  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
    1.0k
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.8k Aufrufe 2 Beobachtet
  • M mrMuppet
    @AlCalzone aber das sind doch immer noch keinen funktionierenden Befehle oder?
    root@iobroker_v2:~ # name="iobroker"
    name=iobroker: Command not found
    mrMuppet
    schrieb am zuletzt editiert von mrMuppet
    @mrMuppet
    root@iobroker_v2:~ # rcvar="iobroker_enable"
    rcvar=iobroker_enable: Command not found.
    root@iobroker_v2:~ # iobroker_enable=${iobroker_enable-"NO"}
    Missing '}'.
    root@iobroker_v2:~ # iobroker_pidfile=${iobroker_pidfile-"/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid"}
    Missing '}'.
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • M mrMuppet
      @mrMuppet
      Missing '}'.
      Missing '}'.
      mrMuppet
      @mrMuppet
      root@iobroker_v2:~ # PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
      PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid: Command not found.
      root@iobroker_v2:~ # NODECMD=$(which node)
      Illegal variable name.
      root@iobroker_v2:~ # iobroker_start ()
      Badly placed ()'s.
      root@iobroker_v2:~ # {
      {: Command not found.
      root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
      NODECMD: Undefined variable.
      root@iobroker_v2:~ # }
      }: Command not found.
      M AlCalzoneA 2 Antworten Letzte Antwort
      • M mrMuppet
        @mrMuppet
        Badly placed ()'s.
        mrMuppet
        jetzt hab ich sie glaube ich durch:
        root@iobroker_v2:~ # iobroker_stop ()
        Badly placed ()'s.
        root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
        root@iobroker_v2:~ # iobroker_status ()
        Badly placed ()'s.
        root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status"
        root@iobroker_v2:~ # PATH="${PATH}:/usr/local/bin"
        PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/root/bin:/usr/local/bin: Command not found.
        root@iobroker_v2:~ # pidfile="${iobroker_pidfile}"
        iobroker_pidfile: Undefined variable.
        root@iobroker_v2:~ # start_cmd=iobroker_start
        start_cmd=iobroker_start: Command not found.
        root@iobroker_v2:~ # stop_cmd=iobroker_stop
        stop_cmd=iobroker_stop: Command not found.
        root@iobroker_v2:~ #  status_cmd=iobroker_status
        status_cmd=iobroker_status: Command not found.
        • M mrMuppet
          @mrMuppet
          Badly placed ()'s.
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
          Das ist es möglicherweise!
          Die sollten Variablen setzen, aber möglicherweise geht das auf FreeBSD doch nur in Skripten?!
          • M mrMuppet
            Badly placed ()'s.
            Badly placed ()'s.
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @mrMuppet
            Ich hab da eine Idee... Das Skript soll mit /bin/sh ausgeführt werden, FreeBSD scheint es möglicherweise mit einer alternativen Shell auszuführen, die $(...befehle...) nicht versteht.
            • M mrMuppet
              Badly placed ()'s.
              Badly placed ()'s.
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @mrMuppet Habe die Änderungen gemerged. Bitte mit dem offiziellen Installationsbefehl probieren:
              curl -sL https://iobroker.net/install.sh | bash -
              • AlCalzoneA AlCalzone
                joehackerz
                @AlCalzone Hallo, hab die neue routine gerade ausprobiert, es kommt immer noch der fehler mit dem pidfile
                • J joehackerz
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @joehackerz Ok, kannst du bitte einen vollständigen Log der Installation posten?
                    joehackerz
                    @AlCalzone putty.log
                    Hab grad nochmal dann den kompletten JAil neu gemacht, hier ist das Protokoll der Installation
                    • J joehackerz
                      AlCalzoneA Offline
                      AlCalzoneA Offline
                      AlCalzone
                      @joehackerz sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
                      Verdammt - das war es dann wohl doch nicht.
                      • J joehackerz
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @joehackerz @mrMuppet
                        Bitte nochmal versuchen, diesmal mit einem neuen Branch:
                        curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix-2/installer.sh | bash -
                          mrMuppet
                          @AlCalzone scheint immer noch der selbe Fehler zu sein.
                          Pastebin
                          • M mrMuppet
                            Pastebin
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @mrMuppet :(
                            Nochmal bitte
                              @mrMuppet :(
                              Nochmal bitte
                              mrMuppet
                              @AlCalzone https://pastebin.com/84MNQsnu
                                mrMuppet
                                Hab gerade mal reingeschaut: In Zeile 770 steht was von "su" . Das kommt doch von Linux und das gibt es doch IMO bei FreeBSD nicht, oder?
                                • M mrMuppet
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  @mrMuppet Doch su müsste es geben. Anscheinend wird NODECMD nicht befüllt, somit versucht diese Zeile eine js-Datei mit Bash auszuführen. Nächster Versuch bitte ;)
                                  • M mrMuppet
                                    mrMuppet
                                    @mrMuppet https://pastebin.com/6sQ6RWRG
                                    • M mrMuppet
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #66
                                      @mrMuppet Was passiert, wenn du den Befehl von Hand ausführst?
                                      su -m iobroker -s /usr/local/bin/bash -c '/usr/local/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start'
                                        mrMuppet
                                        #67
                                        @AlCalzone keine Ahnung was da genau passiert ist:
                                        root@iobroker_v2:~ # su -m iobroker -s /usr/local/bin/bash -c '/usr/local/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start'
                                        iobroker@iobroker_v2:~ %
                                        • M mrMuppet
                                          AlCalzoneA Offline
                                          AlCalzoneA Offline
                                          AlCalzone
                                          #68
                                          @mrMuppet Der hat dich als User iobroker angemeldet und in diesem Kontext iobroker gestartet. Also genau was es tun soll... Warum die Fehlermeldung kommt ist mir schleierhaft.
                                          Ich bin übers Wochenende erst mal unterwegs. Kannst du mir solange beschreiben, wie du das Jail aufsetzt? Oder gleich ein Image ohne ioBroker drauf erstellen? Dann versuche ich das in VirtualBox zu reproduzieren. Ist einfacher wenn man selbst testet.
                                          H 1 Antwort Letzte Antwort
