  4. IoBroker stürzt ab
IoBroker stürzt ab
iobrokerabsturzadaptersonosputty8081admin adapter
45 Beiträge 9 Kommentatoren 9.3k Aufrufe 6 Beobachtet
  • T toki1973
    Der Teil hier sieht seltsam aus. Ich habe radar2.0 und ble.0 über putty mal gestoppt.
    2019-10-10 09:49:11.436 - error: radar2.0 no connection to objects DB
    2019-10-10 09:49:11.428 - error: ble.0 no connection to objects DB
    2019-10-10 09:48:54.750 - error: telegram.0 no connection to objects DB
    2019-10-10 09:49:18.637 - error: terminal.0 no connection to objects DB
    2019-10-10 09:49:20.769 - error: Caught by controller[0]: FATAL ERROR: NewSpace::Rebalance Allocation failed - process out of memory
    2019-10-10 09:49:20.770 - warn: host.ioBroker-Pi instance system.adapter.admin.1 terminated due to SIGABRT
    2019-10-10 09:49:20.770 - error: host.ioBroker-Pi instance system.adapter.admin.1 terminated with code null ()
    2019-10-10 09:49:20.771 - info: host.ioBroker-Pi Restart adapter system.adapter.admin.1 because enabled
    2019-10-10 09:49:20.922 - error: Caught by controller[0]: FATAL ERROR: Committing semi space failed. Allocation failed - process out of memory
    2019-10-10 09:49:20.923 - warn: host.ioBroker-Pi instance system.adapter.node-red.0 terminated due to SIGABRT
    2019-10-10 09:49:20.923 - error: host.ioBroker-Pi instance system.adapter.node-red.0 terminated with code null ()
    2019-10-10 09:49:20.923 - info: host.ioBroker-Pi Restart adapter system.adapter.node-red.0 because enabled
    2019-10-10 09:49:21.045 - error: Caught by controller[0]: FATAL ERROR: Committing semi space failed. Allocation failed - process out of memory
    2019-10-10 09:49:21.046 - warn: host.ioBroker-Pi instance system.adapter.sonoff.0 terminated due to SIGABRT
    2019-10-10 09:49:21.046 - error: host.ioBroker-Pi instance system.adapter.sonoff.0 terminated with code null ()
    2019-10-10 09:49:21.047 - info: host.ioBroker-Pi Restart adapter system.adapter.sonoff.0 because enabled
    2019-10-10 09:49:21.118 - warn: backitup.0 Reconnection to DB.
    2019-10-10 09:49:21.143 - warn: web.0 Reconnection to DB.
    2019-10-10 09:49:21.152 - warn: alexa2.0 Reconnection to DB.
    2019-10-10 09:49:21.149 - warn: zigbee.0 Reconnection to DB.
    2019-10-10 09:49:21.328 - warn: backitup.0 Reconnection to DB.
    2019-10-10 09:49:21.335 - warn: alexa2.0 Reconnection to DB.
    2019-10-10 09:49:21.348 - warn: zigbee.0 Reconnection to DB.
    2019-10-10 09:49:21.349 - warn: web.0 Reconnection to DB.
    2019-10-10 09:49:21.589 - warn: javascript.0 Reconnection to DB.
    2019-10-10 09:49:21.656 - error: javascript.0 already running
    2019-10-10 09:49:21.672 - error: web.0 already running
    2019-10-10 09:49:21.727 - error: zigbee.0 already running
    2019-10-10 09:49:21.762 - error: backitup.0 already running
    2019-10-10 09:49:21.994 - error: host.ioBroker-Pi instance system.adapter.web.0 terminated with code 7 (Adapter already running)
    2019-10-10 09:49:21.994 - info: host.ioBroker-Pi Restart adapter system.adapter.web.0 because enabled
    2019-10-10 09:49:22.114 - error: host.ioBroker-Pi instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
    2019-10-10 09:49:22.115 - info: host.ioBroker-Pi Restart adapter system.adapter.javascript.0 because enabled
    2019-10-10 09:49:22.222 - error: host.ioBroker-Pi instance system.adapter.backitup.0 terminated with code 7 (Adapter already running)
    2019-10-10 09:49:22.223 - info: host.ioBroker-Pi Restart adapter system.adapter.backitup.0 because enabled
    2019-10-10 09:49:22.331 - error: host.ioBroker-Pi instance system.adapter.zigbee.0 terminated with code 7 (Adapter already running)
    2019-10-10 09:49:22.331 - info: host.ioBroker-Pi Restart adapter system.adapter.zigbee.0 because enabled
    2019-10-10 09:49:22.359 - info: alexa2.0 starting. Version 2.6.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.15.1
    2019-10-10 09:49:22.902 - info: alexa2.0 starting. Version 2.6.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.15.1
    2019-10-10 09:49:23.464 - info: terminal.0 starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.terminal, node: v8.15.1
    2019-10-10 09:49:23.884 - info: radar2.0 starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.15.1
    2019-10-10 09:49:24.271 - info: terminal.0 http server listening on port 8088
    2019-10-10 09:49:24.579 - info: ble.0 starting. Version 0.9.0 in /opt/iobroker/node_modules/iobroker.ble, node: v8.15.1
    2019-10-10 09:49:25.173 - info: ble.0 loaded plugins: Xiaomi, mi-flora, ruuvi-tag, _default
    2019-10-10 09:49:25.509 - info: telegram.0 starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.1
    2019-10-10 09:49:25.914 - warn: radar2.0 Promise failed @ '' error: { TypeError: Cannot read property 'name' of undefined at seriesOf.i (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:265:56) at p.then (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:794:37) at [stack]: 'TypeError: Cannot read property \'name\' of undefined\n at seriesOf.i (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:265:56)\n at p.then (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:794:37)\n at ', [message]: 'Cannot read property \'name\' of undefined' }
    2019-10-10 09:49:26.061 - info: radar2.0 radar2 initialization started...
    2019-10-10 09:49:25.191 - info: ble.0 enabled plugins: _default
    2019-10-10 09:49:25.193 - info: ble.0 monitored services:
    2019-10-10 09:49:26.148 - info: ble.0 starting scan for services []
    @toki1973 sagte in IoBroker stürzt ab:
    Das ist doch recht eindeutig ... Da solltest Du in /var/log/syslog was finden.
    Das bringt mich zur Frage: Scheint ja ein System mit 1GB RAM zu sein. Wieviele Instanzen hast Du denn so laufen?
    • apollon77A apollon77
      toki1973
      Ja das ist ein Raspberry 3 - ich habe die meisten deaktiviert und hoffe das damit kein Speicher verbraucht wird.
      Die Andriod App die den Status das RP anzeigt zeigt 576 von 927 MiB an. Auslagerung 36 von 100, Dateisystem hat 11 von 11Gb frei
      bind: 0.0.0.0, run as: admin
      + system.adapter.admin.1                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                : alexa2      -  enabled
      + system.adapter.backitup.0              : backitup    -  enabled
        system.adapter.ble.0                   : ble         - disabled
        system.adapter.cloud.0                 : cloud       - disabled
        system.adapter.discovery.0             : discovery   - disabled
        system.adapter.habpanel.0              : habpanel    - disabled
        system.adapter.history.0               : history     - disabled
        system.adapter.hue.0                   : hue         - disabled, port: 80
        system.adapter.ical.0                  : ical        - disabled
        system.adapter.icons-material-png.0    : icons-material-png -  enabled
        system.adapter.icons-material-svg.0    : icons-material-svg -  enabled
        system.adapter.icons-mfd-svg.0         : icons-mfd-svg -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png -  enabled
        system.adapter.icons-ultimate-png.0    : icons-ultimate-png -  enabled
        system.adapter.info.0                  : info        - disabled
      + system.adapter.javascript.0            : javascript  -  enabled
        system.adapter.lightify.0              : lightify    - disabled
        system.adapter.mihome-vacuum.0         : mihome-vacuum - disabled, port: 54321
        system.adapter.mihome.0                : mihome      - disabled, port: 9898, bind: 0.0.0.0
        system.adapter.mobile.0                : mobile      -  enabled
        system.adapter.mqtt-client.0           : mqtt-client - disabled, port: 1884
        system.adapter.mqtt.0                  : mqtt        - disabled, port: 1884
      + system.adapter.node-red.0              : node-red    -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.ping.0                  : ping        - disabled
        system.adapter.pollenflug.0            : pollenflug  - disabled
        system.adapter.pushover.0              : pushover    - disabled
        system.adapter.pushover.1              : pushover    - disabled
        system.adapter.radar2.0                : radar2      - disabled
        system.adapter.rpi2.0                  : rpi2        - disabled
        system.adapter.samsung.0               : samsung     - disabled
      + system.adapter.sonoff.0                : sonoff      -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.synology.0              : synology    - disabled, port: 5000
        system.adapter.tankerkoenig.0          : tankerkoenig - disabled
        system.adapter.telegram.0              : telegram    - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0              : terminal    -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.text2command.0          : text2command - disabled
        system.adapter.vis-hqwidgets.0         : vis-hqwidgets -  enabled
        system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd -  enabled
        system.adapter.vis-metro.0             : vis-metro   -  enabled
        system.adapter.vis-plumb.0             : vis-plumb   -  enabled
        system.adapter.vis-rgraph.0            : vis-rgraph  -  enabled
        system.adapter.vis-timeandweather.0    : vis-timeandweather -  enabled
        system.adapter.vis-weather.0           : vis-weather -  enabled
        system.adapter.vis.0                   : vis         -  enabled
        system.adapter.weatherunderground.0    : weatherunderground - disabled
      + system.adapter.web.0                   : web         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                   : web         - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                : zigbee      -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1F563-if00
      + instance is alive
      NUC, PROXMOX, Grafana, Influx, Unify
      • T toki1973
        + instance is alive
        @toki1973 Also mit 9+1 Prozessen kann die Zahl 576 MB durchaus passen.
        Am Ende ists jetzt so: IRGENDWAS passiert auf dem System was Speicher braucht ... von daher wäre /var/log/syslog mit check nach "OOM" immer noch mega interessant .... Das hat ggf nichts mit ioBroker zu tun.
        Dein System hat "im normalen Betrieb" 300MB freien RAM ... je nachdem was da passiert kann das recht schnell verbraucht sein. Keine Ahnung Backitup und Paketaktualisierung via apt-get läuft beides parallel gegen 6:30 ... beides braucht ggf einiges an RAM kurzzeitig ... und schon machts Bumm
        Wann macht Backitup das Backup?
          toki1973
          @apollon77 Okay danke schonmal. Um 2 Uhr mach ich die Backups. Im syslog ist nicht von OOM zu sehen.
          Heut morgen konnte ich über die web Schnittstelle verbinden und wollte ein Script erstellen. Nach kurzer Zeit brach die Verbindung ab. Und ich komme per Web nicht mehr drauf. Auslastung ist lt. APP bei bei 44% Temperatur bei 49 Grad
          • T toki1973
            @toki1973 naja mit der Meldung im Log ist Dir der Speicher ausgegangen ... Wodurch ... puuhhh...
              toki1973
              Naja, aber aktuell habe ich Speicher und komme nicht mehr auf den Admin. admin.1 Instanz läuft aber. VIS funktioniert ebenfalls. Kann es an der nicht verwendeten admin.0 Instanz liegen?
              • T toki1973
                @toki1973 Mit dem Log oben und den doppelt laufenden Adaptern und allem kann alles und nichts duie Ursache sein. AM besten reboot und gut.
                Du musst rausfinden was genau passiert wenn der RAM ausgeht und welcher Prozess "schuld" ist. Wenn Du das nicht findest ist blöd.
                Lass eine Shell mit "top" offen und versuche es irgendwie zu provozieren und dann schau was top sagt. Welcher Prozess braucht grad mehr RAM als sonst und so
                  toki1973
                  iobroker Restart und dann der Versuch mich zu Verbinden bleibt hängen:
                  ![alt text](93b635da-7ebc-4587-ab41-28d99d70ee16-image.png image url)
                  • T toki1973
                    @toki1973 Ja direkt beim Start wenn alle Adapter hochkommen kann schon bissl Last entstehen ... Immer noch so danach?
                    sigi234S T 2 Antworten Letzte Antwort
                      sigi234S Online
                      sigi234S Online
                      @apollon77 sagte in IoBroker stürzt ab:
                      Hm, vielleicht ein Skript was läuft?
                        toki1973
                        @apollon77 Aktuell funktioniert es. Ich lasse jetzt mal das htop offen und warte bis es wieder hängt und schaue dann die die var/logs.
                        Vielen Dank für deine Tipps und Geduld!
                          Mapio90
                          Hallo kann mir jemand bei der Fehlermeldung vom Log weiterhelfen? Wollte den Slave updaten auf die neuste Version...
                          host.Master 2019-11-19 17:27:41.076 error Objects 192.168.178.73:56888 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                          host.Master 2019-11-19 17:27:36.063 error Objects 192.168.178.73:56886 (Init=false) Redis error:Error: Invalid Chunk: parse failed
                          • M Mapio90
                            @Mapio90 ich muss jetzt zuerst diese Frage stellen: nen schlechter passenden thread für diese Frage hast du nicht gefunden?!
                            Ziemlich off topic?!
                            Schau mal in die faq zu Controller 2.0 thread (Post #2). Da wird genau diese Frage beantwortet.
                            M 2 Antworten Letzte Antwort
                              Mapio90
                              @apollon77 du hast recht, entschuldige. Ich hatte es gestern eillig und deswegen meine Fehler schnell zur frage stellen wollen.
                              Ich habe, wie du sagtest über die Suchfunktion den zweiten Beitrag gefunden und unter Nummer 9 alles ausgeführt. Habe leider trotzdem noch die Fehlermeldung wie im oberen zu sehen ist.
                                Mapio90
                                @apollon77 Hier meine Vorgehensweise
                                • M Mapio90
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @Mapio90
                                  FAQ
                                  • GlasfaserG Glasfaser
                                    @Mapio90
                                    FAQ
                                    Mapio90
                                    @Glasfaser vielen dank für deine Hilfe, der slave ist leider noch nicht wieder online und die Fehlermeldun besteht immer noch
                                    Ausgeführt:
                                    • apollon77A Offline
                                      Warum auch immer er bei ir die 1.5.14 installiert ... mach mal den install Befehl mit "@2.1.0" am Ende
                                        Mapio90
                                        Funktioniert leider auch nicht. Ich habe den Fehler gemacht, dass ich den Master zu erst upgedatet habe. Dann erst gelesen, dass der slave erst aktualisiert werden sollte.
                                        • M Mapio90
                                          @Mapio90 Hat doch geklappt ... Wo ist dein Problem? Die paar meldungen sind nur Warnungen
