  4. Script Xiaomi Battery leer ?
Geplant Angeheftet Gesperrt Verschoben Ungelöst Skripten / Logik
blockly
93 Beiträge 19 Kommentatoren 14.8k Aufrufe 16 Beobachtet
  • P passuff
    Wollte jetzt den Raumnamen entfernen aber irgendwie habe ich das skript zerschossen:
    const idVis = 'Batterie.HomematicBatterietausch';
    const batt = $('hm-rpc.0.*.LOWBAT');
    createState(idVis, '', {type: 'string'});
    function lowBatt() {
    	console.log('lowbat Homematic wird ausgeführt');
        var low = [];
        batt.each(function (id, i) {
    	if(getState(id).val == true) {
    			id = id.split('.');
    			id = 'hm-rpc.0.' + id[2];
                low.push(getObject(id).common.name); // Kanal-Name: Raum
    	setState(idVis, low.join(','), true);
    schedule('*/5 * * * * *', lowBatt); // jeden Tag
    //schedule('{"time":{"exactTime":true,"start":"18:00"},"period":{"days":1}}', lowBatt)
    Folgendes Warn im Log:
    javascript.0 2019-08-04 21:53:45.008 warn at Timer.processTimers (timers.js:223:10)
    javascript.0 2019-08-04 21:53:45.008 warn at listOnTimeout (timers.js:263:5)
    javascript.0 2019-08-04 21:53:45.008 warn at tryOnTimeout (timers.js:300:5)
    javascript.0 2019-08-04 21:53:45.007 warn at ontimeout (timers.js:436:11)
    javascript.0 2019-08-04 21:53:45.007 warn at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0 2019-08-04 21:53:45.007 warn at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0 2019-08-04 21:53:45.007 warn at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0 2019-08-04 21:53:45.007 warn at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1191:34)
    javascript.0 2019-08-04 21:53:45.007 warn at Object.lowBatt (script.js.common.Batteriestatus.Batteriestatus_Homematic:9:10)
    javascript.0 2019-08-04 21:53:45.007 warn at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:778:29)
    javascript.0 2019-08-04 21:53:45.006 warn at script.js.common.Batteriestatus.Batteriestatus_Homematic:10:5
    javascript.0 2019-08-04 21:53:45.004 warn getState "hm-rpc.0.PEQ0508233.0.LOWBAT" not found (3) states[id]=null
    javascript.0 2019-08-04 21:53:45.001 info script.js.common.Batteriestatus.Batteriestatus_Homematic: lowbat Homematic wird ausgeführt
    GlasfaserG Offline
    GlasfaserG Offline
    #70
    @passuff sagte in Script Xiaomi Battery leer ?:
    …………………….> javascript.0 2019-08-04 21:53:45.004 warn getState "hm-rpc.0.PEQ0508233.0.LOWBAT" not found (3) states[id]=null
    Dein Skript macht kein Fehler .
    Da ist ein Fehler im Datenpunkt hm-rpc.0.PEQ0508233.0.LOWBAT not found (3) states[id]=null
    Schau mal nach ob da ein Wert vorhanden ist !?
    P 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      passuff
      #71
      @Glasfaser
      Der Datenpunkt ist ein Homematic Schaltaktor. Der hat, wie andere Geräte auch, keinen Batteriestatus. Warum stört sich das Skript daran?
      Darüber hinaus funktioniert die Bedingung ( == true) nicht. Es werden schlussendlich alle Homematicgeräte mit LOWBAT gelistet, auch die die false sind...
      GlasfaserG P 2 Antworten Letzte Antwort
      • P passuff
        @Glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        #72
        @passuff
        Sieht es nicht bei dir so aus !?
          @passuff
          passuff
          #73
          @Glasfaser
          Nein, wie gesagt das Gerät ist eine Steckdose. Diese hat keine Batterie und daher auch keinen Batteriestatus...
          • P passuff
            @Glasfaser
            GlasfaserG Offline
            GlasfaserG Offline
            #74
            @passuff
            Sorry ...mit der Angabe " Homematic Schaltaktor " konnte ich leider nicht erlesen , das es sich um eine Steckdose handelt .
              @passuff
              GlasfaserG Offline
              GlasfaserG Offline
              #75
              @Glasfaser
              Hier die HM Steckdose ( Keine IP )
              Es gibt da ein Datenpunkt !
                @Glasfaser
                passuff
                #76
                @Glasfaser
                Muss mich entschuldigen. Ich habe mich im Gerät geirrt. Du hattest völlig recht:
                Scheint als hat de Fernbedienung keinen Empfang und sendet daher weder true noch false.
                • P passuff
                  @Glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #77
                  @passuff
                  Richtig … kein Empfang ….
                  • P passuff
                    @Glasfaser
                    passuff
                    #78
                    Das erschließt sich mir allerdings immer noch nicht...
                    • P passuff
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #79
                      @passuff
                      Kann leider nicht testen , da ich gerade keine leere Batterie habe , aber dein Script läuft ohne Fehler bei mir im LOG .
                        @passuff
                        passuff
                        #80
                        @Glasfaser
                        Ich habe auch keine leere Batterie. Dennoch habe ich im erzeugten Datenpunkt alle HM Geräte gelistet..
                        • P passuff
                          @Glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #81
                          @passuff
                          Habe mal den Wert Lowbat händisch auf true gesetzt .
                          Und die gleiche Fehlermeldungen wie bei Dir !!!
                          • P passuff
                                var low = [];
                            			id = id.split('.');
                            #82
                            @passuff sagte:
                            Anscheinend hat das Objekt noch keinen Zustand ? Dann gib mal manuell den Wert false ein.
                            • P Offline
                              passuff
                              #83
                              Das führt lediglich dazu, dass die Fehlermeldungen verschwinden. Die Bedingung wird immer noch falsch ausgewertet bzw alle Sensoren werden als lowbat = true erkannt.
                              • P passuff
                                #84
                                @passuff sagte:
                                Wie sieht das Log aus, wenn in Zeile 10 ein zusätzliches Log eingefügt wird ?
                                        log(id + ': ' + getState(id).val);
                                  @passuff sagte:
                                  passuff
                                  schrieb am zuletzt editiert von passuff
                                  #85
                                  @paul53 sagte in Script Xiaomi Battery leer ?:
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: lowbat Homematic wird ausgeführt
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.0.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.1.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.2.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.3.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.4.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0672249.5.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0708741.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0708741.1.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0708748.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0708748.1.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0709520.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0709520.1.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0709589.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0709589.1.LOWBAT: false
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0860057.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1359645.0.LOWBAT: true
                                  23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1360423.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424242.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424242.1.LOWBAT: false
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424270.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424270.1.LOWBAT: false
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424271.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424271.1.LOWBAT: false
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424294.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1424294.1.LOWBAT: false
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1675616.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1676108.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711771.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711789.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711802.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711818.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711819.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711829.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711834.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1711836.0.LOWBAT: true
                                  23:57:50.015 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1714864.0.LOWBAT: true
                                  23:57:50.016 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1715250.0.LOWBAT: true
                                  23:57:50.016 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1959899.0.LOWBAT: true
                                  23:57:50.016 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ1959979.0.LOWBAT: true
                                  23:57:50.016 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.PEQ0508233.0.LOWBAT: false
                                  23:57:50.016 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.PEQ1921813.0.LOWBAT: true
                                  23:57:53.261 info javascript.0 Stop script script.js.common.Batteriestatus.Batteriestatus_Homematic
                                  "23:57:50.014 info javascript.0 script.js.common.Batteriestatus.Batteriestatus_Homematic: hm-rpc.0.OEQ0708741.0.LOWBAT: true"
                                  • P passuff
                                    #86
                                    @passuff
                                    Es liefern zwar viele, aber nicht alle LOWBAT true. Es liegt nicht am Skript. Hast Du mal die JS-Instanz neu gestartet ?
                                      @passuff
                                      passuff
                                      #87
                                      Js, iobroker und auch die VM...
                                      • P passuff
                                        #88
                                        @passuff
                                        Und trotzdem weicht die Log-Ausgabe so stark von den angezeigten Werten im Reiter "Objekte" (auch in der Statusansicht) ab ? Dann bin ich mit meinem Latein am Ende 😢
                                          @passuff
                                          passuff
                                          #89
                                          @paul53 genau so ist es.
                                          Ich schau.mir das heute Abend noch mal an. Ich glaube es konnte am nodejs update liegen. (10.16.1)
