  4. [gelöst] IRobot Roomba Adapter Installation
roomba
20 Beiträge 4 Kommentatoren 3.8k Aufrufe 3 Beobachtet
    adlerauge1980
    Hier noch eine Info für Zefau:
    Heute morgen erneut versucht zu installieren mit folgender Meldung:
    $ ./iobroker url "https://github.com/Zefau/ioBroker.roomba"
    install https://github.com/Zefau/ioBroker.roomba/tarball/master
    npm install https://github.com/Zefau/ioBroker.roomba/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp
     WARN Using request for node-pre-gyp https download
    node-pre-gyp
     WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.2.0/canvas-prebuilt-v2.2.0-node-v57-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.2.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp
     ERR! System Linux 4.14.79-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas-prebuilt.node" "--module_name=canvas-prebuilt" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v8.15.0gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp
     ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas-prebuilt.node --module_name=canvas-prebuilt --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR!
    stack     at maybeClose (internal/child_process.js:915:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.79-v7+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
    node-pre-gyp ERR! node -v v8.15.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm
     ERR!
     code ELIFECYCLEnpm ERR! errno 1
    npm
     ERR! canvas@2.2.0 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1
    npm ERR!
    npm ERR!
     Failed at the canvas@2.2.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-01-07T11_20_50_992Z-debug.log
    process exited with code 0</anonymous>
      adlerauge1980
      Hallo Zefau
      Danke für die Info, respektive den link (Hatte ich auf gitHub irgend wie nicht gesehen. Sorry!).
      Nach dem der erste teil nicht funktioniert hat, habe ich dies gemacht:
      If you are receiving an error message that canvas is not installed, try to install it manually in the ioBroker.roomba folder (via SSH) by running:
      sudo npm install canvas --unsafe-perm=true
      Folgende Meldung:
      pi@shserver:/opt/iobroker/node_modules/iobroker.roomba $ sudo npm install canvas                      --unsafe-perm=true
      > canvas@2.2.0 install /opt/iobroker/node_modules/iobroker.roomba/node_modules/c                     anvas
      node-pre-gyp WARN Using request for node-pre-gyp https download
      node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canva                     s-prebuilt/releases/download/v2.2.0/canvas-prebuilt-v2.2.0-node-v57-linux-glibc-                     arm.tar.gz
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.roomba/node_modules/canva                     s/build“ wird betreten
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
      ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8                     _t*, int, uint8_t*)’:
      ../src/bmp/BMPParser.cc:193:16: warning: comparison between signed and unsigned                      integer expressions [-Wsign-compare]
         E(ptr - data > imgdOffset, "image data overlaps with another structure");
      ../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’
       #define E(cond, msg) if(cond) return setErr(msg)
      ../src/bmp/BMPParser.cc:208:27: warning: comparison between signed and unsigned                      integer expressions [-Wsign-compare]
         E(ptr - data + imgdSize > len, "not enough image data");
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
      ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_S                     ETTER_RETURN_TYPE Context2d::SetFillStyle(v8::Local<v8::string>, v8::Local<v8::v alue="">, Nan::NAN_SETTER_ARGS_TYPE)’:
      ../src/CanvasRenderingContext2d.cc:1763:18: warning: variable ‘ctx’ set but not                      used [-Wunused-but-set-variable]
         Local <context>ctx = Nan::GetCurrentContext();
      ../src/CanvasRenderingContext2d.cc: In static member function ‘static Nan::NAN_S                     ETTER_RETURN_TYPE Context2d::SetStrokeStyle(v8::Local<v8::string>, v8::Local<v8: :value="">, Nan::NAN_SETTER_ARGS_TYPE)’:
      ../src/CanvasRenderingContext2d.cc:1810:12: warning: unused variable ‘iso’ [-Wun                     used-variable]
         Isolate *iso = Isolate::GetCurrent();
      ../src/CanvasRenderingContext2d.cc:1811:18: warning: variable ‘ctx’ set but not                      used [-Wunused-but-set-variable]
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadFromBuffer(uint8_                     t*, unsigned int)’:
      ../src/Image.cc:323:47: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
         this->errorInfo.set("Unsupported image type");
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadSurface()’:
      ../src/Image.cc:442:55: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
           this->errorInfo.set(NULL, "fopen", errno, filename);
      ../src/Image.cc:504:47: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadGIF(FILE*)’:
      ../src/Image.cc:570:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
           this->errorInfo.set(NULL, "malloc", errno);
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadGIFFromBuffer(uin                     t8_t*, unsigned int)’:
      ../src/Image.cc:623:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc: In member function ‘cairo_status_t Image::decodeJPEGIntoSurface                     (jpeg_decompress_struct*)’:
      ../src/Image.cc:809:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc:818:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc:847:54: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
             this->errorInfo.set("Unsupported JPEG encoding");
      ../src/Image.cc: In member function ‘cairo_status_t Image::decodeJPEGBufferIntoM                     imeSurface(uint8_t*, unsigned int)’:
      ../src/Image.cc:936:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc: In member function ‘cairo_status_t Image::assignDataAsMime(uint                     8_t*, int, const char*)’:
      ../src/Image.cc:985:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc:992:46: warning: ISO C++ forbids converting a string constant to                      ‘char*’ [-Wwrite-strings]
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadJPEG(FILE*)’:
      ../src/Image.cc:1098:48: warning: ISO C++ forbids converting a string constant t                     o ‘char*’ [-Wwrite-strings]
      ../src/Image.cc: In member function ‘cairo_status_t Image::loadBMP(FILE*)’:
      ../src/Image.cc:1293:40: warning: ISO C++ forbids converting a string constant t                     o ‘char*’ [-Wwrite-strings]
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        CXX(target) Release/obj.target/canvas/src/toBuffer.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
      make: Verzeichnis „/opt/iobroker/node_modules/iobroker.roomba/node_modules/canva                     s/build“ wird verlassen
      npm notice created a lockfile as package-lock.json. You should commit this file.
      + canvas@2.2.0
      added 169 packages from 133 contributors and audited 485 packages in 111.676s
      found 0 vulnerabilities
      pi@shserver:/opt/iobroker/node_modules/iobroker.roomba $</context></v8:></v8::string></context></v8::v></v8::string>
      Dann unter ioBroker erneut versucht "aus eigenem Link" zu installieren (Wie oben beschrieben)
      Folgende ausgabe erhalte ich:
      Fertig mit Fehler: host.shserver Cannot install https://github.com/Zefau/ioBroker.roomba/tarball/master: 243
      npm
       WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrevnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ansi-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/aproba
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/assert-plus
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/async-limiter
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/asynckit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/aws-sign2
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/aws4
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/balanced-match
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/bluebird
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/buffer-from
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/caseless
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/chownr
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/code-point-at
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/commist/node_modules/minimistnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/concat-map
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/brace-expansion
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/console-control-strings
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/core-util-is
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/dashdash
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/deep-extend
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/delayed-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/combined-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/delegates
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/detect-libcnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/extend
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/extsprintf
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/fast-deep-equal
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/fast-json-stable-stringify
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/forever-agent
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/fs.realpath
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/getpass
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/har-schema
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/has-unicode
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/inherits
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ini
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-extglob
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-glob
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-negated-glob
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-typedarray
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-windows
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/isarray
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/isstream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/jsbn
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/json-schema
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/json-schema-traverse
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/json-stable-stringify-without-jsonify
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/json-stringify-safe
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/leven
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/commist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/lodash
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mime-db
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mime-types
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/form-datanpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/minimatch
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ignore-walk
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/minimist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mkdirp
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mqtt/node_modules/minimist
      npm WARN
      checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/msnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/debug
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/nan
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/next-tick
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/es5-ext
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/es6-symbol
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/es6-iterator
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/event-emitter
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/es6-set
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/es6-map
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/npm-bundled
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/npm-packlist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/number-is-nan
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-fullwidth-code-point
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/oauth-sign
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/object-assign
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/os-homedir
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/os-tmpdir
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/osenv
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/nopt
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/path-dirname
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/glob-parent
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/path-is-absolutenpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/performance-now
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/process-nextick-args
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/psl
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/punycode
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/qsnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/rc/node_modules/minimist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/reinterval
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/remove-trailing-separator
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/request-promise-core
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/safe-buffer
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/safer-buffer
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/asn1
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ecc-jsbn
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/iconv-lite
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/sax
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/needle
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/semvernpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/set-blocking
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/signal-exit
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/stealthy-require
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/stream-shift
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/string_decodernpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/strip-ansi
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/string-width
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/strip-json-comments
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/tough-cookie/node_modules/punycode
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/tunnel-agent
      npm WARN
      checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/tweetnaclnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/bcrypt-pbkdf
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/sshpk
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/typedarray
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ultron
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/unc-path-regex
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-unc-path
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-relative
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/is-absolutenpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/to-absolute-glob
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/uri-js
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ajv
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/har-validator
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/util-deprecate
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/readable-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/are-we-there-yet
       Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/blnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mqtt-packet
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/callback-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/concat-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ordered-read-streams
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/uuid
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/verror
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/jsprim
       Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/http-signaturenpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/request
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/wide-align
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/gauge
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/npmlog
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/wrappy
      npm
      WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/oncenpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/end-of-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/duplexify
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/inflight
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/rimraf
      npm WARN
      checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/pumpnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/pumpify/node_modules/pump
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/ws
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/xtend
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/through2
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/split2
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/through2-filter
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/unique-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/glob-stream
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/help-me
      npm
       WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/websocket-streamnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/mqtt
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/yallist
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/minipass
       Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/fs-minipassnpm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/minizlib
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/tar
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/node-pre-gyp
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/canvas
      npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.roomba/node_modules/commist/node_modules
      npm
       ERR! path /opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrevnpm ERR! code EACCES
      npm
       ERR! errno -13npm ERR! syscall access
      npm
       ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrev'npm ERR!  { Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrev'
      npm ERR!   stack: 'Error: EACCES: permission denied, access \'/opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrev\'',
      npm ERR!   errno: -13,
      npm ERR!   code: 'EACCES',
      npm ERR!   syscall: 'access',
      npm ERR!
         path: '/opt/iobroker/node_modules/iobroker.roomba/node_modules/abbrev' }npm ERR!
      npm ERR! The operation was rejected by your operating system.
      npm ERR! It is likely you do not have the permissions to access this file as the current user
      npm ERR!
      npm ERR! If you believe this might be a permissions issue, please double-check the
      npm
       ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-01-09T12_31_32_609Z-debug.log
      ERROR: host.shserver Cannot install https://github.com/Zefau/ioBroker.roomba/tarball/master: 243
      • ZefauZ Offline
        ZefauZ Offline
        Zefau
        Er versucht canvas zu installieren und findet die dependencies nicht.
        Hast du diese mit folgendem Befehl vorher installiert?
        sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
        Dann sollte es gehen.
        Ansonsten sag mir mal die Plattform auf der du unterwegs bist (Raspberry?) und Node.js / npm version. Node.js muss mindestens v6 sein!
          adlerauge1980
          hallo Zefau
          Ich war nicht sicher ob ich dies genau mit diesem Befehl ausgeführt hatte, deshalb habe ich dies nochmals gemacht:
          Meldung:
          Anschliessend nochmals versucht über IO-Broker zu Installieren, gleiche Meldung wie im vorherigen Post.
          Betreffend Nodes und co:
          Sieht meiner Meinung nach auch gut aus.
          Ich habe folgende Installation, Installationsablauf:
          -Raspbian Stretch Lite (Images auf SD Karte geschrieben) Auf einem Raspberry Pi 3
          • install node /nodejs
          • ioBroker installiert mit dem Nachfolgenden Befehl aus der IoBroker Installationsanleitung (Zitat Anleitung; Die Installation kann mit dem User pi aber auch mit dem User root erfolgen -> Ich habe dies mit dem User Pi gemacht):
          curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash -
          Ich habe eine Vermutung, weiss aber nicht wie prüfen:
          über Konsole bin ich mit pi angemeldet. Canvas habe also unter Pi mit sudo installiert. ioBroker scheint aber einen User ioBroker zu nuten. Kann er deshalb evt. Canvas nicht finden?
          Ich kommen auf diese Vermutung, wegen der "Datenstruktur" die ich hier gepostet habe:
          @adlerauge1980: `
          • ZefauZ Offline
            ZefauZ Offline
            Zefau
            Hast du den Fehler beheben können?
            Alternativ
            sudo iobroker url https://github.com/Zefau/ioBroker.roomba
            bzw. inzwischen ist der Adapter auch in npm aktualisiert, also sollte folgendes klappen
            iobroker update
            iobroker upgrade
            Sollte alles nicht funktionieren, dann ggf. mit chown den Besitzer für das Verzeichnis /opt/iobroker wechseln?
              adlerauge1980
              hallo Zefau
              Danke der Nachfrage. Ich kämpfe noch damit. Aber grundsätzlich wäre es gegangen…. Was heisst das...
              Nach dem ich das Thema Roomba zur Seite gelegt hatte weil es nicht ging. hatte ich meine Vis ausgebaut und da plötzlich Probleme (Widget auf verschiedenen Vis seiten anzuzeigen scheint noch nicht ganz ausgereift zu sein) ich dachte e seien Performance Probleme des Raspi 3. wieder gegooglet und ne Anleitung gefunden ioBroker direkt auf meinem e immer laufendem Syno NAS zu installieren. also nicht lang gefackelt doker rauf und dann ioBroker neu drauf. -> Perfekt läuft, alles von vorne am Installieren, und die VIS Seite über export / Import rübergezogen. Und wieder die gleichen Probleme mit den Widgets (Konnte das Problem dann mit View in view lösen). Die Woche wollte ich nun einen andern gitub adappter installieren. Zuerst habe ich gedacht scheisse geht auch nicht.... aber dann hab ich gefunden was ich nirgends in einer offiziellen Anleitung beschrieben gefunden habe; "Grundprinzip Adapter".
              Im Expertenmodus finde ich nun den Roomba Adapter auf meinen Raspi auf der Syno habe ich es noch nicht geschaft, dazu weiter unten. Mein Problem war ein Verständnissproblem ein Github adapter erscheint nach der installation im Expertenmodus unter adapter und nicht wie von mir angenommen unter Instanzen! Und unter Adapter mit dem + kann man dann auch Instanzen hinzufügen (Hatte das System nicht verstanden) Sorry!! (Würde ich gerne Dokumentieren weiss aber noch nicht wo.... (Damit andere nicht das gleiche Problem haben)...
              Nun jetzt läuft also ioBroker unterdessen auf meiner Syno NAS habe dann die Cannvans Installation erfolgreich abgeschlossen:
              ````(Ohne sudo da bei einer Doker Syno Installation direkt mit dem Superuser gearbeitet wird, falls das hier mal jemand gleich machen möchte)
              Fehlermeldung habe ich keine erhalten jupee….. :)
              Dann den Adapter versucht zu installieren da gibts jetzt aber nochmals fehlermeldungen:
              $ ./iobroker url "https://github.com/Zefau/ioBroker.roomba" --debug
              authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
              node-gyp rebuild
              gyp
              ERR! clean error
              gyp
              ERR! stack Error: EACCES: permission denied, rmdir 'build'
              gyp ERR! System Linux 3.10.105gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v8.15.0
              gyp ERR! node-gyp -v v3.8.0gyp ERR!
              not ok
              epoll@0.1.22 install /opt/iobroker/node_modules/epoll
              node-gyp rebuild
              gyp
              WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/epoll/.node-gyp"
              gyp
              WARN
              install got an error, rolling back install
              gyp WARN install got an error, rolling back install
              gyp ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/epoll/.node-gyp'
              "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/epoll
              gyp ERR!
              gyp ERR! not ok
              node-aead-crypto@2.1.4 install /opt/iobroker/node_modules/node-aead-crypto
              node lib/install.js
              running default installation script
              npm
              ERR! path /root/.npm/_logs
              npm ERR! errno -13npm
              ERR! syscall scandir
              npm
              ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'npm ERR! { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
              npm ERR! stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',
              npm ERR!
              errno: -13,npm ERR! code: 'EACCES',
              npm ERR! syscall: 'scandir',
              npm
              ERR! path: '/root/.npm/_logs' }npm ERR!
              npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current user
              npm ERR!
              npm ERR!
              If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try running
              glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs' stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',
              errno: -13,
              code: 'EACCES',
              syscall: 'scandir',
              node-aead-crypto@2.1.4 install:default /opt/iobroker/node_modules/node-aead-crypto
              prebuild-install || node-gyp rebuild
              prebuild-install
              WARN install EACCES: permission denied, access '/root/.npm'
              gyp
              WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/node-aead-crypto/.node-gyp"
              gyp
              gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/node-aead-crypto/.node-gyp'
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-aead-crypto
              gyp ERR!
              gyp ERR! not ok
              npm ERR! code ELIFECYCLEnpm ERR! errno
              1npm ERR! node-aead-crypto@2.1.4 install:default: prebuild-install || node-gyp rebuild
              npm ERR! npm ERR! Failed at the node-aead-crypto@2.1.4 install:default script.
              child_process.js:650 throw err;
              Error: Command failed: npm run install:default
              at checkExecSyncError (child_process.js:607:13)
              at execSync (child_process.js:647:13)
              at Object. <anonymous>(/opt/iobroker/node_modules/node-aead-crypto/lib/install.js:29:1)
              at Module._compile (module.js:653:30)
              at Object.Module._extensions..js (module.js:664:10)
              at Module.load (module.js:566:32)
              at tryModuleLoad (module.js:506:12)
              at Function.Module._load (module.js:498:3)
              at Function.Module.runMain (module.js:694:10)
              at startup (bootstrap_node.js:204:16)
              canvas@2.3.1 install /opt/iobroker/node_modules/canvas
              node-pre-gyp
              node-pre-gyp
              WARN Pre-built binaries not installable for canvas@2.3.1 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp) node-pre-gyp WARN Hit error EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/build'
              gyp
              WARN
              gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/canvas/.node-gyp"
              gyp
              gyp
              gyp
              ERR! configure error gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/canvas/.node-gyp'
              gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd /opt/iobroker/node_modules/canvas
              gyp ERR!
              node-gyp -v v3.8.0gyp ERR! not ok
              node-pre-gyp
              ERR! build error
              node-pre-gyp
              ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)node-pre-gyp ERR! stack
              at ChildProcess. <anonymous>(/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
              node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
              node-pre-gyp
              ERR! System Linux 3.10.105node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
              /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v8.15.0
              node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
              npm
              WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 (node_modules/epoll):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: epoll@0.1.22 install: node-gyp rebuild
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 (node_modules/node-aead-crypto):
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-aead-crypto@2.1.4 install: node lib/install.js
              npm
              ERR! code ELIFECYCLEnpm ERR! errno 1
              npm ERR! canvas@2.3.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the canvas@2.3.1 install script.
              npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-01-26T10_54_16_724Z-debug.log
              process exited with code 0</anonymous></anonymous>
              Ausgabe aber gibt "Erfolgreich" an.
              Zurück auf der Adapterseite "unter Expertenmodus" unter iRo gesucht aber nichts vorhanden.
              Eigentlich wollte ich noch nun noch den Befehl:
              Ausführen. bin aber nicht sicher in welchem verzeichnis ich den Ausführen muss. ein iobroker.roomba verzeichnis gibt es unter opt/iobroker/node-modul noch nicht. oder kann ich den Befehl auch unter /node-modul ausführen?
              Ps. Deine Nachfrage hat mich sehr gefreut! Nicht selbstverständlich für ein Forum! DANKE!!
              • ZefauZ Offline
                ZefauZ Offline
                Zefau
                @adlerauge1980:
                Dann den Adapter versucht zu installieren da gibts jetzt aber nochmals fehlermeldungen `
                Hast du das von der GUI versucht? In dem Fehlerprotokoll steht, dass die Berechtigungen auf die Ordner fehlen:
                @adlerauge1980:
                gyp
                WARN EACCES user "undefined" does not have permission to access the dev dir "/root/.node-gyp/8.15.0"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/epoll/.node-gyp" `
                Versuch mal mit sudo zu installieren.
                Wenn das nicht geht (oder du schon mit root drin bist), dann guck mal, wem der Ordner node_modules gehört (ls -al) und ändere ggf. die Berechtigungen (chmod).
                Viele Grüße
                Zefau
                  adlerauge1980
                  Hallo Zefau
                  Ich habe ioBroker auf meinem Synology NAS (Docker) installiert gemäss einer Anleitung hier im Forum. Wenn ich mit der Konsole arbeite bin ich bereits als Root angemeldet. Ich denke jedoch nicht, wenn ich mit aus ioBroker heraus installiere (Vermutlich ist dies dann der User iobroker wobei so wirklich sicher bin ich mir da nicht.
                  • ZefauZ Offline
                    ZefauZ Offline
                    Zefau
                    Wenn du von der GUI installierst, dann installiert er mit dem Benutzer "iobroker".
                    Prüfe mal im Ordner /opt/iobroker mit "ls -al", wie die Besitzer der Ordner "iobroker.xxxx" sind. Du kannst den Besitzer mit "chown" ändern, z. B. "chown -R iobroker:iobroker /opt/iobroker/node_modules/iobroker.roomba".
                    Danach solltest du normal von der GUI aus installieren können.
                    • ZefauZ Zefau
                      adlerauge1980
                      @Zefau Hallo Zefau
                      Sorry das ich so lange nicht geantwortet habe, ich hatte das Thema ioBroker etwas auf die Seite gelegt, weil andere Projekte Vorrang hatten.
                      Ich habe mich heute nochmal dahinter gesetzt. und endlich auch den Adapter zum laufen bekommen.
                      ich musste mir den Ordner iobroker.roomba in /opt/iobroker/node_modules/ manuell mit mkdir anlegen (über die Konsole vom Doker) anschliessend habe ich den Befehl: npm install canvas --unsafe-perm=true in diesem Ordner ausgeführt. und dann konnte ich den Adapter normal installieren! (Manchmal bringt es etwas, solche Dinge auf die Seite zu legen und später wieder hervor zu nehmen).
                        adlerauge1980
                        wie kann ich im neuen Forum einen Thred als gelöst markieren?
                        BBTownB 1 Antwort Letzte Antwort
                        • A adlerauge1980
                          BBTownB Offline
                          BBTownB Offline
                          BBTown
                          schrieb am zuletzt editiert von BBTown
                          @adlerauge1980 indem Du in deinem ersten Beitrag in der Überschrift das [gelöst] vorne hin schreibst ;-)
                          • BBTownB BBTown
                            adlerauge1980
                            @BBTown Danke.... für den Tipp / Info
