  4. Iot error read ECONNRESET !!!
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
iotiot adaptererroreconnresetverbindungsprobleme
58 Beiträge 8 Kommentatoren 11.3k Aufrufe 5 Beobachtet
  • marcusklM Offline
    marcusklM Offline
    marcuskl
    2019-09-10 17:51:07.137  - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.iot/main.js:777
    2019-09-10 17:51:07.138  - error: Caught by controller[0]: 		keepalive: 60,
    2019-09-10 17:51:07.138  - error: Caught by controller[0]: 		^^^^^^^^^
    2019-09-10 17:51:07.138  - error: Caught by controller[0]: SyntaxError: Unexpected identifier
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:723:23)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    2019-09-10 17:51:07.138  - error: Caught by controller[0]:     at startup (internal/bootstrap/node.js:283:19)
    2019-09-10 17:51:07.139  - error: Caught by controller[0]:     at bootstrapNodeJSCore (internal/bootstrap/node.js:622:3)
    2019-09-10 17:51:07.139  - error: host.iobroker instance system.adapter.iot.0 terminated with code 1 ()
    2019-09-10 17:51:07.139  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
    2019-09-10 17:51:37.153  - info: host.iobroker instance system.adapter.iot.0 started with pid 18328
    Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
    Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
    M apollon77A 2 Antworten Letzte Antwort
    • marcusklM marcuskl
      Megawaldi
      @marcuskl
      Da fehlt ein Komma nach den 5000
        @marcuskl exakt ... zeile davor ein komma ans ende
        • marcusklM Offline
          marcusklM Offline
          marcuskl
          Anscheinend hat "Keepalive", das Problem behoben.
          Bis jetzt gab es kein Verbindungsabbruch mehr, nur heute morgen hat der Iot Adapter sich neu gestartet und hat ein Error ausgespuckt:
          2019-09-11 03:12:35.240  - error: iot.0 uncaught exception: Cannot read property 'message' of undefined
          2019-09-11 03:12:35.241  - error: iot.0 TypeError: Cannot read property 'message' of undefined
          2019-09-11 03:12:35.279  - error: Caught by controller[0]: TypeError: Cannot read property 'message' of undefined
          2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1713:102)
          2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.emit (events.js:198:13)
          2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
          2019-09-11 03:12:35.280  - error: Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
          2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at Object.onceWrapper (events.js:286:20)
          2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at IncomingMessage.emit (events.js:203:15)
          2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at endReadableNT (_stream_readable.js:1145:12)
          2019-09-11 03:12:35.281  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
          2019-09-11 03:12:35.281  - error: host.iobroker instance system.adapter.iot.0 terminated with code 0 (OK)
          2019-09-11 03:12:35.281  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
          2019-09-11 03:13:05.297  - info: host.iobroker instance system.adapter.iot.0 started with pid 28192
          2019-09-11 03:13:06.646  - info: iot.0 starting. Version 1.0.8 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
          2019-09-11 03:13:06.681  - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2019-09-11 03:13:07.229  - info: iot.0 shelly.0.SHSW-1#12C27E#1.Relay0.Switch is auto added with type  light.
          2019-09-11 03:13:07.236  - info: iot.0 shelly.0.SHSW-1#94147C#1.Relay0.Switch is auto added with type  light.
          2019-09-11 03:13:07.241  - info: iot.0 sonoff.0.Nachtlicht Benchy.POWER is auto added with type  light.
          2019-09-11 03:13:07.246  - info: iot.0 sonoff.0.Nachtlicht Liah.POWER is auto added with type  light.
          2019-09-11 03:13:07.250  - info: iot.0 sonoff.0.Nachtlicht Marcus.POWER is auto added with type  light.
          2019-09-11 03:13:07.255  - info: iot.0 sonoff.0.Stehlampe.POWER is auto added with type  light.
          2019-09-11 03:13:07.259  - info: iot.0 shelly.0.SHSW-1#943F39#1.Relay0.Switch is auto added with type  light.
          2019-09-11 03:13:07.288  - info: iot.0 shelly.0.SHRGBW2#5A38A7#1.color is auto added with type  rgb.
          2019-09-11 03:13:07.294  - info: iot.0 sonoff.0.Schreibtischlampe.POWER is auto added with type  light.
          2019-09-11 03:13:07.298  - info: iot.0 sonoff.0.Küchenlicht.POWER is auto added with type  light.
          2019-09-11 03:13:07.303  - info: iot.0 sonoff.0.TV Steckdose.POWER is auto added with type  socket.
          2019-09-11 03:13:07.310  - info: iot.0 tuya.0.17014830b4e62d5a02cc.1 is auto added with type  socket.
          2019-09-11 03:13:07.313  - info: iot.0 javascript.0.scriptEnabled.Steckdosen.Schreibtischsteckdosen_Automatik is auto added with type  socket.
          2019-09-11 03:13:07.322  - info: iot.0 Cannot auto convert chromecast.0.Küche.status.volume. Type volume is not available, yet. If you need the state please add him manually
          2019-09-11 03:13:07.326  - info: iot.0 Cannot auto convert chromecast.0.Schlafzimmer.status.volume. Type volume is not available, yet. If you need the state please add him manually
          2019-09-11 03:13:07.330  - info: iot.0 Cannot auto convert chromecast.0.WohnzimmerJBL.status.volume. Type volume is not available, yet. If you need the state please add him manually
          2019-09-11 03:13:07.715  - info: iot.0 Connection changed: connect
          Ich glaube das hat aber nichts damit zu tun oder ?
          • apollon77A Offline
            An alle weiteren betroffenen bitte auch mal die Änderung aus https://github.com/aws/aws-iot-device-sdk-js/issues/280#issuecomment-529990098 versuchen und zurückmelden!!
            Der Fehler kommt eher aus der 1.0.8 ... am besten nimm mal die 1.0.7 vom npm als basis oder versuchen die 1.1.0 vom Github
            marcusklM 1 Antwort Letzte Antwort
            • apollon77A apollon77
              marcusklM Offline
              marcusklM Offline
              marcuskl
              @apollon77 sagte in Iot error read ECONNRESET !!!:
              Ich habe gesehen Bluefox hat in der Version 1.1.4 den keepalive Value hinzugefügt, man kann ja dann einfach die neuste Version von Github laden oder ?
                @marcuskl Ja, das ist noch viel einfacher! :-) Und die Version sollte auch schon im Latest Repo sein
                • marcusklM Offline
                  marcusklM Offline
                  marcuskl
                  schrieb am zuletzt editiert von marcuskl
                  Endlich ist das Problem gelöst 👏
                  Großes danke an alle :)
                  • marcusklM Offline
                    marcusklM Offline
                    marcuskl
                    @apollon77 Eine frage, zum Verständnis: Was hat das keepalive jetzt eigentlich geändert zu vorher ?
                      @marcuskl Ich denke es werden öfter "ping-pong" nachrichten ausgetauscht um die Verbindung am leben zu halten. Scheinbar hat der "Standard" 5 Minuten nicht gereicht und deswegen ist es immer wieder gekillt worden.
                      • marcusklM Offline
                        marcusklM Offline
                        marcuskl
                        Seit neusten bekomme ich diese Fehlermeldung im Log:
                        2019-09-11 11:53:18.343  - error: iot.0 uncaught exception: Cannot read property 'message' of undefined
                        2019-09-11 11:53:18.377  - error: Caught by controller[0]: TypeError: Cannot read property 'message' of undefined
                        2019-09-11 11:53:18.377  - error: Caught by controller[0]:     at Request.request.post [as _callback] (/opt/iobroker/node_modules/iobroker.iot/lib/GoogleHome.js:1713:102)
                        2019-09-11 11:53:18.377  - error: Caught by controller[0]:     at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Request.emit (events.js:198:13)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at Object.onceWrapper (events.js:286:20)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at IncomingMessage.emit (events.js:203:15)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at endReadableNT (_stream_readable.js:1145:12)
                        2019-09-11 11:53:18.378  - error: Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
                        2019-09-11 11:53:18.378  - error: host.iobroker instance system.adapter.iot.0 terminated with code 0 (OK)
                        2019-09-11 11:53:18.378  - info: host.iobroker Restart adapter system.adapter.iot.0 because enabled
                        2019-09-11 11:53:48.396  - info: host.iobroker instance system.adapter.iot.0 started with pid 7265
                        2019-09-11 11:53:49.834  - info: iot.0 starting. Version 1.1.4 in /opt/iobroker/node_modules/iobroker.iot, node: v10.16.3
                        2019-09-11 11:53:49.873  - info: iot.0 Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                        Was hat das zu bedeuten ?
                          Das da leider ein Bug ist. Bitte GitHub Version versuchen
                            marcusklM Offline
                            marcusklM Offline
                            marcuskl
                            Ich habe die Github Version geladen.
                            Oder muss ich das was ich Manuell in die js reingeschrieben (keepalive: 60) habe wieder rückgängig machen ?
                            apollon77A BluefoxB 2 Antworten Letzte Antwort
                              @marcuskl ne das sollte eh überschrieben wordenr sein., iot einmal neu starten nach GitHub Update
                                BluefoxB Offline
                                BluefoxB Offline
                                @marcuskl Kannst du dein iobroker.pro login an info@iobroker.net mailen?
                                Ich will was testen
                                • BluefoxB Bluefox
                                  Ich will was testen
                                  marcusklM Offline
                                  marcusklM Offline
                                  marcuskl
                                  @Bluefox sagte in Iot error read ECONNRESET !!!:
                                  Ich will was testen
                                  Was heißt Login ? Passwort und Email, Freischaltcode?
                                  BluefoxB 1 Antwort Letzte Antwort
                                    Ich will was testen
                                    BluefoxB Offline
                                    BluefoxB Offline
                                    @marcuskl
                                    Nur email in iobroker.pro.
                                    Bitte kein Passwort
                                    • BluefoxB Bluefox
                                      @marcuskl
                                      Bitte kein Passwort
                                      marcusklM Offline
                                      marcusklM Offline
                                      marcuskl
                                      @marcuskl
                                      Bitte kein Passwort
                                      Habe ich getan. :)
                                        @marcuskl
                                        Bitte kein Passwort
                                        Habe ich getan. :)
                                        BluefoxB Offline
                                        BluefoxB Offline
                                        schrieb am zuletzt editiert von Bluefox
                                        @marcuskl Man muss die Version von iot updaten. 1.1.7
                                        • BluefoxB Bluefox
                                          marcusklM Offline
                                          marcusklM Offline
                                          marcuskl
                                          @marcuskl Man muss die Version von iot updaten. 1.1.6
                                          In Ordnung hab ich jetzt.
                                          Hast du meine Email bekommen ?
