  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. MegaD 328
MegaD 328
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
430 Beiträge 28 Kommentatoren 204.1k Aufrufe 2 Beobachtet
  • V
    V
    vtec
    #113
    Сканирование (из php файла):
    $sock = socket_create(AF_INET, SOCK_DGRAM, SOL_UDP);
    socket_set_option($sock, SOL_SOCKET, SO_BROADCAST, 1);
    $broadcast_ip = preg_replace("/(\d+)\.(\d+)\.(\d+)\.(\d+)/", "$1.$2.$3.255", $local_ip);
    # Prepearing sockets
    if ( !empty($options['local-ip']) )
    $local_ip = $options['local-ip'];
    else
    	$local_ip = gethostbyname(gethostname());
    	if ( empty($local_ip) || preg_match("/127\./", $local_ip) )
    		if ( preg_match("/^WIN/", PHP_OS) )
    		$local_ip = get_local_ip_win();
    		else
    			$find_ip = get_local_ip();
    			foreach ( $find_ip as $iface => $iface_ip)
    				if ( preg_match("/^192\.168/", $find_ip[$iface]) || preg_match("/^10\./", $find_ip[$iface]) )
    				$local_ip = $find_ip[$iface];
    	if ( !preg_match("/192\.168\./", $local_ip) && !preg_match("/10\.0\./", $local_ip) && !preg_match("/172\.16\./", $local_ip) )
    		echo "Unable to detect local network\nPlase, specify local IP-address with --local-ip\n";
    		exit;
    # Scanning network for Mega-cool MegaD-devices ;)
    if ( array_key_exists('scan', $options) || array_key_exists('s', $options) )
    	$broadcast_string = chr(0xAA).chr(0).chr(12);
    	socket_sendto($sock, $broadcast_string, strlen($broadcast_string), 0, $broadcast_ip, 52000);
    	usleep(100);
    	do
    		$pkt = fread($socket, 10);
    		if ( !empty($pkt) && ord($pkt[0]) == 0xAA )
    		echo ord($pkt[1]).".".ord($pkt[2]).".".ord($pkt[3]).".".ord($pkt[4])."\n";
    	while ( $pkt != false );
    Чтение конфига
    	if ( array_key_exists('read-conf', $options) )
    		echo "Reading configuration... ";
    		$pages = array("cf=1", "cf=2");
    		//$pages = array();
    		$page = file_get_contents("http://".$options['ip']."/".$options['p']);
    		$ports = preg_replace("/.*\?pt=(\d+).*/", "$1", $page);
    		for ( $i = 0; $i <= $ports; $i++ )
    		$pages[] = "pt=$i";
    		$fh = fopen($options['read-conf'], "w");
    		$dom = new DOMDocument();
    		$preset_flag = 0;
    		for ( $i = 0; $i < count($pages); $i++ )
    			if ( $preset_flag == 1 )
    				//echo "Setting preset 0\n";
    				$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?cf=1&pr=0");
    				sleep(1);
    				$preset_flag = 2;
    			$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?".$pages[$i]);
    			@$dom->loadHTML($page);
    			//$url = "http://".$options['ip']."/".$options['p']."/?";
    			$url = "";
    			$els=$dom->getelementsbytagname('input');
    			foreach($els as $inp)
    				if ( $inp->getAttribute('type') != "submit" )
    					$name=$inp->getAttribute('name');
    					//$value=urlencode($inp->getAttribute('value'));
    					if ( $inp->getAttribute('type') == "checkbox" )
    						if ( $inp->hasAttribute('checked') )
    						$value=1;
    						else
    						$value='';
    					else
    					$value=$inp->getAttribute('value');
    					if ( $name != "pt" )
    						if ( $name == "sl" && empty($value));
    						else
    						$url .= "$name=$value&";
    			$select = $dom->getelementsbytagname('select');
    			foreach($select as $elem)
    				$name=$elem->getAttribute('name');
    				$els=$elem->getelementsbytagname('option');
    				$sel_flag = 0;
    					if ( $inp->hasAttribute('selected') )
    						//$name=$inp->getAttribute('name');
    						$sel_flag = 1;
    						if ( $pages[$i] == "cf=1" && $name == "pr" && !empty($value) )
    							$preset_flag = 1;
    							$stored_preset = $value;
    				// Хак ввиду того, что PHP DOM почему-то не может распарсить значение <> поля "Mode"
    				if ( $sel_flag == 0 && $name == "m" )
    				$url .= "m=3&";
    			$url = preg_replace("/&$/", "", $url);
    			fwrite($fh, "$url\n");
    		fclose($fh);
    		if ( $preset_flag == 2 )
    			//echo "Setting preset 1\n";
    			$page = file_get_contents("http://".$options['ip']."/".$options['p']."/?cf=1&pr=$stored_preset");
    			sleep(1);
    		echo "OK\n";
    • V
      V
      vtec
      #114
      Посмотрел чтение конфига, там тот же парсинг идет :lol:
      А вот поиск устройств, всего две строки, отправка udp запроса бродкастом на порт 52000
      • V
        V
        vtec
        #115
        Из мануала:
        Если порт настроен как вход, то через слеш указывается значение счетчика входа. То есть там может быть не 0, а любая цифра.
        • BluefoxB
          #116
          Спасибо. Вот теперь я знаю, что я буду делать на выходных.
          • BluefoxB
            #117
            Что возвращают?
            • http://192.168.0.14/sec
            • http://192.168.0.14/sec/
            • http://192.168.0.14/sec/?cf=1
            • http://192.168.0.14/sec/?cf=2
            Как HTML.
            • V
              V
              vtec
              #118
              MegaD-328 by [ab-log.ru](http://ab-log.ru) (fw: 3.30b5)
              [Config](/sec/?cf=1)
              -- Ports --
              [P0 - IN](/sec/?pt=0)
              [P1 - IN](/sec/?pt=1)
              [P2 - IN](/sec/?pt=2)
              [P3 - IN](/sec/?pt=3)
              [P4 - IN](/sec/?pt=4)
              [P5 - IN](/sec/?pt=5)
              [P6 - IN](/sec/?pt=6)
              [P7 - OUT](/sec/?pt=7)
              [P8 - OUT](/sec/?pt=8)
              [P9 - OUT](/sec/?pt=9)
              [P10 - OUT](/sec/?pt=10)
              [P11 - OUT](/sec/?pt=11)
              [P12 - OUT](/sec/?pt=12)
              [P13 - OUT](/sec/?pt=13)
              [A6 - ADC](/sec/?pt=14)
              [A7 - ADC](/sec/?pt=15)
              2. Тоже самое что и первое
              3.
              [Back](/sec) | [Megad-ID](/sec/?cf=2)
              <form action="/sec/">IP:
              Pwd:
              GW:
              SRV:
              Script:
              Preset: <select name="pr"><option value="0" selected="">Norm</option><option value="1">7I7O</option></select>
              T check:
              Alarm T:
              Cur T: 37
              </form>
              [Back](/sec) | [Config](/sec/?cf=1)
              <form action="/sec/">Megad-ID:
              srv loop:
              </form>
              • V
                V
                vtec
                #119
                Предложение, если я выставляю режим кнопки "изменение", то соответственно, я буду использовать доп. режимы, это либо долгое нажатие, либо двойное, либо в сумме. Так вот предлагаю эти галочки у этих двух параметров по умолчанию чтобы были выставлены. Возможно такое?
                • BluefoxB
                  #120
                  Дописал драйвер с твоей помощью. Можешь попробовать?
                  • H
                    H
                    Haus
                    #121
                    Привет
                    В новой прошивке Megad есть поддержка датчиков 1wire DS18B20 и DS1990A (считыватели ключей iButton, EM-Marene с поддержкой протокола TM/1-wire). Вместо DHT22 определился DHT11, а вместо 1W тоже определился DHT11.
                    1W
                    [Back](/sec)
                    P7
                    temp:26.81
                    <form action="/sec/">Type <select name="pty"><option value="255">NC</option><option value="0">In</option><option value="1">Out</option><option value="3" selected="">DSen</option></select>
                    Mode <select name="m"><option value="0">Norm</option><option value="1" selected="">></option><option value="2"><</option><option value="3"><></option></select>
                    Val
                    Act
                    Net
                    Sensor: <select name="d"><option value="1">DHT11</option><option value="2">DHT22</option><option value="3" selected="">1W</option><option value="4">iB</option></select>
                    </form>
                    DHT22
                    [Back](/sec)
                    P0
                    temp:30.30
                    hum:38.70
                    <form action="/sec/">Type <select name="pty"><option value="255">NC</option><option value="0">In</option><option value="1">Out</option><option value="3" selected="">DSen</option><option value="2">ADC</option></select>
                    Sensor: <select name="d"><option value="1">DHT11</option><option value="2" selected="">DHT22</option><option value="3">1W</option><option value="4">iB</option></select>
                    </form>
                    js-controller: 1.5.7 / node.js: v8.15.1/ npm: 6.4.1
                    admin: 3.6.0
                    javascript: 4.1.10
                    web: 2.4.1 vis: 1.1.10
                    cloud: 2.6.2
                    Server: DELL FX170 / linux: Debian 9.5 Stretch
                    Adapter: MegaD-2561, Mega-ES…
                    • BluefoxB
                      #122
                      В новой версии фирмваре поменялось значение аттрибута m для цифровых датчиков.
                      Я запрограммировал, как в новой версии. Кстати у неё есть номер, что бы я мог написать, что поддерживается версия от X.Y
                      Может кто нибудь попробовать новую версию?
                      cd /opt/iobroker
                      npm install https://github.com/ioBroker/ioBroker.megad/tarball/master
                      А всё остальное работает???
                      • A
                        A
                        Andrei34
                        #123
                        В настройках параметры считываются шыкарно , но не записываются . А в Vis ни на что не реагирует :( .
                        • B
                          B
                          Bosya
                          #124
                          Поигрался с новым драйвером и есть вопрос про длинное нажатие. Сейчас это работает как одинарное и двойное нажатие - true и сразу false, хотя я продолжаю держать кнопку.Хотелось бы иметь true после времени задержки, а false по отпусканию кнопки…
                          2015-09-03 13:54:06.920 - debug: inMem message * megad.0.p11_P11_long val=true, ack=true, ts=1441277647, from=system.adapter.megad.0, lc=1441277647
                          2015-09-03 13:54:07.126 - debug: inMem message * megad.0.p11_P11_long val=false, ack=true, ts=1441277647, from=system.adapter.megad.0, lc=1441277647
                          • V
                            V
                            vtec
                            #125
                            А зачем?
                            Вообще мега такой запрос отправляет, можете на свой скрипт направить мегу.
                            • B
                              B
                              Bosya
                              #126
                              @vtec:
                              А зачем? `
                              Мне это нужно для димирования. На одиночный и двойной клик вешаем какие то функции - например включение/выключение свете, общее выключение света. На длинное нажатие вешаем плавную регулировку яркости.
                              @vtec:
                              Вообще мега такой запрос отправляет, можете на свой скрипт направить мегу. `
                              Мега не может такой запрос отправлять, так как p11_P11_long, это чисто программная переменная, которая генерируется после определенной задержки длинного нажатия и выставляется в true, а вот после этого сразу скидывается в false. Не совсем логично. Если кому надо не для димирования, то он ловит только true и пользует его, а для димирования нужен реальный false который будет генерироваться по отпусканию кнопки.
                              Свой скрипт написать конечно могу, но мне тогда придется переписывать полностью все одинарные, двойные нажатия и полностью отказаться от достаточно удобного драйвера.
                              А чем может помешать правильная обработка конца нажатия?
                              • BluefoxB
                                #127
                                @Andrei34:
                                В настройках параметры считываются шыкарно , но не записываются . `
                                А можно логи? (Предварительно выставить на level=debug)
                                @Andrei34:
                                А в Vis ни на что не реагирует :( . `
                                Поправил. Должно работать.
                                Осталось выяснить, что делать с выходом в режиме PWM.
                                • BluefoxB
                                  #128
                                  @Bosya:
                                  2015-09-03 13:54:07.126 - debug: inMem message * megad.0.p11_P11_long val=false, ack=true, ts=1441277647, from=system.adapter.megad.0, lc=1441277647 `
                                  Поправил. Установка через github, как сверху описано.
                                  • B
                                    B
                                    Bosya
                                    #129
                                    @Bluefox:
                                    Поправил. Установка через github, как сверху описано. `
                                    Спасибо, это заработало отлично.
                                    Есть следующая проблема. Для выходов ШИМ не правильно читаются данные. Если 0 то val=false, а если 1-255 то val = true.
                                    Приєтом команды:
                                    http://192.168.24.69/sec/?pt=12&cmd=get
                                    255 (ШИМ Р12 - 250, val=true)
                                    http://192.168.24.69/sec/?cmd=all
                                    ;;;;;;;temp:0/hum:0;;;ON;OFF/14;<color color="red">1;temp:25/hum:33;799;1023 (ШИМ р12 - 1, val=true)
                                    2015-09-09 10:37:08.053 - debug: megad.0 detected new value on port [12]: false
                                    2015-09-09 10:37:08.078 - debug: inMem message megad.0.* megad.0.p12_P12 val=false, ack=true, ts=1441784228, from=system.adapter.megad.0, lc=1441784228
                                    • BluefoxB
                                      #130
                                      @Bosya:
                                      @Bluefox:
                                      Приєтом команды:
                                      2015-09-09 10:37:08.078 - debug: inMem message megad.0.* megad.0.p12_P12 val=false, ack=true, ts=1441784228, from=system.adapter.megad.0, lc=1441784228 `
                                      Поправил. Только значение скалируется от 0 до 1. Что бы получить значение как в меге надо указать фактор 256.
                                      Output 1 => 1 / 256 = 0.00390625
                                      А запись настроек в мегу работает?
                                      • A
                                        A
                                        Andrei34
                                        #131
                                        @Bluefox:
                                        А запись настроек в мегу работает? `
                                        Да. Обновил до 0.23 , но с PWM ситуация вроде не изменилась , может я что не так делаю ? Остальное вроде работает :)
                                        • BluefoxB
                                          #132
                                          @Andrei34:
                                          @Bluefox:
                                          А запись настроек в мегу работает? Да. Обновил до 0.23 , но с PWM ситуация вроде не изменилась , может я что не так делаю ? Остальное вроде работает :)
                                          А ты значения пишешь или читаешь?
                                          Что говорит лог с уровнем debug?
                                          33.2k
                                          84.3k
