  4. [Vorstellung] Meine zweite Visualisierung
    6.5k
vistemplate
1.3k Beiträge 148 Kommentatoren 671.6k Aufrufe 157 Beobachtet
  • sigi234S sigi234
    @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
    @Paan83 du weißt, dass es immer zwie Linien sind ?
    eine linke und eine rechte ?
    Der Verlauf wird unter CCS Hintergrund gesteuert!
    linear-gradient(to left, #282828 5px, white 200px )
    Kuddel
    #686
    @sigi234 ja stimmt
    linear-gradient(to right, #212121 20px, White 200px )
    • sigi234S Online
      sigi234S Online
      #687
      Hallo @Kuddel ,
      arbeite gerade an einer Echo Show5 Vis. Wie bekomme ich den Hintergrund Transparent beim jqi-input Widget?
      Beiße mir gerade die Zähne aus.😀
      [{"tpl":"tplJquiInput","data":{"oid":"alexa2.0.Echo-Devices.G0913L0592570PHD.Music-Provider.Amazon-Music-Playlist","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","label":"Playlist to play with AM","digits":"0","size":"81","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"asString":true},"style":{"left":"28px","top":"558px","z-index":"5","background-color":"transparent","color":"#d7cec1","font-family":"RobotoCondensed-Light","font-size":"large","background":"transparent","width":"766px","height":"33px"},"widgetSet":"jqui"}]
      • sigi234S sigi234
        Hallo @Kuddel ,
        Kuddel
        #688
        @sigi234 habs bei mir importiert. Leider wird bei mir der Hintergrund auch weiß dargestellt.
        Bei meinen anderen Input Widgets wurde der Hintergrund mit Verwendung des Material-Designs durchsichtig.
        Leider scheint das hier nicht zu funktionieren. Da bin ich gerade ein wenig überfragt.
        • K Kuddel
          sigi234S Online
          sigi234S Online
          #689
          Aha, hab es, es ändert sich mit dem Thema.Aber leider nicht Transparent.
          • NegaleinN Offline
            NegaleinN Offline
            Negalein
            #690
            @Kuddel
            Hi Kuddel!
            Du hast bei deinem Anwesenheitsblockly unteranderem auf den DP javascript.0.echo.sprachausgabe_wohnzimmer verwiesen.
            In deinen Scripts finde ich leider kein Script, dass in diesen erstellten DP schreibt.
            Könntest du es hier reinstellen?
            ° Fixer ---> iob fix
            • D David16
              @Kuddel
              Also meine Version ist 4.1.16.
              Ansonsten passen die Versionen soweit auch:
              Ich habe gestern Abend aber mal den iobroker komplett neu gestartet. Die Adapter leuchtet jetzt "grün". In den Logs sind auch keine Fehlermeldung mehr zu erkennen. - Keine Ahnung an was es gelegen haben soll.
              In der VIS ist die Rollo-Steuerung und Astro-Steuerung auch wieder da und die Rollos sind auch um 19:45 heruntergefahren:
              Ich beobachte das mal die nächsten Tage intensiv und berichte dann. - Dir vielen Dank für drüber schauen!👍
              David16
              #691
              @Kuddel Also es gab seit dem keine Probleme mehr. - Vielen Dank für deine Unterstützung!
              • D David16
                @Kuddel
                David16
                #692
                @David16 said in [Vorstellung] Meine zweite Visualisierung:
                @Kuddel
                  David16
                  #693
                  @Kuddel kannst du eine Flot-Einstellungen für das Temperatur auslesen hier nochmal hochladen? - Komme nicht ganz mit den Einstelllungen hin.
                  Ebenso wie du das Objekt in den History-Parametern eingestellt hast. 😊
                  • D David16
                    Kuddel
                    #694
                    @David16
                    • NegaleinN Negalein
                      @Kuddel
                      Hi Kuddel!
                      Kuddel
                      #695
                      @Negalein ich hatte mal rumgestestet, dass Alexa mich beim nach Hause kommen bergrüßt.
                      Das funktioniert aber nicht wirklich. Daher nutze ich das nicht mehr.
                      • K Kuddel
                        @David16
                        David16
                        #696
                        @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                        @David16
                        Besten Dank sollte jetzt gehen! 👍 👍
                        • P Offline
                          Puch
                          #697
                          Guten Morgen,
                          erstmal vielen Dank für die Bereitstellung! das ist wirklich Wahnsinn!
                          Ich hab es auch Installiert nur bekomme ich die Icons nicht dargestellt...
                          Grüß und vielen dank!
                          NegaleinN K 2 Antworten Letzte Antwort
                          • P Puch
                            Guten Morgen,
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #698
                            @Puch sagte in [Vorstellung] Meine zweite Visualisierung:
                            Liegen die Icons im richtigem Ordner?
                            Zeig mal den Screenshot vom Pfad des Icons.
                            • P Puch
                              Guten Morgen,
                              Kuddel
                              #699
                              @Puch dir fehlt noch ein Adapter.
                              installiere mal icons-mfd-png, dann wird alles richtig angezeigt
                              P Pat1968P 2 Antworten Letzte Antwort
                              • K Kuddel
                                Puch
                                #700
                                @Kuddel Danke!! das wars.... :-)
                                • K Kuddel
                                  Pat1968P Offline
                                  Pat1968P Offline
                                  Pat1968
                                  #701
                                  @Kuddel
                                  Hallo
                                  Wie hast du es hinbekommen mit den BVB Spiele?
                                  Ueber script oder iCal?
                                  Mfg
                                  • Pat1968P Pat1968
                                    @Kuddel
                                    Hallo
                                    Mfg
                                    Kuddel
                                    #702
                                    @Pat1968 ist ein ical Kalender in meinem Google Account
                                    Pat1968P 1 Antwort Letzte Antwort
                                    • K Kuddel
                                      Pat1968P Offline
                                      Pat1968P Offline
                                      Pat1968
                                      #703
                                      @Kuddel
                                      Ok das heisst du hast die alle manuel eingegeben?
                                      • Pat1968P Pat1968
                                        @Kuddel
                                        Kuddel
                                        #704
                                        @Pat1968 nein, die habe ich mir natürlich alle importiert
                                        https://www.fussball-spielplan.de/spielplan-borussia-dortmund-als-ical-abonnieren/
                                        • K Kuddel
                                          Pat1968P Offline
                                          Pat1968P Offline
                                          Pat1968
                                          #705
                                          @Kuddel
                                          Danke Dir 👍
