  4. [SOLVED] Instal.auf FreeBSD funktioniert nicht.
    1.0k
freenasfreebsdinstaller
74 Beiträge 6 Kommentatoren 10.8k Aufrufe 2 Beobachtet
  • M mrMuppet
    @mrMuppet
    root@iobroker_v2:~ # PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid
    PIDF=/opt/iobroker/node_modules/iobroker.js-controller/lib/iobroker.pid: Command not found.
    root@iobroker_v2:~ # NODECMD=$(which node)
    Illegal variable name.
    root@iobroker_v2:~ # iobroker_start ()
    Badly placed ()'s.
    root@iobroker_v2:~ # {
    {: Command not found.
    root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start"
    NODECMD: Undefined variable.
    root@iobroker_v2:~ # }
    }: Command not found.
    mrMuppet
    jetzt hab ich sie glaube ich durch:
    root@iobroker_v2:~ # iobroker_stop ()
    Badly placed ()'s.
    root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js stop"
    root@iobroker_v2:~ # iobroker_status ()
    Badly placed ()'s.
    root@iobroker_v2:~ # su -m iobroker -s "/usr/local/bin/bash" -c "${NODECMD} /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js status"
    root@iobroker_v2:~ # PATH="${PATH}:/usr/local/bin"
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/root/bin:/usr/local/bin: Command not found.
    root@iobroker_v2:~ # pidfile="${iobroker_pidfile}"
    iobroker_pidfile: Undefined variable.
    root@iobroker_v2:~ # start_cmd=iobroker_start
    start_cmd=iobroker_start: Command not found.
    root@iobroker_v2:~ # stop_cmd=iobroker_stop
    stop_cmd=iobroker_stop: Command not found.
    root@iobroker_v2:~ #  status_cmd=iobroker_status
    status_cmd=iobroker_status: Command not found.
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    AlCalzoneA 2 Antworten Letzte Antwort
    • M mrMuppet
      @mrMuppet
      Badly placed ()'s.
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @mrMuppet sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
      Das ist es möglicherweise!
      aber das sind doch immer noch keinen funktionierenden Befehle oder?
      Die sollten Variablen setzen, aber möglicherweise geht das auf FreeBSD doch nur in Skripten?!
      • M mrMuppet
        Badly placed ()'s.
        Badly placed ()'s.
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @mrMuppet
        Ich hab da eine Idee... Das Skript soll mit /bin/sh ausgeführt werden, FreeBSD scheint es möglicherweise mit einer alternativen Shell auszuführen, die $(...befehle...) nicht versteht.
        • M mrMuppet
          Badly placed ()'s.
          Badly placed ()'s.
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @mrMuppet Habe die Änderungen gemerged. Bitte mit dem offiziellen Installationsbefehl probieren:
          curl -sL https://iobroker.net/install.sh | bash -
          • AlCalzoneA AlCalzone
            joehackerz
            @AlCalzone Hallo, hab die neue routine gerade ausprobiert, es kommt immer noch der fehler mit dem pidfile
            • J joehackerz
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @joehackerz Ok, kannst du bitte einen vollständigen Log der Installation posten?
                joehackerz
                @AlCalzone putty.log
                Hab grad nochmal dann den kompletten JAil neu gemacht, hier ist das Protokoll der Installation
                • J joehackerz
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @joehackerz sagte in Neue Installation auf FreeBSD/FreeNAS 11.2 funktioniert nicht.:
                  Verdammt - das war es dann wohl doch nicht.
                  • J joehackerz
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @joehackerz @mrMuppet
                    Bitte nochmal versuchen, diesmal mit einem neuen Branch:
                    curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/freebsd-fix-2/installer.sh | bash -
                      mrMuppet
                      @AlCalzone scheint immer noch der selbe Fehler zu sein.
                      Pastebin
                      • M mrMuppet
                        Pastebin
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @mrMuppet :(
                        Nochmal bitte
                          @mrMuppet :(
                          Nochmal bitte
                          mrMuppet
                          @AlCalzone https://pastebin.com/84MNQsnu
                            mrMuppet
                            Hab gerade mal reingeschaut: In Zeile 770 steht was von "su" . Das kommt doch von Linux und das gibt es doch IMO bei FreeBSD nicht, oder?
                            • M mrMuppet
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @mrMuppet Doch su müsste es geben. Anscheinend wird NODECMD nicht befüllt, somit versucht diese Zeile eine js-Datei mit Bash auszuführen. Nächster Versuch bitte ;)
                              • M mrMuppet
                                mrMuppet
                                @mrMuppet https://pastebin.com/6sQ6RWRG
                                • M mrMuppet
                                  AlCalzoneA Offline
                                  AlCalzoneA Offline
                                  AlCalzone
                                  #66
                                  @mrMuppet Was passiert, wenn du den Befehl von Hand ausführst?
                                  su -m iobroker -s /usr/local/bin/bash -c '/usr/local/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start'
                                    mrMuppet
                                    #67
                                    @AlCalzone keine Ahnung was da genau passiert ist:
                                    root@iobroker_v2:~ # su -m iobroker -s /usr/local/bin/bash -c '/usr/local/bin/node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js start'
                                    iobroker@iobroker_v2:~ %
                                    • M mrMuppet
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #68
                                      @mrMuppet Der hat dich als User iobroker angemeldet und in diesem Kontext iobroker gestartet. Also genau was es tun soll... Warum die Fehlermeldung kommt ist mir schleierhaft.
                                      Ich bin übers Wochenende erst mal unterwegs. Kannst du mir solange beschreiben, wie du das Jail aufsetzt? Oder gleich ein Image ohne ioBroker drauf erstellen? Dann versuche ich das in VirtualBox zu reproduzieren. Ist einfacher wenn man selbst testet.
                                      H 1 Antwort Letzte Antwort
                                        mrMuppet
                                        #69
                                        FreeNAS verwendet den Jail-manager "iocage". Deshalb baue ich meine Jails über den Befehl:
                                        echo '{"pkgs":["iobroker","ca_root_nss"]}' > /tmp/pkg.json
                                        iocage create -n "iobroker" -p /tmp/pkg.json -r 11.2-RELEASE ip4_addr="vnet0|192.168.178.167/24" defaultrouter="192.168.178.1" vnet="on" allow_raw_sockets="1" boot="on"
                                        rm /tmp/pkg.json
                                          Happz0r
                                          #70
                                          @AlCalzone gibt es hier einen neuen Stand? Ich habe leider auch die oben geschilderten Probleme :(
