  4. IoBroker.scenes
    5.6k
IoBroker.scenes
64 Beiträge 14 Kommentatoren 20.1k Aufrufe
  • ruhr70R Offline
    ruhr70R Offline
    ruhr70
    Die Installation ging irgendwie schief :(
    root@iobroker:~# cd /opt/iobroker
    root@iobroker:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
    > iobroker.scenes@0.0.1 install /opt/iobroker/node_modules/iobroker.scenes
    > node main.js --install
    2015-08-04 21:50:26.430  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
    ^Croot@iobroker:/opt/iobroker# 2015-08-04 21:51:43.404  - info: scenes.0 terminating
    nach 1,5 Minuten mit strg + c abgebrochen
    dann, trotzdem mutig:
    root@iobroker:/opt/iobroker# ./iobroker add scenes
    install adapter scenes
    npm install --production --prefix "/opt/iobroker/node_modules/iobroker.scenes" (System call)
    npm WARN cannot run in wd iobroker.scenes@0.0.1 node main.js --install (wd=/opt/iobroker/node_modules/iobroker.scenes)
    got /opt/iobroker/node_modules/iobroker.scenes/admin
    upload [4] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/words.js words.js application/javascript
    upload [3] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.js tab.js application/javascript
    upload [2] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/tab.html tab.html text/html
    upload [1] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/scenes.png scenes.png image/png
    upload [0] scenes.admin /opt/iobroker/node_modules/iobroker.scenes/admin/index.html index.html text/html
    object system.adapter.scenes created
    create instance scenes
    object system.adapter.scenes.0.uptime created
    object system.adapter.scenes.0.memRss created
    object system.adapter.scenes.0.memHeapTotal created
    object system.adapter.scenes.0.memHeapUsed created
    object system.adapter.scenes.0.connected created
    object system.adapter.scenes.0.alive created
    object system.adapter.scenes.0 created
    seitdem komme ich nicht mehr auf ioBroker/admin :(
    es lädt nur eine weiße Seite, zwischendurch dreht sich mal kurz das Zahnrad.
    ioBroker habe ich mit stop/start einmal neu gestartet
    VIS, VIS Edit, Flot,funktionieren
      Danach taucht gar nichts mehr auf 😢
      bleibt hier irgendwie hängen:
      root@quad-pi:/opt/iobroker# npm install https://github.com/ioBroker/ioBroker.scenes/tarball/master
      npm http GET https://github.com/ioBroker/ioBroker.scenes/tarball/master
      npm http 200 https://github.com/ioBroker/ioBroker.scenes/tarball/master
      2015-08-04 21:52:09.531  - info: scenes.0 starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.scenes
      wenn ich vorher iobroker stoppe:
      root@quad-pi:/opt/iobroker# iobroker stop
      Stopping ioBroker controller daemon...
      ioBroker controller daemon stopped.
      2015-08-04 21:50:14.388  - warn: scenes.0 no connection to objects DB
      iobroker.scenes@0.0.1 node_modules/iobroker.scenes
      Da kommt er wenigstens wieder zu sich ;-)
      auf den admin komme ich nicht mehr, auch kein drehendes Zahnrad (nur ganz kurz - dann alles weiß)
      Zweimal CTRL-C dann: adapter scenes terminating
      und jetzt kann ich eingeben:
      root@quad-pi:/opt/iobroker# iobroker add scenes
      root@quad-pi:/opt/iobroker# reboot
      Nach dem reboot auch nichts mehr.
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        Du hast von mir abgeschrieben ;-)
        bei mir ist es nur leider das Produktivsystem :-(
          @ruhr70:
          bei mir ist es nur leider das Produktivsystem :-( `
          Dito!!!
          • P Offline
            pix
            Trau mich jetzt gar nicht, zu testen. Hab nur das Produktivsystem.
            Gesendet von meinem iPhone mit Tapatalk
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              root@iobroker:/opt/iobroker# ./iobroker del scenes
              delete /opt/iobroker/node_modules/iobroker.js-controller/lib/../../iobroker.scenes
              Counted 1 instances of scenes
              Counted 6 states (system.adapter.scenes.*) from states
              Counted 1 adapters for scenes
              Counted 6 states of scenes
              Deleting 8 object(s).
              root@iobroker:/opt/iobroker# ./iobroker stop
              root@iobroker:/opt/iobroker# ./iobroker start
              Starting ioBroker controller daemon...
              ioBroker controller daemon started. PID: 5115
              hat geholfen…
              • ruhr70R Offline
                ruhr70R Offline
                ruhr70
                pix, Du hattest doch immer geschrieben… Datensicherung, Datensicherung, ...
                trau Dich :twisted: :)
                Das mit den Szenen ist schon cool.
                  Da bist du mir schon wieder zuvorgekommen!
                  ich geh jetzt ins Bett, es läuft ja wieder.
                  • BluefoxB Offline
                    BluefoxB Offline
                    Installation habe ich jetzt gefixt.
                    Mit neuer Version vom admin sehe ich das Problem nicht mehr:
                    cd /opt/iobroker
                    npm install https://github.com/ioBroker/ioBroker.admin/tarball/master
                    iobroker add scenes
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      Funktioniert! Sieht aus, als ob der Adapter Potential hat!
                      Man kann wunderbar die Szenen definieren, für true und für false. Mit dem aktuellen hue Adapter können auch die hue Lampen ganz gezielt eingestellt werden.
                      Sieht klasse aus!
                      Jetzt geht ich erst einmal schlafen. Morgen teste ich damit. Gefällt mir auf jeden Fall bisher sehr gut :-)
                      • P Offline
                        pix
                        ich habe mich getraut und wurde belohnt.Ich bin begeistert. :D
                        Ein paar Fragen zum Verständnis:
                        Kann man Gruppen, wie Direktverknüpfungen verstehen?
                        Werden die festgelegten States bei der Realisierung einer Scene im Burstmodus gesetzt (Funkhygiene) oder irgendwie nacheinander?
                        Macht es Sinn zB Abwesenheit als Szene oder als Gruppe zu beschreiben (alle Lichter aus, einzelne [nicht alle] Geräte aus, Anwesenheit=aus, Alarmanlage=aus [Delay 45s])?
                        Auf jeden Fall ein Top-Geschichte, die sehr viel Scripte spart.
                        Kleine Anregeung: Bitte die Spalte "Name" etwas breiter (auf Kosten der flexiblen Spalte Beschreibung).
                        Pix
                        • P Offline
                          pix
                          Noch eine Kleinigkeit:
                          Wenn ich Zustände erneut hinzufüge (mit dem + Button), werden die bisher schon hinzugefügten noch einmal zugefügt.
                          Pix
                          • P Offline
                            pix
                            Es gibt wohl doch etwas mehr Probleme:
                            2015-08-04 23:13:30.213  - info: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 started with pid 43079
                            2015-08-04 23:13:30.844  - info: scenes.0 starting. Version 0.0.1 in /Users/pix/Desktop/iobroker/node_modules/iobroker.scenes
                            2015-08-04 23:14:46.609  - error: uncaught exception: Cannot call method 'toString' of undefined
                            2015-08-04 23:14:46.613  - error: TypeError: Cannot call method 'toString' of undefined
                                at checkTrigger (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:187:118)
                                at Adapter.id (/Users/pix/Desktop/iobroker/node_modules/iobroker.scenes/main.js:32:17)
                                at Adapter.emit (events.js:98:17)
                                at null._onTimeout (/Users/pix/Desktop/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1865:34)
                                at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                            2015-08-04 23:14:46.920  - error: host.MacMini-Ethernet.fritz.box instance system.adapter.scenes.0 terminated with code 6 (uncaught exception)
                            Lasse es erstmal dabei. Morgen gehts weiter ;)
                            • BluefoxB Offline
                              BluefoxB Offline
                              @pix:
                              Lasse es erstmal dabei. Morgen gehts weiter ;) `
                              Danke. Im letzen Moment eingebaute Debug-Outputs haben versagt.
                              jetzt sollte gehen.
                              Ja
                              Das ist die Aufgabe von hm-rpc Adapter. Obwohl falls es wirklich nicht geht, ich kann eine Einstellung einbauen: Intervall zwischen Befehlen.
                              Alarmanlage=ein ?
                              Ja, genau das.
                              Sollte auch gefixt werden.
                              Nicht vergessen nach update einen Upload aufrufen.
                              iobroker upload scenes
                              • ruhr70R Offline
                                ruhr70R Offline
                                ruhr70
                                Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt.
                                • BluefoxB Offline
                                  BluefoxB Offline
                                  @ruhr70:
                                  Die Objekte (Szenen) werden nicht in einer Baumstruktur abgelegt, wie bei den anderen Adapter. Für jede Szene wird in Ebene 1 in den Objekten eine neue Zeile erzeugt. `
                                  Na ja. Um eine Ebene zu erschaffen, braucht ein Objekt zwei stufen zu haben.
                                  Falls du deine Szenen "common.szene1" und "common.szene2" nennst, dann wird es gruppiert.
                                  Ich kann wirklich machen, dass die Szenen erst mal unter "scene.all" abgelegt werden.
                                  Oder ich werde machen, dass alle Szenen "scenes.scene.xxx" heißen. Bin noch nicht schlüssig.
                                  GEHT das überhaupt?
                                  • ruhr70R Offline
                                    ruhr70R Offline
                                    ruhr70
                                    Ich dachte an scenes.0
                                    Aber jetzt wo Du das schreibt, ist mir gerade bewusst geworden, dass man die Szenennamen mit bedacht wählen sollte. Wenn man sie fleissig verwendet (Vis, Javascript, suw.) und dann auf die Idee kommt, die Szenen umzubenennen, bzw. die Namen neu zu strukturieren, stimmen alle Datenpunkte nicht mehr (Vis, Javascript, usw).
                                    @Bluefox:
                                    GEHT das überhaupt? `
                                    • BluefoxB Offline
                                      BluefoxB Offline
                                      > GEHT das überhaupt?
                                      Geht iobroker.scenes? Kannst du was schalten damit?
                                      scenes.0 geht nicht, weil man kann mehrere scenes Adapterinstanzen haben (weiß noch nicht wozu :lol: ) und man kann jede Szene zu einer Instanz zuweisen.
                                      Dann kommt so was wie scene.0.blabla wird auf dem Adapter scenes.1 ausgeführt. Verwirrt.
                                      Richtig…
                                      Also "scenes.scene.blabla" ?
                                      • BluefoxB Offline
                                        BluefoxB Offline
                                        Es gibt neue Version. Man muss aber die Szenen neu konfigurieren.
                                        • ruhr70R Offline
                                          ruhr70R Offline
                                          ruhr70
                                          @Bluefox:
                                          > GEHT das überhaupt?
                                          Geht iobroker.scenes? Kannst du was schalten damit? `
                                          ja, geht :-)
