Keboard.
                                          Zum WLAN: Ich kann's mir nicht aussuchen. Da wo der Bapi stehen muss (da stehen auch die Aktivboxen für Sayit) ist leider kein WLAN vorhanden.
                                          Es sein denn ich würde einen Accesspoint dort ausfstellen und den Bapi per Kabel anschliessen; was allerdings ein wenig überdimensioniert wäre. Der andere Bapi mit dem alten IBroker funktioniert ja auch halbwegs. Zumindest bricht die SSH Verbindung nicht ab.
                                          PS: Seit ich auf meinem Router ein OPENWRT installiert habe, habe ich auch keine Abbrüche mehr im VIS!
                                          Was anderes: Bei mir at sich das Image nicht vergrössert nach der Installation. Die Karte ist 16GB aber ich habe nur 2GB. Muss man das manuell machen?
                                          Gruss Ralf
