  2. English
  3. Scripting / Logic
  5. ASTRO function. Does not work again
blockly
58 Beiträge 6 Kommentatoren 13.3k Aufrufe 7 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    Re: Is there problem with Blockly after last update?
    After testing for many weeks I came to a conclusion that ASTRO function does not work continuously, meaning it works ones after controller physical reboot and then never execute, see my simple Blockly script in reference post. I use all latest Linux, controller and adapters updates and 8.16.0 Node.js. Any idea what is going on?
    • R Offline
      RappiRN
      Please show your Blockly Script here, i think there is an errror in it.
      The Astro funktion works fine in my Blocklys.
      Enrico
        ap2017
        • R Offline
          RappiRN
          What does not work, set the control level to 99 or 0, or the telegram message, or both?
          You can use debug-blocks to control the trigger-blocks.
          Enrico
          A 2 Antworten Letzte Antwort
          • R RappiRN
            Enrico
            ap2017
            @RappiRN As you see, I use telegram for debugging, so schedule block works all the time (the light goes on, then off and I am getting notification from telegram), while astro works only once in a while, it works for sure once after restarting RPI by interrupting the power
            • R RappiRN
              Enrico
              ap2017
              @RappiRN May be I was not clear in my response. In ASTRO block, both telegram and setting level do not work (to be precise, work once after resetting power to Raspberry PI). In SCHEDULE block telegram and level setting work fine all the time.
              • R Offline
                RappiRN
                Ok, in the settings from the javascript-Adapter you must set your location, or check to use the ioBroker location.
                Enrico
                • R RappiRN
                  Enrico
                  ap2017
                  @RappiRN I am aware of this and it was done. Don't forget, in my case ASTRO work right once after fresh power up, it turns up the light in expected time.
                  • R Offline
                    RappiRN
                    The right once working, is it also at the right time?
                    Which location settings you are using, from the adapter or from ioBroker? Sometimes it was a problem to use the ioBroker settings instead the adapter settings.
                    Sorry i have not really an idea what the matter with your astro-function.
                    Enrico
                    • R RappiRN
                      Enrico
                      ap2017
                      @RappiRN Yes, when I say it works right once, it means the timing is right. I tried both location settings, from the adapter as well as from system with same result.
                        ap2017
                        Have brand new ioBroker installation on different platform (x64) with same script as show above, the Astro function still does not work. What am I doing wrong?
                        • iomountainI Offline
                          iomountainI Offline
                          iomountain
                          schrieb am zuletzt editiert von iomountain
                          @ap2017 for debuging use debug, not telegram.
                          substitute telegram whith debug to see what's going on.
                          Look at the LOG.
                          mine works:
                          c8d8d908-8721-440c-b8e0-f1d21907f888-image.png ,
                          Do you wanna Post an export of your Blockly?
                          • iomountainI iomountain
                            Look at the LOG.
                            mine works:
                            ap2017
                            @iomountain Thank you for your response. I changed my script as you suggested, where do I find debugging log?
                              iomountainI Offline
                              iomountain
                              Try Log at main screen Admin
                              There you will find your "debug output" Messages
                                ap2017
                                @iomountain I think that after long time of straggling I am getting close to resolving the issue with ASTRO function that I am experiencing. It looks like ASTRO algorithm does not like GEO coordinates in North America since it started to work fine after I set ASTRO for Berlin, Germany. Maybe negative value of Longitude confuses the algorithm?
                                Could you do me a favor and try your script with GEO set to Hartford CT in USA? Thank you.
                                  iomountainI Offline
                                  iomountain
                                  It works, United States Hartford 41.76 -72.68
                                  If you wanna see all astro times try the Script
                                  // Astrotime for today - V2.0
                                  console.log("=====================");
                                  console.log("Astro time for today");
                                  var nightEnd = getAstroDate("nightEnd");
                                  console.log(" (0) nightEnd (End of night)........................: " + nightEnd.toLocaleTimeString());
                                  var nauticalDawn = getAstroDate("nauticalDawn");
                                  console.log(" (1) nauticalDawn (naut. Dämmerung Morgens)...........: " + nauticalDawn.toLocaleTimeString());
                                  var dawn = getAstroDate("dawn");
                                  console.log(" (2) dawn (Dämmerung Morgens).........................: " + dawn.toLocaleTimeString());
                                  var sunrise = getAstroDate("sunrise");
                                  console.log(" (3) sunrise (Sonnenaufgang)..........................: " + sunrise.toLocaleTimeString());
                                  var sunriseEnd = getAstroDate("sunriseEnd");
                                  console.log(" (4) sunriseEnd (Ende des Sonnenaufgangs).............: " + sunriseEnd.toLocaleTimeString());
                                  var goldenHourEnd = getAstroDate("goldenHourEnd");
                                  console.log(" (5) goldenHourEnd (Ende der Golden Hour VM)..........: " + goldenHourEnd.toLocaleTimeString());
                                  var solarNoon = getAstroDate("solarNoon");
                                  console.log(" (6) solarNoon (Mittag)...............................: " + solarNoon.toLocaleTimeString());
                                  var goldenHour = getAstroDate("goldenHour");
                                  console.log(" (7) goldenHour (Start der Golden Hour NM)............: " + goldenHour.toLocaleTimeString());
                                  var sunsetStart = getAstroDate("sunsetStart");
                                  console.log(" (8) sunsetStart (Start des Sonnenuntergangs).........: " + sunsetStart.toLocaleTimeString());
                                  var sunset = getAstroDate("sunset");
                                  console.log(" (9) sunset (Sonnenuntergang).........................: " + sunset.toLocaleTimeString());
                                  var dusk = getAstroDate("dusk");
                                  console.log("(10) dusk (Dämmerung Abends)..........................: " + dusk.toLocaleTimeString());
                                  var nauticalDusk = getAstroDate("nauticalDusk");
                                  console.log("(11) nauticalDusk (naut. Dämmerung Abends)............: " + nauticalDusk.toLocaleTimeString());
                                  var night = getAstroDate("night");
                                  console.log("(12) night (Start of night)..........................: " + night.toLocaleTimeString());
                                  var nadir = getAstroDate("nadir");
                                  console.log("(13) nadir (midnight)..............................: " + nadir.toLocaleTimeString());
                                  var today = new Date();
                                  var tomorrow = today.setDate(today.getDate()+1);
                                  var tomorrowNight = getAstroDate("night", tomorrow);
                                  console.log("Night starts tomorrow at " + tomorrowNight.toLocaleTimeString());
                                  console.log(obj.id);
                                  @ap2017
                                    @ap2017
                                    ap2017
                                    @iomountain I will try to set ASTRO back to US, thanks
                                      iomountainI Offline
                                      iomountain
                                      @ap2017 don't forget to restart iobroker. Like "iobroker stop" and "iobroker start"
                                        ap2017
                                        @iomountain Day I switched to US the ASTRO stopped working (no ASTRO string in LOG file). I restarted computer after I made a change. I will try your ASTRO script
                                        Here is my script:
                                        // Living Room Light
                                        schedule({astro: "goldenHour", shift: 0}, function () {
                                        console.log('astro_on');
                                        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
                                        schedule("0 18 * * *", function () {
                                        console.log('schedule_on');
                                        schedule("30 23 * * *", function () {
                                        console.log('schedule_off');
                                        setState("zwave.0.NODE7.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
                                          ap2017
                                          @iomountain Here is the log from running your script Astro Time for Today, if it helps. So, script runs but shows error code at the end of each run.
                                          2019-10-19 18:48:42.414 - info: mysensors.0 (18452) STARTED
                                          2019-10-19 18:48:42.415 - info: mysensors.0 (18452) STARTED
                                          2019-10-19 18:48:55.725 - info: javascript.0 (18920) Stop script script.js.ASTRO
                                          2019-10-19 18:48:55.770 - info: javascript.0 (18920) Start javascript script.js.ASTRO
                                          2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                          2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: Astro time for today
                                          2019-10-19 18:48:55.773 - info: javascript.0 (18920) script.js.ASTRO: (0) nightEnd (End of night)........................: 5:36:06 AM
                                          2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (1) nauticalDawn (naut. Dämmerung Morgens)...........: 6:08:18 AM
                                          2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (2) dawn (Dämmerung Morgens).........................: 6:40:39 AM
                                          2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (3) sunrise (Sonnenaufgang)..........................: 7:08:50 AM
                                          2019-10-19 18:48:55.774 - info: javascript.0 (18920) script.js.ASTRO: (4) sunriseEnd (Ende des Sonnenaufgangs).............: 7:11:46 AM
                                          2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (5) goldenHourEnd (Ende der Golden Hour VM)..........: 7:46:57 AM
                                          2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (6) solarNoon (Mittag)...............................: 12:37:25 PM
                                          2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (7) goldenHour (Start der Golden Hour NM)............: 5:27:52 PM
                                          2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (8) sunsetStart (Start des Sonnenuntergangs).........: 6:03:04 PM
                                          2019-10-19 18:48:55.775 - info: javascript.0 (18920) script.js.ASTRO: (9) sunset (Sonnenuntergang).........................: 6:06:00 PM
                                          2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (10) dusk (Dämmerung Abends)..........................: 6:34:11 PM
                                          2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (11) nauticalDusk (naut. Dämmerung Abends)............: 7:06:31 PM
                                          2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (12) night (Start of night)..........................: 7:38:44 PM
                                          2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: (13) nadir (midnight)..............................: 12:37:25 AM
                                          2019-10-19 18:48:55.776 - info: javascript.0 (18920) script.js.ASTRO: =====================
                                          2019-10-19 18:48:55.777 - info: javascript.0 (18920) script.js.ASTRO: Night starts tomorrow at 7:37:17 PM
                                          2019-10-19 18:48:55.777 - error: javascript.0 (18920) script.js.ASTRO: script.js.ASTRO:41
                                          2019-10-19 18:48:55.777 - error: javascript.0 (18920) console.log(obj.id);
                                          2019-10-19 18:48:55.778 - error: javascript.0 (18920) ^
                                          2019-10-19 18:48:55.778 - error: javascript.0 (18920) ReferenceError: obj is not defined
                                          2019-10-19 18:48:55.778 - error: javascript.0 (18920) at script.js.ASTRO:41:13
                                          2019-10-19 18:48:55.778 - error: javascript.0 (18920) at Script.runInContext (vm.js:133:20)
                                          iomountainI 1 Antwort Letzte Antwort
