  4. [Projekt] ioGo # Smarthome to go
    1.0k
    6.1k
iogoappandroid
1.1k Beiträge 61 Kommentatoren 472.8k Aufrufe 20 Beobachtet
    @crunchip bitte erneut die aktuelle Version von GitHub installieren und nochmal Restart des Adapters
    crunchipC Offline
    crunchipC Offline
    #878
    @nis adapter gestartet, noch nicht beendet
    iogo.0	2019-09-02 22:05:18.796	info	database initialized with 23 enums
    iogo.0	2019-09-02 22:05:18.655	info	database initialized with 106 instances
    iogo.0	2019-09-02 22:05:18.311	info	database initialized with 1 hosts
    iogo.0	2019-09-02 22:05:17.985	info	database initialized with 822 states
    iogo.0	2019-09-02 22:05:12.783	info	initialize app devices
    iogo.0	2019-09-02 22:05:12.765	info	states from remote database removed
    iogo.0	2019-09-02 22:05:12.755	info	logged in as: qwertz <= please keep this uid as your secret
    iogo.0	2019-09-02 22:05:12.754	info	licence key found. licence valid until 2020-08-27 20:38:10
    iogo.0	2019-09-02 22:05:11.948	info	triggered listener removed
    iogo.0	2019-09-02 22:05:11.824	info	starting. Version 0.4.3 in /opt/iobroker/node_modules/iobroker.iogo, node: v10.16.0
    host.IoBroker	2019-09-02 22:05:10.322	info	instance system.adapter.iogo.0 started with pid 13700
    host.IoBroker	2019-09-02 22:05:10.303	info	object change system.adapter.iogo.0
    zwischen drin alle state.system.adapter...has wrong type
    iogo.0	2019-09-02 22:05:22.623	info	database initialized with 805 state values
    iogo.0	2019-09-02 22:07:20.826	info	database initialized with 102 adapters
    adapter gestoppt
    host.IoBroker	2019-09-02 22:10:29.063	info	instance system.adapter.iogo.0 terminated with code 156 ()
    iogo.0	2019-09-02 22:10:29.018	info	listener removed
    iogo.0	2019-09-02 22:10:29.017	info	triggered listener removed
    iogo.0	2019-09-02 22:10:29.015	info	signed out
    iogo.0	2019-09-02 22:10:29.009	info	listener removed
    iogo.0	2019-09-02 22:10:29.001	info	triggered listener removed
    iogo.0	2019-09-02 22:10:29.000	info	cleaned everything up...
    host.IoBroker	2019-09-02 22:10:28.999	info	stopInstance system.adapter.iogo.0 killing pid 13700
    host.IoBroker	2019-09-02 22:10:28.999	info	object change system.adapter.iogo.0
      adapter gestoppt
      #879
      @crunchip sieht recht gut aus, ist auch alles in der App sichtbar?
        @nis das hab ich auch gelesen, is eher die frage, warum so viele.
        1. hab ich nichts geändert
        2. sind das nur ein paar Lichtschalter, Steckdosen, Xiaomi Sensoren, Strom/Gas Werte und Spritkosten
          sind da die state´s von der gesamten Iobroker Installation gemeint?
        #880
        @crunchip sagte in [Projekt] ioGo # Native Android App:
        Die vielen zusätzlichen States kommen durch die Synchronisation der Instanzen. In der App soll demnächst auch Speicher und CPU Verbrauch angezeigt werden jeder einzelnen Instanz
          crunchipC Offline
          crunchipC Offline
          #881
          @nis soweit ich sehen konnte ja, werd ich mir heute nachmittag nochmal genauer anschauen
            @mpenno du hast einen state vom type=number den wert "true" zugewiesen. Bei Verwendung des web Adapter musst du bei nach der Ursache suchen.
            Ich versuche zudem das logging für diesen Fall in Zukunft zu verbessern
            mpenno
            #882
            @nis Danke. Ich habe den Übeltäter gefunden. :-)
            Bzgl. den Einheiten: In der aktuellen Beta werden mir auch keine Einheiten mehr angezeigt. Egal, ob "°C", "kWh" oder "%".
            PS: Ich nutze ausschließlich den Web-Adapter.
              @NightWatcher da ist ein Leerzeichen in der ID des States, das würde ich mal entfernen und sehen ob es dann klappt
              N Offline
              N Offline
              NightWatcher
              #883
              @nis Daran liegt es nicht. Dieses Objekt ist nur beispielhaft für ungefähr 20 ähnlicher Objekte, wo es nicht geht. Manche mit, manche ohne Leerzeichen. Ich denke das ist eher ein grundsätzliches Problem mit unit?
              Wago 750-881 - mit über 200 Ein- und Ausgängen, DMX512 Art-Net für Beleuchtung, 1-Wire für Umweltsensoren Aussen und Innen, ioBroker als Visualisierung
              • ? Offline
                #884
                @NightWatcher @mpenno stehen irgendwelche Fehler im Log der App in Bezug auf die Probleme bei der Anzeige von "unit"?
                  mpenno
                  #885
                  @nis Nein, im Log (verbose) steht gar nichts auffälliges.
                  190903-verbose.log
                  Hast Du übrigens noch Lust einen besseren Status als "true" für das Schloss zu hinterlegen?
                  Als Rolle habe ich "sensor.lock" angegeben.
                  Danke fürs debuggen!
                  • crunchipC Offline
                    crunchipC Offline
                    #886
                    @nis soweit so gut, hab mal ein bisschen rumgespielt, funktioniert soweit.
                    was mir noch fehlt sind die units, hatte ich aber ein paar zeilen weiter oben schon gefragt, mit raw beispiel.
                    Was nicht mehr funktioniert, ist die Admin-Seite, beim öffnen des Host, Adapter oder Instanzen, bleibt die liste leer.
                    Was auch noch nicht funktioniert
                    Nach einer Synchronisation, ist die zuvor eingerichtete Homeseite wieder leer.
                      MGK
                      #887
                      @nis Gelöschte Funktionen werden in der App leider nicht gelöscht und demzufolge weiter angezeigt, siehe Bild.
                      • M mpenno
                        190903-verbose.log
                        #888
                        @mpenno sagte in [Projekt] ioGo # Native Android App:
                        Klar gerne. Wie soll sensor.lock denn angezeigt werden in deutsch und englisch? Vorschläge?
                        Gerne kann ich auch noch mehr Rollen aus der Gruppe sensor.* übersetzen.
                          @e-s Einzelne Issues auf Github wäre schön, Danke
                          e-s
                          #889
                          @nis sagte in [Projekt] ioGo # Native Android App:
                          habe gerade mal in github geschaut, da finde ich nur die alte App und dern iobroker Adapter, da wären die meisten issues aber falsch.
                          • E e-s
                            #890
                            @e-s hier bitte Issues zur App erfassen: GitHub
                            • ? Offline
                              #891
                              Es sind wieder ein paar Fehler behoben und Verbesserungen eingebaut.
                              Damit ist nun eine weitere Version unterwegs: 2.0.0-beta5
                              Diese benötigt den Adapter in der neuesten Version: 0.4.4
                              Anpassungen:
                              • Passwörter nicht im Klartext anzeigen
                              • Objekte beim Sync nicht mehr löschen, damit bleiben Sortierung und "starred" Einstellungen erhalten
                              • Automatisches Löschen von Objekten in der App sobald diese in ioBroker entfernt wurden (Instanzen, Adapter, Enums, States)
                              • Anzeige der aktuellen Anzahl von Adapter, Instanz, Host im Info View ergänzt
                              • Anzeige der Instanz ergänzt um aktuellen Speicherverbrauch: MemRSS, MemHeapTotal, MemHeapUsed
                              crunchipC E 2 Antworten Letzte Antwort
                                Anpassungen:
                                crunchipC Offline
                                crunchipC Offline
                                #892
                                @nis 👍 dann sind wir mal gespannt
                                  Anpassungen:
                                  e-s
                                  #893
                                  @nis
                                  Hallo, kurzer schnelltest. Adapter und app aktualisiert. Synchronisiert, Funktionen sortiert und ein paar starred. Erneut in der app gesynct, alles wieder unsortiert und Startseite leer. Leider.
                                  In der app ist das Passwort verschleiert, Also Top.
                                  Im raw vom Adapter leider immer noch als Klartext.
                                    MGK
                                    #894
                                    @nis Ich habe beides aktualisiert, leider sind auch bei mir die gespeicherten States nach dem Sync auf der Home Seite wieder verschwunden. Auch die gelöschten Funktionen im ioBroker werden in der App immer noch angezeigt.
                                    • ? Offline
                                      #895
                                      @crunchip @MGK ich habe es selber auch schon bemerkt (leider). Bin schon an der Lösung dran...
                                      • ? Offline
                                        #896
                                        Eine weitere Version ist deployed: 2.0.0-beta6
                                        Hoffe darin klappt es nun mit den ober erwähnten Verbesserungen :-)
                                        E 1 Antwort Letzte Antwort
                                          e-s
                                          #897
                                          @nis
                                          Scheint jetzt zu funktionieren
