  4. [Vorstellung] Meine zweite Visualisierung
    6.5k
vistemplate
1.3k Beiträge 148 Kommentatoren 671.5k Aufrufe 157 Beobachtet
  • K Kuddel
    @Paan83 du weißt, dass es immer zwie Linien sind ?
    eine linke und eine rechte ?
    sigi234S Online
    sigi234S Online
    #685
    @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
    Der Verlauf wird unter CCS Hintergrund gesteuert!
    linear-gradient(to left, #282828 5px, white 200px )
    • sigi234S sigi234
      Kuddel
      #686
      @sigi234 ja stimmt
      linear-gradient(to right, #212121 20px, White 200px )
      • sigi234S Online
        sigi234S Online
        #687
        Hallo @Kuddel ,
        arbeite gerade an einer Echo Show5 Vis. Wie bekomme ich den Hintergrund Transparent beim jqi-input Widget?
        Beiße mir gerade die Zähne aus.😀
        [{"tpl":"tplJquiInput","data":{"oid":"alexa2.0.Echo-Devices.G0913L0592570PHD.Music-Provider.Amazon-Music-Playlist","g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","label":"Playlist to play with AM","digits":"0","size":"81","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"asString":true},"style":{"left":"28px","top":"558px","z-index":"5","background-color":"transparent","color":"#d7cec1","font-family":"RobotoCondensed-Light","font-size":"large","background":"transparent","width":"766px","height":"33px"},"widgetSet":"jqui"}]
        • sigi234S sigi234
          Hallo @Kuddel ,
          Kuddel
          #688
          @sigi234 habs bei mir importiert. Leider wird bei mir der Hintergrund auch weiß dargestellt.
          Bei meinen anderen Input Widgets wurde der Hintergrund mit Verwendung des Material-Designs durchsichtig.
          Leider scheint das hier nicht zu funktionieren. Da bin ich gerade ein wenig überfragt.
          • K Kuddel
            sigi234S Online
            sigi234S Online
            #689
            Aha, hab es, es ändert sich mit dem Thema.Aber leider nicht Transparent.
            • NegaleinN Offline
              NegaleinN Offline
              Negalein
              #690
              @Kuddel
              Hi Kuddel!
              Du hast bei deinem Anwesenheitsblockly unteranderem auf den DP javascript.0.echo.sprachausgabe_wohnzimmer verwiesen.
              In deinen Scripts finde ich leider kein Script, dass in diesen erstellten DP schreibt.
              Könntest du es hier reinstellen?
              ° Fixer ---> iob fix
              • D David16
                @Kuddel
                Also meine Version ist 4.1.16.
                Ansonsten passen die Versionen soweit auch:
                Ich habe gestern Abend aber mal den iobroker komplett neu gestartet. Die Adapter leuchtet jetzt "grün". In den Logs sind auch keine Fehlermeldung mehr zu erkennen. - Keine Ahnung an was es gelegen haben soll.
                In der VIS ist die Rollo-Steuerung und Astro-Steuerung auch wieder da und die Rollos sind auch um 19:45 heruntergefahren:
                Ich beobachte das mal die nächsten Tage intensiv und berichte dann. - Dir vielen Dank für drüber schauen!👍
                David16
                #691
                @Kuddel Also es gab seit dem keine Probleme mehr. - Vielen Dank für deine Unterstützung!
                • D David16
                  @Kuddel
                  David16
                  #692
                  @David16 said in [Vorstellung] Meine zweite Visualisierung:
                  @Kuddel
                    David16
                    #693
                    @Kuddel kannst du eine Flot-Einstellungen für das Temperatur auslesen hier nochmal hochladen? - Komme nicht ganz mit den Einstelllungen hin.
                    Ebenso wie du das Objekt in den History-Parametern eingestellt hast. 😊
                    • D David16
                      Kuddel
                      #694
                      @David16
                      • NegaleinN Negalein
                        @Kuddel
                        Hi Kuddel!
                        Kuddel
                        #695
                        @Negalein ich hatte mal rumgestestet, dass Alexa mich beim nach Hause kommen bergrüßt.
                        Das funktioniert aber nicht wirklich. Daher nutze ich das nicht mehr.
                        • K Kuddel
                          @David16
                          David16
                          #696
                          @Kuddel said in [Vorstellung] Meine zweite Visualisierung:
                          @David16
                          Besten Dank sollte jetzt gehen! 👍 👍
                          • P Offline
                            Puch
                            #697
                            Guten Morgen,
                            erstmal vielen Dank für die Bereitstellung! das ist wirklich Wahnsinn!
                            Ich hab es auch Installiert nur bekomme ich die Icons nicht dargestellt...
                            Grüß und vielen dank!
                            NegaleinN K 2 Antworten Letzte Antwort
                            • P Puch
                              Guten Morgen,
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #698
                              @Puch sagte in [Vorstellung] Meine zweite Visualisierung:
                              Liegen die Icons im richtigem Ordner?
                              Zeig mal den Screenshot vom Pfad des Icons.
                              • P Puch
                                Guten Morgen,
                                Kuddel
                                #699
                                @Puch dir fehlt noch ein Adapter.
                                installiere mal icons-mfd-png, dann wird alles richtig angezeigt
                                P Pat1968P 2 Antworten Letzte Antwort
                                • K Kuddel
                                  Puch
                                  #700
                                  @Kuddel Danke!! das wars.... :-)
                                  • K Kuddel
                                    Pat1968P Offline
                                    Pat1968P Offline
                                    Pat1968
                                    #701
                                    @Kuddel
                                    Hallo
                                    Wie hast du es hinbekommen mit den BVB Spiele?
                                    Ueber script oder iCal?
                                    Mfg
                                    • Pat1968P Pat1968
                                      @Kuddel
                                      Hallo
                                      Mfg
                                      Kuddel
                                      #702
                                      @Pat1968 ist ein ical Kalender in meinem Google Account
                                      Pat1968P 1 Antwort Letzte Antwort
                                      • K Kuddel
                                        Pat1968P Offline
                                        Pat1968P Offline
                                        Pat1968
                                        #703
                                        @Kuddel
                                        Ok das heisst du hast die alle manuel eingegeben?
                                        • Pat1968P Pat1968
                                          @Kuddel
                                          Kuddel
                                          #704
                                          @Pat1968 nein, die habe ich mir natürlich alle importiert
                                          https://www.fussball-spielplan.de/spielplan-borussia-dortmund-als-ical-abonnieren/
