  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • M Muchul
    Hallo @Rene_HM
    hier erst mal die Einstelllungen, damit ich nichts verkehrt habe:
    und hier das Log:
    2019-07-14 18:11:23.790 - info: host.iobroker object change system.adapter.heatingcontrol.0
    2019-07-14 18:11:23.796 - info: host.iobroker instance system.adapter.heatingcontrol.0 started with pid 19609
    2019-07-14 18:11:24.242 - debug: heatingcontrol.0 objectDB connected
    2019-07-14 18:11:24.255 - debug: heatingcontrol.0 statesDB connected
    2019-07-14 18:11:24.258 - info: heatingcontrol.0 States connected to redis: 127.0.0.1:6379
    2019-07-14 18:11:24.276 - info: heatingcontrol.0 starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.16.0
    2019-07-14 18:11:24.291 - debug: heatingcontrol.0 devices [{"room":"Wohnzimmer","thermostat":"","thermostatType":"","thermostatTypeID":"","actor1":"","actor1Type":"","actor1TypeID":"","actor2":"","actor2Type":"","actor2TypeID":"","isActive":true}]
    2019-07-14 18:11:24.292 - debug: heatingcontrol.0 CreateDatepoints
    2019-07-14 18:11:24.320 - debug: heatingcontrol.0 Profile Type Mo-So, profiles 1
    2019-07-14 18:11:24.320 - debug: heatingcontrol.0 rooms 1
    2019-07-14 18:11:24.328 - debug: heatingcontrol.0 room Wohnzimmer with 5 periods
    2019-07-14 18:11:24.328 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Periods.0 max 5
    2019-07-14 18:11:24.331 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Periods.1 max 5
    2019-07-14 18:11:24.335 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Periods.2 max 5
    2019-07-14 18:11:24.338 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Periods.3 max 5
    2019-07-14 18:11:24.341 - debug: heatingcontrol.0 add state Profiles.0.Wohnzimmer.Periods.4 max 5
    2019-07-14 18:11:24.345 - debug: heatingcontrol.0 #start subscribtion
    2019-07-14 18:11:24.345 - debug: heatingcontrol.0 #subscribtion finished
    2019-07-14 18:11:24.345 - debug: heatingcontrol.0 start CalculateNextTime
    2019-07-14 18:11:24.345 - debug: heatingcontrol.0 profile type 1
    2019-07-14 18:11:24.346 - debug: heatingcontrol.0 get profile
    2019-07-14 18:11:24.346 - debug: heatingcontrol.0 profile 0
    2019-07-14 18:11:24.346 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Periods.0.time
    2019-07-14 18:11:24.347 - debug: heatingcontrol.0 ---found time for Wohnzimmer at {"val":"05:00:00","ack":true,"ts":1562703034562,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1562703034562} 05:00:00
    2019-07-14 18:11:24.347 - debug: heatingcontrol.0 push to list = 05,00,00
    2019-07-14 18:11:24.347 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Periods.1.time
    2019-07-14 18:11:24.347 - debug: heatingcontrol.0 ---found time for Wohnzimmer at {"val":"08:00:00","ack":true,"ts":1562703034578,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1562703034578} 08:00:00
    2019-07-14 18:11:24.348 - debug: heatingcontrol.0 push to list = 08,00,00
    2019-07-14 18:11:24.348 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Periods.2.time
    2019-07-14 18:11:24.348 - debug: heatingcontrol.0 ---found time for Wohnzimmer at {"val":"14:09:00","ack":true,"ts":1563106051568,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1563106051563} 14:09:00
    2019-07-14 18:11:24.348 - debug: heatingcontrol.0 push to list = 14,09,00
    2019-07-14 18:11:24.348 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Periods.3.time
    2019-07-14 18:11:24.349 - debug: heatingcontrol.0 ---found time for Wohnzimmer at {"val":"17:50:00","ack":true,"ts":1563119218858,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1563119218855} 17:50:00
    2019-07-14 18:11:24.349 - debug: heatingcontrol.0 push to list = 17,50,00
    2019-07-14 18:11:24.349 - debug: heatingcontrol.0 check time for Wohnzimmer Profiles.0.Wohnzimmer.Periods.4.time
    2019-07-14 18:11:24.349 - debug: heatingcontrol.0 ---found time for Wohnzimmer at {"val":"18:12:00","ack":false,"ts":1563120660311,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1563120660311} 18:12:00
    2019-07-14 18:11:24.349 - debug: heatingcontrol.0 push to list = 18,12,00
    2019-07-14 18:11:24.350 - debug: heatingcontrol.0 create cron job #0 at 5:0 string: 0 0 5 * * * Europe/Berlin
    2019-07-14 18:11:24.370 - debug: heatingcontrol.0 create cron job #1 at 8:0 string: 0 0 8 * * * Europe/Berlin
    2019-07-14 18:11:24.387 - debug: heatingcontrol.0 create cron job #2 at 14:9 string: 0 9 14 * * * Europe/Berlin
    2019-07-14 18:11:24.391 - debug: heatingcontrol.0 create cron job #3 at 17:50 string: 0 50 17 * * * Europe/Berlin
    2019-07-14 18:11:24.396 - debug: heatingcontrol.0 create cron job #4 at 18:12 string: 0 12 18 * * * Europe/Berlin
    2019-07-14 18:11:24.398 - debug: heatingcontrol.0 cron jobs
    2019-07-14 18:11:24.399 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 05:00:00
    2019-07-14 18:11:24.400 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 08:00:00
    2019-07-14 18:11:24.402 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 14:09:00
    2019-07-14 18:11:24.405 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 17:50:00
    2019-07-14 18:11:24.405 - debug: heatingcontrol.0 [INFO] status = true next event: 14 Jul 2019 18:12:00
    2019-07-14 18:11:24.406 - debug: heatingcontrol.0 CheckTemperatureChange is called
    2019-07-14 18:11:24.418 - debug: heatingcontrol.0 get profile
    2019-07-14 18:11:24.419 - debug: heatingcontrol.0 profile 0
    2019-07-14 18:11:24.422 - debug: heatingcontrol.0 cron jobs
    2019-07-14 18:11:24.423 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 05:00:00
    2019-07-14 18:11:24.424 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 08:00:00
    2019-07-14 18:11:24.425 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 14:09:00
    2019-07-14 18:11:24.429 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 17:50:00
    2019-07-14 18:11:24.429 - debug: heatingcontrol.0 [INFO] status = true next event: 14 Jul 2019 18:12:00
    2019-07-14 18:12:00.011 - debug: heatingcontrol.0 CheckTemperatureChange is called
    2019-07-14 18:12:00.014 - debug: heatingcontrol.0 get profile
    2019-07-14 18:12:00.014 - debug: heatingcontrol.0 profile 0
    2019-07-14 18:12:00.017 - debug: heatingcontrol.0 cron jobs
    2019-07-14 18:12:00.019 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 05:00:00
    2019-07-14 18:12:00.020 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 08:00:00
    2019-07-14 18:12:00.023 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 14:09:00
    2019-07-14 18:12:00.028 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 17:50:00
    2019-07-14 18:12:00.034 - debug: heatingcontrol.0 [INFO] status = true next event: 15 Jul 2019 18:12:00
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    @Muchul irgendwie sehe ich den Fehler nicht :-( Ich habe mal eine neue Version in's github hochgeladen. Die enthält nur noch ein paar logs mehr zu dem Zeitpunkt, wenn ein neuer Wert auf ein Thermostat geschrieben werden soll. Villeicht kannst du den Test mit dieser Version nochmal wiederholen. In den Einstellungen sehe ich, dass einige Temperaturanpassungen (party usw.) nicht gesetzt sind. Setze die bitte mal auf 0.
    • C Offline
      ChrisXY
      gibt es eine möglichkeit auch HM Thermostate welche per fhem iobroker Adapter eingefügt sind damit zu steuern ? befinden sich unter fhem.0
      • Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        Ich bin dabei, den Adapter komplett zu überarbeiten. Dann wird es möglich sein, die OID's manuell für Thermostate, Aktoren und Sensoren zu konfigurieren, wenn die Geräte nicht automatisch gefunden werden. Damit kann man praktisch alle Thermostate mit dem Adapter steuern. Manche werden automatisch konfiguriert andere muss man dann manuell konfigurieren.
        • C Offline
          ChrisXY
          Ja sehr geil. Kann dann gerne tester spielen im Zusammenhang mit homematic welche über den fhem Adapter kommen
          • E Offline
            e-i-k-e
            Guten Abend,
            würde auch gerne beim testen behilflich sein.
            Nutze aktuell das Heizungsthermostatsteuerung Skript, welches allerdings nie richtig lief und nach Umstieg auf redis überhaupt nicht mehr funktioniert.
            Setze folgend Komponenten ein.
            • HM Thermostate
            • HM Raumthermostate
            • HM Fensterkontakte
            • Xiaomi Fensterkontakte
            • Xiaomi Temperatursensoren
            Ganz großes Kino wäre es, wenn dieser Adapter die Logik des Fußbodenheizungs Skript implementiert. Und ich auch dieses Skript ersetzen könnte. :)
            • Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              okay, jetzt ist es soweit, ich habe die Version 0.1.0 im github und NPM veröffentlicht.
              Wichtigste Änderung vorweg: Der Adapter wurde intern komplett überarbeitet. Damit musste ich leider auch die Datenpunkte zur Profileinstellung pro Raum verschieben. Damit ist es notwendig, die Einstellungen im Vis o.ä. anzupassen :-(
              Nun zu den Neuerungen:
              • Man kann nun eine nicht limitierte Anzahl von Thermostate, Aktoren und Sensoren pro Raum konfigurieren. Die alte Grenze von einem Thermostat pro Raum gibt es nicht mehr.
              • die drei verschiedenen Profiltypen
                ** Montag bis Sonntag
                ** Montag bis Freitag und Samstag / Sonntag
                ** jeden Tag einzeln
                funktionieren nun
              • es gibt auch die Möglichkeit, Fenstersensoren einzubinden. Damit kann man die Raum-Zieltemperatur absenken, wenn Fenster offen sind
              • es gibt ein Interface zum Feiertag-Adapter. Damit kann man erkennen, ob heute ein Feiertag ist. Ein Feiertag wird dann entweder als normaler Tag oder wie ein Sonntag behandelt. das ist im admin einstellbar
              • es wird weiterhin versucht, die Geräte pro Raum automatisch zu erkennen. Da das aber oft nicht so einfach ist (insbesondere bei nicht-Homematic-Geräten) gibt es jetzt die Möglichkeit, die Geräte auch manuell zu konfigurieren. Man fügt einfach ein neues Gerät im neuen Raum ein, setzt ein oder zwei Pfade (zu Zieltemperatur, aktueller Temperatur für Thermostate bzw. state zu Aktoren und Sensoren) und aktiviert das Gerät.
                Hier noch ein screenshoots vom neuen Adapter-admin:
              ein Teil der Hauptkonfiguration:
              die Profil-Konfiguration
              zunächst die Räume
              und dann die Konfiguration des Raumes, nachdem man den rot markierten Edit-Knopf gedrückt hat:
              BBTownB I 2 Antworten Letzte Antwort
              • Rene_HMR Rene_HM
                  funktionieren nun
                zunächst die Räume
                BBTownB Offline
                BBTownB Offline
                BBTown
                @Rene_HM
                schade, dass es sich eingebürgert hat, alles nur noch englisch zu bezeichnen ... 😢
                Rene_HMR 1 Antwort Letzte Antwort
                • BBTownB BBTown
                  @Rene_HM
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  @BBTown Die Übersetzungen sind für alle unterstützten Sprachen vorhanden. Die screenshots sind von meinem Test-System, welches in englisch läuft...
                  BBTownB 1 Antwort Letzte Antwort
                  • Rene_HMR Rene_HM
                    BBTownB Offline
                    BBTownB Offline
                    BBTown
                    @Rene_HM
                    danke dir für den Hinweis 👍
                    • C Offline
                      ChrisXY
                      cool aber wie funktioniert das den ?
                      Hab per FHEM Adapter den Homematik _Clima channel im room "Heizung"
                      Dieser taucht im Adapter unter room auch auf. Jedoch bekomme ich da kein Aktor oder so ausgewählt ..
                      Muss ich das ganze Gerät auswählen ? Also nicht nur den _Clima channel?
                      • Rene_HMR Rene_HM
                          funktionieren nun
                        zunächst die Räume
                        I Offline
                        I Offline
                        iobroker_Alex
                        @Rene_HM Sehe ich es in deinem Screenshot richtig, dass der "Pfad zum Feiertagskalender" nur auf die "erste Verzeichnisstruktur" abzielt: Also nur "feiertage.0" statt: "feiertage.0.heute.boolean"?
                        Wenn ja würde ich mich freuen, wenn du das umbaust um meinen echten eigenen Datenpunkt auszuwählen, statt auf die Struktur vom Feiertagskalender zu reflektieren...
                        Ansonsten gute Arbeit. Ich konfigurier mich mal durch...
                        Viele Grüße
                        • Rene_HMR Offline
                          Rene_HMR Offline
                          Rene_HM
                          ja, vielleicht keine schlecht Idee, da ich ja auch die Geräte-Datenpunkte frei konfigurierbar gmacht habe. Ich baue das um. Eventuell finde ich eine Lösung, die beide Varianten abdeckt...
                          • C ChrisXY
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            schrieb am zuletzt editiert von Rene_HM
                            @ChrisXY Unter "Edit Room" musst du den Pfad zum jeweiligen Datenpunkt eintragen, nicht nur das Gerät. Für einen Aktor so wie oben im screenshot dargestellt den Datenpunkt für den "state"...
                            • I Offline
                              I Offline
                              iobroker_Alex
                              schrieb am zuletzt editiert von iobroker_Alex
                              @Rene_HM kannst du nochmal kurz sagen ob der Adapter sich die Radiatoren selbst zieht, wenn diese sich unter "maxcul.0" befinden oder ist das noch nicht implementiert?
                              Zudem: Kannst du kurz erklären was für dich ein "Thermostat" "Aktor" und "Sensor" ist.
                              Ich verstehe es so:
                              Thermostat = Wandthermostat zur Steuerung der Einstellung der Ist und Soll Temperatur
                              Aktor = Heizkörperthermostat, Radiator zur eigentlich Heizungssteuerung
                              Sensor = Fensterkontakt oder anderer Sensor, welcher Einfluss auf den Aktor nimmt...
                              Ist das so richtig?
                              Wenn ja: Ist es nicht so, dass das Thermostat nichts anderes macht als den aktuellen Zustand des Profils und der Periode darzustellen? Kann man hiermit diese Datenpunkte verändern?
                              Wenn möglich bitte in zukünftigen Versionen "eindeutigere" Begriffe verwenden oder und ein Wiki aufbauen...
                              Vielen Dank!
                              • ? Offline
                                Ich hätte da jetzt auch mal eine Frage, denn so ganz verstehe ich nicht, was ich denn nun im Falle von HM-IP Heizkörperthermostaten unter Thermostat, Aktor und Sensor eintragen muss. Vor allem Aktor erscheint mir unplausibel. Denn als State habe ich dort nur Windowstate oder Valve State, beides ist aber nicht nutzbar um meine Heizung zu regeln.
                                • Rene_HMR Offline
                                  Rene_HMR Offline
                                  Rene_HM
                                  Die Idee des Adapters ist, auf Thermostate zeitgesteuert eine bestimmte Solltemperatur zu schreiben. Ein z.Bsp. Heizkörperthermostat regelt mit dieser Soll-Temperatur selbständig den Zufluß in die Heizung. Damit ist also in so einem Fall kein Eintrag unter Aktor notwendig. Auch ein Eintrag unter Ist-Temperatur des Thermostats ist eigentlich nicht notwendig. Wenn man aber z.Bsp. eine Fußbodenheizung betreibt, wo die entsprechenden Ventile über digitale Ausgänge des z.Bsp. Homematic-Systems gesteuert werden, verwendet man das "Thermostat" einfach nur als Thermometer (verwendet also dort Soll und Ist) und benötigt dann die Aktor-Einstellung, um das Ventil basierend auf den Werten vom Thermostat zu schalten.
                                  Die Sensoren dienen einfach dazu, bei z.Bsp. offenen Fenstern die Solltemperatur entsprechend zu reduzieren.
                                  • ? Offline
                                    Also kommen bei mir quasi die Heizkörperthermostate als Thermostat und bei Sensor die zugeordneten Fenstersensoren hinein.
                                    Klingt einfach.
                                      Klingt einfach.
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      @Beliar_666 genau so... Du musst eben nur den gesamten Pfad zum Datenpunkt der Soll-Temperatur und gegebenenfalls auch zur Ist-Temperatur des Thermostats konfigurieren...
                                      • I iobroker_Alex
                                        Ich verstehe es so:
                                        Ist das so richtig?
                                        Vielen Dank!
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        @iobroker_Alex sagte in Adapter: HeatingControl:
                                        Derzeit werden (wieder nur) Homematic-Geräte automatisch erkannt. Alle anderen Geräte müssen manuell konfiguriert werden.
                                        Die Begriffe und wie die Geräte genutzt werden sollen, hatte ich im vorherigen post beschrieben. Falls da noch Fragen sind, bitte einfach noch mal melden...
                                          mrMuppet
                                          Was ist eigentlich der Unterschied zum bekannten Heizungsthermostatskript? Soweit ich das verstehe ist hauptsächlich die Bedienung etwas vereinfacht, weil man keine Visualisierungen mehr anlegen muss um alles zu programmieren. Gibt es sonst noch nennenswerte Unterschiede?
                                          ioBroker auf NUC (Celeron mit Ubuntu-Server)
                                          Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
