  4. [Gelöst] influxdb nicht erreichbar
influxdb
13 Beiträge 2 Kommentatoren 6.1k Aufrufe
  • softwarecrashS Offline
    softwarecrash
    schrieb am zuletzt editiert von softwarecrash
    kann mir jemand bei diesem problem weiterhelfen?
    nach einer neuinstallation des systems und influxdb hab ich folgendes im log
    influxdb.0	2019-06-07 13:12:50.500	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    influxdb.0	2019-06-07 13:12:50.454	info	enabled logging of mqtt.0.Buero_Luft.Luftsensor.Temperature, Alias=false, 1 points now activated
    influxdb.0	2019-06-07 13:12:50.274	info	Connecting http://localhost:8086 ...
    influxdb.0	2019-06-07 13:12:50.264	info	Buffer initialized with data for 35 points and 0 conflicts from last exit
    influxdb.0	2019-06-07 13:12:50.145	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v8.16.0
    influxdb.0	2019-06-07 13:12:41.420	info	terminating
    influxdb.0	2019-06-07 13:12:41.385	info	Adapter is disabled => stop
    influxdb.0	2019-06-07 13:12:41.367	warn	Store data for 35 points and 0 conflicts
    influxdb.0	2019-06-07 13:12:26.767	warn	Error on writePoint("{"value":35.97,"time":"2019-06-07T11:12:26.743Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:11:26.412	warn	Error on writePoint("{"value":35.95,"time":"2019-06-07T11:11:26.372Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:10:26.086	warn	Error on writePoint("{"value":35.84,"time":"2019-06-07T11:10:26.067Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:09:25.725	warn	Error on writePoint("{"value":35.85,"time":"2019-06-07T11:09:25.704Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:08:25.362	warn	Error on writePoint("{"value":35.91,"time":"2019-06-07T11:08:25.338Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:07:25.031	warn	Error on writePoint("{"value":35.94,"time":"2019-06-07T11:07:24.980Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
    influxdb.0	2019-06-07 13:05:30.049	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    influxdb.0	2019-06-07 13:05:30.007	info	enabled logging of mqtt.0.Buero_Luft.Luftsensor.Temperature, Alias=false, 1 points now activated
    influxdb.0	2019-06-07 13:05:29.868	info	Connecting http://localhost:8086 ...
    influxdb.0	2019-06-07 13:05:29.861	info	Buffer initialized with data for 28 points and 0 conflicts from last exit
    influxdb.0	2019-06-07 13:05:29.772	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v8.16.0
    influxdb.0	2019-06-07 13:05:23.406	warn	Store data for 28 points and 0 conflicts
    influxdb.0	2019-06-07 13:05:23.232	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    • softwarecrashS softwarecrash
      @lacrimosa2k2 sagte in influixdb nicht erreichbar:
      Wie hast du installiert?
        softwarecrash
        auf einem raspbian image, nach der anleitung auf der webseite
        1. Erst Node.js installieren (wenn noch nicht vorhanden):
        curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
        sudo apt-get install -y nodejs
        2. Anschließend ioBroker installieren:
        curl -sL https://iobroker.net/install.sh | bash -
        die datenbank dann über das web admin pannel den influxdb adapter installiert
          @lacrimosa2k2
          Ähm...
          nach einer neuinstallation des systems und influixdb
          Das klingt für mich nach ioBroker Installation
            softwarecrash
            @Homoran habs korrigiert.
            ja komplette neuinstallation von iobroker
              @lacrimosa2k2
              Dann verstehe ich das nicht.
              Ausser:
              Hast du influxdb überhaupt installiert?
                softwarecrash
                @Homoran
                ja hab den influixdb adapter normal über das webinterface installiert.
                oder muss man die datenbank an sich nochmal über die konsole installieren?
                  @Homoran
                  @lacrimosa2k2 sagte in influxdb nicht erreichbar:
                  Ja!
                  der Adapter dient nur zum Verbinden mit der Datenbank
                    softwarecrash
                    @Homoran
                    super! :D
                    gibt es dafür irgendwo eine howto oder docu? oder wie geht das?
                      @Homoran
                      super! :D
                      @lacrimosa2k2
                      kommt drauf an welche Hardware und welches OS du hast.
                      Sollte auf der Seite des Herstellers zu finden sein
                      softwarecrashS 1 Antwort Letzte Antwort
                        @lacrimosa2k2
                        softwarecrash
                        @Homoran
                        das ganze läuft auf einem raspberry pi mit raspbian-stretch.
                        was mich wundert, bei der vorhergehenden installation war die datenbank nach der installation des adapters einfach da
                          @Homoran
                          @lacrimosa2k2
                          Habe auf die Schnelle das hier gefunden:
                          https://gist.github.com/boseji/bb71910d43283a1b84ab200bcce43c26
                          keine Ahnung ob es noch einfacher geht
                            softwarecrash
                            danke.
                            funktioniert jetzt bestens.
                            gibt es irgendein webinterface wie phpmyadmin für diese datenbank?
