  4. Script zur Überprüfung ob eine Instanz noch läuft.
blocklyjavascript
52 Beiträge 15 Kommentatoren 10.8k Aufrufe 21 Beobachtet
  • D deta
    Aber nun kommen im Log neue Fehler:
    javascript.0 2019-05-23 13:48:52.637 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-23 13:48:52.637 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2019-05-23 13:48:52.636 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0 2019-05-23 13:48:52.636 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0 2019-05-23 13:48:52.636 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-23 13:48:52.635 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0 2019-05-23 13:48:52.635 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0 2019-05-23 13:48:52.634 error at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0 2019-05-23 13:48:52.634 error at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0 2019-05-23 13:48:52.633 error at Object.<anonymous> (script.js.common.Instanzen_Überwachung:61:26)
    javascript.0 2019-05-23 13:48:52.633 error Error in callback: TypeError: Cannot read property 'common' of null
    javascript.0 2019-05-23 13:48:52.629 warn Object "system,adapter,lgtv,0,alive" does not exist
    @deta sagte:
    Wie kommen Kommata in die ID ?
    • paul53P Offline
      Mit folgendem Skript
      on(/^system\.adapter\..+\.alive$/, function(dp) {
          log(dp.common.name + ': ' + dp.state.val);
      on(/^system\.adapter\..+\.connected$/, function(dp) {
      habe ich festgestellt, dass etliche Adapter (ping, web, admin, linkeddevices, javascript, ...) immer wieder null und kurz darauf true bei alive liefern. Bei connected dagegen ist es ruhig.
      Schlussfolgerung: Entweder man verwendet connected
      on(/^system\.adapter\..+\.connected$/, function (dp) {
      oder man prüft explizit auf false.
               } else if(dp.state.val === false) {
      eumatsE 1 Antwort Letzte Antwort
        @deta sagte:
        deta
        @paul53 sagte in Script zur Überprüfung ob eine Instanz noch läuft.:
        @deta sagte:
        Woher soll ich das Wissen, vom Adapter warscheinlich 😁
          eumatsE Offline
          eumatsE Offline
          eumats
          Danke das Du noch mal geschaut hast. Ich versuche mal else if Variante...
          • thewhoboxT thewhobox
            @deta Die Adapter laufen nicht ständig, sondern per Cron.
            In der io-package.json sieht man das schön:
            "mode": "schedule",
            "schedule": "*/5 * * * *",
            Evtl müsste man noch einbauen, dass er sich das common Objekt des Adapters holt und überprüft ob es dauernd läuft (daemond glaube ich) oder eben nur alle paar Mintuen zum abholen von Daten (scheduled).
            @thewhobox sagte:
            Ich habe das Skript entsprechend geändert. Bitte testen !
            • D deta
              eumatsE Offline
              eumatsE Offline
              eumats
              @deta sagte in Script zur Überprüfung ob eine Instanz noch läuft.:
              Poste mal das Skript was Du nutzt (bitte mit Code-Tag). Du scheinst irgendwo mit id und nicht id[<zahl>] zu arbeiten.
              Denn der split (var id = (dp.id.split('.'));) zerlegt das ja und zeigt dann in id alles mit Komma an.
                @deta sagte:
                Das Wetter und tvspielfilm ein Problem mit alive
                Laufen die Instanzen nicht ständig ? Dann ergänze die Zeile
                    if (id[2] != 'admin' && id[2] != 'daswetter' && id[2] != 'tvspielfilm') {
                um diese Adapter.
                Michi68
                schrieb am zuletzt editiert von Michi68
                bitte löschen fehler mit dem handy gemacht
                • paul53P Offline
                  Bitte folgendes Skript testen !
                  Hier ist berücksichtigt, dass laufende Instanzen im Datenpunkt alive immer wieder den Wert null annehmen und gestörte Instanzen immer wieder (minütlich) kurzzeitig den Wert true. Die Ausblendung des Wertes null erfolgt durch Prüfung auf false und die Ausblendung des Wertes true durch Timer, wobei jede Instanz ihren eigenen Timer benötigt.
                  Da ich nicht weiß, wie ich gestörte Instanzen simulieren kann, kann ich es nicht selbst vollständig testen.
                  function alarmMsg(txt) {
                     log('Instanz ' + txt);
                     // sendTo();
                  var ids = [];
                  var timers = [];
                     var idx = ids.indexOf(dp.id);
                     if(idx == -1) {
                        idx = ids.push(dp.id) - 1;
                        timers[idx] = null;
                     var id = dp.id.split('.');
                     var common = getObject('system.adapter.' + id[2] + '.' + id[3]).common;
                     if(common.mode == 'daemon' && common.enabled) {  // Instanzen mit cronjob und gesperrte Instanzen ausblenden
                        if(dp.state.val && dp.oldState.val === false) {
                           if(timers[idx]) clearTimeout(timers[idx]);
                           timers[idx] = setTimeout(function() {
                              timers[idx] = null;
                              alarmMsg(dp.common.name + ' läuft wieder');
                           }, 150000); // 2,5 Minuten
                        } else if(dp.state.val === false && !timers[idx]) alarmMsg(dp.common.name + ' meldet Probleme');
                  • Z Offline
                    Z Offline
                    zahnheinrich
                    schrieb am zuletzt editiert von zahnheinrich
                    Das Script läuft soweit.
                    Wenn ich einen Adapter händisch neu starte, kommt sofort die entsprechende Problemmeldung, ca 3 Minuten später die Gutmeldung.
                    Könnte evtl ein nur kurzer "Ausfall" ignoriert werden, also ohne Meldung bleiben?
                    Vielen Dank für das Script!
                    Edit: Schalte ich einen Adapter dauernd aus, kommt wie erwartet zunächst die Fehlmeldung, nach drei Minuten aber trotzdem die Gutmeldung, obwohl der Adapter nicht läuft.
                    MfG Ulrich
                    • Z zahnheinrich
                      @zahnheinrich sagte:
                      Das kann ich bei mir nicht nachvollziehen.
                      @zahnheinrich sagte in Script zur Überprüfung ob eine Instanz noch läuft.:
                      Im folgenden Skript habe ich "kurzer Ausfall" mit 5 s definiert, denn 3 s waren zu wenig. Da nur ein Kurzzeit-Timer verwendet wird, muss man hoffen, dass innerhalb der 5 s keine andere Instanz "reingrätscht". Andernfalls müsste man ein zweites Timer-Array verwenden. Bitte testen:
                         txt = 'Instanz ' + txt;
                         log(txt);
                         // sendTo();
                      var ids = [];
                      var timers = [];
                      var timer = null; // Kurzzeit-Timer
                         if(idx == -1) {
                            timers[idx] = null;
                               if(timer) {
                                  clearTimeout(timer);
                                  timer = null;
                               } else {
                                     timers[idx] = null;
                            } else if(dp.state.val === false && dp.oldState.val && !timers[idx]) {
                               timer = setTimeout(function() {
                                  timer = null;
                               }, 5000);
                      • N Offline
                        N Offline
                        nevermind
                        schrieb am zuletzt editiert von nevermind
                        Danke für das Script, wirklich sehr nützlich!
                        Wäre es auch möglich zusätzlich z.b. dieses "verbunden mit..." Abzufangen? Bei mir geht gelegentlich der Alexa Adapter auf gelb, was vom Script aber nicht berücksichtigt wird.
                          deta
                          Kann bitte jetzt mal das aktuelle und letzte Version hier gepostet werden? Ich blicke gerade gar nicht mehr durch.
                          • Z Offline
                            Z Offline
                            zahnheinrich
                            Das sript läuft so einwandfrei, ohne überflüssige Fehlermeldungen!
                            Vielen Dank!
                            MfG Ulrich
                            • ? Offline
                              Hallo Leute
                              Kann mir eventuell jemand kurz Schritt für Schritt erklären, wie man nun den Script von Paul53 erstellt und dann in Telegram einbindet? Telegram ist installiert. Mir geht es um das Zusammenspiel von Script und Telegram....
                              Ich wäre Euch sehr dankbar.
                              Gruss
                              Vazi
                                M-A-X
                                schrieb am zuletzt editiert von M-A-X
                                Ich krame dieses alte Topic mal aus, da ich genau nach so einem Skript gesucht habe :)
                                Sehe ich das richtig, dass ich im "letzten" von paul53 geposteten Skript nur noch die Zeile
                                sendTo('telegram.0', 'iobroker - ' + txt);
                                in Zeile 7 einfügen muss, damit ich eine Meldung in mein Telgram bekomme^^?
                                Also so?
                                   log(txt);
                                var ids = [];
                                var timers = [];
                                   if(idx == -1) {
                                      timers[idx] = null;
                                         if(timer) {
                                            timer = null;
                                         } else {
                                               timers[idx] = null;
                                            timer = null;
                                         }, 5000);
                                Danke im Voraus. Ich bin zwar ganz "firm" beim verstehen vieler Skripte, aber hier das ist mir zu hoch :(
                                Edit: Skript läuft. Habe um 5:06 Uhr, nach dem Neustart des Telegram bots (ich glaube es ist der bot, der um 5 Uhr neu startet?!) eine Meldung in Telegram bekommen, dass der Adapter wieder läuft.
                                P 1 Antwort Letzte Antwort
                                • M M-A-X
                                  Also so?
                                     log(txt);
                                  var ids = [];
                                  var timers = [];
                                     if(idx == -1) {
                                        timers[idx] = null;
                                           if(timer) {
                                              timer = null;
                                           } else {
                                                 timers[idx] = null;
                                              timer = null;
                                           }, 5000);
                                  PichlAlex
                                  ich habe das Script erweitert um alle 3 Statuswerte der Instanzen abzufragen.
                                  Damit werden auch folgende Situationen erkannt:
                                  • InfluxDB ist nicht erreichbar (oder User gesperrt/ungültig)
                                  • Plex verweigert die Verbindung weil Token abgelaufen ist (passiert manchmal nach Updates
                                  • Spotify Login-Token ist abgelaufen
                                  • ....und viele mehr
                                  Funktionsweise (am Beispiel von Instanz plex.0):
                                  • "Connected to host" wird über Event system.adapter.plex.0.connected geprüft
                                  • "Connected to device or service" wird über Event plex.0.info.connection geprüft
                                  • "Heartbeat" wird über Event system.adapter.plex.0.alive geprüft
                                  // Überwacht alle 3 Statuswerte der laufenden Adapter
                                   var G_TelegramChatId = 37342026;
                                  function alarmMeldung(txt) {
                                      //txt =  txt;
                                      //sendeStatusPerTelegram(txt);
                                      sendTo('telegram.0', 'Instanzmonitoring: ' + txt);
                                      sendTo("telegram.0", "send", {
                                          text: ('Instanzmonitoring: ' + txt),
                                          chatId: G_TelegramChatId
                                      log('Sende via Telegram: ' + txt);
                                  var cnt = 0,
                                      timeoutZeit = 1 * 30000;
                                  //Prüfen auf: Connected to host
                                  //['system','adapter','plex','0','connected']
                                      log("CONNECTED-EVENT " + ( JSON.stringify(dp)));
                                      //log(dp.id);
                                      //log(id);
                                      if (id[2] != 'admin') {
                                          if (dp.state.val) {
                                              cnt--;
                                              if (cnt <= 0) {
                                                  log('"Connected to host" Adapter laufen fehlerfrei');
                                                  cnt = 0; // falls verzählt und cnt < 0
                                           } else {
                                              log('### "Connected to host"-Fehler entdeckt. Warte auf Selbstheilung: ' + id[2]);
                                              var newid  = ('system.adapter.' + id[2] + '.' + id[3]);
                                              recheckWithIntervall(dp.common.name, newid, id[2], "Connected to host");
                                              cnt++;
                                  //Prüfen auf: Connected to device or service
                                  //plex.0.info.connection
                                  on(/^.*info\.connection.*$/, function (dp) {
                                      log("INFO-EVENT " + ( JSON.stringify(dp)));
                                      //log(dp.id);
                                      //log(id);
                                      if (id[0] != 'admin') {
                                          if (dp.state.val) {
                                              cnt--;
                                              if (cnt <= 0) {
                                                  log('"Connected to device or service" Adapter laufen fehlerfrei');
                                           } else {
                                              log('### "Connected to device or service"-Fehler entdeckt. Warte auf Selbstheilung: ' + id[2]);
                                              recheckWithIntervall(dp.common.name, newid, id[2], "Connected to device or service");
                                              cnt++;
                                  //Prüfen auf: Heartbeat
                                  on(/^system\.adapter\..+\.alive$/, function (dp) {
                                      //if (dp.state.val)
                                      //    log('trigger für Adapterüberwachung aktiv');
                                      //log(dp.id);
                                      //log(id);
                                      // Ausnahmen definieren. id[2] != 'admin' && id[2] != 'yahka'
                                      if (id[2] != 'admin' && id[2] != 'openweathermap') {
                                          if (dp.state.val) {
                                              cnt--;
                                              if (cnt <= 0) {
                                                  log('"Heartbeat"-Adapter laufen fehlerfrei');
                                           } else {
                                              log('### "Heartbeat"-Fehler entdeckt. Warte auf Selbstheilung: ' + id[2]);
                                              var dpname = ('system.adapter.' + id[2] + '.' + id[3] + '.' + id[4]);
                                              recheckWithIntervall(dp.common.name, newid, id[2], "Heartbeat");
                                              cnt++;
                                   function recheckWithIntervall(dpname, newid, adapter, eventtyp) {
                                      var timeout = setTimeout(function () {
                                          var instance = getObject(newid);
                                          log('### "' + eventtyp + '"-Wartezeit vorrüber. Prüfe noch mal: ' + newid);
                                          // nur einen Fehler melden, wenn der Adapter vorher auch mal aktiv war. Bzw. deaktivierte Adapter ignorieren
                                          if (!getState(dpname).val) {
                                              if (instance.common.enabled) {
                                                  alarmMeldung('"' + eventtyp + '"-Fehler bei Instanz: ' + dpname);
                                          } else {
                                              log('### Der "' + eventtyp + '"-Fehler hat selbst geheilt: '+ newid);
                                      }, timeoutZeit);
                                  tobasiumT 1 Antwort Letzte Antwort
                                  • P PichlAlex
                                        //txt =  txt;
                                    var cnt = 0,
                                        //log(dp.id);
                                        //log(id);
                                            if (dp.state.val) {
                                                cnt--;
                                                if (cnt <= 0) {
                                             } else {
                                                cnt++;
                                        //log(dp.id);
                                        //log(id);
                                            if (dp.state.val) {
                                                cnt--;
                                                if (cnt <= 0) {
                                             } else {
                                                cnt++;
                                        //if (dp.state.val)
                                        //log(dp.id);
                                        //log(id);
                                            if (dp.state.val) {
                                                cnt--;
                                                if (cnt <= 0) {
                                             } else {
                                                cnt++;
                                            } else {
                                        }, timeoutZeit);
                                    tobasiumT Offline
                                    tobasiumT Offline
                                    tobasium
                                    schrieb am zuletzt editiert von tobasium
                                    @pichlalex
                                    Moin,
                                    kannst du hier noch erklären wie ich die Ausnahmen einrichte? Ich bekomme Heartbeat Fehler in regelmässigen Abständen von z.B.
                                    dwd.0, ical.0, daswetter.0,
                                    Ebenfalls sehe ich keine logs in IoBroker muss ich hier noch was beachten
                                    Ich bekomme auch hier einen Fehler in der Zeile: ( Error in callback: TypeError: Cannot read properties of null (reading 'common'))
                                    Vielen Dank.
                                    MyzerATM 1 Antwort Letzte Antwort
                                    • tobasiumT tobasium
                                      @pichlalex
                                      Moin,
                                      Vielen Dank.
                                      MyzerATM Offline
                                      MyzerATM Offline
                                      MyzerAT
                                      @tobasium sagte in Script zur Überprüfung ob eine Instanz noch läuft.:
                                      ical.0
                                      bei ical.0 bekomme ich auch hi und da Meldung im Telegram am Handy, aber ist es nicht so das ical per cronjob regelmäßig durchstartet und deswegen diese Meldung zu recht kommt!
                                      lg Rudi
                                      Node 22.23.0
                                      Nodejs 22.23.0
                                      npm 10.9.8
                                      js-controller 7.2.2
                                      • MyzerATM MyzerAT
                                        ical.0
                                        @myzerat sagte: ical per cronjob regelmäßig durchstartet und deswegen diese Meldung zu recht kommt!
                                        Ist diese Abfrage nicht enthalten?
                                          MyzerATM Offline
                                          MyzerATM Offline
                                          MyzerAT
                                          schaut nicht so aus, ich habe das script von @PichlAlex genommen
                                          lg Rudi
                                          Node 22.23.0
                                          Nodejs 22.23.0
                                          npm 10.9.8
                                          js-controller 7.2.2
