  4. [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar
    6.8k
hamhomebridge
38 Beiträge 7 Kommentatoren 5.4k Aufrufe 4 Beobachtet
  • F Offline
    fisch
    Moin, moin...
    kann hier jemand was zu dem Fehler sagen?
    Danke Greetz
    am.1	2019-07-21 10:38:40.349	warn	Exception: TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
    ham.1	2019-07-21 10:38:40.347	info	cleaned everything up...
    ham.1	2019-07-21 10:38:40.345	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    ham.1	2019-07-21 10:38:40.345	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    ham.1	2019-07-21 10:38:40.345	error	at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2695:25)
    ham.1	2019-07-21 10:38:40.345	error	at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
    ham.1	2019-07-21 10:38:40.345	error	at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
    ham.1	2019-07-21 10:38:40.345	error	at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:279:14)
    ham.1	2019-07-21 10:38:40.345	error	at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:57:24)
    ham.1	2019-07-21 10:38:40.345	error	at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:145:22)
    ham.1	2019-07-21 10:38:40.345	error	at Array.forEach (<anonymous>)
    ham.1	2019-07-21 10:38:40.345	error	at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:171:14)
    ham.1	2019-07-21 10:38:40.345	error	TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
    ham.1	2019-07-21 10:38:40.343	error	uncaught exception: Class constructor homebridgeLib cannot be invoked without 'new'
    • F fisch
      Moin, moin...
      Danke Greetz
      @fisch ohne mehr Infos zu deiner konfig und deinen homebridge Plugins fürchte ich kann da keiner was sagen. Sieht mir aus wie ein Plugin Fehler.
      • F Offline
        fisch
        schrieb am zuletzt editiert von fisch
        ok, so wie es aussieht handelt sich um das plugin homebridgelib, welches ich installiert habe...wie kann ich das wieder löschen?
        ok ich habs
        npm uninstall homebridge-wieauchimmer
        F 1 Antwort Letzte Antwort
        • F fisch
          ok ich habs
          fisch
          ok, doch noch eine Frage...
          wo finde ich die homebridge.log wenn ich die lokale Version via ham installiert habe?
          • F fisch
            @fisch Nirgends ... wenn Du die Adapter-Instanz auf "Debug" stellst kommt genau dieses Log ins ioBroker-Log
            • apollon77A apollon77
              fisch
              @apollon77
              Ol, danke dir für die Info!!!
              Ingo , wenn ick den Adapter homebridge-lib installiere kommt die Fehlermeldung von oben und ham verhindert den Start bzw. bricht ab.
              Deinstallliere ich diesen wieder, startet ham einwandfrei durch. Das heißt für mich, dass der Adapter das Problem ist -oder liege ich da falsch?
              Kann man herausfinden wo es genau hakt?
              Besten Dank!!
              Grüße nach KA aus OG 😉
              • F fisch
                @apollon77
                Besten Dank!!
                @fisch ich denke du meinst „plugin“ und nicht adapter oder?
                Hast du mal den Link zu dem Plugin was Probleme macht?
                • F Offline
                  fisch
                  Mmmm ganz genau ich meine das Plugin 🙈
                  Link kommt gleich ...
                  https://github.com/ebaauw/homebridge-lib
                  Das wird für folgendes Plugin benötigt....
                  https://github.com/ebaauw/homebridge-hue/blob/master/README.md
                  • F fisch
                    @fisch Welche Versionen hast du ... ich sehe Dinge wie:
                    https://www.gitmemory.com/issue/ebaauw/homebridge-lib/11/502158619
                      fisch
                      @apollon77
                      ich habe die homebridge-lib@4.3.0 und die homebridge-lib@4.2.9 getestet...
                      es kommt beim Starten leider immer diese Meldung:
                      host.samsung	2019-07-22 12:13:11.606	error	instance system.adapter.ham.1 terminated with code 0 (OK)
                      Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                      Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                      Caught	2019-07-22 12:13:11.605	error	by controller[5]: at Socket.that.objects.getObjectView (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2693:25)
                      Caught	2019-07-22 12:13:11.604	error	by controller[5]: at adapter.getDevices (/opt/iobroker/node_modules/iobroker.ham/main.js:177:27)
                      Caught	2019-07-22 12:13:11.604	error	by controller[5]: at loadExistingAccessories (/opt/iobroker/node_modules/iobroker.ham/main.js:276:39)
                      Caught	2019-07-22 12:13:11.604	error	by controller[5]: at Object.start (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:279:14)
                      Caught	2019-07-22 12:13:11.604	error	by controller[5]: at new Server (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:57:24)
                      Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server._loadPlugins (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:145:22)
                      Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Array.forEach (<anonymous>)
                      Caught	2019-07-22 12:13:11.603	error	by controller[5]: at Server.<anonymous> (/opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge/lib/server.js:171:14)
                      Caught	2019-07-22 12:13:11.603	error	by controller[5]: TypeError: Class constructor homebridgeLib cannot be invoked without 'new'
                      Caught	2019-07-22 12:13:11.602	error	by controller[4]: [2019-7-22 12:13:11] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-lib requires Node version of ^10.16.0 which does not satisfy the current Node version of
                      Caught	2019-07-22 12:13:11.602	error	by controller[3]: [2019-7-22 12:13:10] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-hue requires Node version of ^10.16.0 which does not satisfy the current Node version of
                      Caught	2019-07-22 12:13:11.602	error	by controller[2]: [2019-7-22 12:13:09] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-lib' since we already loaded the same plugin from '/opt/iobroker/node_modules/iobroker.ham/n
                      Caught	2019-07-22 12:13:11.601	error	by controller[1]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                      Caught	2019-07-22 12:13:11.600	error	by controller[0]: [2019-7-22 12:13:08] Plugin /opt/iobroker/node_modules/iobroker.ham/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                      ham.1	2019-07-22 12:13:11.582	info	terminating
                      ah ich glaube es liegt an der Node Version! Ich brauch 10.16.0...
                      • F fisch
                        @apollon77
                        @fisch seems so :-)
                          @fisch seems so :-)
                          fisch
                          @apollon77
                          mmmm jetzt suche ich mal die Doku..wie ich das ohne zerschiessen hinbekomme :-), dass ich node update machen kann..habe da immer etwas Bammel.
                          mmm leider scheint der link nicht zu gehen...
                          https://www.iobroker.net/docu/?page_id=8323&lang=de#Upgrade_von_nodejs_und_npm
                          • apollon77A Offline
                            https://forum.iobroker.net/topic/22867/how-to-node-js-für-iobroker-richtig-updaten
                              fisch
                              @apollon77
                              super danke...
                              leider gibt es für den host keine node10...naja dann muss ich es wohl auf dem pi versuchen...
                              Plattform: linux
                              Die Architektur: ia32
                              CPUs: 4
                              Geschwindigkeit: 1000 MHz
                              Modell: Intel(R) Atom(TM) CPU N550 @ 1.50GHz
                              RAM: 1.9 GB
                              System uptime: 00:24:05
                              Node.js: v8.16.0
                              NPM: 6.4.1
                              Festplattengröße: 226.3 GiB
                              Festplatten frei: 220.2 GiB
                              Adapter zählen: 282
                              Uptime: 00:01:28
                              Aktivierte Instanzen: 7
                              • SBorgS Offline
                                SBorgS Offline
                                SBorg
                                @fisch sagte in [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar:
                                = Linux 32Bit
                                Node >=10 läuft nur auf Linux 64 Bit :(
                                LG SBorg ( SBorg auf GitHub)
                                • SBorgS SBorg
                                  = Linux 32Bit
                                  fisch
                                  @SBorg
                                  mmm das habe och mir schon gedacht.... ist das nur aktuell so oder kann da auch mal nich was kommen?
                                  • SBorgS Offline
                                    SBorgS Offline
                                    SBorg
                                    Zumindest, man mag es eigentlich nicht so recht glauben, für Windows gibt es auch eine 32 Bit Variante.
                                    Man könnte sich aber, wenn man so diversen Quellen glauben schenken mag, eine funktionsfähige 32 Bit Version aus den Sourcen selbst bauen.
                                    Leider kann man Linux 32 Bit auch nicht so ohne weiteres auf 64 Bit upgraden, da hilft eigentlich nur Neuinstallation.
                                      Denzel1994
                                      schrieb am zuletzt editiert von Denzel1994
                                      ich habe mich jetzt auch mal für den lokalen Modus des Adapters entschieden.
                                      Mein Problem besteht allerdings mit dem homebridge-samsung-tizen Plugin.
                                      Auf meiner alten Homebridge Installation lief das Ganze mit einer identischen Config problemlos.
                                      Im ham-adapter wird allerdings weder ein Objekt für ioBroker angelegt, noch kriege ich den Fernseher in HomeKit hinzugefügt. Die Homebridge-Bridge war nach Eingabe des Pins sofort drin in HomeKit.
                                      Wenn man versucht den Fernseher hinzuzufügen und den Pin eingibt (= Bridge-Pin) passiert in HomeKit nichts und in ioBroker stürzt der Adapter ab und im Log bekomme ich folgende Meldung:
                                      Und hier nochmal meine Config.
                                        "bridge": {
                                          "name": "Homebridge",
                                          "username": "CC:22:3D:E3:CE:99",
                                          "port": 51826,
                                          "pin": "090-99-090"
                                        "accessories": [],
                                        "platforms": [
                                            "platform": "config",
                                            "name": "Config-UI-X",
                                            "port": 8080,
                                            "restart": "sudo systemctl restart homebridge",
                                            "log": "systemd",
                                            "theme": "blue"
                                            "platform": "SamsungTizen",
                                            "devices": [
                                                "name": "Wohnzimmer TV",
                                                "ip": "192.168.178.25",
                                                "mac": "7C:64:22:A2:6E:XQ",
                                                "inputs": [
                                                    "name": "Live TV",
                                                    "type": "command",
                                                    "value": [
                                                      "KEY_SOURCE",
                                                      "KEY_LEFT*3",
                                                      "KEY_ENTER"
                                                    "name": "Netflix",
                                                    "type": "app",
                                                    "value": "11101200001"
                                                    "name": "Amazon Prime",
                                                    "type": "app",
                                                    "value": "3201512006785"
                                                    "name": "YouTube",
                                                    "type": "app",
                                                    "value": "111299001912"
                                        @Denzel1994 sagte in [Aufruf] HAM (Homebridge) Adapter 1.1.1 verfügbar:
                                        hm ... also du es stand alone getestst hast war die Homebridge version die gleiche wie im Lokalen Modus? Wir nutzen 0.4.50.
                                        Der Fehler scheint mir irgendwie tief aus node-Hap zu kommen und die haben in den letzten Versionen die verschlüsselung umgebaut.
                                        Kannst Du mal schaen ob es mit der 0.4.50 ausserhalb von ioBroker noch läuft?
                                          Denzel1994
                                          @apollon77 Also die Homebridge hab ich gestern testweise installiert. Ist also die aktuelle 0.4.50. Version gewesen auf der ich das getestet habe.
