  4. [gelöst] Sonos Cover in VIS
vis
15 Beiträge 5 Kommentatoren 3.8k Aufrufe 1 Beobachtet
  • sigi234S Online
    sigi234S Online
    Widget, teste es mal....
    [{"tpl":"tplValueStringImg","data":{"oid":"sonos.0.root.192_168_178_26.current_cover","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"2000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_prepend":"","visibility-oid":""},"style":{"left":"827px","top":"51px","width":"225px","height":"231px","background":""},"widgetSet":"basic"}]
    • S stockics6
      habe gerade den Adapter "Sonos" zum laufen bekommen, funktioniert auch alles bis auf das unter "now playing" keine
      Covers angezeigt werden.
      Ziel ist es, die Covers in VIS (grünes Feld) darszustellen sobald die Lautsprecher eingeschaltet sind und die Covers auszublenden sobald der Lautsprecher pausiert wurde.
      Hat jemand schon das Problem lösen können?
      Vielen Dank!
      sigi234S Online
      sigi234S Online
      @stockics6 sagte in Sonos Cover in VIS:
      Das geht mit Sichtbarkeit..........und z-index
        stockics6
        leider funktioniert das Widget nicht.
        Komischerweise wird auch unter den Objekten "media.current.cover, cover_url, cover_png nichts angezeigt.
        Alles weitere funktioniert aber perfekt
        • H Offline
          hesse
          Sicher, dass sich alle anderen Datenpunkte aktualisieren?
          Der Sonos Adapter zickt akztuell, vor allem bei Neuinstalltionen, rum und aktualisert nur ein paar wenige Datenpunkte .... so wird z.B. State nicht aktualiert, aber Volume hingegen schon
            stockics6
            wenn der Adapter zickt müssten ja alle das Problem haben oder nicht ?
            Bin erst vor kurzem auf ioBroker umgestiegen hatte vorher auf nem Rasp immer node-sonos-http-api am laufen, funktionierte auch perfekt.
            Ich habe den Adapter soebend einmal neu eingerichtet:
            Jetzt habe ich die Situation, dass sich kein Datenpunkt mehr aktualisiert aber die Befehlstaste play, pause und stop problemlos funktionieren.
            Die Radiosender- und Favoritenänderungen sowie die anderen Datenpunkte werden nicht mehr aktualisiert.
            Komisch?
            • cashC Offline
              cashC Offline
              cash
              Bei mir werden alle Datenpunkte die ich nutze aktualisiert. Alle meine Scripte laufen ganz normal und fehlerfrei. Habe also keine Probleme. Bin aber noch bei node 8
                stockics6
                Mhhh bei mir wird nichts mehr aktualisiert.
                Habe gerade zum testen node-sonos-http-api installiert und via netzwerkbefehle kann ich die Sonos ebenfalls steuern.
                Habe gerade herausgefunden, dass ich über den Befehl "http://192.168.178.35:1400/getaa?s=1&u=x-sonosapi-stream%3As45087%3Fsid%3D254%26flags%3D8224%26sn%3D0" das aktuelle Cover sehen kann nur leider ist der hintere Bereich der URL bei jedem Lied/Sender anders.
                Kennt jemand einen Befehl für die Coverabfrage?
                Habe Node 10.16 also >4.0 ?
                So langsam weiß ich auch nicht mehr weiter
                • H Offline
                  hesse
                  Ich habe zu dem Fehler hier schon ein bisschen was zusammen geschrieben und analysiert:
                  https://forum.iobroker.net/topic/23609/sonos-adapter-aktualisiert-nur-teilweise/31
                  und in Github sind auch 2 Issues dazu offen:
                  https://github.com/ioBroker/ioBroker.sonos/issues/48
                  https://github.com/ioBroker/ioBroker.sonos/issues/46
                  Und ich habe hier im Github mal angefragt, ob es evtl Sinn machen würde auf die http-api als datenquelle um zu stellen:
                  https://github.com/ioBroker/ioBroker.sonos/issues/49
                  • P Offline
                    Pascal1909
                    Ich lasse mir das Cover über den Sonos Adapter anzeigen und wenn ich die Wiedergabe über Spotify starte muss ich das Cover vom Spotify Adapter nehmen, weil der Sonos Adapter dann nicht mehr aktualisiert. Funktioniert aber ganz gut.
                    Allerdings muss ich mit zwei verschiedenen Aktualisierungsintervallen bei dem Widget arbeiten. Beim current Cover vom Sonos Adapter steht die Aktualisierung auf 0ms und über Spotify bei 50ms.
                      stockics6
                      Welches Widget benutzt zu denn ?
                      Ich habe jetzt einige ausprobiert, aber leider wird bei mir kein Cover angezeigt.
                      • H Offline
                        hesse
                        @stockics6 hast du mal die neue Version des Adapters (2.0.0) von Github getestet, damit funktionieren bei mir auch die Cover wieder
                          stockics6
                          schrieb am zuletzt editiert von stockics6
                          Ja, habe ich soeben installiert, bekomme das Cover aber nicht im Widget dargestellt.
                          Welches Widget benutzt ihr zum visualisieren?
                          (sonos.0.root.192_168_178_XX.cover_png)
                          • H Offline
                            hesse
                            @stockics6
                            Versuch mal den Datenpunkt: sonos.0.root.192_168_178_XX.current_cover
                            Der funktioniert bei mir mit dem vis-players widget.
                              stockics6
                              hey,
                              sorry für die späte Antwort (war im Urlaub :D)
                              Super vielen Dank für eure Hilfe!
                              Funktioniert mit dem Plugin perfekt!
                              1. Sonos Adapter 2.0 installieren
                              2. Adapter: vis-players widget installieren
                              3. Verknüpfungen in VIS einfügen
                              4. Spaß haben :D
