  4. Zigbee funktioniert in Version 0.11 nicht mehr
zigbeenpm versionadapter updateERROR/PROBLEM
5 Beiträge 3 Kommentatoren 632 Aufrufe 1 Beobachtet
  • L Offline
    Leviathan09
    seit heute morgen bekomme ich folgende Fehlermeldung zu dem Zigbee Adapter den ich auf Version 0.11 geupdatet habe.
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:787:10)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Module._compile (internal/modules/cjs/loader.js:776:30)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:1:36)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Module.require (internal/modules/cjs/loader.js:690:17)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Caught	2019-06-15 07:36:02.099	error	by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:805:18)
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: was compiled against a different Node.js version using
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: ^
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: throw e;
    Caught	2019-06-15 07:36:02.098	error	by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
    Kann mir jemand sagen was da nicht simmt? Wohl irgendwas mit meiner NPM Version oder?
    npm -v 6.9.0
    node -v v10.16.0
    • L Offline
      Leviathan09
      Habe jetzt mal ein "npm rebuild" durchgeführt.
      Nun startet der Adapter wieder und funktioniert auch wie gewohnt.
      Frage mich nur woran das nun gelegen hat
      • L Leviathan09
        arteckA Offline
        arteckA Offline
        arteck
        @Leviathan09 im ernst..du machst ein node update und fragst warum der Adapter nicht mehr geht..
        L 1 Antwort Letzte Antwort
        • arteckA arteck
          Leviathan09
          @arteck Nein!
          An Node und NPM habe ich nichts geändert, das ist schon zwei oder drei Wochen her.
          Und die ganze Zeit lief der Adapter auch.
          Ich habe heute NUR den Zigbee Adapter geupdatet.
          Sonst habe ich nichts geändert heute morgen, einfach nur den Zigbee Adapter in Version 0.11 installiert.
          Und der Output von oben wann dann das Ergebnis.
          • ? Offline
            Seit dem Update hängt bei der Netzwerkkarte alles in der "Luft". Ich hoffe nicht das jetzt nix mehr funktioniert. Muss ich gleich mal testen.
