  4. Tado und HAM Adapter
91 Beiträge 17 Kommentatoren 21.1k Aufrufe 7 Beobachtet
    senger1985
    So sieht es aus.
    • S senger1985
      So sieht es aus.
      denjo
      @senger1985 die " aber stehen lassen oder?
        senger1985
        Auch diese Aussage ist korrekt
        • S senger1985
          denjo
          @senger1985 ja bekomme es einfach nicht zum laufen
          host.raspberrypi	2019-09-15 16:12:14.138	info	Restart adapter system.adapter.ham.0 because enabled
          host.raspberrypi	2019-09-15 16:12:14.138	error	instance system.adapter.ham.0 terminated with code 0 (OK)
          host.raspberrypi	2019-09-15 16:12:14.138	error	Caught by controller[2]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2694:25)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:111:23)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:223:17)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:90:36)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at Server._loadPlatforms (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:327:45)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: at API.platform (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/api.js:134:13)
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[2]: Error: The requested platform 'Tado' was not registered by any plugin.
          host.raspberrypi	2019-09-15 16:12:14.137	error	Caught by controller[1]: [2019-9-15 4:12:13 PM] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          host.raspberrypi	2019-09-15 16:12:14.136	error	Caught by controller[0]: [2019-9-15 4:12:13 PM] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
          host.raspberrypi	2019-09-15 16:12:11.745	info	instance system.adapter.ham.0 started with pid 18073
            senger1985
            Nimm mal bitte dieses Plugin:
            homebridge-tado-thermostat-plugin
            • S senger1985
              denjo
              @senger1985 wie wird das denn installiert über GitHub?
                senger1985
                schrieb am zuletzt editiert von senger1985
                Wie hast du denn das andere Plugin installiert?
                Bei den Haupteinstellungen unter "zusätzliche npm-Module" einfach "homebridge-tado-thermostat-plugin" eintragen.(Ohne die ")
                • S senger1985
                  denjo
                  schrieb am zuletzt editiert von denjo
                  #66
                  @senger1985 dort meinst du, sorry bin neu mit Ham unterwegs.15-09-_2019_16-21-47.png
                  wenn ja läuft trotzdem nicht
                    senger1985
                    #67
                    Kein Ding.
                    Ja, genau dort.
                    Bin jetzt aber auch erstmal AFK, Real life ruft.
                    Evtl. später wieder online.
                    Viel Erfolg und wenn was ist, ich antworte später, oder vielleicht kann auch jemand anderes unterstützen, während ich nicht da bin.
                    • S senger1985
                      Kein Ding.
                      Ja, genau dort.
                      denjo
                      #68
                      @senger1985 okay danke erst mal.
                      hier noch die neuen fehler Meldungen
                      host.raspberrypi	2019-09-15 16:24:31.712	info	Restart adapter system.adapter.ham.0 because enabled
                      host.raspberrypi	2019-09-15 16:24:31.712	error	instance system.adapter.ham.0 terminated with code 0 (OK)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2694:25)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/wrapper-handler.js:111:23)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at HomebridgeWrapper.init (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/index.js:223:17)
                      Caught	2019-09-15 16:24:31.712	error	by controller[3]: at Server.run (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:93:8)
                      Caught	2019-09-15 16:24:31.711	error	by controller[3]: at Server._configCachedPlatformAccessories (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper/homebridge/server.js:386:24)
                      Caught	2019-09-15 16:24:31.711	error	by controller[3]: at TadoPlatform.configureAccessory (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tado-platform/src/platform.js:624:23)
                      Caught	2019-09-15 16:24:31.711	error	by controller[3]: TypeError: Cannot read property 'set' of undefined
                      Caught	2019-09-15 16:24:31.711	error	by controller[2]: [2019-9-15 4:24:31 PM] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-tado-thermostat-plugin requires Node version of ^8.9.4 which does not satisfy the curre
                      Caught	2019-09-15 16:24:31.711	error	by controller[1]: [2019-9-15 4:24:30 PM] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                      Caught	2019-09-15 16:24:31.711	error	by controller[0]: [2019-9-15 4:24:30 PM] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                      • D denjo
                        K_o_bold
                        #69
                        @denjo ,
                        konntest du in der Zwischenzeit dein Problem lösen?
                        Ich werde auch demnächst das Tado System einsetzen und stehe dann auch vor der Inbetriebnahme im Iobroker..
                          denjo
                          #70
                          Nee leider nicht
                          • D denjo
                            Nee leider nicht
                            Stormbringer
                            #71
                            @denjo
                            Mit meinem Plug in funktioniert es auch nicht? Wobei das jetzt auch voll spinnt. Der Adapter setzt ständig unregelmäßig irgendwelche Zieltemperaturen.... Bin da auch grad am basteln ob ich das mit einem Skript in Griff bekomme. Momentan ist es leider definitiv so, dass tado ohne ioBroker viel besser läuft 🤦
                            Angaben zur Installation: JS Controller 5.0.12, npm 9.6.7, node 18.17.1, auf einem Intel NUC mit Ubuntu 22.04
                              Skymaster123
                              #72
                              Hallo liebe Forums Gemeinde,
                              Ich bin neu auf dem Gebiet und brauche bitte eure Hilfe.
                              5 Tado Thermostate, eine zentrale Steuerung und die Tado Bridge.
                              Leider ist es so das ich, nach dem ich hier alles durgelesen habe und so manche Anleitung angewandt habe ich es leider nicht geschafft die Tado´s Richtig in Iobroker einbinden zu können, so das ich auch die Werte sehe.
                              Geschafft habe ich es zu mindestens das die Thermostate in Iobroker zu sehen sind das ist aber auch alles.
                              Habe versucht die Home ID laut Anleitung hier raus zu bekommen, was leider nicht funktioniert hat bekomme immer die Fehlermeldung von der Website :
                              {"errors":[{"code":"unauthorized","title":"Bad credentials"}]}
                              Hat Jemand eine detaillierte Anleitung wie ich an mein Ziel kommen, die Tado Geräte in Iobroker eizubinden bzw. die Home ID zu bekommen.
                              Vielen Dank im Voraus
                              Gruß Mark
                              • S Skymaster123
                                Gruß Mark
                                Stormbringer
                                #73
                                @Skymaster123 Steht eigentlich oben schon 😉aber gern nochmal. schreib tado, dass du deine home id brauchst. die antworten im normalfall sehr schnell.
                                • S Stormbringer
                                  Skymaster123
                                  #74
                                  @Stormbringer Danke für deine Antwort , das habe ich auch schon versucht ich wurde darauf hin ins Forum von Tado verwiesen um für mein anliegen eine Lösung zu bekommen. Leider warte ich immer noch auf eine Lösung.
                                  Ich werde aber Tado nochmal kontaktieren.
                                    Skymaster123
                                    #75
                                    So ich habe jetzt endlich meine Home ID von Tado bekommen welchen von den oben genannten Config Dateien ist denn jetzt die auch funktioniert ? Ich habe 5 smarte Heizkörper Thermostate und 1 smartes Central Thermostat.
                                    Ich habe alle Config Dateien die hier beschrieben werden versucht, leider funktionieren die alle nicht, bekomme keine Daten angezeigt, selbst wenn ich die Originale Config von homebridge-tado-platform nehme.
                                      "bridge": {},
                                      "accessories": [],
                                      "platforms": [
                                          "platform": "TadoPlatform",
                                          "username": "****@****.de",
                                          "password": "******",
                                          "homeID": meine Home ID,
                                          "unit": "celsius",
                                          "polling": 10,
                                          "exclude": [],
                                          "reConfig": false,
                                          "occupancy": false,
                                          "anyone": false,
                                          "weather": true,
                                          "openWindow": true,
                                          "solarIntensity": true,
                                          "centralSwitch": true,
                                          "externalSensor": false,
                                          "deviceOptions": {
                                            "RU****": {
                                              "active": true,
                                              "heatValue": 5,
                                              "coolValue": 5,
                                              "maxDelay": 10,
                                              "overrideMode": "manual",
                                              "ID": 48,
                                              "zoneName": "Heizung",
                                              "zoneType": "HEATING",
                                              "deviceType": "RU",
                                              "serial": "RU****"
                                            "VA****": {
                                              "active": true,
                                              "heatValue": 5,
                                              "coolValue": 5,
                                              "maxDelay": 10,
                                              "ID": 26,
                                              "zoneName": "Büro",
                                              "deviceType": "VA",
                                              "serial": "VA****"
                                            "VA****": {
                                              "active": true,
                                              "heatValue": 5,
                                              "coolValue": 5,
                                              "maxDelay": 10,
                                              "ID": 31,
                                              "zoneName": "Küche",
                                              "deviceType": "VA",
                                              "serial": "VA****"
                                            "VA****": {
                                              "active": true,
                                              "heatValue": 5,
                                              "coolValue": 5,
                                              "maxDelay": 10,
                                              "ID": 32,
                                              "zoneName": "Schlafzimmer",
                                              "deviceType": "VA",
                                              "serial": "VA****"
                                            "VA****": {
                                              "active": true,
                                              "heatValue": 5,
                                              "coolValue": 5,
                                              "maxDelay": 10,
                                              "ID": 48,
                                              "zoneName": "Bad",
                                              "deviceType": "VA",
                                              "serial": "VA****"
                                    N 1 Antwort Letzte Antwort
                                    • S Skymaster123
                                        "bridge": {},
                                        "accessories": [],
                                        "platforms": [
                                            "unit": "celsius",
                                            "polling": 10,
                                            "exclude": [],
                                            "reConfig": false,
                                            "occupancy": false,
                                            "anyone": false,
                                            "weather": true,
                                            "openWindow": true,
                                            "deviceOptions": {
                                              "RU****": {
                                                "active": true,
                                                "heatValue": 5,
                                                "coolValue": 5,
                                                "maxDelay": 10,
                                                "ID": 48,
                                                "deviceType": "RU",
                                                "serial": "RU****"
                                              "VA****": {
                                                "active": true,
                                                "heatValue": 5,
                                                "coolValue": 5,
                                                "maxDelay": 10,
                                                "ID": 26,
                                                "zoneName": "Büro",
                                                "deviceType": "VA",
                                                "serial": "VA****"
                                              "VA****": {
                                                "active": true,
                                                "heatValue": 5,
                                                "coolValue": 5,
                                                "maxDelay": 10,
                                                "ID": 31,
                                                "deviceType": "VA",
                                                "serial": "VA****"
                                              "VA****": {
                                                "active": true,
                                                "heatValue": 5,
                                                "coolValue": 5,
                                                "maxDelay": 10,
                                                "ID": 32,
                                                "deviceType": "VA",
                                                "serial": "VA****"
                                              "VA****": {
                                                "active": true,
                                                "heatValue": 5,
                                                "coolValue": 5,
                                                "maxDelay": 10,
                                                "ID": 48,
                                                "zoneName": "Bad",
                                                "deviceType": "VA",
                                                "serial": "VA****"
                                      N Offline
                                      N Offline
                                      Nicolettasiobroker
                                      #76
                                      @Skymaster123
                                      Hallo Skymaster, hast du Sonderzeichen in deinem Passwort? Versuche mal bei Tado ein einfaches Passwort zum Testen zu hinterlegen und verwende dieses in dem Configfile. Solltest du weiter Sonderzeichen verwenden, müssen diese womöglich encodiert dargestellt werden. Viele Grüße Nicole
                                      • S Stormbringer
                                        @K_o_bold
                                        Ja mit tado ist das leider so eine Sache. Die meisten nehmen hier wohl Homematic oder Max her.
                                        DutchmanNL habe ich nur einpaar mal gehört, dass er es in Erwägung zieht einen Adapter zu schreiben, dass er dabei ist habe ich nichts mitbekommen. Würde da eher meine Hoffnung auf Apollon richten. Der hat ja den HAM Adapter programmiert. Nachdem er rausgekommen ist hat er gemeint er ist ioBroker untypisch schwer zu händeln (wo er ned unrecht hat ;D) und es kommen irgendwann vielleicht einzelnen HAM Adapter die die Module und Config schon drinnen haben. Und im Homebridge Sektor wird tado dann wiederrum eher zu den gefragteren gehören, hoffe ich zumindest mal :-)
                                        Habs im übrigen jetzt wieder zum Laufen gebracht. Liegen zwar noch keine Langtests vor aber bisher schauts gut aus.
                                        Nach Update auf das neue NPM Hombridge Modul und Anpassung der Config läufts.
                                        Modulname bleibt gleich mit : homebridge-tado-platform
                                        In den Adapter Einstellungen haken setzen für "Aktualisieren Sie die Homebridge Plugins von npm"
                                        danach sieht man im LOG, dass das Modul geupdated wird
                                        und anschließend Configfile wie folgt ändern:
                                         "platforms": [
                                             "username": "USERNAME",
                                             "password": "PASSWORT",
                                             "homeID": 123456,
                                             "unit": "celsius",
                                             "polling": 10,
                                             "exclude": [],
                                             "reConfig": false,
                                             "occupancy": false,
                                             "anyone": false,
                                             "weather": true,
                                             "openWindow": true,
                                             "deviceOptions": {
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "zoneName": "Arbeitszimmer",
                                                 "deviceType": "VA",
                                                 "serial": "VA1234567890"
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "zoneName": "Bad",
                                                 "deviceType": "VA",
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "deviceType": "VA",
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "zoneName": "Wohnzimmer",
                                                 "deviceType": "VA",
                                        Im unteren Bereich den Abschnitt z. B. "VA1234567890-9" ändern in die Seriennummer von euch und nach dem Bindestrich kommt die Zone.
                                        Das dann natürlich auch bei dem Unterpunkt ID und Serial mit ändern.
                                        Aber lange Rede kurzer Sinn. Es ist ein Kampf.... Aber wenn es dann mal läuft ist tado zuverlässig. Zwar nicht perfekt aber finde nach wie vor das Beste am Markt. Also grünes Licht zum Shoppen.
                                        Stormbringer
                                        #77
                                        @Stormbringer sagte in Tado und HAM Adapter:
                                        @K_o_bold
                                         "platforms": [
                                             "homeID": 123456,
                                             "unit": "celsius",
                                             "polling": 10,
                                             "exclude": [],
                                             "reConfig": false,
                                             "occupancy": false,
                                             "anyone": false,
                                             "weather": true,
                                             "openWindow": true,
                                             "deviceOptions": {
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "deviceType": "VA",
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "zoneName": "Bad",
                                                 "deviceType": "VA",
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "deviceType": "VA",
                                               "VA1234567890-9": {
                                                 "active": true,
                                                 "heatValue": 5,
                                                 "coolValue": 5,
                                                 "maxDelay": 10,
                                                 "ID": 9,
                                                 "deviceType": "VA",
                                        Mit der Config müsste es eigentlich klappen
                                        • N Nicolettasiobroker
                                          @Skymaster123
                                          Skymaster123
                                          #78
                                          @Nicolettasiobroker Ok... das mit den Sonderzeichen wusste ich nicht, habe auch welche drin, habe promt mal geändert aber es ist keine sichtbares Ergebnis zu sehn. Schade Aber danke für den Tipp 👍
