<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Gelöst] influxdb nicht erreichbar]]></title><description><![CDATA[<p dir="auto">kann mir jemand bei diesem problem weiterhelfen?<br />
nach einer neuinstallation des systems und influxdb hab ich folgendes im log</p>
<pre><code>influxdb.0	2019-06-07 13:12:50.500	error	Error: connect ECONNREFUSED 127.0.0.1:8086
influxdb.0	2019-06-07 13:12:50.454	info	enabled logging of mqtt.0.Buero_Luft.Luftsensor.Temperature, Alias=false, 1 points now activated
influxdb.0	2019-06-07 13:12:50.274	info	Connecting http://localhost:8086 ...
influxdb.0	2019-06-07 13:12:50.264	info	Buffer initialized with data for 35 points and 0 conflicts from last exit
influxdb.0	2019-06-07 13:12:50.145	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v8.16.0
influxdb.0	2019-06-07 13:12:41.420	info	terminating
influxdb.0	2019-06-07 13:12:41.385	info	Adapter is disabled =&gt; stop
influxdb.0	2019-06-07 13:12:41.367	warn	Store data for 35 points and 0 conflicts
influxdb.0	2019-06-07 13:12:26.767	warn	Error on writePoint("{"value":35.97,"time":"2019-06-07T11:12:26.743Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:11:26.412	warn	Error on writePoint("{"value":35.95,"time":"2019-06-07T11:11:26.372Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:10:26.086	warn	Error on writePoint("{"value":35.84,"time":"2019-06-07T11:10:26.067Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:09:25.725	warn	Error on writePoint("{"value":35.85,"time":"2019-06-07T11:09:25.704Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:08:25.362	warn	Error on writePoint("{"value":35.91,"time":"2019-06-07T11:08:25.338Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:07:25.031	warn	Error on writePoint("{"value":35.94,"time":"2019-06-07T11:07:24.980Z","from":"system.adapter.mqtt.0","q":0,"ack":true}): Error: connect ECONNREFUSED 127.0.0.1:8086 / "connect ECONNREFUSED 127.0.0.1:8
influxdb.0	2019-06-07 13:05:30.049	error	Error: connect ECONNREFUSED 127.0.0.1:8086
influxdb.0	2019-06-07 13:05:30.007	info	enabled logging of mqtt.0.Buero_Luft.Luftsensor.Temperature, Alias=false, 1 points now activated
influxdb.0	2019-06-07 13:05:29.868	info	Connecting http://localhost:8086 ...
influxdb.0	2019-06-07 13:05:29.861	info	Buffer initialized with data for 28 points and 0 conflicts from last exit
influxdb.0	2019-06-07 13:05:29.772	info	starting. Version 1.6.3 in /opt/iobroker/node_modules/iobroker.influxdb, node: v8.16.0
influxdb.0	2019-06-07 13:05:23.406	warn	Store data for 28 points and 0 conflicts
influxdb.0	2019-06-07 13:05:23.232	error	Error: connect ECONNREFUSED 127.0.0.1:8086
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/23016/gelöst-influxdb-nicht-erreichbar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 23:34:49 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/23016.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 07 Jun 2019 11:15:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:43:25 GMT]]></title><description><![CDATA[<p dir="auto">danke.<br />
funktioniert jetzt bestens.<br />
gibt es irgendein webinterface wie phpmyadmin für diese datenbank?</p>
]]></description><link>https://forum.iobroker.net/post/268984</link><guid isPermaLink="true">https://forum.iobroker.net/post/268984</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:43:25 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:38:04 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2</p>
<p dir="auto">Habe auf die Schnelle das hier gefunden:</p>
<p dir="auto"><a href="https://gist.github.com/boseji/bb71910d43283a1b84ab200bcce43c26" rel="nofollow ugc">https://gist.github.com/boseji/bb71910d43283a1b84ab200bcce43c26</a></p>
<p dir="auto">keine Ahnung ob es noch einfacher geht</p>
]]></description><link>https://forum.iobroker.net/post/268980</link><guid isPermaLink="true">https://forum.iobroker.net/post/268980</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:38:04 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:34:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a><br />
das ganze läuft auf einem raspberry pi mit raspbian-stretch.<br />
was mich wundert, bei der vorhergehenden installation war die datenbank nach der installation des adapters einfach da</p>
]]></description><link>https://forum.iobroker.net/post/268978</link><guid isPermaLink="true">https://forum.iobroker.net/post/268978</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:33:31 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2<br />
kommt drauf an welche Hardware und welches OS du hast.</p>
<p dir="auto">Sollte auf der Seite des Herstellers zu finden sein</p>
]]></description><link>https://forum.iobroker.net/post/268975</link><guid isPermaLink="true">https://forum.iobroker.net/post/268975</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:33:31 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:31:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a><br />
super! :D<br />
gibt es dafür irgendwo eine howto oder docu? oder wie geht das?</p>
]]></description><link>https://forum.iobroker.net/post/268973</link><guid isPermaLink="true">https://forum.iobroker.net/post/268973</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:30:19 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2 sagte in <a href="/post/268969">influxdb nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">muss man die datenbank an sich nochmal über die konsole installieren?</p>
</blockquote>
<p dir="auto">Ja!</p>
<p dir="auto">der Adapter dient nur zum Verbinden mit der Datenbank</p>
]]></description><link>https://forum.iobroker.net/post/268971</link><guid isPermaLink="true">https://forum.iobroker.net/post/268971</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:29:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a><br />
ja hab den influixdb adapter normal über das webinterface installiert.<br />
oder muss man die datenbank an sich nochmal über die konsole installieren?<br />
<img src="/assets/uploads/files/1559906930889-324532wtrgfdfgds.jpg" alt="324532wtrgfdfgds.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/268969</link><guid isPermaLink="true">https://forum.iobroker.net/post/268969</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:29:43 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:26:28 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2<br />
Dann verstehe ich das nicht.</p>
<p dir="auto">Ausser:<br />
Hast du influxdb überhaupt installiert?</p>
]]></description><link>https://forum.iobroker.net/post/268968</link><guid isPermaLink="true">https://forum.iobroker.net/post/268968</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:23:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: Homoran">@<bdi>Homoran</bdi></a> habs korrigiert.<br />
ja komplette neuinstallation von iobroker</p>
]]></description><link>https://forum.iobroker.net/post/268965</link><guid isPermaLink="true">https://forum.iobroker.net/post/268965</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:23:24 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:21:14 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2<br />
Ähm...</p>
<p dir="auto">@lacrimosa2k2 sagte in <a href="/post/268958">influixdb nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">nach einer <strong>neuinstallation des systems</strong> und influixdb</p>
</blockquote>
<p dir="auto">Das klingt für mich nach ioBroker Installation</p>
]]></description><link>https://forum.iobroker.net/post/268964</link><guid isPermaLink="true">https://forum.iobroker.net/post/268964</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:21:38 GMT]]></title><description><![CDATA[<p dir="auto">auf einem raspbian image, nach der anleitung auf der webseite</p>
<pre><code>
1. Erst Node.js installieren (wenn noch nicht vorhanden):
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejs
2. Anschließend ioBroker installieren:
curl -sL https://iobroker.net/install.sh | bash -
</code></pre>
<p dir="auto">die datenbank dann über das web admin pannel den influxdb adapter installiert</p>
]]></description><link>https://forum.iobroker.net/post/268962</link><guid isPermaLink="true">https://forum.iobroker.net/post/268962</guid><dc:creator><![CDATA[softwarecrash]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to [Gelöst] influxdb nicht erreichbar on Fri, 07 Jun 2019 11:19:37 GMT]]></title><description><![CDATA[<p dir="auto">@lacrimosa2k2 sagte in <a href="/post/268958">influixdb nicht erreichbar</a>:</p>
<blockquote>
<p dir="auto">nach einer neuinstallation des systems</p>
</blockquote>
<p dir="auto">Wie hast du installiert?</p>
]]></description><link>https://forum.iobroker.net/post/268961</link><guid isPermaLink="true">https://forum.iobroker.net/post/268961</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 07 Jun 2019 11:19:37 GMT</pubDate></item></channel></rss>
