  4. ioBroker.upnp - please test
    6.6k
testadapter
196 Beiträge 18 Kommentatoren 40.9k Aufrufe 17 Beobachtet
  • Jey CeeJ Jey Cee
    @sigi234 das ist doch aber nur info von der Fritz Box oder?
    sigi234S Online
    sigi234S Online
    #177
    @Jey-Cee sagte in ioBroker.upnp - please test:
    Nein, Daten kommen vom Adapter
    • crunchipC Offline
      crunchipC Offline
      #178
      vllt kann mir hier jemand helfen, hatte schon einen Thread eröffnet aber bisher keine Hilfe.
      2019-07-07 00:49:31.614 - error: upnp.0 uncaught exception: Cannot read property 'match' of undefined
      2019-07-07 00:49:31.615 - error: upnp.0 TypeError: Cannot read property 'match' of undefined
      at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
      at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
      at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: TypeError: Cannot read property 'match' of undefined
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1390:28)
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      2019-07-07 00:49:32.647 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      2019-07-07 00:49:32.648 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      2019-07-07 00:49:32.648 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
      2019-07-07 00:49:32.648 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
      BluefoxB 1 Antwort Letzte Antwort
        BluefoxB Offline
        BluefoxB Offline
        #179
        @crunchip Version upnp?
        sigi234S crunchipC 2 Antworten Letzte Antwort
        • BluefoxB Bluefox
          sigi234S Online
          sigi234S Online
          #180
          @Bluefox
          version 1.0.12 laut Thread
          • BluefoxB Bluefox
            crunchipC Offline
            crunchipC Offline
            #181
            @Bluefox ja wie @sigi234 schon geschrieben
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              #182
              @crunchip kannst du mal den Adapter löschen und von Github neu installieren? Der Fehler sollte jetzt abgefangen werden und im Log wird ausgegeben bei welchem Objekt das Passiert.
              Persönlicher Support
              Spenden -> paypal.me/J3YC33
              crunchipC 3 Antworten Letzte Antwort
              • Jey CeeJ Jey Cee
                crunchipC Offline
                crunchipC Offline
                #183
                @Jey-Cee ok, werd ich laufe des Tages mal machen und berichten
                • Jey CeeJ Jey Cee
                  crunchipC Offline
                  crunchipC Offline
                  #184
                  @Jey-Cee hab nun istalliert von git
                  was mir noch eingefallen ist, früher wurden die sky receiver mit gelistet, die aber seit der umstellung auf community nicht mehr im Verzeichnisbaum erscheinen
                  nur im log zu sehen unendlich fortlaufend
                  upnp.0	2019-07-09 16:36:39.575	info	Found new device: http://192.168.xxx.xx:49153/description17.xml
                  upnp.0	2019-07-09 16:36:37.771	info	Found new device: http://192.168.xxx.xx:49153/description8.xml
                    Jey CeeJ Online
                    Jey CeeJ Online
                    Jey Cee
                    #185
                    @crunchip die Meldung hat nix mit dem Fehler zu tun. Wohin gehören den die IP Adressen? Er scheint die Geräte zu finden kann sie aber nicht anlegen und deshalb kommt die Meldung immer wieder.
                    Du kannst auch die XML datei im Browser aufrufen, da steht drin zu welchem Gerät/Dienst sie gehört, das hilft vielleicht auch weiter.
                    • Jey CeeJ Jey Cee
                      crunchipC Offline
                      crunchipC Offline
                      #186
                      @Jey-Cee das sind meine beiden sky -receiver.
                      wie gesagt, mit dem alten upnp Adapter wurden diese beiden angelegt, seit der Umstellung des Adapters wird nichts mehr angelegt
                      aufrufen kann ich da nichts
                        Jey CeeJ Online
                        Jey CeeJ Online
                        Jey Cee
                        #187
                        @crunchip und da haben wir das problem, warum die nicht erkannt werden. Der Zugriff auf die XML ist notwendig um die Geräte an zu legen.
                        • Jey CeeJ Jey Cee
                          crunchipC Offline
                          crunchipC Offline
                          #188
                          @Jey-Cee so sehen nun meine Fehler aus
                          einzigste ist, das nun nicht mehr jeden Tag, die Fehlermeldungen kommen
                          2019-07-15 07:54:51.629 - error: upnp.0 uncaught exception: Cannot read property 'LastChange' of undefined
                          2019-07-15 07:54:51.630 - error: upnp.0 TypeError: Cannot read property 'LastChange' of undefined
                          at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
                          2019-07-15 07:54:52.664 - error: Caught by controller[0]: TypeError: Cannot read property 'LastChange' of undefined
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at setNewState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1384:70)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.adapter.getState (/opt/iobroker/node_modules/iobroker.upnp/main.js:1361:17)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                          2019-07-15 07:54:52.665 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                          2019-07-15 07:54:52.666 - error: Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                          2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS. (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                          2019-07-15 07:54:52.666 - error: Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                          2019-07-15 07:54:52.666 - error: host.IoBroker instance system.adapter.upnp.0 terminated with code 6 (uncaught exception)
                          2019-07-15 07:54:52.666 - info: host.IoBroker Restart adapter system.adapter.upnp.0 because enabled
                          2019-07-15 07:55:22.691 - info: host.IoBroker instance system.adapter.upnp.0 started with pid 30593
                          2019-07-15 07:55:24.266 - info: upnp.0 starting. Version 1.0.13 in /opt/iobroker/node_modules/iobroker.upnp, node: v10.16.0
                          2019-07-15 07:55:24.300 - info: upnp.0 Auto discover: false
                            Andre R.
                            #189
                            kann ich die Geräte die ich nicht brauche unter Objekte eigentlich löschen?
                            • SBorgS Offline
                              SBorgS Offline
                              SBorg
                              #190
                              Ich sag mal Jein. Löschen an sich stellt kein Problem dar, nur wenn das entsprechende Gerät selbst UPnP macht, werden sie erneut angelegt ;)
                              LG SBorg ( SBorg auf GitHub)
                              • A Andre R.
                                sigi234S Online
                                sigi234S Online
                                #191
                                @Andre-R sagte in ioBroker.upnp - please test:
                                Ja, aber beim Adapter die automatische Erkennung ausschalten..........
                                • sigi234S sigi234
                                  Andre R.
                                  #192
                                  @sigi234
                                  hab ich eh abgeschalten
                                    BluefoxB Offline
                                    BluefoxB Offline
                                    #193
                                    @crunchip Fehler gefixt
                                    • BluefoxB Bluefox
                                      crunchipC Offline
                                      crunchipC Offline
                                      #194
                                      @Bluefox dann test ich mal
                                      • Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        #195
                                        Auf github liegt die Version 1.0.15 zum Testen bereit.
                                        Ich hab einen Fehler gefixt der verhindert hat das Befehle mit Parametern ausgeführt werden.
                                        • Jey CeeJ Jey Cee
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #196
                                          Test läuft.
                                          A.
